Question about Dolphin
epicrean
I have tried different versions of Dolphin and am currently running 4.0-6314 with RocketLauncher 1.0.0.1
This issue may have to do with HS, RL or Dolphin, so hopefully someone here can help.
So the issue.  In dolphin under graphics I check "Use Fullscreen" and am forcing the aspect ratio to 4:3.
Load it up in RL and it works like a dream with the fade and bezel.
Load it up in HS and it works like a dream with the fade and bezel.
So the issue is every so often when I go to launch a dolphin game the "use fullscreen" is unchecked and dolphin is running in a small window with a menu bar and everything.  Looks like poop.  I have to exit everything, open dolphin and re-click "use fullscreen"
Never had that issue with Dolphin, and I update with the current builds at least on a weekly basis--- everything reliably runs in fullscreen for me, but I never needed to force the aspect ratio to 4:3 as I run it on my hdtv. If you have an old crt or 4:3 monitor it may be worth unchecking the forced 4:3 and see if it's more reliable. Other than that, check out your log files after a failed launch?
HTPC: Gigabyte BRIX Pro w/Intel Iris Pro graphics, Windows 8.1 x64/8gb RAM
