NES and Retroarch not functioning as I would like.....
muppets4
When I run NES games in RetroArch they are playing fine. I like it to use de D3D driver and let the screen ratio 4:3 or decided by the emulator. But whenever I use HyperLaunch (Rocket) or HyperSpin to  open a rom, Retroarch uses the GL driver and the screen sits left top of my monitor. Like Retroarch uses another config file when started through HS that I cannot find.
Anyone care to help?
Nothing special. I had it setup for Genesis, that is working great. So I just pointed RL to the rom dir and choose RA as my default emulator. That's it.
  On 8/16/2015 at 1:19 AM, thcdgaf said:
You gotta change it in retroarch under drivers in settings
Sent from my LGL16C using Tapatalk
I did. As I Saïd, in RetroArch itself it is werking great.
  On 8/16/2015 at 1:20 AM, jeremy0203 said:
Did you follow the instructions to have system specific configs?
In RL I saw only a few system specific settings. Some network settings, but nothing about the video settings. Where to look? Because as mentioned above, in RA all worked.
  On 8/16/2015 at 8:20 AM, austin585 said:
Configs. You need to set things like this in the configs folder. Each system config labeled EXACTLY how Hyperspin likes them.
Take a look at my retroarch vid for tips on how to save and use configs.
 I've been following your excellent video guides! Fan of your work! I somehow missed the part in RA where you pointed out to rename the config files to system names. Did that, and all is good. Maybe I have to go to sleep earlier (-:
