Upgrading to Rocket Launcher
twmac
I am now in the process of upgrading to rocket launcher. I have upgraded hyperspin to latest via platinum member area. I have changed the default and active front end to hyperspin but it seems as if its still not set. When I am setting up controls the "front end profile" in key mapper is still pointing to rocket launcher.
Well did you tell HS where rocketlauncher is?
I believe so, is that in settings ini? Do I just point it to rocketlauncher exe or rocket launcher?
The exe
Got it working thanks. I wonder if you know this answer to this. I am currently using joy2key but now the joy2key window pops up every time I open hyperspin and I have all the settings telling it to stay minimized on  :/
Here is wiki that helped if anyone else finds themselves having this issue.
http://www.rlauncher.com/wiki/index.php?title=HyperSpin
Make sure your joytokey ini is not set to read only - on first install mine was and I needed to manually change it
Sent from my SM-G925F using Tapatalk
