olytechy Posted April 23, 2015 Posted April 23, 2015 I followed the tutorial I found at this link: And I can get the Joystick to work in HyperSpin. Enter key works when selecting an emulator, escape works to go back a menu, FGLV and space all work with their bindings. However when I want to click on a game to play nothing happens. I can't get it to load. If I go back and disable the settings I made and remove all the xpadder profiles, I can use the keyboard to select and run games no problem. I have been playing with this for hours and I can't figure out how to get HyperSpin to work with my joystick. Any help would be greatly appreciated. Thanks, Mike
methos01 Posted April 30, 2015 Posted April 30, 2015 I used the same guide and having a different problem but I may be able to help you with yours. It sounds like Xpadder is still using the hyperspin profile after mame is launched. Did you set up a blank profile for the emulator in hyperlaunch? If not you need to do that so xpadder isn't controlling your key commands after the emulator starts up. My question is is it possible to use this blank profile for everything in hyperlunch ie globally? Or do I have to set it up each emulator one by one with a blank profile.
