Hyperpin Menu Assets
citizninsane
I'm currently redesigning the menus in Hyperpin and some of the image assets appear to be missing. Specifically the wheel underlay, the hyperpin logo on top of the wheel underlay, and the "Back/Exit/Shutdown" menu. After doing some reading in the help file I found the solution to the wheel underlay but can't find any solutions for replacing/editing the hyperpin logo on top of the wheel underlay and the "Back/Exit/Shutdown" menu. I can understand why the logo may be hands off and I'm totally fine with not being able to edit it but I'd still like to be able to edit the "Back/Exit/Shutdown" menu. Has anyone been able to edit any of these assets? If so, how did you do it?
Thanks,
citiznInsane
its hardcoded into hyperpin. bill had a reason for this but i suspect when he starts to work on HP2.0 eventually he will change it alltogether
Nice Guys Finish Last, Player Finishes On Her Face....................
Thanks for the reply. That's what I had assumed but, there is a workaround for the hardcoded wheel underlay so I was hoping that there would be one for the menus as well.
In the case of the wheel underlay, HP will load the hardcoded one by default but, if there's another file in your Hyperpin/Images folder labeled "underlay.png" it will use that one instead. It would be awesome if that were the case for the main HP "Back/Exit/Shutdown" menu as well. Maybe a good add to the feature list that Dazz has started to compile.
