Patched Raw-input with No-Nag and hiscore support
What's New in Version 0.171
  • 0.171
  • MAMETesters Bugs Fixed
  • - 06137: [Crash/Freeze] (maygay1bsw.c) Many sets in maygay1bsw.cpp: Several games
  • are crashing while "initializing.." (Osso)
  • - 06135: [Interface] ROM-less games cannot be started from internal UI
  • - 02327: [Graphics] (megasys1.c) chimerab: Priorty PROM is missing. (David Haywood)
  • - 06134: [Misc.] all games with LED outputs: ledutil no longer works (micko)
  • - 06139: [Color/Palette] (x68k.c) x68k [akumajo]: Some elements turn blue (crazyc)
  • Source Changes
  • -New video chip support : Thomson EF9364 / Sescosem SFF96364 [Jean-Francois DEL NERO]
  • -Pyon Pyon Jump: [Roberto Fresca]
  • Create derivative machine driver.
  • Hooked the V9938 Yamaha VDP.
  • Added the DIP switches bank #1
  • Hooked the system input ports.
  • Added support for Yamaha YM2149.
  • Decoupled the YM2149 data read.
  • Correct bankswitching.
  • Added sound latch & output port.
  • Version added to the game description.
  • Proper inputs + DIP switches support.
  • Second CPU IRQ ack. Promoted to working.
  • OKI M5205 ADPCM samples support.
  • -pulsarlb: Added extra bios [Robbbert]
  • -Modernized sound volume setting code in various Atari drivers [AJR]
  • -Fixed F3 soft-reset on Arkanoid sets with MCU [Lord Nightmare]
  • -osdmini: Fixes build issues [Stuart Carnie]
  • -Replaced osd_lock with std::mutex [Miodrag Milanovic]
  • -Software list entries can now supply slot option defaults [AJR]
  • -i8271: Unload head after programmed revolutions [Nigel Barnes]
  • -apple2: Fix parallel card ACK handling, Print Shop almost works with
  • the lx810l now. [R. Belmont]
  • -Nibble driver: Rewrote the whole driver. Added video hardware,
  • preliminary machine driver and memory map. Decoded the graphics.
  • [Roberto Fresca]
  • -Made anonymous timer non-anonymous in arkanoid.cpp, fixes savestates
  • for the sets using the original Taito MCU code [Lord Nightmare]
  • -Allow load/saved state slots to be bound to joystick buttons [Victor Vasiliev]
  • -Dumped "Dead or Alive 2 (Rev A)", match existent set, fix game and EPRROM names
  • [Smitdogg, The Dumping Union]
  • -Dumped "King of Fighters XI" EN, match JP one, add notes [Brizzo]
  • -Substantial improvements to Web Audio sound backend for Emscripten
  • port. [Grant Galitz]
  • -disound: Don't crash on state load when the mixer is disabled by lack
  • of inputs (misconfiguration or missing samples) [O. Galibert]
  • -Initial import of MEWUI to MAME [Maurizio Petrarota]
  • -External DATs grouped into a single view. [Maurizio Petrarota]
  • -New video chip support: Thomson EF9364 / Sescosem SFF96364 [Jean-Francois DEL NERO]
  • -z80.cpp: Added a debug mechanism for /WAIT pin assertion mechanism
  • (enable with STALLS_ON_WAIT_ASSERT in CPU core), and hooked it up to
  • Night Gal driver as a quick example. [Angelo Salese]
  • -Make octal flag part of address_space/address_space_config [AJR]
  • -Added unknown NAOMI development(?) board BOOT ROM [coolmod]
  • -Initial support for BGFX [Ryan Holtz, Dario Manesku, Branimir Karadic, Miodrag Milanovic]
  • -Significant speed improvements to the BGFX renderer. [Ryan Holtz]
  • -Added basic JSON-based single-pass shader effect support to BGFX renderer. [Ryan Holtz]
  • -Added hat trick hero 93 PALs [Alex Cmaylo]
  • -catnmous: graphical improvements [Vernimark, Vas Crabb]
  • * Redumped Cat and Mouse colour sprite ROM as the correct size
  • * Implement sprite ROM banking
  • * Improve colour palette using resistor values from board photographs
  • -laserbat: fix inadvertently swapped TMS organ chip clocks (fixes music) [Vas Crabb]
  • -Make Zaccaria 1B11107 and 1B11142 boards devices and share common parts [Vas Crabb]
  • -apple1: Completely rewrote the driver in modern idioms. All
  • functionality should be the same. [R. Belmont]
  • -Descrambled the ROM on the Xerox NoteTaker, and mapped it in the
  • correct areas to make it start to boot. [Lord Nightmare]
  • -Xerox NoteTaker: Corrected CPU Clock speed, and map at least some of RAM
  • [Lord Nightmare]
  • -electron: Added cassette softlist and implemented BREAK key [Nigel Barnes]
  • -Xerox NoteTaker: Corrected RAM amount. Attached the pic8259 interrupt
  • controller, though no interrupts are attached to that yet. Added
  • documentation of i/o writes during the boot process. [Lord Nightmare]
  • -vigilant.cpp: Added video timing PROM. [Pasky, caius]
  • -Videosnaps patch (additional file to write: gamename.inp.timecode) [Michele Fochi]
  • Added new options:
  • * [no]exit_after_playback (default=no)
  • * [no]record_input (default=no) Added new UI shortcut to save current
  • timecode (default F12) Translated variable names and comments to
  • english language
  • -Sord m5 driver update [Ales Dlabac]
  • added support for RAM expansions EM-5,64KBI,64KBF,64KRX
  • added m5p_brno mod Sord m5+1024kB
  • ramdisk+cp/m 2 cart slots
  • -Moon Light (Set 2): Fix the program ROM addressing. This fix the
  • corrupt graphics in the double-Up feature. [Roberto Fresca]
  • -Moved JANGOU_BLITTER into a device [Angelo Salese]
  • -NCS8105 ADCX opcode is actually an ADDX, fixes gfx garbage in
  • nightgal.cpp [Angelo Salese]
  • -Corrected ROM labels and removed endian-swap during descramble for
  • notetaker in favor of loading ROMs the other way round. Add ROM
  • locations. [Lord Nightmare]
  • -Xerox NoteTaker: Implement ROM/RAM overlay as per schematics.
  • Documented Address map and part of I/O map. [Lord Nightmare]
  • -Note that one of the buccaneers proms matches the vigilante video sync
  • prom [caius, David Haywood]
  • -Moon Light: Rearranged and split by program. This generated new sets
  • due to the hidden extra programs in the program ROMs. [Roberto Fresca]
  • -Xerox NoteTaker: Added the IO Processor firmware v1.50 as an alt bios
  • after typing it from the assembly source listing on bitsavers. Added
  • two PROMs as NO_DUMP. Updated comments and history a bit, but needs
  • further improvement. [Lord Nightmare]
  • -Updated Xerox NoteTaker documentation and history section, with cited
  • sources. [Lord Nightmare]
  • -Cherry Master v1.10: Fixed inputs / DIP switches. [Roberto Fresca]
  • -Xerox NoteTaker: Finished documenting the I/O CPU's I/O ports, updated
  • history documentation a bit more [Lord Nightmare]
  • -Figured out algorithm and replaced SnowBoard Championship lookup
  • table with proper emulation of device [Samuel Neves & Peter
  • Wilhelmsen]
  • -chihiro.c: Redumped "Sega Network Taisen Mahjong MJ 2 (Rev G)" [ANY]
  • Re-parented set
  • -mitchell.cpp: Dumped a blockjoy board and noted a rom label difference
  • [Andrea Palazzetti]
  • -snotec.xml: Added 3 new cart dumps. [TeamEurope]
  • -Extended LUA API [Jeffrey Clark]
  • -Support for the AMPAL18P8 to the jedutil tool. [Kevin Eshbach]
  • -Improved cross compile support [Jeffrey Clark]
  • -Hp9845: Added tape driver [F. Ulivi]
  • -r9751: Add more DMA registers for serial and floppy [Brandon Munger]
  • -slapstic: One small step toward slapstic modernization [AJR]
  • * Make chip number part of device configuration, not init param
  • * Correct mainpcb slapstic number in racedrivpan
  • * Remove many unused slapstics
  • -c64_cart.xml, c128_cart.xml: Added some diagnostic carts.
  • [World of Jani]
  • -COM5016/COM8116 Baud Generator: Added a bunch more divisor tables and
  • notes [Lord Nightmare]
  • -Apollo changes: [Hans Ostermeyer]
  • * Unified logging format in associated devices
  • * Use correct raw video modes
  • -Xerox NoteTaker: Finished IOCPU memory map documentation. Hooked up the two
  • UARTS. Begin hookup of the screen/CRTC. Fixed an issue with writes to
  • ROM-mapped areas shadowing to RAM. Added 960KHz xtal for the keyboard UART.
  • [Lord Nightmare]
  • -AY-3-1015 UART: Fixed two swapped pin functions. [Lord Nightmare]
  • -Added multi-language support for MAME [Miodrag Milanovic]
  • -sq1: Much-improved LCD and front panel button support.
  • [Parduz, R. Belmont]
  • -weddingr: better input port descriptions [Vas Crabb]
  • -Added Chinese Simplified and Chinese Traditional translation [YuiFAN]
  • -Added German translation [Raf Tacker]
  • -Added Japanese translation [Fujix]
  • -Added Italian translation [Angelo Salese,Antonio Paradossi,Fabio Priuli]
  • -Added Portuguese (Brazil) translation [Ashura-X]
  • -pacman.cpp, meadwttl.cpp: small fix of game years for Novomatic's Cannon
  • Ball and Meadows' Meadows 4 in 1, respectively, to synchronize with
  • history.dat [Antonio Paradossi]
  • New machines added or promoted from NOT_WORKING status
  • Pyon Pyon Jump (V1.40, Japan) [Roberto Fresca]
  • Carnival King [Ted Green]
  • Fidelity Chess Challenger 10 [hap, Berger]
  • Fidelity Sensory Chess Challenger 12-B [hap, Berger]
  • Fidelity Voice Chess Challenger [hap]
  • Fidelity Voice Sensory Chess Challenger [hap]
  • Fidelity Champion Sensory Chess Challenger [hap]
  • Fidelity Chess Challenger 7 [hap, Berger]
  • Fidelity Excellence [hap, plgDavid]
  • Fidelity Voice Excellence [hap, plgDavid]
  • SMT Goupil G1 [Jean-Francois DEL NERO]
  • Michigan Super Draw (2131-16, U5-2)
  • [Charles MacDonald, Brian Troha, David Haywood, The Dumping Union]
  • '96 Flag Rally [Nosunosu, ShouTime, David Haywood]
  • Apple IIe (Spanish) [robcfg, R. Belmont]
  • Super Cherry Master (v1.0) [Roberto Fresca, Ioannis Bampoulas]
  • Fidelity Elite Avant Garde (model 6114) [hap, Micha]
  • Coleco Electronic Quarterback [hap, Sean Riddle]
  • Fidelity Elite Avant Garde (model 6117-7) [hap, Micha]
  • Fidelity Elite Avant Garde (V10/V11) [hap, Micha]
  • Parker Brothers Lost Treasure [hap, Sean Riddle]
  • Coleco Zodiac [hap, Sean Riddle]
  • Conic Electronic Football II [hap, Sean Riddle]
  • New clones added or promoted from NOT_WORKING status
  • Touche Me (set 2, harder) [system11]
  • Speak & Math (1980 version) [Sean Riddle, plgDavid]
  • La Dictee Magique (French Speak & Spell) [Sean Riddle, plgDavid]
  • Grillo Parlante (Italian Speak & Spell) [Sean Riddle, plgDavid]
  • 1000 Miglia: Great 1000 Miles Rally (94/05/10) [Corrado Tomaselli]
  • Multi Champ (World, older) [f205v]
  • 1000 Miglia: Great 1000 Miles Rally (94/05/26) [caius]
  • NBA Jam (rev 1.00 02/1/93 [Alex Meijer, Bernard Tack]
  • Raiden Fighters 2 - Operation Hell Dive (Italy) [Corrado Tomaselli]
  • 64th. Street - A Detective Story (Japan, set 2) [Corrado Tomaselli]
  • World Rally (Version 1.0, Checksum 8AA2) [Artemio Urbina]
  • Fighting Golf (US, Ver 2)
  • [Ryan Holtz, Shoutime, Smitdogg, The Dumping Union]
  • World Cup Volley '95 Extra Version (Asia v2.0B) [Kevin Eshbach]
  • Moon Light (bootleg of Golden Star, set 2) [f205v, Roberto Fresca]
  • Frogger (Sega set 3) [Team Europe]
  • Moon Light (v.0629, high program) [Roberto Fresca, f205v]
  • Moon Light (v.02L0A, low program) [Roberto Fresca, f205v]
  • Moon Light (v.02L0A, high program, alt gfx) [Roberto Fresca, f205v]
  • Cherry Gold I (set 2, encrypted bootleg) [Roberto Fresca, f205v]
  • Cherry Master I (ver.1.01, set 8, V4-B-) [Roberto Fresca, f205v]
  • Cherry Master I (ver.1.10) [Roberto Fresca, Ioannis Bampoulas]
  • Super Bobble Bobble (bootleg, set 4) [Jose Jorge Fuentes]
  • 1943: Midway Kaisen (bootleg) [Andrea Palazzetti]
  • Space Rocks (Spanish clone of Asteroids) [pako ikarihardmods]
  • Block Block (World 911219 Joystick) [caius, The Dumping Union]
  • Royal Poker '96 (set 4, C3 board) [Roberto Fresca, Ioannis Bampoulas]
  • New Cherry '96 (bootleg of New Fruit Bonus?) [Roberto Fresca, Ioannis Bampoulas]
  • New machines marked as NOT_WORKING
  • Argox Rabbit Printer (model OS-214) [Felipe Sanches]
  • Xerox NoteTaker [Lord Nightmare, bitsavers]
  • Unknown Nibble game
  • [Team Europe, Marcus Jendroska, Y~K, Smitdogg, Roberto Fresca, The Dumping Union]
  • Name Club Ver.2 (J 960315 V1.000) [TeamEurope, Ryan Holtz]
  • Cross Puzzle [Ryan Holtz, Smitdogg, The Dumping Union]
  • Print Club LoveLove (J 970421 V1.000) [TeamEurope, Ryan Holtz]
  • Print Club Yoshimoto V2 (J 970422 V1.100) [TeamEurope, Ryan Holtz]
  • Print Club 2 Vol. 7 Spring (J 970313 V1.100) [TeamEurope, Ryan Holtz]
  • Print Club 2 Puffy (Japan) [TeamEurope, Ryan Holtz]
  • Print Club 2 Pepsiman (J 970618 V1.100) [Team Europe, Ryan Holtz]
  • Print Club 2 Vol. 6 Winter (J 961210 V1.000) [Team Europe, Ryan Holtz]
  • Print Club 2 Warner Bros (J 970228 V1.000) [Team Europe, Ryan Holtz]
  • Print Club 2 '97 Winter Ver (J 971017 V1.100, set 2) [Team Europe, Ryan Holtz]
  • Print Club 2 '98 Summer Ver (J 980603 V1.100) [Team Europe, Ryan Holtz]
  • Print Club LoveLove Ver 2 (J 970825 V1.000) [TeamEurope, Ryan Holtz]
  • Name Club (J 960315 V1.000) [Team Europe, Ryan Holtz]
  • Dragon Treasure 2 (Rev A) (GDS-0037A)
  • [Jorge Valero, rtw, The Dumping Union]
  • Tiger K28/Coleco Talking Teacher
  • [hap, Jonathan Gevaryahu, Sean Riddle, plgDavid, Kevin Horton]
  • Mattel Computer Gin [hap, Kevin Horton]
  • Tiger K28 (model 7-230) [hap, Kevin Horton]
  • Coleco Head to Head Basketball (COP420L) [Sean Riddle]
  • Wangan Midnight R (WMR1 Ver. A) [Darksoft, Guru, R. Belmont]
  • IGT Multistar 7 2c [Miodrag Milanovic]
  • New clones marked as NOT_WORKING
  • Jurassic Park 3 (ver UA) [ShouTime]
  • Police 24/7 (ver EAA, alt) [Guru]
  • Thrill Drive 2 (ver EAA, 2 alt versions) [Guru]
  • Tsurugi (ver EAB, alt) [Guru]
  • World Combat (ver AAD, alt) [Guru]
  • The Rumble Fish (prototype) [Brizzo, MetalliC, Arzeno Fabrice]
  • NeoGeo Battle Coliseum (World) [Brizzo, MetalliC, Arzeno Fabrice]
  • New WORKING software list additions
  • Fidelity Chess CB16 [anonymous]
  • New NOT_WORKING software list additions
