Look, I finally did something!!
Audio is still not emulated and it's not running at full speed.  Still people want it, so here you go!
Scanning the IntelliCards (HyperScan playing cards) through Mame File Manager is very frustrating. MAME software list named each card with only a number.  I renamed each card assuming they were numbered in correct sequence.  For the most part it seems to be correct when selecting Character cards.
This system is barely playable. Even if the audio and speed issues were solved, the card scanning component will not work unless you can actually see the cards you are selecting.
What's New in Version 1.0.0   See changelog
Released
Added compatible MAME core
  • Like 4
  • Super Like 7
Recommended Comments
JefeMonteiro
Hello, do you need the hash file? Do you use the mother nucleus?
floatingyeti
If I ever forget something just let me know.  There are many parts to these full setup uploads and I often forget a part.
JefeMonteiro
Hello, my screen is black and Spiderman opens and gives an error, I'm using Nucleo Mame
JefeMonteiro
Could you help? Or send the correct mame core
floatingyeti
Expand
Sorry again, I'm not receiving notifications for comments on my uploads.  All my RetroArch (MAME) setups are using Arcade(MAME) core [mame_libretro.dll]
JefeMonteiro
Hello great work, could you make mame_libreto.dll available, I don't know what else is wrong
JefeMonteiro
I use a different mame_libreto.dll with this one I can play the console super a'can more when using this system some games give a blue error screen of the mame others stay on a black screen I tried putting the latest version of the mame core but opening and closing the games I will attach the .xml file
hyperscan.xmlFetching info...
floatingyeti
When you run RetroArch just go to "Core Downloader" and select Arcade(MAME) to download mame_libretro.dll.
I added the MAME core to the upload. Extract it to your RetroArch cores folder and it should work.
Yes, that hash file is correct.
Which MAME Core are you using to play Super A'Can?
JefeMonteiro
Hi, I did this and it gave me an error. Could you send me the file so I can see it? Via Discord? I use core mame_libreto and a single old core that works on super A'can
floatingyeti
I have provided the file as part of the HyperScan upload.
JefeMonteiro
Hello, I put this core in, it won't work, I even downloaded all the retroarch again, it wasn't, one thing I remembered was the games I had to download from somewhere else, these are giving errors in both games 1 and 2, you can't extract them, could you take a look at the rosm that you put here?
floatingyeti
I downloaded my own upload and the files and games work.  The games are not extracted to run because the .zip files are empty "dummy" files.  MAME loads the "dummy" roms inorder to launch the corresponding CHD files.
If you are using anything other than the standard current MAME core with the current MAME software list CHD, I dont think it will work.
JefeMonteiro
So, isn't it to extract the ZIP file? Does that name remain the same as in the .zip file?
JefeMonteiro
Hello friend, I'm going to give up, I extracted the ZIP file and left it unextracted, my core is all up to date, but as I said, it only works on the old mame core that I have, the games open and the screen is black
