I just installed this latest version and I really like the new features that have been incorporated into the system creation wizard. I did find however, that when the process of creating the system begins, the box that was positioned at the top right of the screen that showed the ROMs being validated is no longer there. The number of ROMs that are displayed next to the system on the left is always zero. It makes no difference which system you try to create, the results are the same. I fell if that portion was fixed, the rest of the process would fall into place.
It does download and install Retroarch and MAME. But for MAME, it actually shows the progress bar, like it's validating the ROMs, but I don't believe it actually is. MAME even shows and error dialog box that states the system failed to be created.
In the images I've attached:
194436 shows my file extensions are correct for the 5200
194615 shows Retroarch being installed
194653 shows the dialog box showing the validation of ROMNs missing from the upper right corner
002043 shows the error dialog that the system creation for MAME has failed
Recommended Comments
