HQ
-only mame launches from hq
-for all my current setup systems there are multiple instances of several games i.e. psp shows 10+ instances of 007, mame multiple 10x10 etc... in hq same for all other systems.
-Artifacts like .txt files or folders can be seen in database (onscreen in hq).
if they are not designated rom extensions per emulator, they should not be seen.
-gui- X or the close current window button and varios other buttons get hidden behind "processing" windows/slats so you cant see that you can use escape key
-maybe put "processing" slats in its own tab or page
-HQ is very slow to populate art (visually in system specific fields
hq crashes when trying to create collections
-Log-in
Constantly have to re-login even though "processing" is still in progress.
should only need to log in once while app is running and login again if relaunching Hq.
id like to see login credentials saved on exit but maybe theres a reason not to save credentials?
