SSF Flicking
thcdgaf
Depends.. is this happening on every game, because i get flickering on some games and not on others, so i use different versions of SSF and Yabause to get the best possible quality, like Rayman plays and looks great on SSF v0.9 Beta R3
Here you can find all Older versions of SSF
http://evilboris.sonic-cult.net/SSF/index.php?x=download
Here's a compatibility list so you can see what version to run certain games
http://evilboris.sonic-cult.net/SSF/index.php?x=satcomp
And Here Also
http://segasaturn.org/
You'd think so, but in all truth when fixing one bug sometimes that breaks something else, but if you look at the compatibilty charts it's easy to find which ones work best with which emu.
ill go back to R3 see if it does same thing besides is driver ask to install necessary on daemon tools lite 4? spd thing
im going try tackle xbox coding soon as i setup dreamcast and start doing artwork and so on the other systems so best thing to do is use different emu for each game how do you set that up in rlui
I don't us RLUI, but i'm assuming its the same as HLHQ, And you only have to do this for games that your having problems with, some games just require some settings changed.
Goto Global
Then select Emulators Tab
Click + Add Emulator
a Window will pop up in there Type in the Name of your SSF Version i do mine like this "SSF 09 R3", Then select the path to the version of SSF, then select the Module which is SSF.
Then select Sega Saturn, then Select the Games Tab, Next click on tab Alternate Emulator in there click the + Add Button this will list your games, select the game for the alternate version of SSF and a window will pop up Select the System Sega Saturn, Select the Emulator path, then select the Emu Info you just created SSF 09 R3 and so on.
It's not too difficult you will soon see it's easy when you start. I'm not very good at explaining stuff :)
