Aantiik Posted August 17, 2015 Posted August 17, 2015 Set up genesis with SimplyAustin video support to run utilizing Retroarch. Fires up within rlauncher, but when I select the Genesis from main wheel within Hyperspin, system completely shuts down. I must have gooned something up, but am unsure what it might be. Aaaargh.
iNTiGOD Posted August 18, 2015 Posted August 18, 2015 Check your hyperhq settings. Have you setup rom filter options for that system? MAME High Score Tutorial For HyperSpin
Aantiik Posted August 18, 2015 Author Posted August 18, 2015 Thanks iNTiGOD. Sorted. Now I just have to sort out Retroarch. Getting a notice that error while waiting for "Retroarch ahk_class Retroarch". and that I should check to see if I have the correct module for the emulator. Also does that with NES through Retroarch. Will try to research first.
iNTiGOD Posted August 18, 2015 Posted August 18, 2015 Thanks iNTiGOD. Sorted. Now I just have to sort out Retroarch. Getting a notice that error while waiting for "Retroarch ahk_class Retroarch". and that I should check to see if I have the correct module for the emulator. Also does that with NES through Retroarch. Will try to research first. Check the module notes within rocketlauncher for retroarch. There it will mention which version of retroarch is supported and thats what you should be using. Here is a great thread on getting retroarch running within hyperspin/rocketlauncher RE versions and modules etc. Give a shout if you get stuck. MAME High Score Tutorial For HyperSpin
