HyperSpin
    1,123
    40
Everything posted by HyperSpin
  1. Version 1.0
    417 downloads
    Examu Ex-Board HyperBase Database v1.0 (XML)
  2. Version 1.1
    308 downloads
    DICE HyperBase Database v1.1 (XML)
  3. Version 1.0
    169 downloads
    Commodore VIC-20 HyperBase Database (XML)
  4. Version 1.0
    161 downloads
    Commodore 128 HyperBase Database v1.0 (XML)
  5. Version 1.0
    132 downloads
    Commodore 16 HyperBase Database v1.0 (XML) Note: Also includes Commodore Plus4
  6. Version 1.0
    1,900 downloads
    Commodore 64 HyperBase Database v1.0 (XML)
  7. Version 20100414
    274 downloads
    DICE - Main Menu (4:3) Video Snap available from EmuMovies
  8. Version 1.0
    114 downloads
    Astrocade MESS by djvj 1.0 Notes: This module assumes you have astrocde bios in your MESS roms directory, which might be different than your actual roms directory.
  9. Version 1.0
    189 downloads
    Bally Astrocade Database (Official)
  10. Version 1.0
    134 downloads
    Arcadia 2001 MESS by djvj 1.0 Notes: This module assumes you have apfimag bios in your MESS roms directory, which might be different than your actual roms directory.
  11. Version 1.0
    169 downloads
    Emerson Arcadia 2001 Database (Official)
  12. Version 1.0
    432 downloads
    Laser Disk Daphne v1.0.6 by Shaterdsoul 1.0 Info: Using Daphne.exe not tested with Daphneloader.
  13. Version 1.4
    872 downloads
    Daphne Database (Official)
  14. Version 1.0
    475 downloads
    PC Games by Chillinwater 1.0 Info: Make a "dummy" exe script and set it as the Emulator Point "rom path" to your folder with your .LNK files Use the PC game's native exit routine *RetroFitted from BBB's Mame .140 module*
  15. Version 1.0
    637 downloads
    ArcadePC Database (Official)
  16. Version 1.1
    250 downloads
    Atari Lynx Mednafen 0.9.15 by BBB 1.1 Notes: This module assumes you have lynxboot.img in your mednafen directory. Below are some basic params you can change, there are many other params located in the mednafen documentation that you can add if needed. Some people experience screen flickering or black screen and mednafen will not stay in fullscreen, you can changed vDriver below to -vdriver sdl and it will possibly fix the issue. There is no error checking if mednafen fails, so if you try to launch your game and nothing happens, then check the stdout.txt in your mednafen installation directory to see what went wrong. To remap your keys, start a game then press alt + shift + 1 to enter the key configuration. Also see mednafen.cfg to change other keys such as the exit key.
  17. Version 1.1
    413 downloads
    Atari Lynx HyperBase Database (Official)
  18. Version 1.0
    262 downloads
    Atari 5200 kat5200 v0.6.2 by djvj 1.0 Notes: In you emu dir, create a subdir named bios and place the 5200.rom there extracted. When you first start kat5200, you will be presented with a Wizard. Set the bios folder you created as your "Atari 8-bit Image Directory" and leave Scan for BIOS? checked. While in the wizard, check the Fullscreen box to enable it and set Video Zoom to 2x. CLI is supported but doesn't seem to work. So for now, set your video options from the GUI. Settings are stored in the kat5200.db3 file. Roms must be extracted, zip is not supported
  19. Version 1.0
    274 downloads
    Atari 5200 MESS by BBB 1.0 Notes: This module assumes you have a5200 bios in your MESS roms directory, which might be different than your actual roms directory.
  20. Version 1.1
    581 downloads
    Atari 5200 HyperBase Database (Official)
  21. Version 1.0
    1,233 downloads
    Sega Naomi Demul .56 by BBB 1.0
  22. Version 1.2
    1,961 downloads
    Sega Naomi Database (Official)
  23. Version 20150509
    1,421 downloads
    Nintendo NES Pointer
  24. Version 20150509
    878 downloads
    Default NES Main Menu Wheel
  25. Version 20140428
    593 downloads
    NES 2D Cart Pack
