Hyperspin freezing upon loading rom in mame
pil196
Hi i have a problem with hyperspin when loading a mame rom, when i select a rom from the wheel it just freezes and i cant select nothing else i have to close it in task manager any one have any ideas thanks
this is my hyperspin log
03:53:28 PM |  HyperSpin Started
03:53:28 PM |  Going windowed mode
03:53:28 PM |  Checking for updates
03:53:28 PM |  Update Check Complete
03:53:28 PM |  Startup program unavailable
03:53:28 PM |  Playing intro video
03:53:36 PM |  Error intializing joysticks
03:53:36 PM |  Menu Mode is multi
03:53:36 PM |  Loading Main Menu.xml
03:53:36 PM |  Main Menu.xml successfully loaded
03:53:37 PM |  Main Menu wheel loaded successfully
03:53:39 PM |  Loading MAME.xml
03:53:39 PM |  Main Menu.xml successfully loaded
03:53:40 PM |  MAME wheel loaded successfully
03:53:44 PM |  Launching Game
03:53:44 PM |  Not using HyperLaunch
03:53:44 PM |  Running in normal rom mode
03:53:44 PM |  Excecutable is RocketLauncher.exe
03:53:44 PM |  Command Line is: "C:\Hyperspin\RocketLauncher\RocketLauncherUI\RocketLauncher.exe" "airwolf." "MAME" -f "C:\Hyperspin\HyperSpin.exe" -p "HyperSpin"
Check your settings for the various folders for everything RocketLauncher etc
What's happening is supposed to happen - when you load a game the HyperSpin process is paused meaning it freezes. When you close the emulator it will spring back to life.
could it be in my MAME INI folder
[exe info]
path=C:\Hyperspin\RocketLauncher\RocketLauncherUI\
rompath=C:\Hyperspin\Emulators\MAME\roms\
userompath=true
exe=RocketLauncher.exe
romextension=
parameters="MAME" -f "C:\Hyperspin\HyperSpin.exe" -p "HyperSpin"
searchsubfolders=false
pcgame=false
winstate=NORMAL
hyperlaunch=false
Per_Game_Modules=false
Skipchecks=false
Hide_Cursor=use_global
Hide_Desktop=use_global
Hide_Taskbar=use_global
CPWizard_Enabled=use_global
CPWizard_Delay=use_global
CPWizard_Params=use_global
Fade_In=use_global
Fade_Out=use_global
Fade_Color=use_global
Fade_In_Duration=use_global
Fade_Out_Duration=use_global
Fade_In_Delay=use_global
7z_Enabled=use_global
7z_Extract_Dir=use_global
7z_Delete_Temp=use_global
Keymapper_Enabled=use_global
Keymapper=use_global
MultiGame_Enabled=use_global
MultiGame_Background_Color=use_global
MultiGame_Side_Padding=use_global
MultiGame_Y_Offset=use_global
MultiGame_Image_Adjust=use_global
MultiGame_Font=use_global
MultiGame_Text_1_Options=use_global
MultiGame_Text_1_Text=use_global
MultiGame_Text_2_Options=use_global
MultiGame_Text_2_Offset=use_global
MultiGame_Use_Sound=use_global
MultiGame_Sound_Frequency=use_global
MultiGame_Exit_Effect=use_global
MultiGame_Selected_Effect=use_global
MultiGame_Use_Game_Art=use_global
MultiGame_Art_Folder=use_global
Cp_Wizard_Enabled=true
? thanks
strange???? if I restart pc and start hyperspin a mame rom will work and play but as soon as I exit a game and return to game select it freezes up again and game wont load????????
It seems like your trying to use both RL and HS to launch the rom.
how would i know if this is the case? sorry for a noobie question. thanks
That's ok. Have you got any other systems setup to test?
you mean install it all on another system?
No I mean do you have any other systems setup in HyperSpin, like Genesis, SNES etc or are you just starting with MAME?
sorry lol just started with mame
No problem. Can you give us a brief run down on what you've done so far to set it up?
installed hyperspin 3.1 installed rocketlauncher in its own folder with in hyperspin set every thing up in rocketlauncher after update to piont to my emulator and roms all test work fine in rocketlauncher updated my mame.xml to suit my roms then run rl transition to suit hyperspin 1.3 and edited the dxwnd example to just dxwnd thats about it really
Ok. Firstly, I'd advise using the setup tools rather than editing the settings files directly. HSHQ is the setup for HyperSpin and RLUI is for RocketLauncher.
Secondly you need to be using the new HyperSpin 1.4 beta to use RocketLauncher. You'll need to get access to that first.
  On 6/7/2015 at 5:40 PM, jeremy0203 said:
Why does your log say you have RocketLauncher.exe inside the RocketLauncherUI folder?
Also if you are going to use RL with HS 1.3 you need to run the transition tool from RL.
Ha ha top man that was the problem I just edited the MAME.INI from path=C:\Hyperspin\RocketLauncher\RocketLauncherUI\ to path=C:\Hyperspin\RocketLauncher\ and all is working i must have cocked up with the rl transition tool some were.
a big thanks for all your help people just got figure out how get me joysticks and buttons working now
