lzuGabriel Posted April 10, 2015 Posted April 10, 2015 i am running Nintendo Game boy through Visual Boy Advance I have the Rom I change the Name to Match the one in my databases choose the rom path to my roms folder game can't be found. [code] 21:39:12:593 | HL | INFO | +N/A | Main - HyperLaunch v3.1.0.5b BETA (www.hyperlaunch.net) 21:39:12:594 | HL | WARNING | +0 | Main - You have "Logging_Show_Command_Window" enabled. This is only for showing errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done. 21:39:12:596 | HL | WARNING | +0 | Main - You have "Logging_Log_Command_Window" enabled. This is only for logging errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done. 21:39:12:614 | HL | WARNING | +15 | Main - You cannot use debug console and show/log a console for an emulator simultaneously. Turning off debug console to avoid errors launching. 21:39:13:448 | HL | INFO | +844 | Main - System Specs: HyperLaunch Dir: C:\Users\Gabriel\Desktop\Hyperspin1 HyperLaunch is: 32-bit OS: Microsoft Windows 10 Pro Technical Preview SKU: Professional Total Memory: 7133.17 MB Free Memory: 4713.90 MB Used Memory: 2419.273 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 2 GPU 1 Name: Intel(R) G45/G43 Express Chipset (Microsoft Corporation - WDDM 1.1) GPU 1 RAM: -753.41 MB GPU 1 Driver Version: 8.15.10.2702 GPU 2 Name: Intel(R) G45/G43 Express Chipset (Microsoft Corporation - WDDM 1.1) GPU 2 RAM: 0.00 MB GPU 2 Driver Version: 8.15.10.2702 Sound 1 Device: USB Audio Device Sound 1 Status: Enabled Sound 2 Device: Realtek High Definition Audio Sound 2 Status: Enabled OS Language: English_United_States OS Admin Status: No Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1040 work) Monitor #1 Orientation: Landscape Current AHK Desktop Width: 1920 Current AHK Desktop Height: 1080 AutoHotkey Path: AHK Version: 1.1.09.04 Unicode: No 21:39:13:448 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\HyperLaunch.exe exists 21:39:13:450 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription Your favorite Front End companion! Visit us @ www.hyperlaunch.net FileVersion 3.1.0.5 LegalCopyright �2014 HyperLaunch ProductName djvj's one swell guy! ProductVersion 1.1.9.4 CompanyName HyperLaunch BETA File Size: 971264 bytes Created: 4/2/2015 - 11:10:16 PM Modified: 4/2/2015 - 11:37:24 PM 21:39:13:450 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\dxwnd\dxwnd.ini exists 21:39:13:454 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 409 bytes Created: 4/3/2015 - 1:12:45 AM Modified: 4/2/2015 - 11:37:25 PM 21:39:13:455 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\dxwnd\dxwnd.exe exists 21:39:13:458 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription DxWnd MFC application FileVersion 1, 0, 0, 1 InternalName DxWnd LegalCopyright Copyright (C) 2004/2012 OriginalFilename DxWnd.exe ProductName DxWnd application ProductVersion 1, 0, 0, 1 File Size: 539136 bytes Created: 4/2/2015 - 11:10:19 PM Modified: 4/2/2015 - 11:37:25 PM 21:39:13:459 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\BinHexRW.ahk exists 21:39:13:483 | HL | DEBUG1 | +31 | CRC Check - CRC matches, this is an official unedited Library. 21:39:13:487 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 4961 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:25 PM 21:39:13:492 | HL | INFO | +16 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\BlockInput.exe exists 21:39:13:509 | HL | DEBUG1 | +16 | CheckFile - Attributes: FileDescription FileVersion 1.1.09.04 InternalName OriginalFilename ProductName ProductVersion 1.1.09.04 File Size: 657920 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:25 PM 21:39:13:510 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\CLR.ahk exists 21:39:13:522 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Extension. 21:39:13:525 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 10586 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:25 PM 21:39:13:526 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\COM.ahk exists 21:39:13:540 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 21:39:13:544 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26342 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:25 PM 21:39:13:544 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\Control_AniGif.ahk exists 21:39:13:558 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Extension. 21:39:13:562 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 5716 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:25 PM 21:39:13:563 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\dxwnd\dxwnd.ini exists 21:39:13:567 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 409 bytes Created: 4/3/2015 - 1:12:45 AM Modified: 4/2/2015 - 11:37:25 PM 21:39:13:568 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\dxwnd\dxwnd.exe exists 21:39:13:575 | HL | DEBUG1 | +16 | CheckFile - Attributes: FileDescription DxWnd MFC application FileVersion 1, 0, 0, 1 InternalName DxWnd LegalCopyright Copyright (C) 2004/2012 OriginalFilename DxWnd.exe ProductName DxWnd application ProductVersion 1, 0, 0, 1 File Size: 539136 bytes Created: 4/2/2015 - 11:10:19 PM Modified: 4/2/2015 - 11:37:25 PM 21:39:13:578 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\gdip.ahk exists 21:39:13:638 | HL | DEBUG1 | +63 | CRC Check - CRC matches, this is an official unedited Extension. 21:39:13:646 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 88789 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:25 PM 21:39:13:646 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\gdip_alt.ahk exists 21:39:13:658 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 21:39:13:661 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 3394 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:25 PM 21:39:13:662 | HL | DEBUG1 | +0 | gdip_alt.ahk Version: 1.0.1 21:39:13:663 | HL | INFO | +16 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\gsdll32.dll exists 21:39:13:705 | HL | DEBUG1 | +31 | CheckFile - Attributes: File Size: 13090816 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:26 PM 21:39:13:706 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\itextsharp.dll exists 21:39:13:719 | HL | DEBUG1 | +16 | CheckFile - Attributes: FileDescription iTextSharp FileVersion 5.4.2.0 InternalName itextsharp.dll LegalCopyright Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved. OriginalFilename itextsharp.dll ProductName iTextSharp ProductVersion 5.4.2.0 CompanyName 1T3XT BVBA File Size: 3743744 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:26 PM 21:39:13:720 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\Java.ahk exists 21:39:13:751 | HL | DEBUG1 | +31 | CRC Check - CRC matches, this is an official unedited Library. 21:39:13:754 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 7841 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:25 PM 21:39:13:757 | HL | DEBUG1 | +16 | Java.ahk Version: 1.0.0 21:39:13:758 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\JSON.ahk exists 21:39:13:770 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 21:39:13:777 | HL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 9203 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:25 PM 21:39:13:778 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\Origin.ahk exists 21:39:13:789 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 21:39:13:794 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 4901 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:25 PM 21:39:13:796 | HL | DEBUG1 | +0 | Origin.ahk Version: 1.0.1 21:39:13:797 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\PacDrive32.dll exists 21:39:13:815 | HL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 69120 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:25 PM 21:39:13:819 | HL | INFO | +16 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\RegRW64.ahk exists 21:39:13:868 | HL | DEBUG1 | +47 | CRC Check - CRC matches, this is an official unedited Extension. 21:39:13:871 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 6915 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:25 PM 21:39:13:871 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\RIni.ahk exists 21:39:13:890 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 21:39:13:893 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 67561 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:25 PM 21:39:13:893 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\SevenZipSharp.dll exists 21:39:13:905 | HL | DEBUG1 | +15 | CheckFile - Attributes: FileDescription SevenZipSharp FileVersion 0.64.4841.31212 InternalName SevenZipSharp.dll LegalCopyright Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3 OriginalFilename SevenZipSharp.dll ProductName SevenZipSharp ProductVersion 0.64.4841.31212 CompanyName Markovtsev Vadim File Size: 165888 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:25 PM 21:39:13:906 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\Steam.ahk exists 21:39:13:926 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 21:39:13:929 | HL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 5344 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:25 PM 21:39:13:930 | HL | DEBUG1 | +0 | Steam.ahk Version: 1.0.1 21:39:13:930 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\VA.ahk exists 21:39:13:980 | HL | DEBUG1 | +47 | CRC Check - CRC matches, this is an official unedited Extension. 21:39:13:986 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 34688 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:25 PM 21:39:13:987 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\VA_Extension.ahk exists 21:39:13:990 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 21:39:13:992 | HL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 3833 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:25 PM 21:39:13:993 | HL | DEBUG1 | +0 | VA_Extension.ahk Version: 1.0.1 21:39:13:994 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Lib\Bezel.ahk exists 21:39:14:062 | HL | DEBUG1 | +62 | CRC Check - CRC matches, this is an official unedited Library. 21:39:14:066 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 101738 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:24 PM 21:39:14:069 | HL | DEBUG1 | +16 | Bezel.ahk Version: 1.0.9 21:39:14:072 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Lib\Fade.ahk exists 21:39:14:093 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 21:39:14:096 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 36402 bytes Created: 4/2/2015 - 11:10:16 PM Modified: 4/2/2015 - 11:37:24 PM 21:39:14:097 | HL | DEBUG1 | +0 | Fade.ahk Version: 1.0.9 21:39:14:098 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Lib\Fade Init.ahk exists 21:39:14:101 | HL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 21:39:14:104 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 999 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:24 PM 21:39:14:105 | HL | DEBUG1 | +0 | Fade Init.ahk Version: 1.0.1 21:39:14:106 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Lib\Fade Animations.ahk exists 21:39:14:111 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 21:39:14:113 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 67602 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:24 PM 21:39:14:115 | HL | DEBUG1 | +0 | Fade Animations.ahk Version: 1.1.1 21:39:14:115 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Lib\HyperPause.ahk exists 21:39:14:163 | HL | DEBUG1 | +63 | CRC Check - CRC matches, this is an official unedited Library. 21:39:14:166 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 392193 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:24 PM 21:39:14:168 | HL | DEBUG1 | +0 | HyperPause.ahk Version: 1.0.8 21:39:14:169 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Lib\HyperPause Init.ahk exists 21:39:14:170 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 21:39:14:173 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 537 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:24 PM 21:39:14:174 | HL | DEBUG1 | +0 | HyperPause Init.ahk Version: 1.0.1 21:39:14:175 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Lib\Keymapper.ahk exists 21:39:14:178 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 21:39:14:181 | HL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 32953 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:24 PM 21:39:14:181 | HL | DEBUG1 | +0 | Keymapper.ahk Version: 1.0.9 21:39:14:182 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Lib\Keymapper Init.ahk exists 21:39:14:185 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 21:39:14:188 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 3435 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:24 PM 21:39:14:189 | HL | DEBUG1 | +0 | Keymapper Init.ahk Version: 1.0.2 21:39:14:190 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Lib\MultiGame.ahk exists 21:39:14:199 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 21:39:14:202 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 40584 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:24 PM 21:39:14:203 | HL | DEBUG1 | +0 | MultiGame.ahk Version: 1.0.6 21:39:14:203 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Lib\MultiGame Init.ahk exists 21:39:14:206 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 21:39:14:209 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 161 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:24 PM 21:39:14:210 | HL | DEBUG1 | +16 | MultiGame Init.ahk Version: 1.0.0 21:39:14:212 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Lib\MultiPlayer.ahk exists 21:39:14:223 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 21:39:14:226 | HL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 58605 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:24 PM 21:39:14:227 | HL | DEBUG1 | +0 | MultiPlayer.ahk Version: 1.0.4 21:39:14:227 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Lib\Password.ahk exists 21:39:14:237 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 21:39:14:240 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 10035 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:24 PM 21:39:14:241 | HL | DEBUG1 | +16 | Password.ahk Version: 1.0.0 21:39:14:242 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Lib\Rom Mapping Launch Menu.ahk exists 21:39:14:246 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 21:39:14:249 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 73560 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:24 PM 21:39:14:250 | HL | DEBUG1 | +0 | Rom Mapping Launch Menu.ahk Version: 1.0.3 21:39:14:250 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Lib\Shared.ahk exists 21:39:14:263 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 21:39:14:266 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 145962 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:24 PM 21:39:14:267 | HL | DEBUG1 | +0 | Shared.ahk Version: 1.2.3 21:39:14:268 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Lib\Statistics.ahk exists 21:39:14:271 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 21:39:14:275 | HL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 26170 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:24 PM 21:39:14:276 | HL | DEBUG1 | +0 | Statistics.ahk Version: 1.0.2 21:39:14:276 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Lib\Statistics Init.ahk exists 21:39:14:278 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 21:39:14:280 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 33 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:24 PM 21:39:14:281 | HL | DEBUG1 | +0 | Statistics Init.ahk Version: 1.0.1 21:39:14:282 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Lib\XHotkey.ahk exists 21:39:14:293 | HL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 21:39:14:295 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 29623 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:24 PM 21:39:14:296 | HL | DEBUG1 | +0 | XHotkey.ahk Version: 1.0.2 21:39:14:297 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Lib\XHotkey Init.ahk exists 21:39:14:299 | HL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 21:39:14:301 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1236 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:24 PM 21:39:14:302 | HL | DEBUG1 | +0 | XHotkey Init.ahk Version: 1.0.0 21:39:14:302 | HL | DEBUG1 | +0 | Main - Raw CLI received: "-s Nintendo Game Boy Advance -r Legend of Zelda, The - The Minish Cap (USA) -f C:\Users\Gabriel\Desktop\Hyperspin1\HyperSpin.exe -p HyperSpin -c 1" 21:39:14:303 | HL | DEBUG1 | +0 | Main - Received this dbName with no path via CLI: "Legend of Zelda, The - The Minish Cap (USA)" 21:39:14:303 | HL | DEBUG1 | +0 | Main - dbName: Legend of Zelda, The - The Minish Cap (USA) 21:39:14:304 | HL | INFO | +15 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Plugins\HyperSpin.plugin exists 21:39:14:307 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 8999 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:27 PM 21:39:14:307 | HL | INFO | +0 | Main - Loading Front End Plugin: "HyperSpin" 21:39:14:308 | HL | INFO | +0 | Main - HyperLaunch received "Nintendo Game Boy Advance" and "Legend of Zelda, The - The Minish Cap (USA)" 21:39:14:317 | HL | INFO | +0 | Main - Legend of Zelda, The - The Minish Cap (USA) is using the default emulator: VisualBoyAdvance-M 21:39:14:318 | HL | INFO | +0 | Main - Checking for a [VisualBoyAdvance-M] section in C:\Users\Gabriel\Desktop\Hyperspin1\Settings\Nintendo Game Boy Advance\Emulators.ini 21:39:14:319 | HL | INFO | +16 | Main - Checking for a [VisualBoyAdvance-M] section in C:\Users\Gabriel\Desktop\Hyperspin1\Settings\Global Emulators.ini 21:39:14:321 | HL | INFO | +0 | Main - Found [VisualBoyAdvance-M] in C:\Users\Gabriel\Desktop\Hyperspin1\Settings\Global Emulators.ini 21:39:14:322 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Modules\VisualBoyAdvance-M\VisualBoyAdvance-M.ahk exists 21:39:14:325 | HL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 2385 bytes Created: 4/2/2015 - 11:10:20 PM Modified: 4/2/2015 - 11:37:27 PM 21:39:14:327 | HL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 21:39:14:328 | HL | INFO | +0 | Main - Legend of Zelda, The - The Minish Cap (USA) will use module: C:\Users\Gabriel\Desktop\Hyperspin1\Modules\VisualBoyAdvance-M\VisualBoyAdvance-M.ahk 21:39:14:343 | HL | INFO | +16 | Main - Did not find a "C:\Users\Gabriel\Desktop\Hyperspin1\Settings\Nintendo Game Boy Advance\Game Options.ini" file, skipping any game-specific options. 21:39:14:344 | HL | INFO | +0 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 21:39:14:348 | HL | INFO | +0 | CheckFile - Checking if D:\Hyperspin2\Emulators\Gameboy Advance\VisualBoyAdvance.exe exists 21:39:14:924 | HL | DEBUG1 | +578 | CheckFile - Attributes: FileDescription VisualBoyAdvance emulator FileVersion 1, 8, 0, 600 InternalName VisualBoyAdvance LegalCopyright Copyright � 2004 Forgotten and the VBA team OriginalFilename VisualBoyAdvance.exe ProductName VisualBoyAdvance emulator ProductVersion 1, 8, 0, 600 CompanyName None File Size: 1380476 bytes Created: 4/3/2015 - 11:18:58 PM Modified: 5/1/2006 - 9:47:06 PM 21:39:14:925 | HL | INFO | +0 | Main - INI Keys read 21:39:14:926 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\7z.exe exists 21:39:14:932 | HL | DEBUG1 | +15 | CheckFile - Attributes: FileDescription 7-Zip Console FileVersion 9.20 InternalName 7z LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7z.exe ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 163840 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:25 PM 21:39:14:933 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\7z.dll exists 21:39:14:940 | HL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7z Standalone Plugin FileVersion 9.20 InternalName 7za LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7za.dll ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 914432 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:25 PM 21:39:14:941 | HL | INFO | +0 | CreateRomMapTable - Started 21:39:14:943 | HL | DEBUG1 | +0 | AltNameExistCheck - Looking for rom: D:\Game Roms\Gameboy Advance\roms\Legend of Zelda, The - The Minish Cap (USA).7z 21:39:14:944 | HL | DEBUG1 | +16 | AltNameExistCheck - Looking for rom: D:\Game Roms\Gameboy Advance\roms\Legend of Zelda, The - The Minish Cap (USA)\Legend of Zelda, The - The Minish Cap (USA).7z 21:39:14:945 | HL | DEBUG1 | +0 | AltNameExistCheck - Looking for rom: D:\Game Roms\Gameboy Advance\roms\Legend of Zelda, The - The Minish Cap (USA).zip 21:39:14:946 | HL | DEBUG1 | +0 | AltNameExistCheck - Looking for rom: D:\Game Roms\Gameboy Advance\roms\Legend of Zelda, The - The Minish Cap (USA)\Legend of Zelda, The - The Minish Cap (USA).zip 21:39:14:947 | HL | DEBUG1 | +0 | AltNameExistCheck - Looking for rom: D:\Game Roms\Gameboy Advance\roms\Legend of Zelda, The - The Minish Cap (USA).gb 21:39:14:948 | HL | DEBUG1 | +0 | AltNameExistCheck - Looking for rom: D:\Game Roms\Gameboy Advance\roms\Legend of Zelda, The - The Minish Cap (USA)\Legend of Zelda, The - The Minish Cap (USA).gb 21:39:14:949 | HL | DEBUG1 | +0 | AltNameExistCheck - Looking for rom: D:\Game Roms\Gameboy Advance\roms\Legend of Zelda, The - The Minish Cap (USA).gbc 21:39:14:950 | HL | DEBUG1 | +0 | AltNameExistCheck - Looking for rom: D:\Game Roms\Gameboy Advance\roms\Legend of Zelda, The - The Minish Cap (USA)\Legend of Zelda, The - The Minish Cap (USA).gbc 21:39:14:951 | HL | DEBUG1 | +0 | AltNameExistCheck - Looking for rom: D:\Game Roms\Gameboy Advance\roms\Legend of Zelda, The - The Minish Cap (USA).gba 21:39:14:952 | HL | DEBUG1 | +0 | AltNameExistCheck - Looking for rom: D:\Game Roms\Gameboy Advance\roms\Legend of Zelda, The - The Minish Cap (USA)\Legend of Zelda, The - The Minish Cap (USA).gba 21:39:14:953 | HL | WARNING | +0 | AltNameExistCheck - Could not find "Legend of Zelda, The - The Minish Cap (USA)" in any of your Rom Paths with any defined Rom Extensions 21:39:14:955 | HL | INFO | +0 | CreateRomMapTable - Ended, No mapping inis found. 21:39:14:956 | HL | INFO | +0 | CheckFile - Checking if C:\Users\Gabriel\Desktop\Hyperspin1\Module Extensions\FontReg.exe exists 21:39:14:962 | HL | DEBUG1 | +16 | CheckFile - Attributes: FileDescription Font Registration Utility (x86-32) FileVersion 2.1.3.0 OriginalFilename FontReg.exe File Size: 6144 bytes Created: 4/2/2015 - 11:10:17 PM Modified: 4/2/2015 - 11:37:25 PM 21:39:15:049 | HL | INFO | +78 | Main - "Legend of Zelda, The - The Minish Cap (USA)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side 21:39:15:049 | HL | INFO | +0 | CheckPaths - Started 21:39:15:050 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: D:\Game Roms\Gameboy Advance\roms\Legend of Zelda, The - The Minish Cap (USA).7z 21:39:15:051 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: D:\Game Roms\Gameboy Advance\roms\Legend of Zelda, The - The Minish Cap (USA)\Legend of Zelda, The - The Minish Cap (USA).7z 21:39:15:052 | HL | DEBUG1 | +0 | CheckPaths - Rom not found 21:39:15:052 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: D:\Game Roms\Gameboy Advance\roms\Legend of Zelda, The - The Minish Cap (USA).zip 21:39:15:053 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: D:\Game Roms\Gameboy Advance\roms\Legend of Zelda, The - The Minish Cap (USA)\Legend of Zelda, The - The Minish Cap (USA).zip 21:39:15:054 | HL | DEBUG1 | +15 | CheckPaths - Rom not found 21:39:15:055 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: D:\Game Roms\Gameboy Advance\roms\Legend of Zelda, The - The Minish Cap (USA).gb 21:39:15:055 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: D:\Game Roms\Gameboy Advance\roms\Legend of Zelda, The - The Minish Cap (USA)\Legend of Zelda, The - The Minish Cap (USA).gb 21:39:15:056 | HL | DEBUG1 | +0 | CheckPaths - Rom not found 21:39:15:056 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: D:\Game Roms\Gameboy Advance\roms\Legend of Zelda, The - The Minish Cap (USA).gbc 21:39:15:057 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: D:\Game Roms\Gameboy Advance\roms\Legend of Zelda, The - The Minish Cap (USA)\Legend of Zelda, The - The Minish Cap (USA).gbc 21:39:15:058 | HL | DEBUG1 | +0 | CheckPaths - Rom not found 21:39:15:058 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom: D:\Game Roms\Gameboy Advance\roms\Legend of Zelda, The - The Minish Cap (USA).gba 21:39:15:059 | HL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: D:\Game Roms\Gameboy Advance\roms\Legend of Zelda, The - The Minish Cap (USA)\Legend of Zelda, The - The Minish Cap (USA).gba 21:39:15:060 | HL | DEBUG1 | +0 | CheckPaths - Rom not found 21:39:15:060 | HL | DEBUG1 | +0 | CheckPaths - Current romName: 21:39:15:060 | HL | DEBUG1 | +0 | CheckPaths - Current romPath: 21:39:15:061 | HL | DEBUG1 | +0 | CheckPaths - Current romExtension: 21:39:15:567 | HL | DEBUG1 | +500 | ScriptError - Playing error sound: error6.mp3 21:39:25:088 | HL | ERROR | +9532 | Cannot find Rom "Legend of Zelda, The - The Minish Cap (USA)" In any Rom_Paths provided: "D:\Game Roms\Gameboy Advance\roms" With any provided Rom_Extension: "7z|zip|gb|gbc|gba" 21:39:25:089 | HL | INFO | +0 | ExitScript - Started 21:39:25:156 | HL | INFO | +62 | SystemCursor - Restoring mouse cursor 21:39:25:183 | HL | INFO | +31 | ExitScript - Ended [/code]
Torden Posted April 10, 2015 Posted April 10, 2015 Have you checked the rom extension? With any provided Rom_Extension: "7z|zip|gb|gbc|gba"
