Xpadder + StartUPScript : NO xpadder when returns to wheel...
JordiMayor
FIrst of all, thank you for all the Platinum members for constant support of our newbies questions...
I'll try to synth my problems. I've THT Arcade USB 2 PLAYERS module on my cabinet, perfectly recognized with Windows 7.
I want to start controlling the hyperspin wheel and menus. I've done a profile, and using start up script, I can load it, and when hyperspin loads, I can use the assigments correctly. Now, when I load, for example, ATARI 2600, I've setup  a profile with no key assigments on my HyperLaunchHQ, and it loads perfectly. I can play to all my VCS 2600 games (not all of them... I'm very depressed, because cannot play VIDEO OLYMPICS because it uses pad's... and I'm not able to config them). When I exit of the game and returns to wheel, then only keyboard responds to the hyperspin wheel.
Please, I need help.
Thank you very much....
If x padder works the sane as my joy2key setup, you need to go to global in hyperlaunch hq, key mapper and create a new frontend profile for hyperspin
Make it an exact replica of your startup profile and you'll be good.
This is because you start hyperspin with your startup profile > hlhq sets your blank profile when going in to emulator - but - you haven't told hlhq what profile to use when it goes back to hyperspin.
Setting a fronted profile will do that.
Works in joy2key so would imagine same rules apply to xpadder?
I'm think that is solved.... Thanks to Dunk3000 comment. In my case, I'd created the profile in global, but I don't know why it was no success. Now, I've used HLHQ at global and controllers for showing folder in which global xpadder profile was stored. Then, only copy/paste over it.
Now, it's running. ;)
Thank you very much for your fast responses, Mr Mystul and Dunk3000!!!
