orphen92 Posted June 2, 2015 Posted June 2, 2015 Hi,i have a little probleme with my hyperspin beta 1.4 after make my xpadder configuration.I do not know if the beta version of hyperspin is the cause of this problem.my navigation with xpadder in hypperspin works good, i can select a game and play with it.But when i'm exit the game Hyperspin seems to pass in the background and all my windows element (folder, firefox window etc) pass to foreground so I am forced to reduce everything manually.Do you know this probleme ? can ou help me?Thanks in advance and sorry for my bad english.
orphen92 Posted June 6, 2015 Author Posted June 6, 2015 after many manipulation, when i lauch a game the emulater pass to background and hyperspin interface in the forground. So i can play with my game. can you help me? this is a copy of my HyperSpin Startup Script.ini [Required] HyperSpin_Folder_Path=..\ [General] Primary_Color_RRGGBB=363636 Secondary_Color_RRGGBB=ffffff [Controls] Joysticks_Enabled=False Joysticks_MaxNumberOfJoysticks=4 Joystick_Delay=225 Joystick_Deadzone=25 Joystick_Up=JoyY-|JoyPOVN Joystick_Down=JoyY+|JoyPOVS Joystick_SkipUp=JoyX-|JoyPOVW Joystick_SkipDown=JoyX+|JoyPOVE Joystick_SkipUpNumber=Joy5 Joystick_SkipDownNumber=Joy6 Joystick_HyperSpin=JoyZ-|JoyZ+|Joy9 Joystick_Genre=Joy3 Joystick_Favorites=Joy4 Joystick_Start= Joystick_Exit=Joy2 Joystick_Roulette=Joy7 Joystick_Volume=JoyR- Joystick_Volume_Close= Joystick_QuickLaunch=JoyU+ Joystick_QuickLaunch_Close=JoyU- Joystick_Info=JoyU- Joystick_Info_Close=JoyU+ Joystick_Filters=JoyR+ Joystick_Filters_Close=JoyR- [Startup] Minimize_Background_Windows_Enabled=True Window_Classes_To_Not_Minimize=Shell_TrayWnd,Button Process_Name_To_Close_1= Program_To_Run_Target_1=D:\hubic\hyperspin\RocketLauncher\Profiles\Xpadder\HyperSpin\p1.xpadderprofile Program_To_Run_Working_Dir_1= Program_To_Run_MaxMinHide_1=Hide [Exit] Restore_Windows_On_Exit=True Process_Name_To_Close_1= Program_To_Run_Target_1= Program_To_Run_Working_Dir_1= Program_To_Run_MaxMinHide_1= [Roulette] Roulette_Key=~1 Roulette_Min_MilliSeconds=3000 Roulette_Max_MilliSeconds=8000 [Volume_Menu] Volume_Menu_Key=~2 Volume_Bar_Offset_From_Bottom=44 [QuickLaunch] QuickLaunch_Key=~3 QuickLaunch_Enabled=true QuickLaunch_Left_Offset=5 QuickLaunch_Top_Offset=10 QuickLaunch_Bottom_Offset=10 Item_1_Path= Item_1_Parameters= Item_1_LogoPath= Item_1_Ignore_Process_Close=false thanks you in advance
Dunk3000 Posted June 7, 2015 Posted June 7, 2015 Hi Orphen, That p1.xpadder profile you have starting at launch? Does it add anything extra to your controls than what you have setup in the startup script? If it doesn't, I would stop launching xpadder at hyperspin startup - becase the startup script alone will give you the controls you need, and rocketlauncher can then take care of loading any different profiles for systems should you need them. Once you have done that, if you still have the problem I would try launching a system that you don't have keymmapper setup for in RLUI (just set keys manually in emulator and set keymapper to false in RLUI) because then that will let people know if it is a problem with your overall setup, or just with your keymapper. I don't use xpadder, so maybe someone more experienced can help if that does turn out to be the problem. I'm pretty sure that launching an xpadder profile at startup AND having your controls defined in startup script is not right way to do things though...
