Hyperspin 1.4 with RocketLauncher not starting game
ajdemoed
Hello everyone.
THis is my first post on this forum and Im new with Hyperspin. I followed the tutorial on this page http://www.hyperspin-fe.com/topic/2187-how-to-install-hyperspin and I think I did all the correct settings...
Now games will start from RocketLauncher and the RocketLauncherUI but not from Hyperspin. I've put in the settings from the transition page on www.rlauncher,com in the HyperspinHQ program.
Here are the logs from Hyperspin when I start a game:
01:03:56 PM |  HyperSpin Started
01:03:56 PM |  Going FullScreen
01:03:56 PM |  Checking for updates
01:03:56 PM |  Update Check Complete
01:03:56 PM |  Startup program unavailable
01:03:56 PM |  Playing intro video
01:03:58 PM |  Error intializing joysticks
01:03:58 PM |  Menu Mode is multi
01:03:58 PM |  Loading Main Menu.xml
01:03:58 PM |  Main Menu.xml successfully loaded
01:03:59 PM |  Main Menu wheel loaded successfully
01:04:00 PM |  Loading MAME.xml
01:04:01 PM |  Main Menu.xml successfully loaded
01:04:01 PM |  MAME wheel loaded successfully
01:04:04 PM |  Launching Game
01:04:04 PM |  Not using HyperLaunch
01:04:04 PM |  Running in normal rom mode
01:04:04 PM |  Excecutable is RocketLauncher.exe
01:04:04 PM |  Command Line is: "E:\Hyperspin\RocketLauncher\RocketLauncher.exe" "capbowl." "MAME" -f "E:\HyperSpin\HyperSpin.exe" -p "HyperSpin"
01:04:11 PM |  Loading Main Menu.xml
01:04:11 PM |  Main Menu.xml successfully loaded
01:04:12 PM |  Main Menu wheel loaded successfully
01:04:13 PM |  Exit program unavailable
01:04:13 PM |  Quiting Hyperspin
01:04:13 PM |  Bye!
And the log from RocketLauncher:
[code]
13:04:05:470 | RL |     INFO  | +N/A   | Main - RocketLauncher v1.0.0.0 (www.rlauncher.com)
13:04:05:665 | RL |     INFO  | +202   | Main - System Specs:
					RocketLauncher Dir: E:\Hyperspin\RocketLauncher
					RocketLauncher is: 32-bit
					OS: Microsoft Windows 7 Home Basic
					SKU: Home Basic
					Total Memory: 8079.14 MB
					Free Memory: 5107.89 MB
					Used Memory: 2971.254 MB
					SystemType: 64-bit
					Physical Processors: 1
					Logical Processors: 4
					GPU 1 Name: Intel(R) HD Graphics 4600
					GPU 1 RAM: -1984.00 MB
					GPU 1 Driver Version: 10.18.10.3308
					GPU 2 Name: ASUS HD7770 Series
					GPU 2 RAM: -2048.00 MB
					GPU 2 Driver Version: 13.152.0.0
					Sound 1 Device: AMD High Definition Audio Device
					Sound 1 Status: Enabled
					Sound 2 Device: USB-audioapparaat
					Sound 2 Status: Unknown
					Sound 3 Device: High Definition Audio-apparaat
					Sound 3 Status: Enabled
					Sound 4 Device: Intel(R) Display Audio
					Sound 4 Status: Enabled
					OS Language: Dutch_Standard
					OS Admin Status: Yes
					Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1040 work)
					Monitor #1 Orientation: Landscape
					Current AHK Desktop Width: 1920
					Current AHK Desktop Height: 1080
					AutoHotkey Path:
					AHK Version: 1.1.09.04
					Unicode: No
13:04:05:665 | RL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\RocketLauncher\RocketLauncher.exe exists
13:04:05:673 | RL |     INFO  | +0     | Main - HyperSpin.exe coordinates are x0 y0 w1920 h1080
13:04:05:673 | RL |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\RocketLauncher\Plugins\HyperSpin.plugin exists
13:04:05:687 | RL |     INFO  | +16    | Main - Loading Front End Plugin: "HyperSpin"
13:04:05:687 | RL |     INFO  | +0     | Main - RocketLauncher received "capbowl." and "MAME"
13:04:05:687 | RL |     INFO  | +0     | Main - Did not find a "E:\Hyperspin\RocketLauncher\Settings\capbowl.\Game Options.ini" file, skipping any game-specific options.
13:04:05:687 | RL |  WARNING  | +0     | RIniReadCheck - Created missing RocketLauncher ini key: "Default_Emulator" in section: "Roms" in "E:\Hyperspin\RocketLauncher\Settings\capbowl.\Emulators.ini"
13:04:09:927 | RL |    ERROR  | +4243  | No Default_Emulator found in "E:\Hyperspin\RocketLauncher\Settings\capbowl.\Emulators.ini" Please set one so RocketLauncher knows what module to use.
13:04:09:927 | RL |     INFO  | +0     | ExitScript - Started
13:04:10:225 | RL |     INFO  | +297   | SystemCursor - Restoring mouse cursor
13:04:10:244 | RL |     INFO  | +15    | ExitScript - Ended
[/code]
It seems like it has something to do with the command line....
Thanks in advance for your reply!
