HELP! MESS NOT WORKING ON MY HYPERSPIN
Wellvergton
I wanna play ColecoVison on HyperSpin but nothing happens, the HyperHQ paths and format is correctly configured and the games runs directly from MESS with no problems. The same problem happens on others plataforms that uses MESS to launch games as the all Atari systems, and is so strange because the MAME runs so fine.
ini configuration from ColecoVision
[exe info]
path=C:\Hyperspin\Emulators\MESS\
rompath=C:\Hyperspin\Emulators\MESS\software\coleco\
userompath=false
exe=mess.exe
romextension=col
parameters=
searchsubfolders=true
pcgame=false
winstate=HIDDEN
hyperlaunch=true
Per_Game_Modules=false
Cp_Wizard_Enabled=use_global
Skipchecks=false
Hide_Cursor=use_global
Hide_Desktop=use_global
Hide_Taskbar=use_global
CPWizard_Enabled=use_global
CPWizard_Delay=use_global
CPWizard_Params=use_global
Fade_In=use_global
Fade_Out=use_global
Fade_Color=use_global
Fade_In_Duration=use_global
Fade_Out_Duration=use_global
Fade_In_Delay=use_global
7z_Enabled=use_global
7z_Extract_Dir=use_global
7z_Delete_Temp=use_global
Keymapper_Enabled=use_global
Keymapper=use_global
MultiGame_Enabled=use_global
MultiGame_Background_Color=use_global
MultiGame_Side_Padding=use_global
MultiGame_Y_Offset=use_global
MultiGame_Image_Adjust=use_global
MultiGame_Font=use_global
MultiGame_Text_1_Options=use_global
MultiGame_Text_1_Text=use_global
MultiGame_Text_2_Options=use_global
MultiGame_Text_2_Offset=use_global
MultiGame_Use_Sound=use_global
MultiGame_Sound_Frequency=use_global
MultiGame_Exit_Effect=use_global
MultiGame_Selected_Effect=use_global
MultiGame_Use_Game_Art=use_global
MultiGame_Art_Folder=use_global
[filters]
parents_only=false
themes_only=false
wheels_only=false
roms_only=false
[themes]
use_parent_vids=true
use_parent_themes=false
animate_out_default=false
reload_backgrounds=false
[wheel]
alpha=.15
small_alpha=1
style=normal
speed=high
pin_center_width=500
horz_wheel_y=512
vert_wheel_position=right
y_rotation=center
norm_large=360
norm_small=230
vert_large=400
vert_small=240
pin_large=500
pin_small=200
horz_large=240
horz_small=150
letter_wheel_x=800
letter_wheel_y=384
text_width=700
text_font=Style4
small_text_width=260
large_text_width=400
text_stroke_size=6
text_stroke_color=0x000000
text_color1=0x00BFFD
text_color2=0xFFFFFF
text_color3=0x00BFFD
color_ratio=139
shadow_distance=0
shadow_angle=45
shadow_color=0x000000
shadow_alpha=1
shadow_blur=0
[pointer]
animated=true
x=975
y=384
[video defaults]
path=
[sounds]
game_sounds=true
wheel_click=true
[navigation]
game_jump=50
use_indexes=false
jump_timer=400
remove_info_wheel=false
remove_info_text=false
use_last_game=false
last_game=Gyruss (USA)
random_game=false
start_on_favorites=false
[special Art A]
default=false
active=true
x=512
y=720
in=0.4
out=0.4
length=3
delay=0
type=normal
start=bottom
[special Art B]
default=true
active=true
x=512
y=740
in=0.4
out=0.4
length=3
delay=0
type=fade
start=none
[special Art C]
active=true
x=512
y=384
in=0
out=0
length=3
delay=10
type=fade
start=none
[Game Text]
game_text_active=true
show_year=true
show_manf=true
show_description=true
text_color1=0xffffff
text_color2=0x0099cc
text_font=Style1
text1_textsize=26
text1_strokesize=7
text1_x=32
text1_y=610
text2_textsize=36
text2_strokesize=8
text2_x=30
text2_y=640
Video_1435873984_cut_cut.mp4
I would suggest one thing to you, and one thing to whom ever is making changes to the site.
1. go watch this video:
 https://www.youtube.com/watch?v=62u2yp2ydtk
There is a ton of useful information on how to setup MESS.
2. For the site, allow cutting and pasting.  It is super annoying trying help people out and not being able to cut and past.
E
"E"
  • 3 weeks later...
