autohotkey error
Obsesjohn
Hi,
I.m sorry for my bad english upfront.
my hyperspin machine give me an autohotkey error on my mame games.
this is what it says:
autohotkey....
Error at line 605
line text: hideemustart (ms=2)
error Duplicate function definition
the program will exit.
In rocketlauncher the games starts normaly.
thank you very much.
John
First we need to narrow it down to what is causing your issue. To do this we will need some information.
To verify hyperspin is working, you will need to post your hyperspin log (same folder as hyperspin.exe).
To verify that rocketlauncher is working, you need to post you rocketlauncher troubleshooting log.
If the logs don't reveal anything then it is most likely an emulator problem or a security problem.
  • 1 year later...
Having this same problem since Norton deleted my Hyperlaunch and i redownloaded one.    This is what my log says:
03:38:50 PM |  HyperSpin Started
03:38:50 PM |  Going FullScreen
03:38:50 PM |  Checking for updates
03:38:50 PM |  Update Check Complete
03:38:50 PM |  Startup program unavailable
03:38:50 PM |  Playing intro video
03:38:52 PM |  Error intializing joysticks
03:38:52 PM |  Menu Mode is multi
03:38:52 PM |  Loading Main Menu.xml
03:38:52 PM |  Main Menu.xml successfully loaded
03:38:53 PM |  Main Menu wheel loaded successfully
03:38:55 PM |  Loading MAME.xml
03:38:56 PM |  Main Menu.xml successfully loaded
03:38:57 PM |  MAME wheel loaded successfully
03:38:59 PM |  Launching Game
03:38:59 PM |  Using HyperLaunch
03:38:59 PM |  Getting HyperLaunch path
03:38:59 PM |  HyperLaunch located at h:\Hyperspin\HyperLaunch\HyperLaunch.exe
03:38:59 PM |  Running HyperLaunch.exe
03:38:59 PM |  HyperLaunch Command Line is: h:\Hyperspin\HyperLaunch\HyperLaunch.exe "MAME" "xmen"
03:39:06 PM |  Launching Game
03:39:06 PM |  Using HyperLaunch
03:39:07 PM |  Getting HyperLaunch path
03:39:07 PM |  HyperLaunch located at h:\Hyperspin\HyperLaunch\HyperLaunch.exe
03:39:07 PM |  Running HyperLaunch.exe
03:39:07 PM |  HyperLaunch Command Line is: h:\Hyperspin\HyperLaunch\HyperLaunch.exe "MAME" "xmen"
03:39:16 PM |  Loading Main Menu.xml
03:39:16 PM |  Main Menu.xml successfully loaded
03:39:17 PM |  Main Menu wheel loaded successfully
03:39:20 PM |  Exit program unavailable
03:39:20 PM |  Quiting Hyperspin
03:39:20 PM |  Bye!
