PCSX2 configuration
AxelTerizaki
Hello everyone.
I have trouble configuring PCSX2 correctly for PS2 emulation. I'm not even sure I'm using the right version or anything, but I have glitches here and there on some games and some problems with a few games not loading up when I launch them through Hyperspin/Rocketlauncher, but that work fine when I open them via the Emulator.
Which is best, loading up the ISO or using Daemon Tools?
Does anyone have a PCSX2 setup on FTP perhaps?
Thanks in advance.
Hi i don't use Daemon tools for PS2 i just load the iso,bin etc.
How much Ram do you have..?
Are you using a Bezel..?
Remember if your iso's are zipped/7z in HLHQ Select your Emulator then Settings/Main Setting and change 7z to True.
Make sure in HyperHQ you have the correct Extensions listed e.g. zip|7z|ISO|Bin|IMG etc.
In HLHQ you can change some setting per Rom/Game so Select your Emulator, Modules, then slect the PCSX2.ahk module and then Edit Global Module Settings, in here you can change Global Emu Setting or in the Rom Tab change some settings/plugins etc per game.
My PCSX2 is From Feb 5 2015, i haven't updated since then.
Whats games in particular are you having problems with, maybe if i have any of the same games i can check them in hyperspin to see if i have any problems.
