lolw00t Posted July 9, 2015 Posted July 9, 2015 So does this actually work together if i dont want to use the default keymapping ? I have tried the guide for not using winuaeloader, but i cant get that to work either
rfancella Posted July 9, 2015 Posted July 9, 2015 wOOt! If you are using the guide I wrote a while ago, go to the first page and search for "On to Game ports to configure your controller". This takes you to the section where you can map your controls. http://www.hyperspin-fe.com/topic/2702-complete-guide-for-commodore-amiga-in-hs-and-RL-using-winuae-only/page-1 Thanks, Ron On 7/9/2015 at 11:08 AM, lolw00t said: So does this actually work together if i dont want to use the default keymapping ? I have tried the guide for not using winuaeloader, but i cant get that to work either Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
lolw00t Posted July 10, 2015 Author Posted July 10, 2015 found a buggy workaround, so now i use the joy2key program.
