Sega Master System & Genesis Themes?
Rotgut
I realize the site is still undergoing updates and changes etc, but in the meantime I was wondering if anyone could point me in the direction of the Main Theme as well as the default System Theme?
I got brave and decided to start all over again using the new HS — and for some reason some of my themes are missing.  Any help is appreciated  : )
My HS cab:
I'm assuming you synced with Hypersync? Did you check the themes went to the correct folder (<hyperspin root>\media\sega genesis)? I did the same thing and my Hypersync settings seemed to be set to the default, which was c:\Hyperspin, so all the files went there, but that is not where I have hyperspin. Not sure that's what happened to you but thought it was worth a shot.
Thanks for the reply!
I have used HyperSync but with limited success.  For some reason, even though I have made many, many attempts, not all of the themes download.  I have checked the boxes, indicated the folders for them to download into, etc...  but only about 20 themes appear...  strange.  I am not a noob with HS, I manage to edit databases etc, but man, some of this stuff just throws me for a loop and I can't figure it out...
So I got to thinking...  I created a "New" folder on my desktop that I am downloading these to...  not the actual Sge Media folder...  is that the issue, you think?
They will need to end up in the Media\Sega Genesis\Themes folder for them to appear in Hyperspin.
Right, I am aware of that...  correct...  I was just using the "New" folder on the desktop as a holding station for downloads from HyperCloud...  then transferring them to their proper folders in the Media folder...
