tonycrew Posted June 26, 2015 Posted June 26, 2015 Does anyone know how to configure these 2 systems on RetroArch, because when i choose to Bind All it goes through the B,Y,Select,A,B etc but none of them seem to work for the run button, I think maybe the problem is that my first controller is listed as IPAC and not my U360 sticks...? If not how do i convert all my img's to CHD so i can use them in mess...? i'd rather not do this as it's gonna take awhile...
Guest Posted June 26, 2015 Posted June 26, 2015 On 6/26/2015 at 4:54 PM, tonycrew said: Does anyone know how to configure these 2 systems on RetroArch, because when i choose to Bind All it goes through the B,Y,Select,A,B etc but none of them seem to work for the run button, I think maybe the problem is that my first controller is listed as IPAC and not my U360 sticks...? If not how do i convert all my img's to CHD so i can use them in mess...? i'd rather not do this as it's gonna take awhile... Try remapping the controls in the retroarch menu.
tonycrew Posted June 26, 2015 Author Posted June 26, 2015 Yeh i tried that but for some reason it wasn't working, so i mapped them to keys and use xpadder to control.
newoski Posted July 3, 2015 Posted July 3, 2015 I have both setup and working in RA. Out of town til Sunday. PM me if I haven't posted my config by Sunday evening Sent from my HTC6535LVW using Tapatalk
newoski Posted July 6, 2015 Posted July 6, 2015 NEC TurboGrafx-CD Quote input_max_users = "4" input_axis_threshold = "0.500000" video_gpu_record = "false" input_remap_binds_enable = "true" netplay_client_swap_input = "true" input_descriptor_label_show = "true" autoconfig_descriptor_label_show = "true" input_descriptor_hide_unbound = "false" load_dummy_on_core_shutdown = "false" fps_show = "false" ui_menubar_enable = "true" suspend_screensaver_enable = "true" libretro_path = ":\cores\mednafen_pce_fast_libretro.dll" libretro_directory = ":\cores" cheat_database_path = ":\cheats" cursor_directory = ":\database\cursors" rewind_enable = "false" audio_latency = "64" audio_sync = "true" audio_block_frames = "0" rewind_granularity = "1" video_shader = ":\shaders\crt\crt-royale\crt-royale.cgp" video_shader_enable = "true" video_aspect_ratio = "-1.000000" video_aspect_ratio_auto = "false" video_windowed_fullscreen = "true" video_scale = "3.000000" autosave_interval = "0" video_crop_overscan = "true" video_scale_integer = "false" video_smooth = "true" video_threaded = "false" video_shared_context = "false" video_force_srgb_disable = "false" video_fullscreen = "false" video_refresh_rate = "59.950001" video_monitor_index = "0" video_fullscreen_x = "0" video_fullscreen_y = "0" video_driver = "gl" threaded_data_runloop_enable = "true" menu_driver = "rgui" menu_pause_libretro = "true" menu_mouse_enable = "false" menu_timedate_enable = "true" menu_core_enable = "true" video_vsync = "true" video_hard_sync = "false" video_hard_sync_frames = "0" video_frame_delay = "0" video_black_frame_insertion = "false" video_disable_composition = "false" pause_nonactive = "false" video_swap_interval = "1" video_gpu_screenshot = "true" video_rotation = "0" screenshot_directory = "default" aspect_ratio_index = "20" core_updater_buildbot_url = "http://buildbot.libretro.com/nightly/win-x86_64/latest/" core_updater_buildbot_assets_url = "http://buildbot.libretro.com/assets/" core_updater_auto_extract_archive = "true" camera_allow = "false" audio_rate_control = "true" audio_rate_control_delta = "0.005000" audio_max_timing_skew = "0.050000" audio_volume = "0.000000" audio_driver = "dsound" audio_enable = "true" audio_mute_enable = "false" audio_out_rate = "48000" location_allow = "false" video_font_size = "32.000000" video_font_enable = "true" ups_pref = "false" bps_pref = "false" ips_pref = "false" system_directory = ":\system" input_remapping_directory = ":\configs" audio_resampler = "sinc" savefile_directory = "default" savestate_directory = "default" video_shader_dir = ":\shaders" video_filter_dir = ":\filters\video" audio_filter_dir = ":\filters\audio" core_assets_directory = "default" assets_directory = ":\assets" playlist_directory = ":\playlists" rgui_browser_directory = "E:" rgui_config_directory = ":\configs" rgui_show_start_screen = "false" menu_navigation_wraparound_horizontal_enable = "true" menu_navigation_wraparound_vertical_enable = "true" menu_navigation_browser_filter_supported_extensions_enable = "true" menu_collapse_subgroups_enable = "true" menu_show_advanced_settings = "false" menu_entry_normal_color = "ffffffff" menu_entry_hover_color = "ff64ff64" menu_title_color = "ff64ff64" game_history_path = ":\retroarch-content-history.txt" game_history_size = "100" joypad_autoconfig_dir = ":\autoconfig" input_autodetect_enable = "true" overlay_directory = ":\overlays" input_overlay_enable = "true" input_overlay_opacity = "0.700000" input_overlay_scale = "1.000000" osk_overlay_directory = ":\overlays" input_osk_overlay_enable = "false" video_message_pos_x = "0.050000" video_message_pos_y = "0.050000" gamma_correction = "false" soft_filter_enable = "false" flicker_filter_enable = "false" flicker_filter_index = "0" soft_filter_index = "0" current_resolution_id = "0" custom_viewport_width = "960" custom_viewport_height = "720" custom_viewport_x = "0" custom_viewport_y = "0" block_sram_overwrite = "false" savestate_auto_index = "false" savestate_auto_save = "false" savestate_auto_load = "false" history_list_enable = "true" fastforward_ratio = "1.000000" fastforward_ratio_throttle_enable = "false" slowmotion_ratio = "3.000000" config_save_on_exit = "false" sound_mode = "0" state_slot = "0" netplay_spectator_mode_enable = "false" netplay_mode = "false" netplay_ip_port = "0" netplay_delay_frames = "0" user_language = "0" custom_bgm_enable = "false" input_driver = "dinput" input_joypad_driver = "winxinput" input_device_p1 = "0" input_player1_joypad_index = "0" input_libretro_device_p1 = "1" input_player1_analog_dpad_mode = "0" input_device_p2 = "0" input_player2_joypad_index = "1" input_libretro_device_p2 = "1" input_player2_analog_dpad_mode = "0" input_device_p3 = "0" input_player3_joypad_index = "2" input_libretro_device_p3 = "1" input_player3_analog_dpad_mode = "0" input_device_p4 = "0" input_player4_joypad_index = "3" input_libretro_device_p4 = "1" input_player4_analog_dpad_mode = "0" input_device_p5 = "0" input_player5_joypad_index = "4" input_libretro_device_p5 = "1" input_player5_analog_dpad_mode = "0" input_device_p6 = "0" input_player6_joypad_index = "4" input_libretro_device_p6 = "1" input_player6_analog_dpad_mode = "0" input_device_p7 = "0" input_player7_joypad_index = "4" input_libretro_device_p7 = "1" input_player7_analog_dpad_mode = "0" input_device_p8 = "0" input_player8_joypad_index = "4" input_libretro_device_p8 = "1" input_player8_analog_dpad_mode = "0" input_device_p9 = "0" input_player9_joypad_index = "8" input_libretro_device_p9 = "1" input_player9_analog_dpad_mode = "0" input_device_p10 = "0" input_player10_joypad_index = "9" input_libretro_device_p10 = "1" input_player10_analog_dpad_mode = "0" input_device_p11 = "0" input_player11_joypad_index = "10" input_libretro_device_p11 = "1" input_player11_analog_dpad_mode = "0" input_device_p12 = "0" input_player12_joypad_index = "11" input_libretro_device_p12 = "1" input_player12_analog_dpad_mode = "0" input_device_p13 = "0" input_player13_joypad_index = "12" input_libretro_device_p13 = "1" input_player13_analog_dpad_mode = "0" input_device_p14 = "0" input_player14_joypad_index = "13" input_libretro_device_p14 = "1" input_player14_analog_dpad_mode = "0" input_device_p15 = "0" input_player15_joypad_index = "14" input_libretro_device_p15 = "1" input_player15_analog_dpad_mode = "0" input_device_p16 = "0" input_player16_joypad_index = "15" input_libretro_device_p16 = "1" input_player16_analog_dpad_mode = "0" input_player1_b = "a" input_player1_b_btn = "nul" input_player1_b_axis = "nul" input_player1_y = "nul" input_player1_y_btn = "nul" input_player1_y_axis = "nul" input_player1_select = "s" input_player1_select_btn = "nul" input_player1_select_axis = "nul" input_player1_start = "r" input_player1_start_btn = "nul" input_player1_start_axis = "nul" input_player1_up = "up" input_player1_up_btn = "nul" input_player1_up_axis = "nul" input_player1_down = "down" input_player1_down_btn = "nul" input_player1_down_axis = "nul" input_player1_left = "left" input_player1_left_btn = "nul" input_player1_left_axis = "nul" input_player1_right = "right" input_player1_right_btn = "nul" input_player1_right_axis = "nul" input_player1_a = "b" input_player1_a_btn = "nul" input_player1_a_axis = "nul" input_player1_x = "nul" input_player1_x_btn = "nul" input_player1_x_axis = "nul" input_player1_l = "nul" input_player1_l_btn = "nul" input_player1_l_axis = "nul" input_player1_r = "nul" input_player1_r_btn = "nul" input_player1_r_axis = "nul" input_player1_l2 = "nul" input_player1_l2_btn = "nul" input_player1_l2_axis = "nul" input_player1_r2 = "nul" input_player1_r2_btn = "nul" input_player1_r2_axis = "nul" input_player1_l3 = "nul" input_player1_l3_btn = "nul" input_player1_l3_axis = "nul" input_player1_r3 = "nul" input_player1_r3_btn = "nul" input_player1_r3_axis = "nul" input_player1_l_x_plus = "nul" input_player1_l_x_plus_btn = "nul" input_player1_l_x_plus_axis = "nul" input_player1_l_x_minus = "nul" input_player1_l_x_minus_btn = "nul" input_player1_l_x_minus_axis = "nul" input_player1_l_y_plus = "nul" input_player1_l_y_plus_btn = "nul" input_player1_l_y_plus_axis = "nul" input_player1_l_y_minus = "nul" input_player1_l_y_minus_btn = "nul" input_player1_l_y_minus_axis = "nul" input_player1_r_x_plus = "nul" input_player1_r_x_plus_btn = "nul" input_player1_r_x_plus_axis = "nul" input_player1_r_x_minus = "nul" input_player1_r_x_minus_btn = "nul" input_player1_r_x_minus_axis = "nul" input_player1_r_y_plus = "nul" input_player1_r_y_plus_btn = "nul" input_player1_r_y_plus_axis = "nul" input_player1_r_y_minus = "nul" input_player1_r_y_minus_btn = "nul" input_player1_r_y_minus_axis = "nul" input_player1_turbo = "nul" input_player1_turbo_btn = "nul" input_player1_turbo_axis = "nul" input_toggle_fast_forward = "nul" input_toggle_fast_forward_btn = "nul" input_toggle_fast_forward_axis = "nul" input_hold_fast_forward = "nul" input_hold_fast_forward_btn = "nul" input_hold_fast_forward_axis = "nul" input_load_state = "f4" input_load_state_btn = "nul" input_load_state_axis = "nul" input_save_state = "f3" input_save_state_btn = "nul" input_save_state_axis = "nul" input_toggle_fullscreen = "nul" input_toggle_fullscreen_btn = "nul" input_toggle_fullscreen_axis = "nul" input_exit_emulator = "nul" input_exit_emulator_btn = "nul" input_exit_emulator_axis = "nul" input_state_slot_increase = "f1" input_state_slot_increase_btn = "nul" input_state_slot_increase_axis = "nul" input_state_slot_decrease = "f2" input_state_slot_decrease_btn = "nul" input_state_slot_decrease_axis = "nul" input_rewind = "nul" input_rewind_btn = "nul" input_rewind_axis = "nul" input_movie_record_toggle = "nul" input_movie_record_toggle_btn = "nul" input_movie_record_toggle_axis = "nul" input_pause_toggle = "p" input_pause_toggle_btn = "nul" input_pause_toggle_axis = "nul" input_frame_advance = "nul" input_frame_advance_btn = "nul" input_frame_advance_axis = "nul" input_reset = "nul" input_reset_btn = "nul" input_reset_axis = "nul" input_shader_next = "nul" input_shader_next_btn = "nul" input_shader_next_axis = "nul" input_shader_prev = "nul" input_shader_prev_btn = "nul" input_shader_prev_axis = "nul" input_cheat_index_plus = "nul" input_cheat_index_plus_btn = "nul" input_cheat_index_plus_axis = "nul" input_cheat_index_minus = "nul" input_cheat_index_minus_btn = "nul" input_cheat_index_minus_axis = "nul" input_cheat_toggle = "nul" input_cheat_toggle_btn = "nul" input_cheat_toggle_axis = "nul" input_screenshot = "nul" input_screenshot_btn = "nul" input_screenshot_axis = "nul" input_audio_mute = "nul" input_audio_mute_btn = "nul" input_audio_mute_axis = "nul" input_netplay_flip_players = "nul" input_netplay_flip_players_btn = "nul" input_netplay_flip_players_axis = "nul" input_slowmotion = "nul" input_slowmotion_btn = "nul" input_slowmotion_axis = "nul" input_enable_hotkey = "nul" input_enable_hotkey_btn = "nul" input_enable_hotkey_axis = "nul" input_volume_up = "nul" input_volume_up_btn = "nul" input_volume_up_axis = "nul" input_volume_down = "nul" input_volume_down_btn = "nul" input_volume_down_axis = "nul" input_overlay_next = "nul" input_overlay_next_btn = "nul" input_overlay_next_axis = "nul" input_disk_eject_toggle = "F10" input_disk_eject_toggle_btn = "nul" input_disk_eject_toggle_axis = "nul" input_disk_next = "F11" input_disk_next_btn = "nul" input_disk_next_axis = "nul" input_disk_prev = "F12" input_disk_prev_btn = "nul" input_disk_prev_axis = "nul" input_grab_mouse_toggle = "nul" input_grab_mouse_toggle_btn = "nul" input_grab_mouse_toggle_axis = "nul" input_menu_toggle = "tab" input_menu_toggle_btn = "99" input_menu_toggle_axis = "nul" input_player2_b = "g" input_player2_b_btn = "nul" input_player2_b_axis = "nul" input_player2_y = "nul" input_player2_y_btn = "nul" input_player2_y_axis = "nul" input_player2_select = "u" input_player2_select_btn = "nul" input_player2_select_axis = "nul" input_player2_start = "t" input_player2_start_btn = "nul" input_player2_start_axis = "nul" input_player2_up = "n" input_player2_up_btn = "nul" input_player2_up_axis = "nul" input_player2_down = "q" input_player2_down_btn = "nul" input_player2_down_axis = "nul" input_player2_left = "m" input_player2_left_btn = "nul" input_player2_left_axis = "nul" input_player2_right = "o" input_player2_right_btn = "nul" input_player2_right_axis = "nul" input_player2_a = "h" input_player2_a_btn = "nul" input_player2_a_axis = "nul" input_player2_x = "nul" input_player2_x_btn = "nul" input_player2_x_axis = "nul" input_player2_l = "nul" input_player2_l_btn = "nul" input_player2_l_axis = "nul" input_player2_r = "nul" input_player2_r_btn = "nul" input_player2_r_axis = "nul" input_player2_l2 = "nul" input_player2_l2_btn = "nul" input_player2_l2_axis = "nul" input_player2_r2 = "nul" input_player2_r2_btn = "nul" input_player2_r2_axis = "nul" input_player2_l3 = "nul" input_player2_l3_btn = "nul" input_player2_l3_axis = "nul" input_player2_r3 = "nul" input_player2_r3_btn = "nul" input_player2_r3_axis = "nul" input_player2_l_x_plus = "nul" input_player2_l_x_plus_btn = "nul" input_player2_l_x_plus_axis = "nul" input_player2_l_x_minus = "nul" input_player2_l_x_minus_btn = "nul" input_player2_l_x_minus_axis = "nul" input_player2_l_y_plus = "nul" input_player2_l_y_plus_btn = "nul" input_player2_l_y_plus_axis = "nul" input_player2_l_y_minus = "nul" input_player2_l_y_minus_btn = "nul" input_player2_l_y_minus_axis = "nul" input_player2_r_x_plus = "nul" input_player2_r_x_plus_btn = "nul" input_player2_r_x_plus_axis = "nul" input_player2_r_x_minus = "nul" input_player2_r_x_minus_btn = "nul" input_player2_r_x_minus_axis = "nul" input_player2_r_y_plus = "nul" input_player2_r_y_plus_btn = "nul" input_player2_r_y_plus_axis = "nul" input_player2_r_y_minus = "nul" input_player2_r_y_minus_btn = "nul" input_player2_r_y_minus_axis = "nul" input_player2_turbo = "nul" input_player2_turbo_btn = "nul" input_player2_turbo_axis = "nul" input_player3_b = "nul" input_player3_b_btn = "nul" input_player3_b_axis = "nul" input_player3_y = "nul" input_player3_y_btn = "nul" input_player3_y_axis = "nul" input_player3_select = "nul" input_player3_select_btn = "nul" input_player3_select_axis = "nul" input_player3_start = "nul" input_player3_start_btn = "nul" input_player3_start_axis = "nul" input_player3_up = "nul" input_player3_up_btn = "nul" input_player3_up_axis = "nul" input_player3_down = "nul" input_player3_down_btn = "nul" input_player3_down_axis = "nul" input_player3_left = "nul" input_player3_left_btn = "nul" input_player3_left_axis = "nul" input_player3_right = "nul" input_player3_right_btn = "nul" input_player3_right_axis = "nul" input_player3_a = "nul" input_player3_a_btn = "nul" input_player3_a_axis = "nul" input_player3_x = "nul" input_player3_x_btn = "nul" input_player3_x_axis = "nul" input_player3_l = "nul" input_player3_l_btn = "nul" input_player3_l_axis = "nul" input_player3_r = "nul" input_player3_r_btn = "nul" input_player3_r_axis = "nul" input_player3_l2 = "nul" input_player3_l2_btn = "nul" input_player3_l2_axis = "nul" input_player3_r2 = "nul" input_player3_r2_btn = "nul" input_player3_r2_axis = "nul" input_player3_l3 = "nul" input_player3_l3_btn = "nul" input_player3_l3_axis = "nul" input_player3_r3 = "nul" input_player3_r3_btn = "nul" input_player3_r3_axis = "nul" input_player3_l_x_plus = "nul" input_player3_l_x_plus_btn = "nul" input_player3_l_x_plus_axis = "nul" input_player3_l_x_minus = "nul" input_player3_l_x_minus_btn = "nul" input_player3_l_x_minus_axis = "nul" input_player3_l_y_plus = "nul" input_player3_l_y_plus_btn = "nul" input_player3_l_y_plus_axis = "nul" input_player3_l_y_minus = "nul" input_player3_l_y_minus_btn = "nul" input_player3_l_y_minus_axis = "nul" input_player3_r_x_plus = "nul" input_player3_r_x_plus_btn = "nul" input_player3_r_x_plus_axis = "nul" input_player3_r_x_minus = "nul" input_player3_r_x_minus_btn = "nul" input_player3_r_x_minus_axis = "nul" input_player3_r_y_plus = "nul" input_player3_r_y_plus_btn = "nul" input_player3_r_y_plus_axis = "nul" input_player3_r_y_minus = "nul" input_player3_r_y_minus_btn = "nul" input_player3_r_y_minus_axis = "nul" input_player3_turbo = "nul" input_player3_turbo_btn = "nul" input_player3_turbo_axis = "nul" input_player4_b = "nul" input_player4_b_btn = "nul" input_player4_b_axis = "nul" input_player4_y = "nul" input_player4_y_btn = "nul" input_player4_y_axis = "nul" input_player4_select = "nul" input_player4_select_btn = "nul" input_player4_select_axis = "nul" input_player4_start = "nul" input_player4_start_btn = "nul" input_player4_start_axis = "nul" input_player4_up = "nul" input_player4_up_btn = "nul" input_player4_up_axis = "nul" input_player4_down = "nul" input_player4_down_btn = "nul" input_player4_down_axis = "nul" input_player4_left = "nul" input_player4_left_btn = "nul" input_player4_left_axis = "nul" input_player4_right = "nul" input_player4_right_btn = "nul" input_player4_right_axis = "nul" input_player4_a = "nul" input_player4_a_btn = "nul" input_player4_a_axis = "nul" input_player4_x = "nul" input_player4_x_btn = "nul" input_player4_x_axis = "nul" input_player4_l = "nul" input_player4_l_btn = "nul" input_player4_l_axis = "nul" input_player4_r = "nul" input_player4_r_btn = "nul" input_player4_r_axis = "nul" input_player4_l2 = "nul" input_player4_l2_btn = "nul" input_player4_l2_axis = "nul" input_player4_r2 = "nul" input_player4_r2_btn = "nul" input_player4_r2_axis = "nul" input_player4_l3 = "nul" input_player4_l3_btn = "nul" input_player4_l3_axis = "nul" input_player4_r3 = "nul" input_player4_r3_btn = "nul" input_player4_r3_axis = "nul" input_player4_l_x_plus = "nul" input_player4_l_x_plus_btn = "nul" input_player4_l_x_plus_axis = "nul" input_player4_l_x_minus = "nul" input_player4_l_x_minus_btn = "nul" input_player4_l_x_minus_axis = "nul" input_player4_l_y_plus = "nul" input_player4_l_y_plus_btn = "nul" input_player4_l_y_plus_axis = "nul" input_player4_l_y_minus = "nul" input_player4_l_y_minus_btn = "nul" input_player4_l_y_minus_axis = "nul" input_player4_r_x_plus = "nul" input_player4_r_x_plus_btn = "nul" input_player4_r_x_plus_axis = "nul" input_player4_r_x_minus = "nul" input_player4_r_x_minus_btn = "nul" input_player4_r_x_minus_axis = "nul" input_player4_r_y_plus = "nul" input_player4_r_y_plus_btn = "nul" input_player4_r_y_plus_axis = "nul" input_player4_r_y_minus = "nul" input_player4_r_y_minus_btn = "nul" input_player4_r_y_minus_axis = "nul" input_player4_turbo = "nul" input_player4_turbo_btn = "nul" input_player4_turbo_axis = "nul" input_player5_b = "nul" input_player5_b_btn = "nul" input_player5_b_axis = "nul" input_player5_y = "nul" input_player5_y_btn = "nul" input_player5_y_axis = "nul" input_player5_select = "nul" input_player5_select_btn = "nul" input_player5_select_axis = "nul" input_player5_start = "nul" input_player5_start_btn = "nul" input_player5_start_axis = "nul" input_player5_up = "nul" input_player5_up_btn = "nul" input_player5_up_axis = "nul" input_player5_down = "nul" input_player5_down_btn = "nul" input_player5_down_axis = "nul" input_player5_left = "nul" input_player5_left_btn = "nul" input_player5_left_axis = "nul" input_player5_right = "nul" input_player5_right_btn = "nul" input_player5_right_axis = "nul" input_player5_a = "nul" input_player5_a_btn = "nul" input_player5_a_axis = "nul" input_player5_x = "nul" input_player5_x_btn = "nul" input_player5_x_axis = "nul" input_player5_l = "nul" input_player5_l_btn = "nul" input_player5_l_axis = "nul" input_player5_r = "nul" input_player5_r_btn = "nul" input_player5_r_axis = "nul" input_player5_l2 = "nul" input_player5_l2_btn = "nul" input_player5_l2_axis = "nul" input_player5_r2 = "nul" input_player5_r2_btn = "nul" input_player5_r2_axis = "nul" input_player5_l3 = "nul" input_player5_l3_btn = "nul" input_player5_l3_axis = "nul" input_player5_r3 = "nul" input_player5_r3_btn = "nul" input_player5_r3_axis = "nul" input_player5_l_x_plus = "nul" input_player5_l_x_plus_btn = "nul" input_player5_l_x_plus_axis = "nul" input_player5_l_x_minus = "nul" input_player5_l_x_minus_btn = "nul" input_player5_l_x_minus_axis = "nul" input_player5_l_y_plus = "nul" input_player5_l_y_plus_btn = "nul" input_player5_l_y_plus_axis = "nul" input_player5_l_y_minus = "nul" input_player5_l_y_minus_btn = "nul" input_player5_l_y_minus_axis = "nul" input_player5_r_x_plus = "nul" input_player5_r_x_plus_btn = "nul" input_player5_r_x_plus_axis = "nul" input_player5_r_x_minus = "nul" input_player5_r_x_minus_btn = "nul" input_player5_r_x_minus_axis = "nul" input_player5_r_y_plus = "nul" input_player5_r_y_plus_btn = "nul" input_player5_r_y_plus_axis = "nul" input_player5_r_y_minus = "nul" input_player5_r_y_minus_btn = "nul" input_player5_r_y_minus_axis = "nul" input_player5_turbo = "nul" input_player5_turbo_btn = "nul" input_player5_turbo_axis = "nul" input_player6_b = "nul" input_player6_b_btn = "nul" input_player6_b_axis = "nul" input_player6_y = "nul" input_player6_y_btn = "nul" input_player6_y_axis = "nul" input_player6_select = "nul" input_player6_select_btn = "nul" input_player6_select_axis = "nul" input_player6_start = "nul" input_player6_start_btn = "nul" input_player6_start_axis = "nul" input_player6_up = "nul" input_player6_up_btn = "nul" input_player6_up_axis = "nul" input_player6_down = "nul" input_player6_down_btn = "nul" input_player6_down_axis = "nul" input_player6_left = "nul" input_player6_left_btn = "nul" input_player6_left_axis = "nul" input_player6_right = "nul" input_player6_right_btn = "nul" input_player6_right_axis = "nul" input_player6_a = "nul" input_player6_a_btn = "nul" input_player6_a_axis = "nul" input_player6_x = "nul" input_player6_x_btn = "nul" input_player6_x_axis = "nul" input_player6_l = "nul" input_player6_l_btn = "nul" input_player6_l_axis = "nul" input_player6_r = "nul" input_player6_r_btn = "nul" input_player6_r_axis = "nul" input_player6_l2 = "nul" input_player6_l2_btn = "nul" input_player6_l2_axis = "nul" input_player6_r2 = "nul" input_player6_r2_btn = "nul" input_player6_r2_axis = "nul" input_player6_l3 = "nul" input_player6_l3_btn = "nul" input_player6_l3_axis = "nul" input_player6_r3 = "nul" input_player6_r3_btn = "nul" input_player6_r3_axis = "nul" input_player6_l_x_plus = "nul" input_player6_l_x_plus_btn = "nul" input_player6_l_x_plus_axis = "nul" input_player6_l_x_minus = "nul" input_player6_l_x_minus_btn = "nul" input_player6_l_x_minus_axis = "nul" input_player6_l_y_plus = "nul" input_player6_l_y_plus_btn = "nul" input_player6_l_y_plus_axis = "nul" input_player6_l_y_minus = "nul" input_player6_l_y_minus_btn = "nul" input_player6_l_y_minus_axis = "nul" input_player6_r_x_plus = "nul" input_player6_r_x_plus_btn = "nul" input_player6_r_x_plus_axis = "nul" input_player6_r_x_minus = "nul" input_player6_r_x_minus_btn = "nul" input_player6_r_x_minus_axis = "nul" input_player6_r_y_plus = "nul" input_player6_r_y_plus_btn = "nul" input_player6_r_y_plus_axis = "nul" input_player6_r_y_minus = "nul" input_player6_r_y_minus_btn = "nul" input_player6_r_y_minus_axis = "nul" input_player6_turbo = "nul" input_player6_turbo_btn = "nul" input_player6_turbo_axis = "nul" input_player7_b = "nul" input_player7_b_btn = "nul" input_player7_b_axis = "nul" input_player7_y = "nul" input_player7_y_btn = "nul" input_player7_y_axis = "nul" input_player7_select = "nul" input_player7_select_btn = "nul" input_player7_select_axis = "nul" input_player7_start = "nul" input_player7_start_btn = "nul" input_player7_start_axis = "nul" input_player7_up = "nul" input_player7_up_btn = "nul" input_player7_up_axis = "nul" input_player7_down = "nul" input_player7_down_btn = "nul" input_player7_down_axis = "nul" input_player7_left = "nul" input_player7_left_btn = "nul" input_player7_left_axis = "nul" input_player7_right = "nul" input_player7_right_btn = "nul" input_player7_right_axis = "nul" input_player7_a = "nul" input_player7_a_btn = "nul" input_player7_a_axis = "nul" input_player7_x = "nul" input_player7_x_btn = "nul" input_player7_x_axis = "nul" input_player7_l = "nul" input_player7_l_btn = "nul" input_player7_l_axis = "nul" input_player7_r = "nul" input_player7_r_btn = "nul" input_player7_r_axis = "nul" input_player7_l2 = "nul" input_player7_l2_btn = "nul" input_player7_l2_axis = "nul" input_player7_r2 = "nul" input_player7_r2_btn = "nul" input_player7_r2_axis = "nul" input_player7_l3 = "nul" input_player7_l3_btn = "nul" input_player7_l3_axis = "nul" input_player7_r3 = "nul" input_player7_r3_btn = "nul" input_player7_r3_axis = "nul" input_player7_l_x_plus = "nul" input_player7_l_x_plus_btn = "nul" input_player7_l_x_plus_axis = "nul" input_player7_l_x_minus = "nul" input_player7_l_x_minus_btn = "nul" input_player7_l_x_minus_axis = "nul" input_player7_l_y_plus = "nul" input_player7_l_y_plus_btn = "nul" input_player7_l_y_plus_axis = "nul" input_player7_l_y_minus = "nul" input_player7_l_y_minus_btn = "nul" input_player7_l_y_minus_axis = "nul" input_player7_r_x_plus = "nul" input_player7_r_x_plus_btn = "nul" input_player7_r_x_plus_axis = "nul" input_player7_r_x_minus = "nul" input_player7_r_x_minus_btn = "nul" input_player7_r_x_minus_axis = "nul" input_player7_r_y_plus = "nul" input_player7_r_y_plus_btn = "nul" input_player7_r_y_plus_axis = "nul" input_player7_r_y_minus = "nul" input_player7_r_y_minus_btn = "nul" input_player7_r_y_minus_axis = "nul" input_player7_turbo = "nul" input_player7_turbo_btn = "nul" input_player7_turbo_axis = "nul" input_player8_b = "nul" input_player8_b_btn = "nul" input_player8_b_axis = "nul" input_player8_y = "nul" input_player8_y_btn = "nul" input_player8_y_axis = "nul" input_player8_select = "nul" input_player8_select_btn = "nul" input_player8_select_axis = "nul" input_player8_start = "nul" input_player8_start_btn = "nul" input_player8_start_axis = "nul" input_player8_up = "nul" input_player8_up_btn = "nul" input_player8_up_axis = "nul" input_player8_down = "nul" input_player8_down_btn = "nul" input_player8_down_axis = "nul" input_player8_left = "nul" input_player8_left_btn = "nul" input_player8_left_axis = "nul" input_player8_right = "nul" input_player8_right_btn = "nul" input_player8_right_axis = "nul" input_player8_a = "nul" input_player8_a_btn = "nul" input_player8_a_axis = "nul" input_player8_x = "nul" input_player8_x_btn = "nul" input_player8_x_axis = "nul" input_player8_l = "nul" input_player8_l_btn = "nul" input_player8_l_axis = "nul" input_player8_r = "nul" input_player8_r_btn = "nul" input_player8_r_axis = "nul" input_player8_l2 = "nul" input_player8_l2_btn = "nul" input_player8_l2_axis = "nul" input_player8_r2 = "nul" input_player8_r2_btn = "nul" input_player8_r2_axis = "nul" input_player8_l3 = "nul" input_player8_l3_btn = "nul" input_player8_l3_axis = "nul" input_player8_r3 = "nul" input_player8_r3_btn = "nul" input_player8_r3_axis = "nul" input_player8_l_x_plus = "nul" input_player8_l_x_plus_btn = "nul" input_player8_l_x_plus_axis = "nul" input_player8_l_x_minus = "nul" input_player8_l_x_minus_btn = "nul" input_player8_l_x_minus_axis = "nul" input_player8_l_y_plus = "nul" input_player8_l_y_plus_btn = "nul" input_player8_l_y_plus_axis = "nul" input_player8_l_y_minus = "nul" input_player8_l_y_minus_btn = "nul" input_player8_l_y_minus_axis = "nul" input_player8_r_x_plus = "nul" input_player8_r_x_plus_btn = "nul" input_player8_r_x_plus_axis = "nul" input_player8_r_x_minus = "nul" input_player8_r_x_minus_btn = "nul" input_player8_r_x_minus_axis = "nul" input_player8_r_y_plus = "nul" input_player8_r_y_plus_btn = "nul" input_player8_r_y_plus_axis = "nul" input_player8_r_y_minus = "nul" input_player8_r_y_minus_btn = "nul" input_player8_r_y_minus_axis = "nul" input_player8_turbo = "nul" input_player8_turbo_btn = "nul" input_player8_turbo_axis = "nul" input_player9_b = "nul" input_player9_b_btn = "nul" input_player9_b_axis = "nul" input_player9_y = "nul" input_player9_y_btn = "nul" input_player9_y_axis = "nul" input_player9_select = "nul" input_player9_select_btn = "nul" input_player9_select_axis = "nul" input_player9_start = "nul" input_player9_start_btn = "nul" input_player9_start_axis = "nul" input_player9_up = "nul" input_player9_up_btn = "nul" input_player9_up_axis = "nul" input_player9_down = "nul" input_player9_down_btn = "nul" input_player9_down_axis = "nul" input_player9_left = "nul" input_player9_left_btn = "nul" input_player9_left_axis = "nul" input_player9_right = "nul" input_player9_right_btn = "nul" input_player9_right_axis = "nul" input_player9_a = "nul" input_player9_a_btn = "nul" input_player9_a_axis = "nul" input_player9_x = "nul" input_player9_x_btn = "nul" input_player9_x_axis = "nul" input_player9_l = "nul" input_player9_l_btn = "nul" input_player9_l_axis = "nul" input_player9_r = "nul" input_player9_r_btn = "nul" input_player9_r_axis = "nul" input_player9_l2 = "nul" input_player9_l2_btn = "nul" input_player9_l2_axis = "nul" input_player9_r2 = "nul" input_player9_r2_btn = "nul" input_player9_r2_axis = "nul" input_player9_l3 = "nul" input_player9_l3_btn = "nul" input_player9_l3_axis = "nul" input_player9_r3 = "nul" input_player9_r3_btn = "nul" input_player9_r3_axis = "nul" input_player9_l_x_plus = "nul" input_player9_l_x_plus_btn = "nul" input_player9_l_x_plus_axis = "nul" input_player9_l_x_minus = "nul" input_player9_l_x_minus_btn = "nul" input_player9_l_x_minus_axis = "nul" input_player9_l_y_plus = "nul" input_player9_l_y_plus_btn = "nul" input_player9_l_y_plus_axis = "nul" input_player9_l_y_minus = "nul" input_player9_l_y_minus_btn = "nul" input_player9_l_y_minus_axis = "nul" input_player9_r_x_plus = "nul" input_player9_r_x_plus_btn = "nul" input_player9_r_x_plus_axis = "nul" input_player9_r_x_minus = "nul" input_player9_r_x_minus_btn = "nul" input_player9_r_x_minus_axis = "nul" input_player9_r_y_plus = "nul" input_player9_r_y_plus_btn = "nul" input_player9_r_y_plus_axis = "nul" input_player9_r_y_minus = "nul" input_player9_r_y_minus_btn = "nul" input_player9_r_y_minus_axis = "nul" input_player9_turbo = "nul" input_player9_turbo_btn = "nul" input_player9_turbo_axis = "nul" input_player10_b = "nul" input_player10_b_btn = "nul" input_player10_b_axis = "nul" input_player10_y = "nul" input_player10_y_btn = "nul" input_player10_y_axis = "nul" input_player10_select = "nul" input_player10_select_btn = "nul" input_player10_select_axis = "nul" input_player10_start = "nul" input_player10_start_btn = "nul" input_player10_start_axis = "nul" input_player10_up = "nul" input_player10_up_btn = "nul" input_player10_up_axis = "nul" input_player10_down = "nul" input_player10_down_btn = "nul" input_player10_down_axis = "nul" input_player10_left = "nul" input_player10_left_btn = "nul" input_player10_left_axis = "nul" input_player10_right = "nul" input_player10_right_btn = "nul" input_player10_right_axis = "nul" input_player10_a = "nul" input_player10_a_btn = "nul" input_player10_a_axis = "nul" input_player10_x = "nul" input_player10_x_btn = "nul" input_player10_x_axis = "nul" input_player10_l = "nul" input_player10_l_btn = "nul" input_player10_l_axis = "nul" input_player10_r = "nul" input_player10_r_btn = "nul" input_player10_r_axis = "nul" input_player10_l2 = "nul" input_player10_l2_btn = "nul" input_player10_l2_axis = "nul" input_player10_r2 = "nul" input_player10_r2_btn = "nul" input_player10_r2_axis = "nul" input_player10_l3 = "nul" input_player10_l3_btn = "nul" input_player10_l3_axis = "nul" input_player10_r3 = "nul" input_player10_r3_btn = "nul" input_player10_r3_axis = "nul" input_player10_l_x_plus = "nul" input_player10_l_x_plus_btn = "nul" input_player10_l_x_plus_axis = "nul" input_player10_l_x_minus = "nul" input_player10_l_x_minus_btn = "nul" input_player10_l_x_minus_axis = "nul" input_player10_l_y_plus = "nul" input_player10_l_y_plus_btn = "nul" input_player10_l_y_plus_axis = "nul" input_player10_l_y_minus = "nul" input_player10_l_y_minus_btn = "nul" input_player10_l_y_minus_axis = "nul" input_player10_r_x_plus = "nul" input_player10_r_x_plus_btn = "nul" input_player10_r_x_plus_axis = "nul" input_player10_r_x_minus = "nul" input_player10_r_x_minus_btn = "nul" input_player10_r_x_minus_axis = "nul" input_player10_r_y_plus = "nul" input_player10_r_y_plus_btn = "nul" input_player10_r_y_plus_axis = "nul" input_player10_r_y_minus = "nul" input_player10_r_y_minus_btn = "nul" input_player10_r_y_minus_axis = "nul" input_player10_turbo = "nul" input_player10_turbo_btn = "nul" input_player10_turbo_axis = "nul" input_player11_b = "nul" input_player11_b_btn = "nul" input_player11_b_axis = "nul" input_player11_y = "nul" input_player11_y_btn = "nul" input_player11_y_axis = "nul" input_player11_select = "nul" input_player11_select_btn = "nul" input_player11_select_axis = "nul" input_player11_start = "nul" input_player11_start_btn = "nul" input_player11_start_axis = "nul" input_player11_up = "nul" input_player11_up_btn = "nul" input_player11_up_axis = "nul" input_player11_down = "nul" input_player11_down_btn = "nul" input_player11_down_axis = "nul" input_player11_left = "nul" input_player11_left_btn = "nul" input_player11_left_axis = "nul" input_player11_right = "nul" input_player11_right_btn = "nul" input_player11_right_axis = "nul" input_player11_a = "nul" input_player11_a_btn = "nul" input_player11_a_axis = "nul" input_player11_x = "nul" input_player11_x_btn = "nul" input_player11_x_axis = "nul" input_player11_l = "nul" input_player11_l_btn = "nul" input_player11_l_axis = "nul" input_player11_r = "nul" input_player11_r_btn = "nul" input_player11_r_axis = "nul" input_player11_l2 = "nul" input_player11_l2_btn = "nul" input_player11_l2_axis = "nul" input_player11_r2 = "nul" input_player11_r2_btn = "nul" input_player11_r2_axis = "nul" input_player11_l3 = "nul" input_player11_l3_btn = "nul" input_player11_l3_axis = "nul" input_player11_r3 = "nul" input_player11_r3_btn = "nul" input_player11_r3_axis = "nul" input_player11_l_x_plus = "nul" input_player11_l_x_plus_btn = "nul" input_player11_l_x_plus_axis = "nul" input_player11_l_x_minus = "nul" input_player11_l_x_minus_btn = "nul" input_player11_l_x_minus_axis = "nul" input_player11_l_y_plus = "nul" input_player11_l_y_plus_btn = "nul" input_player11_l_y_plus_axis = "nul" input_player11_l_y_minus = "nul" input_player11_l_y_minus_btn = "nul" input_player11_l_y_minus_axis = "nul" input_player11_r_x_plus = "nul" input_player11_r_x_plus_btn = "nul" input_player11_r_x_plus_axis = "nul" input_player11_r_x_minus = "nul" input_player11_r_x_minus_btn = "nul" input_player11_r_x_minus_axis = "nul" input_player11_r_y_plus = "nul" input_player11_r_y_plus_btn = "nul" input_player11_r_y_plus_axis = "nul" input_player11_r_y_minus = "nul" input_player11_r_y_minus_btn = "nul" input_player11_r_y_minus_axis = "nul" input_player11_turbo = "nul" input_player11_turbo_btn = "nul" input_player11_turbo_axis = "nul" input_player12_b = "nul" input_player12_b_btn = "nul" input_player12_b_axis = "nul" input_player12_y = "nul" input_player12_y_btn = "nul" input_player12_y_axis = "nul" input_player12_select = "nul" input_player12_select_btn = "nul" input_player12_select_axis = "nul" input_player12_start = "nul" input_player12_start_btn = "nul" input_player12_start_axis = "nul" input_player12_up = "nul" input_player12_up_btn = "nul" input_player12_up_axis = "nul" input_player12_down = "nul" input_player12_down_btn = "nul" input_player12_down_axis = "nul" input_player12_left = "nul" input_player12_left_btn = "nul" input_player12_left_axis = "nul" input_player12_right = "nul" input_player12_right_btn = "nul" input_player12_right_axis = "nul" input_player12_a = "nul" input_player12_a_btn = "nul" input_player12_a_axis = "nul" input_player12_x = "nul" input_player12_x_btn = "nul" input_player12_x_axis = "nul" input_player12_l = "nul" input_player12_l_btn = "nul" input_player12_l_axis = "nul" input_player12_r = "nul" input_player12_r_btn = "nul" input_player12_r_axis = "nul" input_player12_l2 = "nul" input_player12_l2_btn = "nul" input_player12_l2_axis = "nul" input_player12_r2 = "nul" input_player12_r2_btn = "nul" input_player12_r2_axis = "nul" input_player12_l3 = "nul" input_player12_l3_btn = "nul" input_player12_l3_axis = "nul" input_player12_r3 = "nul" input_player12_r3_btn = "nul" input_player12_r3_axis = "nul" input_player12_l_x_plus = "nul" input_player12_l_x_plus_btn = "nul" input_player12_l_x_plus_axis = "nul" input_player12_l_x_minus = "nul" input_player12_l_x_minus_btn = "nul" input_player12_l_x_minus_axis = "nul" input_player12_l_y_plus = "nul" input_player12_l_y_plus_btn = "nul" input_player12_l_y_plus_axis = "nul" input_player12_l_y_minus = "nul" input_player12_l_y_minus_btn = "nul" input_player12_l_y_minus_axis = "nul" input_player12_r_x_plus = "nul" input_player12_r_x_plus_btn = "nul" input_player12_r_x_plus_axis = "nul" input_player12_r_x_minus = "nul" input_player12_r_x_minus_btn = "nul" input_player12_r_x_minus_axis = "nul" input_player12_r_y_plus = "nul" input_player12_r_y_plus_btn = "nul" input_player12_r_y_plus_axis = "nul" input_player12_r_y_minus = "nul" input_player12_r_y_minus_btn = "nul" input_player12_r_y_minus_axis = "nul" input_player12_turbo = "nul" input_player12_turbo_btn = "nul" input_player12_turbo_axis = "nul" input_player13_b = "nul" input_player13_b_btn = "nul" input_player13_b_axis = "nul" input_player13_y = "nul" input_player13_y_btn = "nul" input_player13_y_axis = "nul" input_player13_select = "nul" input_player13_select_btn = "nul" input_player13_select_axis = "nul" input_player13_start = "nul" input_player13_start_btn = "nul" input_player13_start_axis = "nul" input_player13_up = "nul" input_player13_up_btn = "nul" input_player13_up_axis = "nul" input_player13_down = "nul" input_player13_down_btn = "nul" input_player13_down_axis = "nul" input_player13_left = "nul" input_player13_left_btn = "nul" input_player13_left_axis = "nul" input_player13_right = "nul" input_player13_right_btn = "nul" input_player13_right_axis = "nul" input_player13_a = "nul" input_player13_a_btn = "nul" input_player13_a_axis = "nul" input_player13_x = "nul" input_player13_x_btn = "nul" input_player13_x_axis = "nul" input_player13_l = "nul" input_player13_l_btn = "nul" input_player13_l_axis = "nul" input_player13_r = "nul" input_player13_r_btn = "nul" input_player13_r_axis = "nul" input_player13_l2 = "nul" input_player13_l2_btn = "nul" input_player13_l2_axis = "nul" input_player13_r2 = "nul" input_player13_r2_btn = "nul" input_player13_r2_axis = "nul" input_player13_l3 = "nul" input_player13_l3_btn = "nul" input_player13_l3_axis = "nul" input_player13_r3 = "nul" input_player13_r3_btn = "nul" input_player13_r3_axis = "nul" input_player13_l_x_plus = "nul" input_player13_l_x_plus_btn = "nul" input_player13_l_x_plus_axis = "nul" input_player13_l_x_minus = "nul" input_player13_l_x_minus_btn = "nul" input_player13_l_x_minus_axis = "nul" input_player13_l_y_plus = "nul" input_player13_l_y_plus_btn = "nul" input_player13_l_y_plus_axis = "nul" input_player13_l_y_minus = "nul" input_player13_l_y_minus_btn = "nul" input_player13_l_y_minus_axis = "nul" input_player13_r_x_plus = "nul" input_player13_r_x_plus_btn = "nul" input_player13_r_x_plus_axis = "nul" input_player13_r_x_minus = "nul" input_player13_r_x_minus_btn = "nul" input_player13_r_x_minus_axis = "nul" input_player13_r_y_plus = "nul" input_player13_r_y_plus_btn = "nul" input_player13_r_y_plus_axis = "nul" input_player13_r_y_minus = "nul" input_player13_r_y_minus_btn = "nul" input_player13_r_y_minus_axis = "nul" input_player13_turbo = "nul" input_player13_turbo_btn = "nul" input_player13_turbo_axis = "nul" input_player14_b = "nul" input_player14_b_btn = "nul" input_player14_b_axis = "nul" input_player14_y = "nul" input_player14_y_btn = "nul" input_player14_y_axis = "nul" input_player14_select = "nul" input_player14_select_btn = "nul" input_player14_select_axis = "nul" input_player14_start = "nul" input_player14_start_btn = "nul" input_player14_start_axis = "nul" input_player14_up = "nul" input_player14_up_btn = "nul" input_player14_up_axis = "nul" input_player14_down = "nul" input_player14_down_btn = "nul" input_player14_down_axis = "nul" input_player14_left = "nul" input_player14_left_btn = "nul" input_player14_left_axis = "nul" input_player14_right = "nul" input_player14_right_btn = "nul" input_player14_right_axis = "nul" input_player14_a = "nul" input_player14_a_btn = "nul" input_player14_a_axis = "nul" input_player14_x = "nul" input_player14_x_btn = "nul" input_player14_x_axis = "nul" input_player14_l = "nul" input_player14_l_btn = "nul" input_player14_l_axis = "nul" input_player14_r = "nul" input_player14_r_btn = "nul" input_player14_r_axis = "nul" input_player14_l2 = "nul" input_player14_l2_btn = "nul" input_player14_l2_axis = "nul" input_player14_r2 = "nul" input_player14_r2_btn = "nul" input_player14_r2_axis = "nul" input_player14_l3 = "nul" input_player14_l3_btn = "nul" input_player14_l3_axis = "nul" input_player14_r3 = "nul" input_player14_r3_btn = "nul" input_player14_r3_axis = "nul" input_player14_l_x_plus = "nul" input_player14_l_x_plus_btn = "nul" input_player14_l_x_plus_axis = "nul" input_player14_l_x_minus = "nul" input_player14_l_x_minus_btn = "nul" input_player14_l_x_minus_axis = "nul" input_player14_l_y_plus = "nul" input_player14_l_y_plus_btn = "nul" input_player14_l_y_plus_axis = "nul" input_player14_l_y_minus = "nul" input_player14_l_y_minus_btn = "nul" input_player14_l_y_minus_axis = "nul" input_player14_r_x_plus = "nul" input_player14_r_x_plus_btn = "nul" input_player14_r_x_plus_axis = "nul" input_player14_r_x_minus = "nul" input_player14_r_x_minus_btn = "nul" input_player14_r_x_minus_axis = "nul" input_player14_r_y_plus = "nul" input_player14_r_y_plus_btn = "nul" input_player14_r_y_plus_axis = "nul" input_player14_r_y_minus = "nul" input_player14_r_y_minus_btn = "nul" input_player14_r_y_minus_axis = "nul" input_player14_turbo = "nul" input_player14_turbo_btn = "nul" input_player14_turbo_axis = "nul" input_player15_b = "nul" input_player15_b_btn = "nul" input_player15_b_axis = "nul" input_player15_y = "nul" input_player15_y_btn = "nul" input_player15_y_axis = "nul" input_player15_select = "nul" input_player15_select_btn = "nul" input_player15_select_axis = "nul" input_player15_start = "nul" input_player15_start_btn = "nul" input_player15_start_axis = "nul" input_player15_up = "nul" input_player15_up_btn = "nul" input_player15_up_axis = "nul" input_player15_down = "nul" input_player15_down_btn = "nul" input_player15_down_axis = "nul" input_player15_left = "nul" input_player15_left_btn = "nul" input_player15_left_axis = "nul" input_player15_right = "nul" input_player15_right_btn = "nul" input_player15_right_axis = "nul" input_player15_a = "nul" input_player15_a_btn = "nul" input_player15_a_axis = "nul" input_player15_x = "nul" input_player15_x_btn = "nul" input_player15_x_axis = "nul" input_player15_l = "nul" input_player15_l_btn = "nul" input_player15_l_axis = "nul" input_player15_r = "nul" input_player15_r_btn = "nul" input_player15_r_axis = "nul" input_player15_l2 = "nul" input_player15_l2_btn = "nul" input_player15_l2_axis = "nul" input_player15_r2 = "nul" input_player15_r2_btn = "nul" input_player15_r2_axis = "nul" input_player15_l3 = "nul" input_player15_l3_btn = "nul" input_player15_l3_axis = "nul" input_player15_r3 = "nul" input_player15_r3_btn = "nul" input_player15_r3_axis = "nul" input_player15_l_x_plus = "nul" input_player15_l_x_plus_btn = "nul" input_player15_l_x_plus_axis = "nul" input_player15_l_x_minus = "nul" input_player15_l_x_minus_btn = "nul" input_player15_l_x_minus_axis = "nul" input_player15_l_y_plus = "nul" input_player15_l_y_plus_btn = "nul" input_player15_l_y_plus_axis = "nul" input_player15_l_y_minus = "nul" input_player15_l_y_minus_btn = "nul" input_player15_l_y_minus_axis = "nul" input_player15_r_x_plus = "nul" input_player15_r_x_plus_btn = "nul" input_player15_r_x_plus_axis = "nul" input_player15_r_x_minus = "nul" input_player15_r_x_minus_btn = "nul" input_player15_r_x_minus_axis = "nul" input_player15_r_y_plus = "nul" input_player15_r_y_plus_btn = "nul" input_player15_r_y_plus_axis = "nul" input_player15_r_y_minus = "nul" input_player15_r_y_minus_btn = "nul" input_player15_r_y_minus_axis = "nul" input_player15_turbo = "nul" input_player15_turbo_btn = "nul" input_player15_turbo_axis = "nul" input_player16_b = "nul" input_player16_b_btn = "nul" input_player16_b_axis = "nul" input_player16_y = "nul" input_player16_y_btn = "nul" input_player16_y_axis = "nul" input_player16_select = "nul" input_player16_select_btn = "nul" input_player16_select_axis = "nul" input_player16_start = "nul" input_player16_start_btn = "nul" input_player16_start_axis = "nul" input_player16_up = "nul" input_player16_up_btn = "nul" input_player16_up_axis = "nul" input_player16_down = "nul" input_player16_down_btn = "nul" input_player16_down_axis = "nul" input_player16_left = "nul" input_player16_left_btn = "nul" input_player16_left_axis = "nul" input_player16_right = "nul" input_player16_right_btn = "nul" input_player16_right_axis = "nul" input_player16_a = "nul" input_player16_a_btn = "nul" input_player16_a_axis = "nul" input_player16_x = "nul" input_player16_x_btn = "nul" input_player16_x_axis = "nul" input_player16_l = "nul" input_player16_l_btn = "nul" input_player16_l_axis = "nul" input_player16_r = "nul" input_player16_r_btn = "nul" input_player16_r_axis = "nul" input_player16_l2 = "nul" input_player16_l2_btn = "nul" input_player16_l2_axis = "nul" input_player16_r2 = "nul" input_player16_r2_btn = "nul" input_player16_r2_axis = "nul" input_player16_l3 = "nul" input_player16_l3_btn = "nul" input_player16_l3_axis = "nul" input_player16_r3 = "nul" input_player16_r3_btn = "nul" input_player16_r3_axis = "nul" input_player16_l_x_plus = "nul" input_player16_l_x_plus_btn = "nul" input_player16_l_x_plus_axis = "nul" input_player16_l_x_minus = "nul" input_player16_l_x_minus_btn = "nul" input_player16_l_x_minus_axis = "nul" input_player16_l_y_plus = "nul" input_player16_l_y_plus_btn = "nul" input_player16_l_y_plus_axis = "nul" input_player16_l_y_minus = "nul" input_player16_l_y_minus_btn = "nul" input_player16_l_y_minus_axis = "nul" input_player16_r_x_plus = "nul" input_player16_r_x_plus_btn = "nul" input_player16_r_x_plus_axis = "nul" input_player16_r_x_minus = "nul" input_player16_r_x_minus_btn = "nul" input_player16_r_x_minus_axis = "nul" input_player16_r_y_plus = "nul" input_player16_r_y_plus_btn = "nul" input_player16_r_y_plus_axis = "nul" input_player16_r_y_minus = "nul" input_player16_r_y_minus_btn = "nul" input_player16_r_y_minus_axis = "nul" input_player16_turbo = "nul" input_player16_turbo_btn = "nul" input_player16_turbo_axis = "nul" core_specific_config = "true" libretro_log_level = "0" log_verbosity = "false" perfcnt_enable = "false" archive_mode = "0" input_dsp_config = "nul" input_dsp_config_btn = "nul" input_dsp_config_axis = "nul" NEC PC Engine CD: Quote input_max_users = "4" input_axis_threshold = "0.500000" video_gpu_record = "false" input_remap_binds_enable = "true" netplay_client_swap_input = "true" input_descriptor_label_show = "true" autoconfig_descriptor_label_show = "true" input_descriptor_hide_unbound = "false" load_dummy_on_core_shutdown = "false" fps_show = "false" ui_menubar_enable = "true" suspend_screensaver_enable = "true" libretro_path = ":\cores\mednafen_pce_fast_libretro.dll" libretro_directory = ":\cores" cheat_database_path = ":\cheats" cursor_directory = ":\database\cursors" rewind_enable = "false" audio_latency = "64" audio_sync = "true" audio_block_frames = "0" rewind_granularity = "1" video_shader = ":\shaders\crt\crt-royale\crt-royale.cgp" video_shader_enable = "true" video_aspect_ratio = "-1.000000" video_aspect_ratio_auto = "false" video_windowed_fullscreen = "true" video_scale = "3.000000" autosave_interval = "0" video_crop_overscan = "true" video_scale_integer = "false" video_smooth = "true" video_threaded = "false" video_shared_context = "false" video_force_srgb_disable = "false" video_fullscreen = "false" video_refresh_rate = "59.950001" video_monitor_index = "0" video_fullscreen_x = "0" video_fullscreen_y = "0" video_driver = "gl" threaded_data_runloop_enable = "true" menu_driver = "rgui" menu_pause_libretro = "true" menu_mouse_enable = "false" menu_timedate_enable = "true" menu_core_enable = "true" video_vsync = "true" video_hard_sync = "false" video_hard_sync_frames = "0" video_frame_delay = "0" video_black_frame_insertion = "false" video_disable_composition = "false" pause_nonactive = "false" video_swap_interval = "1" video_gpu_screenshot = "true" video_rotation = "0" screenshot_directory = "default" aspect_ratio_index = "20" core_updater_buildbot_url = "http://buildbot.libretro.com/nightly/win-x86_64/latest/" core_updater_buildbot_assets_url = "http://buildbot.libretro.com/assets/" core_updater_auto_extract_archive = "true" camera_allow = "false" audio_rate_control = "true" audio_rate_control_delta = "0.005000" audio_max_timing_skew = "0.050000" audio_volume = "0.000000" audio_driver = "dsound" audio_enable = "true" audio_mute_enable = "false" audio_out_rate = "48000" location_allow = "false" video_font_size = "32.000000" video_font_enable = "true" ups_pref = "false" bps_pref = "false" ips_pref = "false" system_directory = ":\system" input_remapping_directory = ":\configs" audio_resampler = "sinc" savefile_directory = "default" savestate_directory = "default" video_shader_dir = ":\shaders" video_filter_dir = ":\filters\video" audio_filter_dir = ":\filters\audio" core_assets_directory = "default" assets_directory = ":\assets" playlist_directory = ":\playlists" rgui_browser_directory = "E:" rgui_config_directory = ":\configs" rgui_show_start_screen = "false" menu_navigation_wraparound_horizontal_enable = "true" menu_navigation_wraparound_vertical_enable = "true" menu_navigation_browser_filter_supported_extensions_enable = "true" menu_collapse_subgroups_enable = "true" menu_show_advanced_settings = "false" menu_entry_normal_color = "ffffffff" menu_entry_hover_color = "ff64ff64" menu_title_color = "ff64ff64" game_history_path = ":\retroarch-content-history.txt" game_history_size = "100" joypad_autoconfig_dir = ":\autoconfig" input_autodetect_enable = "true" overlay_directory = ":\overlays" input_overlay_enable = "true" input_overlay_opacity = "0.700000" input_overlay_scale = "1.000000" osk_overlay_directory = ":\overlays" input_osk_overlay_enable = "false" video_message_pos_x = "0.050000" video_message_pos_y = "0.050000" gamma_correction = "false" soft_filter_enable = "false" flicker_filter_enable = "false" flicker_filter_index = "0" soft_filter_index = "0" current_resolution_id = "0" custom_viewport_width = "960" custom_viewport_height = "720" custom_viewport_x = "0" custom_viewport_y = "0" block_sram_overwrite = "false" savestate_auto_index = "false" savestate_auto_save = "false" savestate_auto_load = "false" history_list_enable = "true" fastforward_ratio = "1.000000" fastforward_ratio_throttle_enable = "false" slowmotion_ratio = "3.000000" config_save_on_exit = "false" sound_mode = "0" state_slot = "0" netplay_spectator_mode_enable = "false" netplay_mode = "false" netplay_ip_port = "0" netplay_delay_frames = "0" user_language = "0" custom_bgm_enable = "false" input_driver = "dinput" input_joypad_driver = "winxinput" input_device_p1 = "0" input_player1_joypad_index = "0" input_libretro_device_p1 = "1" input_player1_analog_dpad_mode = "0" input_device_p2 = "0" input_player2_joypad_index = "1" input_libretro_device_p2 = "1" input_player2_analog_dpad_mode = "0" input_device_p3 = "0" input_player3_joypad_index = "2" input_libretro_device_p3 = "1" input_player3_analog_dpad_mode = "0" input_device_p4 = "0" input_player4_joypad_index = "3" input_libretro_device_p4 = "1" input_player4_analog_dpad_mode = "0" input_device_p5 = "0" input_player5_joypad_index = "4" input_libretro_device_p5 = "1" input_player5_analog_dpad_mode = "0" input_device_p6 = "0" input_player6_joypad_index = "4" input_libretro_device_p6 = "1" input_player6_analog_dpad_mode = "0" input_device_p7 = "0" input_player7_joypad_index = "4" input_libretro_device_p7 = "1" input_player7_analog_dpad_mode = "0" input_device_p8 = "0" input_player8_joypad_index = "4" input_libretro_device_p8 = "1" input_player8_analog_dpad_mode = "0" input_device_p9 = "0" input_player9_joypad_index = "8" input_libretro_device_p9 = "1" input_player9_analog_dpad_mode = "0" input_device_p10 = "0" input_player10_joypad_index = "9" input_libretro_device_p10 = "1" input_player10_analog_dpad_mode = "0" input_device_p11 = "0" input_player11_joypad_index = "10" input_libretro_device_p11 = "1" input_player11_analog_dpad_mode = "0" input_device_p12 = "0" input_player12_joypad_index = "11" input_libretro_device_p12 = "1" input_player12_analog_dpad_mode = "0" input_device_p13 = "0" input_player13_joypad_index = "12" input_libretro_device_p13 = "1" input_player13_analog_dpad_mode = "0" input_device_p14 = "0" input_player14_joypad_index = "13" input_libretro_device_p14 = "1" input_player14_analog_dpad_mode = "0" input_device_p15 = "0" input_player15_joypad_index = "14" input_libretro_device_p15 = "1" input_player15_analog_dpad_mode = "0" input_device_p16 = "0" input_player16_joypad_index = "15" input_libretro_device_p16 = "1" input_player16_analog_dpad_mode = "0" input_player1_b = "a" input_player1_b_btn = "nul" input_player1_b_axis = "nul" input_player1_y = "nul" input_player1_y_btn = "nul" input_player1_y_axis = "nul" input_player1_select = "s" input_player1_select_btn = "nul" input_player1_select_axis = "nul" input_player1_start = "r" input_player1_start_btn = "nul" input_player1_start_axis = "nul" input_player1_up = "up" input_player1_up_btn = "nul" input_player1_up_axis = "nul" input_player1_down = "down" input_player1_down_btn = "nul" input_player1_down_axis = "nul" input_player1_left = "left" input_player1_left_btn = "nul" input_player1_left_axis = "nul" input_player1_right = "right" input_player1_right_btn = "nul" input_player1_right_axis = "nul" input_player1_a = "b" input_player1_a_btn = "nul" input_player1_a_axis = "nul" input_player1_x = "nul" input_player1_x_btn = "nul" input_player1_x_axis = "nul" input_player1_l = "nul" input_player1_l_btn = "nul" input_player1_l_axis = "nul" input_player1_r = "nul" input_player1_r_btn = "nul" input_player1_r_axis = "nul" input_player1_l2 = "nul" input_player1_l2_btn = "nul" input_player1_l2_axis = "nul" input_player1_r2 = "nul" input_player1_r2_btn = "nul" input_player1_r2_axis = "nul" input_player1_l3 = "nul" input_player1_l3_btn = "nul" input_player1_l3_axis = "nul" input_player1_r3 = "nul" input_player1_r3_btn = "nul" input_player1_r3_axis = "nul" input_player1_l_x_plus = "nul" input_player1_l_x_plus_btn = "nul" input_player1_l_x_plus_axis = "nul" input_player1_l_x_minus = "nul" input_player1_l_x_minus_btn = "nul" input_player1_l_x_minus_axis = "nul" input_player1_l_y_plus = "nul" input_player1_l_y_plus_btn = "nul" input_player1_l_y_plus_axis = "nul" input_player1_l_y_minus = "nul" input_player1_l_y_minus_btn = "nul" input_player1_l_y_minus_axis = "nul" input_player1_r_x_plus = "nul" input_player1_r_x_plus_btn = "nul" input_player1_r_x_plus_axis = "nul" input_player1_r_x_minus = "nul" input_player1_r_x_minus_btn = "nul" input_player1_r_x_minus_axis = "nul" input_player1_r_y_plus = "nul" input_player1_r_y_plus_btn = "nul" input_player1_r_y_plus_axis = "nul" input_player1_r_y_minus = "nul" input_player1_r_y_minus_btn = "nul" input_player1_r_y_minus_axis = "nul" input_player1_turbo = "nul" input_player1_turbo_btn = "nul" input_player1_turbo_axis = "nul" input_toggle_fast_forward = "nul" input_toggle_fast_forward_btn = "nul" input_toggle_fast_forward_axis = "nul" input_hold_fast_forward = "nul" input_hold_fast_forward_btn = "nul" input_hold_fast_forward_axis = "nul" input_load_state = "f4" input_load_state_btn = "nul" input_load_state_axis = "nul" input_save_state = "f3" input_save_state_btn = "nul" input_save_state_axis = "nul" input_toggle_fullscreen = "nul" input_toggle_fullscreen_axis = "nul" input_exit_emulator = "nul" input_exit_emulator_btn = "nul" input_exit_emulator_axis = "nul" input_state_slot_increase = "f1" input_state_slot_increase_btn = "nul" input_state_slot_increase_axis = "nul" input_state_slot_decrease = "f2" input_state_slot_decrease_btn = "nul" input_state_slot_decrease_axis = "nul" input_rewind = "nul" input_rewind_btn = "nul" input_rewind_axis = "nul" input_movie_record_toggle = "nul" input_movie_record_toggle_btn = "nul" input_movie_record_toggle_axis = "nul" input_pause_toggle = "p" input_pause_toggle_btn = "nul" input_pause_toggle_axis = "nul" input_frame_advance = "nul" input_frame_advance_btn = "nul" input_frame_advance_axis = "nul" input_reset = "nul" input_reset_btn = "nul" input_reset_axis = "nul" input_shader_next = "nul" input_shader_next_btn = "nul" input_shader_next_axis = "nul" input_shader_prev = "nul" input_shader_prev_btn = "nul" input_shader_prev_axis = "nul" input_cheat_index_plus = "nul" input_cheat_index_plus_btn = "nul" input_cheat_index_plus_axis = "nul" input_cheat_index_minus = "nul" input_cheat_index_minus_btn = "nul" input_cheat_index_minus_axis = "nul" input_cheat_toggle = "nul" input_cheat_toggle_btn = "nul" input_cheat_toggle_axis = "nul" input_screenshot = "nul" input_screenshot_btn = "nul" input_screenshot_axis = "nul" input_audio_mute = "nul" input_audio_mute_btn = "nul" input_audio_mute_axis = "nul" input_netplay_flip_players = "nul" input_netplay_flip_players_btn = "nul" input_netplay_flip_players_axis = "nul" input_slowmotion = "nul" input_slowmotion_btn = "nul" input_slowmotion_axis = "nul" input_enable_hotkey = "nul" input_enable_hotkey_btn = "nul" input_enable_hotkey_axis = "nul" input_volume_up = "nul" input_volume_up_btn = "nul" input_volume_up_axis = "nul" input_volume_down = "nul" input_volume_down_btn = "nul" input_volume_down_axis = "nul" input_overlay_next = "nul" input_overlay_next_btn = "nul" input_overlay_next_axis = "nul" input_disk_eject_toggle = "F10" input_disk_eject_toggle_btn = "nul" input_disk_eject_toggle_axis = "nul" input_disk_next = "F11" input_disk_next_btn = "nul" input_disk_next_axis = "nul" input_disk_prev = "F12" input_disk_prev_btn = "nul" input_disk_prev_axis = "nul" input_grab_mouse_toggle = "nul" input_grab_mouse_toggle_btn = "nul" input_grab_mouse_toggle_axis = "nul" input_menu_toggle = "tab" input_menu_toggle_btn = "99" input_menu_toggle_axis = "nul" input_player2_b = "g" input_player2_b_btn = "nul" input_player2_b_axis = "nul" input_player2_y = "nul" input_player2_y_btn = "nul" input_player2_y_axis = "nul" input_player2_select = "u" input_player2_select_btn = "nul" input_player2_select_axis = "nul" input_player2_start = "t" input_player2_start_btn = "nul" input_player2_start_axis = "nul" input_player2_up = "n" input_player2_up_btn = "nul" input_player2_up_axis = "nul" input_player2_down = "q" input_player2_down_btn = "nul" input_player2_down_axis = "nul" input_player2_left = "m" input_player2_left_btn = "nul" input_player2_left_axis = "nul" input_player2_right = "o" input_player2_right_btn = "nul" input_player2_right_axis = "nul" input_player2_a = "h" input_player2_a_btn = "nul" input_player2_a_axis = "nul" input_player2_x = "nul" input_player2_x_btn = "nul" input_player2_x_axis = "nul" input_player2_l = "nul" input_player2_l_btn = "nul" input_player2_l_axis = "nul" input_player2_r = "nul" input_player2_r_btn = "nul" input_player2_r_axis = "nul" input_player2_l2 = "nul" input_player2_l2_btn = "nul" input_player2_l2_axis = "nul" input_player2_r2 = "nul" input_player2_r2_btn = "nul" input_player2_r2_axis = "nul" input_player2_l3 = "nul" input_player2_l3_btn = "nul" input_player2_l3_axis = "nul" input_player2_r3 = "nul" input_player2_r3_btn = "nul" input_player2_r3_axis = "nul" input_player2_l_x_plus = "nul" input_player2_l_x_plus_btn = "nul" input_player2_l_x_plus_axis = "nul" input_player2_l_x_minus = "nul" input_player2_l_x_minus_btn = "nul" input_player2_l_x_minus_axis = "nul" input_player2_l_y_plus = "nul" input_player2_l_y_plus_btn = "nul" input_player2_l_y_plus_axis = "nul" input_player2_l_y_minus = "nul" input_player2_l_y_minus_btn = "nul" input_player2_l_y_minus_axis = "nul" input_player2_r_x_plus = "nul" input_player2_r_x_plus_btn = "nul" input_player2_r_x_plus_axis = "nul" input_player2_r_x_minus = "nul" input_player2_r_x_minus_btn = "nul" input_player2_r_x_minus_axis = "nul" input_player2_r_y_plus = "nul" input_player2_r_y_plus_btn = "nul" input_player2_r_y_plus_axis = "nul" input_player2_r_y_minus = "nul" input_player2_r_y_minus_btn = "nul" input_player2_r_y_minus_axis = "nul" input_player2_turbo = "nul" input_player2_turbo_btn = "nul" input_player2_turbo_axis = "nul" input_player3_b = "nul" input_player3_b_btn = "nul" input_player3_b_axis = "nul" input_player3_y = "nul" input_player3_y_btn = "nul" input_player3_y_axis = "nul" input_player3_select = "nul" input_player3_select_btn = "nul" input_player3_select_axis = "nul" input_player3_start = "nul" input_player3_start_btn = "nul" input_player3_start_axis = "nul" input_player3_up = "nul" input_player3_up_btn = "nul" input_player3_up_axis = "nul" input_player3_down = "nul" input_player3_down_btn = "nul" input_player3_down_axis = "nul" input_player3_left = "nul" input_player3_left_btn = "nul" input_player3_left_axis = "nul" input_player3_right = "nul" input_player3_right_btn = "nul" input_player3_right_axis = "nul" input_player3_a = "nul" input_player3_a_btn = "nul" input_player3_a_axis = "nul" input_player3_x = "nul" input_player3_x_btn = "nul" input_player3_x_axis = "nul" input_player3_l = "nul" input_player3_l_btn = "nul" input_player3_l_axis = "nul" input_player3_r = "nul" input_player3_r_btn = "nul" input_player3_r_axis = "nul" input_player3_l2 = "nul" input_player3_l2_btn = "nul" input_player3_l2_axis = "nul" input_player3_r2 = "nul" input_player3_r2_btn = "nul" input_player3_r2_axis = "nul" input_player3_l3 = "nul" input_player3_l3_btn = "nul" input_player3_l3_axis = "nul" input_player3_r3 = "nul" input_player3_r3_btn = "nul" input_player3_r3_axis = "nul" input_player3_l_x_plus = "nul" input_player3_l_x_plus_btn = "nul" input_player3_l_x_plus_axis = "nul" input_player3_l_x_minus = "nul" input_player3_l_x_minus_btn = "nul" input_player3_l_x_minus_axis = "nul" input_player3_l_y_plus = "nul" input_player3_l_y_plus_btn = "nul" input_player3_l_y_plus_axis = "nul" input_player3_l_y_minus = "nul" input_player3_l_y_minus_btn = "nul" input_player3_l_y_minus_axis = "nul" input_player3_r_x_plus = "nul" input_player3_r_x_plus_btn = "nul" input_player3_r_x_plus_axis = "nul" input_player3_r_x_minus = "nul" input_player3_r_x_minus_btn = "nul" input_player3_r_x_minus_axis = "nul" input_player3_r_y_plus = "nul" input_player3_r_y_plus_btn = "nul" input_player3_r_y_plus_axis = "nul" input_player3_r_y_minus = "nul" input_player3_r_y_minus_btn = "nul" input_player3_r_y_minus_axis = "nul" input_player3_turbo = "nul" input_player3_turbo_btn = "nul" input_player3_turbo_axis = "nul" input_player4_b = "nul" input_player4_b_btn = "nul" input_player4_b_axis = "nul" input_player4_y = "nul" input_player4_y_btn = "nul" input_player4_y_axis = "nul" input_player4_select = "nul" input_player4_select_btn = "nul" input_player4_select_axis = "nul" input_player4_start = "nul" input_player4_start_btn = "nul" input_player4_start_axis = "nul" input_player4_up = "nul" input_player4_up_btn = "nul" input_player4_up_axis = "nul" input_player4_down = "nul" input_player4_down_btn = "nul" input_player4_down_axis = "nul" input_player4_left = "nul" input_player4_left_btn = "nul" input_player4_left_axis = "nul" input_player4_right = "nul" input_player4_right_btn = "nul" input_player4_right_axis = "nul" input_player4_a = "nul" input_player4_a_btn = "nul" input_player4_a_axis = "nul" input_player4_x = "nul" input_player4_x_btn = "nul" input_player4_x_axis = "nul" input_player4_l = "nul" input_player4_l_btn = "nul" input_player4_l_axis = "nul" input_player4_r = "nul" input_player4_r_btn = "nul" input_player4_r_axis = "nul" input_player4_l2 = "nul" input_player4_l2_btn = "nul" input_player4_l2_axis = "nul" input_player4_r2 = "nul" input_player4_r2_btn = "nul" input_player4_r2_axis = "nul" input_player4_l3 = "nul" input_player4_l3_btn = "nul" input_player4_l3_axis = "nul" input_player4_r3 = "nul" input_player4_r3_btn = "nul" input_player4_r3_axis = "nul" input_player4_l_x_plus = "nul" input_player4_l_x_plus_btn = "nul" input_player4_l_x_plus_axis = "nul" input_player4_l_x_minus = "nul" input_player4_l_x_minus_btn = "nul" input_player4_l_x_minus_axis = "nul" input_player4_l_y_plus = "nul" input_player4_l_y_plus_btn = "nul" input_player4_l_y_plus_axis = "nul" input_player4_l_y_minus = "nul" input_player4_l_y_minus_btn = "nul" input_player4_l_y_minus_axis = "nul" input_player4_r_x_plus = "nul" input_player4_r_x_plus_btn = "nul" input_player4_r_x_plus_axis = "nul" input_player4_r_x_minus = "nul" input_player4_r_x_minus_btn = "nul" input_player4_r_x_minus_axis = "nul" input_player4_r_y_plus = "nul" input_player4_r_y_plus_btn = "nul" input_player4_r_y_plus_axis = "nul" input_player4_r_y_minus = "nul" input_player4_r_y_minus_btn = "nul" input_player4_r_y_minus_axis = "nul" input_player4_turbo = "nul" input_player4_turbo_btn = "nul" input_player4_turbo_axis = "nul" input_player5_b = "nul" input_player5_b_btn = "nul" input_player5_b_axis = "nul" input_player5_y = "nul" input_player5_y_btn = "nul" input_player5_y_axis = "nul" input_player5_select = "nul" input_player5_select_btn = "nul" input_player5_select_axis = "nul" input_player5_start = "nul" input_player5_start_btn = "nul" input_player5_start_axis = "nul" input_player5_up = "nul" input_player5_up_btn = "nul" input_player5_up_axis = "nul" input_player5_down = "nul" input_player5_down_btn = "nul" input_player5_down_axis = "nul" input_player5_left = "nul" input_player5_left_btn = "nul" input_player5_left_axis = "nul" input_player5_right = "nul" input_player5_right_btn = "nul" input_player5_right_axis = "nul" input_player5_a = "nul" input_player5_a_btn = "nul" input_player5_a_axis = "nul" input_player5_x = "nul" input_player5_x_btn = "nul" input_player5_x_axis = "nul" input_player5_l = "nul" input_player5_l_btn = "nul" input_player5_l_axis = "nul" input_player5_r = "nul" input_player5_r_btn = "nul" input_player5_r_axis = "nul" input_player5_l2 = "nul" input_player5_l2_btn = "nul" input_player5_l2_axis = "nul" input_player5_r2 = "nul" input_player5_r2_btn = "nul" input_player5_r2_axis = "nul" input_player5_l3 = "nul" input_player5_l3_btn = "nul" input_player5_l3_axis = "nul" input_player5_r3 = "nul" input_player5_r3_btn = "nul" input_player5_r3_axis = "nul" input_player5_l_x_plus = "nul" input_player5_l_x_plus_btn = "nul" input_player5_l_x_plus_axis = "nul" input_player5_l_x_minus = "nul" input_player5_l_x_minus_btn = "nul" input_player5_l_x_minus_axis = "nul" input_player5_l_y_plus = "nul" input_player5_l_y_plus_btn = "nul" input_player5_l_y_plus_axis = "nul" input_player5_l_y_minus = "nul" input_player5_l_y_minus_btn = "nul" input_player5_l_y_minus_axis = "nul" input_player5_r_x_plus = "nul" input_player5_r_x_plus_btn = "nul" input_player5_r_x_plus_axis = "nul" input_player5_r_x_minus = "nul" input_player5_r_x_minus_btn = "nul" input_player5_r_x_minus_axis = "nul" input_player5_r_y_plus = "nul" input_player5_r_y_plus_btn = "nul" input_player5_r_y_plus_axis = "nul" input_player5_r_y_minus = "nul" input_player5_r_y_minus_btn = "nul" input_player5_r_y_minus_axis = "nul" input_player5_turbo = "nul" input_player5_turbo_btn = "nul" input_player5_turbo_axis = "nul" input_player6_b = "nul" input_player6_b_btn = "nul" input_player6_b_axis = "nul" input_player6_y = "nul" input_player6_y_btn = "nul" input_player6_y_axis = "nul" input_player6_select = "nul" input_player6_select_btn = "nul" input_player6_select_axis = "nul" input_player6_start = "nul" input_player6_start_btn = "nul" input_player6_start_axis = "nul" input_player6_up = "nul" input_player6_up_btn = "nul" input_player6_up_axis = "nul" input_player6_down = "nul" input_player6_down_btn = "nul" input_player6_down_axis = "nul" input_player6_left = "nul" input_player6_left_btn = "nul" input_player6_left_axis = "nul" input_player6_right = "nul" input_player6_right_btn = "nul" input_player6_right_axis = "nul" input_player6_a = "nul" input_player6_a_btn = "nul" input_player6_a_axis = "nul" input_player6_x = "nul" input_player6_x_btn = "nul" input_player6_x_axis = "nul" input_player6_l = "nul" input_player6_l_btn = "nul" input_player6_l_axis = "nul" input_player6_r = "nul" input_player6_r_btn = "nul" input_player6_r_axis = "nul" input_player6_l2 = "nul" input_player6_l2_btn = "nul" input_player6_l2_axis = "nul" input_player6_r2 = "nul" input_player6_r2_btn = "nul" input_player6_r2_axis = "nul" input_player6_l3 = "nul" input_player6_l3_btn = "nul" input_player6_l3_axis = "nul" input_player6_r3 = "nul" input_player6_r3_btn = "nul" input_player6_r3_axis = "nul" input_player6_l_x_plus = "nul" input_player6_l_x_plus_btn = "nul" input_player6_l_x_plus_axis = "nul" input_player6_l_x_minus = "nul" input_player6_l_x_minus_btn = "nul" input_player6_l_x_minus_axis = "nul" input_player6_l_y_plus = "nul" input_player6_l_y_plus_btn = "nul" input_player6_l_y_plus_axis = "nul" input_player6_l_y_minus = "nul" input_player6_l_y_minus_btn = "nul" input_player6_l_y_minus_axis = "nul" input_player6_r_x_plus = "nul" input_player6_r_x_plus_btn = "nul" input_player6_r_x_plus_axis = "nul" input_player6_r_x_minus = "nul" input_player6_r_x_minus_btn = "nul" input_player6_r_x_minus_axis = "nul" input_player6_r_y_plus = "nul" input_player6_r_y_plus_btn = "nul" input_player6_r_y_plus_axis = "nul" input_player6_r_y_minus = "nul" input_player6_r_y_minus_btn = "nul" input_player6_r_y_minus_axis = "nul" input_player6_turbo = "nul" input_player6_turbo_btn = "nul" input_player6_turbo_axis = "nul" input_player7_b = "nul" input_player7_b_btn = "nul" input_player7_b_axis = "nul" input_player7_y = "nul" input_player7_y_btn = "nul" input_player7_y_axis = "nul" input_player7_select = "nul" input_player7_select_btn = "nul" input_player7_select_axis = "nul" input_player7_start = "nul" input_player7_start_btn = "nul" input_player7_start_axis = "nul" input_player7_up = "nul" input_player7_up_btn = "nul" input_player7_up_axis = "nul" input_player7_down = "nul" input_player7_down_btn = "nul" input_player7_down_axis = "nul" input_player7_left = "nul" input_player7_left_btn = "nul" input_player7_left_axis = "nul" input_player7_right = "nul" input_player7_right_btn = "nul" input_player7_right_axis = "nul" input_player7_a = "nul" input_player7_a_btn = "nul" input_player7_a_axis = "nul" input_player7_x = "nul" input_player7_x_btn = "nul" input_player7_x_axis = "nul" input_player7_l = "nul" input_player7_l_btn = "nul" input_player7_l_axis = "nul" input_player7_r = "nul" input_player7_r_btn = "nul" input_player7_r_axis = "nul" input_player7_l2 = "nul" input_player7_l2_btn = "nul" input_player7_l2_axis = "nul" input_player7_r2 = "nul" input_player7_r2_btn = "nul" input_player7_r2_axis = "nul" input_player7_l3 = "nul" input_player7_l3_btn = "nul" input_player7_l3_axis = "nul" input_player7_r3 = "nul" input_player7_r3_btn = "nul" input_player7_r3_axis = "nul" input_player7_l_x_plus = "nul" input_player7_l_x_plus_btn = "nul" input_player7_l_x_plus_axis = "nul" input_player7_l_x_minus = "nul" input_player7_l_x_minus_btn = "nul" input_player7_l_x_minus_axis = "nul" input_player7_l_y_plus = "nul" input_player7_l_y_plus_btn = "nul" input_player7_l_y_plus_axis = "nul" input_player7_l_y_minus = "nul" input_player7_l_y_minus_btn = "nul" input_player7_l_y_minus_axis = "nul" input_player7_r_x_plus = "nul" input_player7_r_x_plus_btn = "nul" input_player7_r_x_plus_axis = "nul" input_player7_r_x_minus = "nul" input_player7_r_x_minus_btn = "nul" input_player7_r_x_minus_axis = "nul" input_player7_r_y_plus = "nul" input_player7_r_y_plus_btn = "nul" input_player7_r_y_plus_axis = "nul" input_player7_r_y_minus = "nul" input_player7_r_y_minus_btn = "nul" input_player7_r_y_minus_axis = "nul" input_player7_turbo = "nul" input_player7_turbo_btn = "nul" input_player7_turbo_axis = "nul" input_player8_b = "nul" input_player8_b_btn = "nul" input_player8_b_axis = "nul" input_player8_y = "nul" input_player8_y_btn = "nul" input_player8_y_axis = "nul" input_player8_select = "nul" input_player8_select_btn = "nul" input_player8_select_axis = "nul" input_player8_start = "nul" input_player8_start_btn = "nul" input_player8_start_axis = "nul" input_player8_up = "nul" input_player8_up_btn = "nul" input_player8_up_axis = "nul" input_player8_down = "nul" input_player8_down_btn = "nul" input_player8_down_axis = "nul" input_player8_left = "nul" input_player8_left_btn = "nul" input_player8_left_axis = "nul" input_player8_right = "nul" input_player8_right_btn = "nul" input_player8_right_axis = "nul" input_player8_a = "nul" input_player8_a_btn = "nul" input_player8_a_axis = "nul" input_player8_x = "nul" input_player8_x_btn = "nul" input_player8_x_axis = "nul" input_player8_l = "nul" input_player8_l_btn = "nul" input_player8_l_axis = "nul" input_player8_r = "nul" input_player8_r_btn = "nul" input_player8_r_axis = "nul" input_player8_l2 = "nul" input_player8_l2_btn = "nul" input_player8_l2_axis = "nul" input_player8_r2 = "nul" input_player8_r2_btn = "nul" input_player8_r2_axis = "nul" input_player8_l3 = "nul" input_player8_l3_btn = "nul" input_player8_l3_axis = "nul" input_player8_r3 = "nul" input_player8_r3_btn = "nul" input_player8_r3_axis = "nul" input_player8_l_x_plus = "nul" input_player8_l_x_plus_btn = "nul" input_player8_l_x_plus_axis = "nul" input_player8_l_x_minus = "nul" input_player8_l_x_minus_btn = "nul" input_player8_l_x_minus_axis = "nul" input_player8_l_y_plus = "nul" input_player8_l_y_plus_btn = "nul" input_player8_l_y_plus_axis = "nul" input_player8_l_y_minus = "nul" input_player8_l_y_minus_btn = "nul" input_player8_l_y_minus_axis = "nul" input_player8_r_x_plus = "nul" input_player8_r_x_plus_btn = "nul" input_player8_r_x_plus_axis = "nul" input_player8_r_x_minus = "nul" input_player8_r_x_minus_btn = "nul" input_player8_r_x_minus_axis = "nul" input_player8_r_y_plus = "nul" input_player8_r_y_plus_btn = "nul" input_player8_r_y_plus_axis = "nul" input_player8_r_y_minus = "nul" input_player8_r_y_minus_btn = "nul" input_player8_r_y_minus_axis = "nul" input_player8_turbo = "nul" input_player8_turbo_btn = "nul" input_player8_turbo_axis = "nul" input_player9_b = "nul" input_player9_b_btn = "nul" input_player9_b_axis = "nul" input_player9_y = "nul" input_player9_y_btn = "nul" input_player9_y_axis = "nul" input_player9_select = "nul" input_player9_select_btn = "nul" input_player9_select_axis = "nul" input_player9_start = "nul" input_player9_start_btn = "nul" input_player9_start_axis = "nul" input_player9_up = "nul" input_player9_up_btn = "nul" input_player9_up_axis = "nul" input_player9_down = "nul" input_player9_down_btn = "nul" input_player9_down_axis = "nul" input_player9_left = "nul" input_player9_left_btn = "nul" input_player9_left_axis = "nul" input_player9_right = "nul" input_player9_right_btn = "nul" input_player9_right_axis = "nul" input_player9_a = "nul" input_player9_a_btn = "nul" input_player9_a_axis = "nul" input_player9_x = "nul" input_player9_x_btn = "nul" input_player9_x_axis = "nul" input_player9_l = "nul" input_player9_l_btn = "nul" input_player9_l_axis = "nul" input_player9_r = "nul" input_player9_r_btn = "nul" input_player9_r_axis = "nul" input_player9_l2 = "nul" input_player9_l2_btn = "nul" input_player9_l2_axis = "nul" input_player9_r2 = "nul" input_player9_r2_btn = "nul" input_player9_r2_axis = "nul" input_player9_l3 = "nul" input_player9_l3_btn = "nul" input_player9_l3_axis = "nul" input_player9_r3 = "nul" input_player9_r3_btn = "nul" input_player9_r3_axis = "nul" input_player9_l_x_plus = "nul" input_player9_l_x_plus_btn = "nul" input_player9_l_x_plus_axis = "nul" input_player9_l_x_minus = "nul" input_player9_l_x_minus_btn = "nul" input_player9_l_x_minus_axis = "nul" input_player9_l_y_plus = "nul" input_player9_l_y_plus_btn = "nul" input_player9_l_y_plus_axis = "nul" input_player9_l_y_minus = "nul" input_player9_l_y_minus_btn = "nul" input_player9_l_y_minus_axis = "nul" input_player9_r_x_plus = "nul" input_player9_r_x_plus_btn = "nul" input_player9_r_x_plus_axis = "nul" input_player9_r_x_minus = "nul" input_player9_r_x_minus_btn = "nul" input_player9_r_x_minus_axis = "nul" input_player9_r_y_plus = "nul" input_player9_r_y_plus_btn = "nul" input_player9_r_y_plus_axis = "nul" input_player9_r_y_minus = "nul" input_player9_r_y_minus_btn = "nul" input_player9_r_y_minus_axis = "nul" input_player9_turbo = "nul" input_player9_turbo_btn = "nul" input_player9_turbo_axis = "nul" input_player10_b = "nul" input_player10_b_btn = "nul" input_player10_b_axis = "nul" input_player10_y = "nul" input_player10_y_btn = "nul" input_player10_y_axis = "nul" input_player10_select = "nul" input_player10_select_btn = "nul" input_player10_select_axis = "nul" input_player10_start = "nul" input_player10_start_btn = "nul" input_player10_start_axis = "nul" input_player10_up = "nul" input_player10_up_btn = "nul" input_player10_up_axis = "nul" input_player10_down = "nul" input_player10_down_btn = "nul" input_player10_down_axis = "nul" input_player10_left = "nul" input_player10_left_btn = "nul" input_player10_left_axis = "nul" input_player10_right = "nul" input_player10_right_btn = "nul" input_player10_right_axis = "nul" input_player10_a = "nul" input_player10_a_btn = "nul" input_player10_a_axis = "nul" input_player10_x = "nul" input_player10_x_btn = "nul" input_player10_x_axis = "nul" input_player10_l = "nul" input_player10_l_btn = "nul" input_player10_l_axis = "nul" input_player10_r = "nul" input_player10_r_btn = "nul" input_player10_r_axis = "nul" input_player10_l2 = "nul" input_player10_l2_btn = "nul" input_player10_l2_axis = "nul" input_player10_r2 = "nul" input_player10_r2_btn = "nul" input_player10_r2_axis = "nul" input_player10_l3 = "nul" input_player10_l3_btn = "nul" input_player10_l3_axis = "nul" input_player10_r3 = "nul" input_player10_r3_btn = "nul" input_player10_r3_axis = "nul" input_player10_l_x_plus = "nul" input_player10_l_x_plus_btn = "nul" input_player10_l_x_plus_axis = "nul" input_player10_l_x_minus = "nul" input_player10_l_x_minus_btn = "nul" input_player10_l_x_minus_axis = "nul" input_player10_l_y_plus = "nul" input_player10_l_y_plus_btn = "nul" input_player10_l_y_plus_axis = "nul" input_player10_l_y_minus = "nul" input_player10_l_y_minus_btn = "nul" input_player10_l_y_minus_axis = "nul" input_player10_r_x_plus = "nul" input_player10_r_x_plus_btn = "nul" input_player10_r_x_plus_axis = "nul" input_player10_r_x_minus = "nul" input_player10_r_x_minus_btn = "nul" input_player10_r_x_minus_axis = "nul" input_player10_r_y_plus = "nul" input_player10_r_y_plus_btn = "nul" input_player10_r_y_plus_axis = "nul" input_player10_r_y_minus = "nul" input_player10_r_y_minus_btn = "nul" input_player10_r_y_minus_axis = "nul" input_player10_turbo = "nul" input_player10_turbo_btn = "nul" input_player10_turbo_axis = "nul" input_player11_b = "nul" input_player11_b_btn = "nul" input_player11_b_axis = "nul" input_player11_y = "nul" input_player11_y_btn = "nul" input_player11_y_axis = "nul" input_player11_select = "nul" input_player11_select_btn = "nul" input_player11_select_axis = "nul" input_player11_start = "nul" input_player11_start_btn = "nul" input_player11_start_axis = "nul" input_player11_up = "nul" input_player11_up_btn = "nul" input_player11_up_axis = "nul" input_player11_down = "nul" input_player11_down_btn = "nul" input_player11_down_axis = "nul" input_player11_left = "nul" input_player11_left_btn = "nul" input_player11_left_axis = "nul" input_player11_right = "nul" input_player11_right_btn = "nul" input_player11_right_axis = "nul" input_player11_a = "nul" input_player11_a_btn = "nul" input_player11_a_axis = "nul" input_player11_x = "nul" input_player11_x_btn = "nul" input_player11_x_axis = "nul" input_player11_l = "nul" input_player11_l_btn = "nul" input_player11_l_axis = "nul" input_player11_r = "nul" input_player11_r_btn = "nul" input_player11_r_axis = "nul" input_player11_l2 = "nul" input_player11_l2_btn = "nul" input_player11_l2_axis = "nul" input_player11_r2 = "nul" input_player11_r2_btn = "nul" input_player11_r2_axis = "nul" input_player11_l3 = "nul" input_player11_l3_btn = "nul" input_player11_l3_axis = "nul" input_player11_r3 = "nul" input_player11_r3_btn = "nul" input_player11_r3_axis = "nul" input_player11_l_x_plus = "nul" input_player11_l_x_plus_btn = "nul" input_player11_l_x_plus_axis = "nul" input_player11_l_x_minus = "nul" input_player11_l_x_minus_btn = "nul" input_player11_l_x_minus_axis = "nul" input_player11_l_y_plus = "nul" input_player11_l_y_plus_btn = "nul" input_player11_l_y_plus_axis = "nul" input_player11_l_y_minus = "nul" input_player11_l_y_minus_btn = "nul" input_player11_l_y_minus_axis = "nul" input_player11_r_x_plus = "nul" input_player11_r_x_plus_btn = "nul" input_player11_r_x_plus_axis = "nul" input_player11_r_x_minus = "nul" input_player11_r_x_minus_btn = "nul" input_player11_r_x_minus_axis = "nul" input_player11_r_y_plus = "nul" input_player11_r_y_plus_btn = "nul" input_player11_r_y_plus_axis = "nul" input_player11_r_y_minus = "nul" input_player11_r_y_minus_btn = "nul" input_player11_r_y_minus_axis = "nul" input_player11_turbo = "nul" input_player11_turbo_btn = "nul" input_player11_turbo_axis = "nul" input_player12_b = "nul" input_player12_b_btn = "nul" input_player12_b_axis = "nul" input_player12_y = "nul" input_player12_y_btn = "nul" input_player12_y_axis = "nul" input_player12_select = "nul" input_player12_select_btn = "nul" input_player12_select_axis = "nul" input_player12_start = "nul" input_player12_start_btn = "nul" input_player12_start_axis = "nul" input_player12_up = "nul" input_player12_up_btn = "nul" input_player12_up_axis = "nul" input_player12_down = "nul" input_player12_down_btn = "nul" input_player12_down_axis = "nul" input_player12_left = "nul" input_player12_left_btn = "nul" input_player12_left_axis = "nul" input_player12_right = "nul" input_player12_right_btn = "nul" input_player12_right_axis = "nul" input_player12_a = "nul" input_player12_a_btn = "nul" input_player12_a_axis = "nul" input_player12_x = "nul" input_player12_x_btn = "nul" input_player12_x_axis = "nul" input_player12_l = "nul" input_player12_l_btn = "nul" input_player12_l_axis = "nul" input_player12_r = "nul" input_player12_r_btn = "nul" input_player12_r_axis = "nul" input_player12_l2 = "nul" input_player12_l2_btn = "nul" input_player12_l2_axis = "nul" input_player12_r2 = "nul" input_player12_r2_btn = "nul" input_player12_r2_axis = "nul" input_player12_l3 = "nul" input_player12_l3_btn = "nul" input_player12_l3_axis = "nul" input_player12_r3 = "nul" input_player12_r3_btn = "nul" input_player12_r3_axis = "nul" input_player12_l_x_plus = "nul" input_player12_l_x_plus_btn = "nul" input_player12_l_x_plus_axis = "nul" input_player12_l_x_minus = "nul" input_player12_l_x_minus_btn = "nul" input_player12_l_x_minus_axis = "nul" input_player12_l_y_plus = "nul" input_player12_l_y_plus_btn = "nul" input_player12_l_y_plus_axis = "nul" input_player12_l_y_minus = "nul" input_player12_l_y_minus_btn = "nul" input_player12_l_y_minus_axis = "nul" input_player12_r_x_plus = "nul" input_player12_r_x_plus_btn = "nul" input_player12_r_x_plus_axis = "nul" input_player12_r_x_minus = "nul" input_player12_r_x_minus_btn = "nul" input_player12_r_x_minus_axis = "nul" input_player12_r_y_plus = "nul" input_player12_r_y_plus_btn = "nul" input_player12_r_y_plus_axis = "nul" input_player12_r_y_minus = "nul" input_player12_r_y_minus_btn = "nul" input_player12_r_y_minus_axis = "nul" input_player12_turbo = "nul" input_player12_turbo_btn = "nul" input_player12_turbo_axis = "nul" input_player13_b = "nul" input_player13_b_btn = "nul" input_player13_b_axis = "nul" input_player13_y = "nul" input_player13_y_btn = "nul" input_player13_y_axis = "nul" input_player13_select = "nul" input_player13_select_btn = "nul" input_player13_select_axis = "nul" input_player13_start = "nul" input_player13_start_btn = "nul" input_player13_start_axis = "nul" input_player13_up = "nul" input_player13_up_btn = "nul" input_player13_up_axis = "nul" input_player13_down = "nul" input_player13_down_btn = "nul" input_player13_down_axis = "nul" input_player13_left = "nul" input_player13_left_btn = "nul" input_player13_left_axis = "nul" input_player13_right = "nul" input_player13_right_btn = "nul" input_player13_right_axis = "nul" input_player13_a = "nul" input_player13_a_btn = "nul" input_player13_a_axis = "nul" input_player13_x = "nul" input_player13_x_btn = "nul" input_player13_x_axis = "nul" input_player13_l = "nul" input_player13_l_btn = "nul" input_player13_l_axis = "nul" input_player13_r = "nul" input_player13_r_btn = "nul" input_player13_r_axis = "nul" input_player13_l2 = "nul" input_player13_l2_btn = "nul" input_player13_l2_axis = "nul" input_player13_r2 = "nul" input_player13_r2_btn = "nul" input_player13_r2_axis = "nul" input_player13_l3 = "nul" input_player13_l3_btn = "nul" input_player13_l3_axis = "nul" input_player13_r3 = "nul" input_player13_r3_btn = "nul" input_player13_r3_axis = "nul" input_player13_l_x_plus = "nul" input_player13_l_x_plus_btn = "nul" input_player13_l_x_plus_axis = "nul" input_player13_l_x_minus = "nul" input_player13_l_x_minus_btn = "nul" input_player13_l_x_minus_axis = "nul" input_player13_l_y_plus = "nul" input_player13_l_y_plus_btn = "nul" input_player13_l_y_plus_axis = "nul" input_player13_l_y_minus = "nul" input_player13_l_y_minus_btn = "nul" input_player13_l_y_minus_axis = "nul" input_player13_r_x_plus = "nul" input_player13_r_x_plus_btn = "nul" input_player13_r_x_plus_axis = "nul" input_player13_r_x_minus = "nul" input_player13_r_x_minus_btn = "nul" input_player13_r_x_minus_axis = "nul" input_player13_r_y_plus = "nul" input_player13_r_y_plus_btn = "nul" input_player13_r_y_plus_axis = "nul" input_player13_r_y_minus = "nul" input_player13_r_y_minus_btn = "nul" input_player13_r_y_minus_axis = "nul" input_player13_turbo = "nul" input_player13_turbo_btn = "nul" input_player13_turbo_axis = "nul" input_player14_b = "nul" input_player14_b_btn = "nul" input_player14_b_axis = "nul" input_player14_y = "nul" input_player14_y_btn = "nul" input_player14_y_axis = "nul" input_player14_select = "nul" input_player14_select_btn = "nul" input_player14_select_axis = "nul" input_player14_start = "nul" input_player14_start_btn = "nul" input_player14_start_axis = "nul" input_player14_up = "nul" input_player14_up_btn = "nul" input_player14_up_axis = "nul" input_player14_down = "nul" input_player14_down_btn = "nul" input_player14_down_axis = "nul" input_player14_left = "nul" input_player14_left_btn = "nul" input_player14_left_axis = "nul" input_player14_right = "nul" input_player14_right_btn = "nul" input_player14_right_axis = "nul" input_player14_a = "nul" input_player14_a_btn = "nul" input_player14_a_axis = "nul" input_player14_x = "nul" input_player14_x_btn = "nul" input_player14_x_axis = "nul" input_player14_l = "nul" input_player14_l_btn = "nul" input_player14_l_axis = "nul" input_player14_r = "nul" input_player14_r_btn = "nul" input_player14_r_axis = "nul" input_player14_l2 = "nul" input_player14_l2_btn = "nul" input_player14_l2_axis = "nul" input_player14_r2 = "nul" input_player14_r2_btn = "nul" input_player14_r2_axis = "nul" input_player14_l3 = "nul" input_player14_l3_btn = "nul" input_player14_l3_axis = "nul" input_player14_r3 = "nul" input_player14_r3_btn = "nul" input_player14_r3_axis = "nul" input_player14_l_x_plus = "nul" input_player14_l_x_plus_btn = "nul" input_player14_l_x_plus_axis = "nul" input_player14_l_x_minus = "nul" input_player14_l_x_minus_btn = "nul" input_player14_l_x_minus_axis = "nul" input_player14_l_y_plus = "nul" input_player14_l_y_plus_btn = "nul" input_player14_l_y_plus_axis = "nul" input_player14_l_y_minus = "nul" input_player14_l_y_minus_btn = "nul" input_player14_l_y_minus_axis = "nul" input_player14_r_x_plus = "nul" input_player14_r_x_plus_btn = "nul" input_player14_r_x_plus_axis = "nul" input_player14_r_x_minus = "nul" input_player14_r_x_minus_btn = "nul" input_player14_r_x_minus_axis = "nul" input_player14_r_y_plus = "nul" input_player14_r_y_plus_btn = "nul" input_player14_r_y_plus_axis = "nul" input_player14_r_y_minus = "nul" input_player14_r_y_minus_btn = "nul" input_player14_r_y_minus_axis = "nul" input_player14_turbo = "nul" input_player14_turbo_btn = "nul" input_player14_turbo_axis = "nul" input_player15_b = "nul" input_player15_b_btn = "nul" input_player15_b_axis = "nul" input_player15_y = "nul" input_player15_y_btn = "nul" input_player15_y_axis = "nul" input_player15_select = "nul" input_player15_select_btn = "nul" input_player15_select_axis = "nul" input_player15_start = "nul" input_player15_start_btn = "nul" input_player15_start_axis = "nul" input_player15_up = "nul" input_player15_up_btn = "nul" input_player15_up_axis = "nul" input_player15_down = "nul" input_player15_down_btn = "nul" input_player15_down_axis = "nul" input_player15_left = "nul" input_player15_left_btn = "nul" input_player15_left_axis = "nul" input_player15_right = "nul" input_player15_right_btn = "nul" input_player15_right_axis = "nul" input_player15_a = "nul" input_player15_a_btn = "nul" input_player15_a_axis = "nul" input_player15_x = "nul" input_player15_x_btn = "nul" input_player15_x_axis = "nul" input_player15_l = "nul" input_player15_l_btn = "nul" input_player15_l_axis = "nul" input_player15_r = "nul" input_player15_r_btn = "nul" input_player15_r_axis = "nul" input_player15_l2 = "nul" input_player15_l2_btn = "nul" input_player15_l2_axis = "nul" input_player15_r2 = "nul" input_player15_r2_btn = "nul" input_player15_r2_axis = "nul" input_player15_l3 = "nul" input_player15_l3_btn = "nul" input_player15_l3_axis = "nul" input_player15_r3 = "nul" input_player15_r3_btn = "nul" input_player15_r3_axis = "nul" input_player15_l_x_plus = "nul" input_player15_l_x_plus_btn = "nul" input_player15_l_x_plus_axis = "nul" input_player15_l_x_minus = "nul" input_player15_l_x_minus_btn = "nul" input_player15_l_x_minus_axis = "nul" input_player15_l_y_plus = "nul" input_player15_l_y_plus_btn = "nul" input_player15_l_y_plus_axis = "nul" input_player15_l_y_minus = "nul" input_player15_l_y_minus_btn = "nul" input_player15_l_y_minus_axis = "nul" input_player15_r_x_plus = "nul" input_player15_r_x_plus_btn = "nul" input_player15_r_x_plus_axis = "nul" input_player15_r_x_minus = "nul" input_player15_r_x_minus_btn = "nul" input_player15_r_x_minus_axis = "nul" input_player15_r_y_plus = "nul" input_player15_r_y_plus_btn = "nul" input_player15_r_y_plus_axis = "nul" input_player15_r_y_minus = "nul" input_player15_r_y_minus_btn = "nul" input_player15_r_y_minus_axis = "nul" input_player15_turbo = "nul" input_player15_turbo_btn = "nul" input_player15_turbo_axis = "nul" input_player16_b = "nul" input_player16_b_btn = "nul" input_player16_b_axis = "nul" input_player16_y = "nul" input_player16_y_btn = "nul" input_player16_y_axis = "nul" input_player16_select = "nul" input_player16_select_btn = "nul" input_player16_select_axis = "nul" input_player16_start = "nul" input_player16_start_btn = "nul" input_player16_start_axis = "nul" input_player16_up = "nul" input_player16_up_btn = "nul" input_player16_up_axis = "nul" input_player16_down = "nul" input_player16_down_btn = "nul" input_player16_down_axis = "nul" input_player16_left = "nul" input_player16_left_btn = "nul" input_player16_left_axis = "nul" input_player16_right = "nul" input_player16_right_btn = "nul" input_player16_right_axis = "nul" input_player16_a = "nul" input_player16_a_btn = "nul" input_player16_a_axis = "nul" input_player16_x = "nul" input_player16_x_btn = "nul" input_player16_x_axis = "nul" input_player16_l = "nul" input_player16_l_btn = "nul" input_player16_l_axis = "nul" input_player16_r = "nul" input_player16_r_btn = "nul" input_player16_r_axis = "nul" input_player16_l2 = "nul" input_player16_l2_btn = "nul" input_player16_l2_axis = "nul" input_player16_r2 = "nul" input_player16_r2_btn = "nul" input_player16_r2_axis = "nul" input_player16_l3 = "nul" input_player16_l3_btn = "nul" input_player16_l3_axis = "nul" input_player16_r3 = "nul" input_player16_r3_btn = "nul" input_player16_r3_axis = "nul" input_player16_l_x_plus = "nul" input_player16_l_x_plus_btn = "nul" input_player16_l_x_plus_axis = "nul" input_player16_l_x_minus = "nul" input_player16_l_x_minus_btn = "nul" input_player16_l_x_minus_axis = "nul" input_player16_l_y_plus = "nul" input_player16_l_y_plus_btn = "nul" input_player16_l_y_plus_axis = "nul" input_player16_l_y_minus = "nul" input_player16_l_y_minus_btn = "nul" input_player16_l_y_minus_axis = "nul" input_player16_r_x_plus = "nul" input_player16_r_x_plus_btn = "nul" input_player16_r_x_plus_axis = "nul" input_player16_r_x_minus = "nul" input_player16_r_x_minus_btn = "nul" input_player16_r_x_minus_axis = "nul" input_player16_r_y_plus = "nul" input_player16_r_y_plus_btn = "nul" input_player16_r_y_plus_axis = "nul" input_player16_r_y_minus = "nul" input_player16_r_y_minus_btn = "nul" input_player16_r_y_minus_axis = "nul" input_player16_turbo = "nul" input_player16_turbo_btn = "nul" input_player16_turbo_axis = "nul" core_specific_config = "true" libretro_log_level = "0" log_verbosity = "false" perfcnt_enable = "false" archive_mode = "0" input_dsp_config = "nul" input_dsp_config_btn = "nul" input_dsp_config_axis = "nul"
tonycrew Posted July 7, 2015 Author Posted July 7, 2015 Sorry i haven't had chance to try these yet, but as soon as i do i'll let you know
