SpuRge79 Posted May 28, 2015 Posted May 28, 2015 When I try to load a zipped SNES game in RocketLauncher the screen gets stuck on the fade-in screen. When I load a unzipped game it works perfect. I have enabled the 7z in RocketLauncher but it doesn't seem to work. My Genesis games work perfect in Rocketlauncher, but when i load them in HS I get a Error. Retroarch Ahk_class................. I tried everything but I can't get them to work in HS. I'm stuck here
Fromlostdays Posted May 28, 2015 Posted May 28, 2015 Need more info and a troubleshooting log. What version of Hyperspin? Are you sure you've set everything up so that Hyperspin is launching through rocketlauncher and not through the Hyperlaunch 2 (which comes stock in the hyperspin beta) Go into HyperHQ navigate to Genesis wheel and make sure the Executable is set to "Hyperlaunch". Not normal. Do the same for SNES. Walter:beerglass:
SpuRge79 Posted May 29, 2015 Author Posted May 29, 2015 I'm using Hyperspin 1.3.3. When I set the executable to "Hyperlaunch" I get the message "cannot find Hyperlaunch.exe" 08:02:31 PM | HyperSpin Started 08:02:31 PM | Going FullScreen 08:02:32 PM | Checking for updates 08:02:32 PM | Update Check Complete 08:02:32 PM | Startup program unavailable 08:02:32 PM | Playing intro video 08:02:34 PM | Error intializing joysticks 08:02:34 PM | Menu Mode is multi 08:02:34 PM | Loading Main Menu.xml 08:02:34 PM | Main Menu.xml successfully loaded 08:02:34 PM | Main Menu wheel loaded successfully 08:02:42 PM | Loading Sega Genesis.xml 08:02:42 PM | roms_only is true, checking files 08:02:43 PM | Main Menu.xml successfully loaded 08:02:44 PM | Sega Genesis wheel loaded successfully 08:02:46 PM | Launching Game 08:02:46 PM | Using HyperLaunch 08:02:46 PM | Getting HyperLaunch path 08:02:46 PM | HyperLaunch located at D:\Hyperspin\HyperLaunch.exe 08:02:46 PM | Cannot find Hyperlaunch.exe 08:02:52 PM | Launching Game 08:02:52 PM | Using HyperLaunch 08:02:52 PM | Getting HyperLaunch path 08:02:52 PM | HyperLaunch located at D:\Hyperspin\HyperLaunch.exe 08:02:52 PM | Cannot find Hyperlaunch.exe 08:02:54 PM | Loading Main Menu.xml 08:02:54 PM | Main Menu.xml successfully loaded 08:02:55 PM | Main Menu wheel loaded successfully 08:02:56 PM | Exit program unavailable 08:02:56 PM | Quiting Hyperspin 08:02:56 PM | Bye!
