ashmck73 Posted July 9, 2015 Posted July 9, 2015 Sorry if this has been solved before but I did a search and couldn't find this issue discussed. I am running ARCulator to emulate the Acorn Archimedes and has followed numerous tutorials on how to set it up. When I run it default screen size games load fine - but when I pout it into Full Screen mode it goes into a loop of continuously switching between full screen and windowed mode - and the only thing you can do is sit back and wait for it to crash or go to task manager and end it. Just wondering if anyone else has come across this issue before or not. ---------------------------------- Regards, Ashley, the curator @ www.raspberryretro.com ----------------------------------
Libertine89 Posted November 18, 2015 Posted November 18, 2015 same problem here, did you have any luck? if not bumping for help
diskmach Posted March 16, 2016 Posted March 16, 2016 Solution is here: http://hyperspin-fe.com/forums/topic/15187-arculator-acorn-archimedes-woes/?do=findComment&comment=210914 Edited the link according to below, they have changed the links in some way since that was written. Way down the page. Hope it works for you. Nintendo 3DS wheels thread || Nintendo 3DS wheel set download Bandai Wonderswan Color wheels thread || Bandai Wonderswan wheels thread NEC PC Engine wheels COMPLETED || Nintendo Wiiware wheels COMPLETED
Bill321 Posted January 27, 2018 Posted January 27, 2018 Reposting solution as that thread is locked: On 16/03/2016 at 10:48 AM, diskmach said: I think I have found a solution to the fullscreen issue. You downloaded Arculator from the web, right? You put it in a folder, and now you have to set it to compatibility mode for Windows XP 3. Now it should be working when it comes to the fullscreen issue. After this you CAN NOT move it again, or rename the folder, or it will stop working again. You can actually see on the Window bar if this is going to work or not. See attachments. So I set up an alternate emulator that starts to the command prompt. This should fix games that didn´t auto-launch with the error "WIMP is currently active", but IRL only fixed Bubble Fair and Colour Umoria, as HamsDemo, Gorm and Ixion have various other launch problems.
Bill321 Posted January 27, 2018 Posted January 27, 2018 Ticking the 'Disable full-screen optimizations' (under Compatibility) is enough to fix the problem for me. I end up with the menu bar still showing at the top of my screen but at least it works.
