PCSX2 worked, no not working?
demonseed
Hey Guys
PSSC2 worked like a charm last time I tried.. now it either goes to a black screen or runs in background somehow.. I have to hit CTRL+alt+Delete to get it to close. Not sure why it is doing this... I am also having issues with PSP as well.  Only thing I recently changed was this  Disable The maximize-minimize windows animation in windows 7 as I was having issues with xpadder.. (which no works great). Could that be the issue? I attached my log for PS2... any help greatly appreciated.
[code]
20:24:05:658 | RL |     INFO  | +N/A   | Main - RocketLauncher v1.0.1.2 (www.rlauncher.com)
20:24:05:658 | RL |  WARNING  | +0     | Main - You have "Logging_Show_Command_Window" enabled. This is only for showing errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done.
20:24:05:658 | RL |  WARNING  | +0     | Main - You have "Logging_Log_Command_Window" enabled. This is only for logging errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done.
20:24:05:668 | RL |  WARNING  | +15    | Main - You cannot use debug console and show/log a console for an emulator simultaneously. Turning off debug console to avoid errors launching.
20:24:05:758 | RL |     INFO  | +94    | Main - System Specs:
					RocketLauncher Dir: E:\Rocketlauncher
					RocketLauncher is: 32-bit
					OS: Microsoft Windows 7 Professional
					SKU: Professional
					Total Memory: 8016.31 MB
					Free Memory: 6738.36 MB
					Used Memory: 1277.949 MB
					SystemType: 64-bit
					Physical Processors: 1
					Logical Processors: 4
					GPU 1 Name: Intel(R) HD Graphics
					GPU 1 RAM: -1924.00 MB
					GPU 1 Driver Version: 9.17.10.3347
					Sound 1 Device: High Definition Audio Device
					Sound 1 Status: Enabled
					Sound 2 Device: High Definition Audio Device
					Sound 2 Status: Enabled
					OS Admin Status: Yes
					Monitor #1 (\\.\DISPLAY1): 1440x900 (1440x860 work) [Landscape] (Primary)
					Current AHK Desktop Width: 1440
					Current AHK Desktop Height: 900
					AutoHotkey Path: C:\Program Files\AutoHotkey\AutoHotkey.exe
					AHK Version: 1.1.09.04
					Unicode: No
20:24:05:768 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\RocketLauncher.exe exists
20:24:05:768 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	RocketLauncher
					FileVersion             	1.0.1.2
					LegalCopyright          	©2015 RocketLauncher
					CompanyName             	Your favorite Front End companion! Visit us @ www.rlauncher.com
					File Size:			2089472 bytes
					Created:			5/23/2015 - 11:53:13 PM
					Modified:			7/18/2015 - 9:13:34 AM
20:24:05:768 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\BinHexRW.ahk exists
20:24:05:778 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
20:24:05:778 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			4961 bytes
					Created:			5/24/2015 - 9:27:48 AM
					Modified:			6/4/2014 - 11:48:13 PM
20:24:05:788 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\BlockInput.exe exists
20:24:05:788 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription
					InternalName
					OriginalFilename
					ProductName
					File Size:			657920 bytes
					Created:			5/24/2015 - 9:26:42 AM
					Modified:			1/2/2014 - 11:27:34 PM
20:24:05:788 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\CLR.ahk exists
20:24:05:798 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
20:24:05:798 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			10586 bytes
					Created:			5/24/2015 - 9:27:29 AM
					Modified:			3/5/2013 - 10:21:59 PM
20:24:05:798 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\COM.ahk exists
20:24:05:808 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
20:24:05:808 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			26342 bytes
					Created:			5/24/2015 - 9:28:19 AM
					Modified:			3/5/2013 - 10:22:00 PM
20:24:05:808 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Control_AniGif.ahk exists
20:24:05:818 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
20:24:05:818 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5716 bytes
					Created:			5/24/2015 - 9:26:30 AM
					Modified:			4/29/2013 - 2:56:02 PM
20:24:05:818 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gdip.ahk exists
20:24:05:828 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
20:24:05:838 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			88789 bytes
					Created:			5/24/2015 - 8:02:39 AM
					Modified:			1/13/2013 - 6:07:30 PM
20:24:05:838 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gdip_alt.ahk exists
20:24:05:848 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
20:24:05:848 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5895 bytes
					Created:			5/24/2015 - 9:25:59 AM
					Modified:			6/28/2015 - 7:41:33 AM
20:24:05:858 | RL |   DEBUG1  | +16    | gdip_alt.ahk Version: 1.0.2
20:24:05:858 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gsdll32.dll exists
20:24:05:868 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			13090816 bytes
					Created:			5/24/2015 - 9:25:19 AM
					Modified:			1/6/2015 - 10:20:42 PM
20:24:05:868 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\itextsharp.dll exists
20:24:05:878 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	iTextSharp
					FileVersion             	5.4.2.0
					InternalName            	itextsharp.dll
					LegalCopyright          	Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
					OriginalFilename        	itextsharp.dll
					ProductName             	iTextSharp
					ProductVersion          	5.4.2.0
					CompanyName             	1T3XT BVBA
					File Size:			3743744 bytes
					Created:			5/24/2015 - 9:24:07 AM
					Modified:			6/14/2013 - 3:06:21 PM
20:24:05:878 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Java.ahk exists
20:24:05:888 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
20:24:05:888 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			7841 bytes
					Created:			5/24/2015 - 9:27:37 AM
					Modified:			12/24/2014 - 12:02:37 AM
20:24:05:888 | RL |   DEBUG1  | +0     | Java.ahk Version: 1.0.0
20:24:05:888 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\JSON.ahk exists
20:24:05:898 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
20:24:05:898 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			9203 bytes
					Created:			5/24/2015 - 9:26:08 AM
					Modified:			5/5/2013 - 3:22:25 PM
20:24:05:898 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Origin.ahk exists
20:24:05:928 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
20:24:05:928 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			4904 bytes
					Created:			5/24/2015 - 9:26:27 AM
					Modified:			3/22/2015 - 3:51:41 PM
20:24:05:928 | RL |   DEBUG1  | +0     | Origin.ahk Version: 1.0.2
20:24:05:938 | RL |     INFO  | +16    | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\RegRW64.ahk exists
20:24:05:948 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
20:24:05:958 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			6915 bytes
					Created:			5/24/2015 - 9:28:09 AM
					Modified:			5/8/2014 - 4:06:39 AM
20:24:05:958 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\RIni.ahk exists
20:24:05:968 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
20:24:05:968 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			67561 bytes
					Created:			5/24/2015 - 9:28:04 AM
					Modified:			6/5/2013 - 7:56:23 PM
20:24:05:978 | RL |     INFO  | +15    | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\SevenZipSharp.dll exists
20:24:05:978 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	SevenZipSharp
					FileVersion             	0.64.4841.31212
					InternalName            	SevenZipSharp.dll
					LegalCopyright          	Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
					OriginalFilename        	SevenZipSharp.dll
					ProductName             	SevenZipSharp
					ProductVersion          	0.64.4841.31212
					CompanyName             	Markovtsev Vadim
					File Size:			165888 bytes
					Created:			5/24/2015 - 9:27:30 AM
					Modified:			4/21/2013 - 12:08:10 AM
20:24:05:978 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Steam.ahk exists
20:24:05:988 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
20:24:05:988 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5347 bytes
					Created:			5/24/2015 - 9:28:20 AM
					Modified:			3/22/2015 - 3:52:25 PM
20:24:05:988 | RL |   DEBUG1  | +0     | Steam.ahk Version: 1.0.2
20:24:05:988 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\VA.ahk exists
20:24:05:998 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
20:24:05:998 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			34688 bytes
					Created:			5/24/2015 - 9:26:53 AM
					Modified:			3/1/2013 - 10:05:47 PM
20:24:05:998 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\VA_Extension.ahk exists
20:24:05:018 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
20:24:06:018 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			3833 bytes
					Created:			5/24/2015 - 9:28:38 AM
					Modified:			1/13/2015 - 9:16:56 PM
20:24:06:028 | RL |   DEBUG1  | +15    | VA_Extension.ahk Version: 1.0.1
20:24:06:028 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\7z.ahk exists
20:24:06:038 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
20:24:06:038 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			29133 bytes
					Created:			5/30/2015 - 12:47:30 AM
					Modified:			5/30/2015 - 12:47:30 AM
20:24:06:048 | RL |   DEBUG1  | +16    | 7z.ahk Version: 1.0.0
20:24:06:048 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Bezel.ahk exists
20:24:06:058 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
20:24:06:058 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			102587 bytes
					Created:			5/24/2015 - 9:28:01 AM
					Modified:			6/28/2015 - 7:41:34 AM
20:24:06:068 | RL |   DEBUG1  | +0     | Bezel.ahk Version: 1.1.2
20:24:06:068 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade.ahk exists
20:24:06:068 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
20:24:06:078 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			37875 bytes
					Created:			5/24/2015 - 9:26:50 AM
					Modified:			6/28/2015 - 7:41:37 AM
20:24:06:078 | RL |   DEBUG1  | +0     | Fade.ahk Version: 1.1.0
20:24:06:078 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade Init.ahk exists
20:24:06:088 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
20:24:06:088 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			999 bytes
					Created:			5/24/2015 - 9:27:38 AM
					Modified:			12/24/2014 - 12:21:02 AM
20:24:06:088 | RL |   DEBUG1  | +0     | Fade Init.ahk Version: 1.0.1
20:24:06:088 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade Animations.ahk exists
20:24:06:108 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
20:24:06:108 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			79822 bytes
					Created:			5/24/2015 - 9:27:41 AM
					Modified:			5/30/2015 - 10:18:25 PM
20:24:06:108 | RL |   DEBUG1  | +0     | Fade Animations.ahk Version: 1.1.6
20:24:06:118 | RL |     INFO  | +16    | CheckFile - Checking if E:\Rocketlauncher\Lib\Pause.ahk exists
20:24:06:138 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
20:24:06:138 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			392758 bytes
					Created:			5/24/2015 - 9:26:19 AM
					Modified:			7/16/2015 - 11:34:24 PM
20:24:06:148 | RL |   DEBUG1  | +16    | Pause.ahk Version: 1.1.3
20:24:06:148 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Pause Init.ahk exists
20:24:06:148 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
20:24:06:158 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			590 bytes
					Created:			5/24/2015 - 9:24:21 AM
					Modified:			4/9/2015 - 5:13:29 AM
20:24:06:158 | RL |   DEBUG1  | +0     | Pause Init.ahk Version: 1.0.2
20:24:06:158 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Keymapper.ahk exists
20:24:06:168 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
20:24:06:168 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			33453 bytes
					Created:			5/24/2015 - 9:28:11 AM
					Modified:			5/30/2015 - 10:18:27 PM
20:24:06:168 | RL |   DEBUG1  | +0     | Keymapper.ahk Version: 1.1.2
20:24:06:168 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Keymapper Init.ahk exists
20:24:06:198 | RL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Library.
20:24:06:198 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			3461 bytes
					Created:			5/24/2015 - 9:26:35 AM
					Modified:			5/30/2015 - 10:18:57 PM
20:24:06:198 | RL |   DEBUG1  | +0     | Keymapper Init.ahk Version: 1.0.4
20:24:06:198 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiGame.ahk exists
20:24:06:208 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
20:24:06:208 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			40768 bytes
					Created:			5/24/2015 - 9:24:03 AM
20:24:06:218 | RL |   DEBUG1  | +15    | MultiGame.ahk Version: 1.0.7
20:24:06:218 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiGame Init.ahk exists
20:24:06:228 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
20:24:06:228 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			161 bytes
					Created:			5/24/2015 - 9:28:32 AM
					Modified:			4/14/2013 - 2:33:19 PM
20:24:06:228 | RL |   DEBUG1  | +0     | MultiGame Init.ahk Version: 1.0.0
20:24:06:238 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiPlayer.ahk exists
20:24:06:248 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
20:24:06:248 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			58770 bytes
					Created:			5/24/2015 - 9:23:41 AM
					Modified:			7/16/2015 - 11:34:20 PM
20:24:06:258 | RL |   DEBUG1  | +15    | MultiPlayer.ahk Version: 1.0.6
20:24:06:258 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Password.ahk exists
20:24:06:258 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
20:24:06:288 | RL |   DEBUG1  | +31    | CheckFile - Attributes:
					File Size:			10040 bytes
					Created:			5/24/2015 - 9:24:18 AM
					Modified:			4/9/2015 - 5:15:55 AM
20:24:06:288 | RL |   DEBUG1  | +0     | Password.ahk Version: 1.0.1
20:24:06:288 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Rom Mapping Launch Menu.ahk exists
20:24:06:298 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
20:24:06:328 | RL |   DEBUG1  | +32    | CheckFile - Attributes:
					File Size:			73772 bytes
					Modified:			7/16/2015 - 11:34:23 PM
20:24:06:328 | RL |   DEBUG1  | +0     | Rom Mapping Launch Menu.ahk Version: 1.0.5
20:24:06:338 | RL |     INFO  | +15    | CheckFile - Checking if E:\Rocketlauncher\Lib\Shared.ahk exists
20:24:06:348 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
20:24:06:358 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			116278 bytes
					Modified:			7/23/2015 - 9:32:36 PM
20:24:06:358 | RL |   DEBUG1  | +0     | Shared.ahk Version: 1.3.1
20:24:06:358 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Statistics.ahk exists
20:24:06:368 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
20:24:06:368 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			26143 bytes
					Created:			5/24/2015 - 9:26:45 AM
					Modified:			4/9/2015 - 5:16:56 AM
20:24:06:378 | RL |   DEBUG1  | +0     | Statistics.ahk Version: 1.0.3
20:24:06:378 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Statistics Init.ahk exists
20:24:06:388 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
20:24:06:398 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			33 bytes
					Modified:			12/24/2014 - 12:23:48 AM
20:24:06:398 | RL |   DEBUG1  | +0     | Statistics Init.ahk Version: 1.0.1
20:24:06:398 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Virtual Drive.ahk exists
20:24:06:418 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
20:24:06:418 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			17072 bytes
					Created:			5/30/2015 - 12:47:33 AM
					Modified:			5/30/2015 - 12:47:33 AM
20:24:06:428 | RL |   DEBUG1  | +0     | Virtual Drive.ahk Version: 1.0.0
20:24:06:428 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\XHotkey.ahk exists
20:24:06:438 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
20:24:06:438 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			29626 bytes
					Created:			5/24/2015 - 9:28:26 AM
					Modified:			4/9/2015 - 5:17:24 AM
20:24:06:438 | RL |   DEBUG1  | +0     | XHotkey.ahk Version: 1.0.3
20:24:06:448 | RL |     INFO  | +15    | CheckFile - Checking if E:\Rocketlauncher\Lib\XHotkey Init.ahk exists
20:24:06:448 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
20:24:06:458 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			1236 bytes
					Created:			5/24/2015 - 9:26:46 AM
					Modified:			4/14/2013 - 2:33:16 PM
20:24:06:458 | RL |   DEBUG1  | +0     | XHotkey Init.ahk Version: 1.0.0
20:24:06:458 | RL |   DEBUG1  | +0     | Main - Raw CLI received: "Sony Playstation 2 Atari Anthology (USA)"
20:24:06:458 | RL |   DEBUG1  | +0     | Main - Received this dbName with no path via CLI: "Atari Anthology (USA)"
20:24:06:468 | RL |   DEBUG1  | +16    | Main - dbName: Atari Anthology (USA)
20:24:06:468 | RL |  WARNING  | +0     | Main - No frontendPath was sent via CLI. Defaulting to use HyperSpin in "..\HyperSpin\HyperSpin.exe". If you want to use a different FE Path, please make sure you set up your Front End so it sends this parameter to RocketLauncher: "-f <PATH_TO_MY_FE\FRONTEND.exe>"
20:24:06:468 | RL |     INFO  | +0     | Main - HyperSpin.exe coordinates are x25 y25 w1080 h625
20:24:06:488 | RL |  WARNING  | +16    | Main - Front End plugin was not sent via CLI. Defaulting to the "HyperSpin" Plugin. If you want to load a different Front End Plugin, please make sure you set up your Front End so it sends this parameter to RocketLauncher: "-p <PLUGINTYPE>"
20:24:06:498 | RL |     INFO  | +15    | CheckFile - Checking if E:\Rocketlauncher\Plugins\HyperSpin.plugin exists
20:24:06:508 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			8969 bytes
					Created:			5/24/2015 - 9:28:44 AM
					Modified:			5/30/2015 - 10:18:21 PM
20:24:06:508 | RL |     INFO  | +0     | Main - RocketLauncher received "Sony Playstation 2" and "Atari Anthology (USA)"
20:24:06:528 | RL |     INFO  | +15    | Main - Did not find a "E:\Rocketlauncher\Settings\Sony Playstation 2\Game Options.ini" file, skipping any game-specific options.
20:24:06:528 | RL |     INFO  | +0     | Main - Atari Anthology (USA) is using the default emulator: PCSX2
20:24:06:528 | RL |     INFO  | +0     | Main - Checking for a [PCSX2] section in E:\Rocketlauncher\Settings\Sony Playstation 2\Emulators.ini
20:24:06:538 | RL |     INFO  | +16    | Main - Checking for a [PCSX2] section in E:\Rocketlauncher\Settings\Global Emulators.ini
20:24:06:538 | RL |     INFO  | +0     | Main - Found [PCSX2] in E:\Rocketlauncher\Settings\Global Emulators.ini
20:24:06:538 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Modules\PCSX2\PCSX2.ahk exists
20:24:06:568 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			16758 bytes
					Created:			5/24/2015 - 9:26:51 AM
					Modified:			6/4/2015 - 1:57:03 PM
20:24:06:578 | RL |     INFO  | +15    | Main - CRC Check - CRC matches, this is an official unedited module.
20:24:06:578 | RL |     INFO  | +0     | Main - Atari Anthology (USA) will use module: E:\Rocketlauncher\Modules\PCSX2\PCSX2.ahk
20:24:06:598 | RL |     INFO  | +16    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
20:24:06:608 | RL |     INFO  | +15    | CheckFile - Checking if E:\Hyperspin\Emulators\Sony Playstation 2\pcsx2-gzip-multi-caching.2014-04-20.5.exe exists
20:24:06:608 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			6689280 bytes
					Created:			7/31/2015 - 12:57:30 AM
					Modified:			4/20/2014 - 9:21:43 AM
20:24:06:628 | RL |     INFO  | +16    | Main - INI Keys read
20:24:06:628 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\7z.exe exists
20:24:06:638 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					FileVersion             	9.20
					InternalName            	7z
					ProductVersion          	9.20
					File Size:			163840 bytes
					Created:			5/24/2015 - 9:26:40 AM
					Modified:			3/5/2013 - 10:21:50 PM
20:24:06:638 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\7z.dll exists
20:24:06:648 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					FileVersion             	9.20
					InternalName            	7za
					ProductVersion          	9.20
					File Size:			914432 bytes
					Created:			5/24/2015 - 9:28:28 AM
					Modified:			3/5/2013 - 10:21:49 PM
20:24:06:658 | RL |     INFO  | +0     | Main - "Atari Anthology (USA)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
20:24:06:658 | RL |     INFO  | +0     | CheckPaths - Started
20:24:06:658 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: E:\PS2GZIPPED\Atari Anthology (USA).7z
20:24:06:668 | RL |   DEBUG1  | +16    | CheckPaths - Looking for rom by name in subfolder: E:\PS2GZIPPED\Atari Anthology (USA)\Atari Anthology (USA).7z
20:24:06:668 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
20:24:06:678 | RL |   DEBUG1  | +15    | CheckPaths - Looking for rom: E:\PS2GZIPPED\Atari Anthology (USA).zip
20:24:06:688 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: E:\PS2GZIPPED\Atari Anthology (USA)\Atari Anthology (USA).zip
20:24:06:688 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
20:24:06:698 | RL |   DEBUG1  | +16    | CheckPaths - Looking for rom: E:\PS2GZIPPED\Atari Anthology (USA).rar
20:24:06:698 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: E:\PS2GZIPPED\Atari Anthology (USA)\Atari Anthology (USA).rar
20:24:06:708 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
20:24:06:708 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: E:\PS2GZIPPED\Atari Anthology (USA).cue
20:24:06:708 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: E:\PS2GZIPPED\Atari Anthology (USA)\Atari Anthology (USA).cue
20:24:06:718 | RL |   DEBUG1  | +16    | CheckPaths - Looking for rom: E:\PS2GZIPPED\Atari Anthology (USA).iso
20:24:06:718 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: E:\PS2GZIPPED\Atari Anthology (USA)\Atari Anthology (USA).iso
20:24:06:718 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
20:24:06:718 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: E:\PS2GZIPPED\Atari Anthology (USA).iso.bz2
20:24:06:728 | RL |   DEBUG1  | +15    | CheckPaths - Looking for rom by name in subfolder: E:\PS2GZIPPED\Atari Anthology (USA)\Atari Anthology (USA).iso.bz2
20:24:06:728 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
20:24:06:728 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: E:\PS2GZIPPED\Atari Anthology (USA).bin.bz2
20:24:06:728 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: E:\PS2GZIPPED\Atari Anthology (USA)\Atari Anthology (USA).bin.bz2
20:24:06:738 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
20:24:06:738 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: E:\PS2GZIPPED\Atari Anthology (USA).bin
20:24:06:738 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: E:\PS2GZIPPED\Atari Anthology (USA)\Atari Anthology (USA).bin
20:24:06:748 | RL |   DEBUG1  | +16    | CheckPaths - Looking for rom: E:\PS2GZIPPED\Atari Anthology (USA).gz
20:24:06:748 | RL |     INFO  | +0     | CheckPaths - Found rom: E:\PS2GZIPPED\Atari Anthology (USA).gz
20:24:06:748 | RL |   DEBUG1  | +0     | CheckPaths - Current romName: Atari Anthology (USA)
20:24:06:748 | RL |   DEBUG1  | +0     | CheckPaths - Current romPath: E:\PS2GZIPPED
20:24:06:758 | RL |   DEBUG1  | +15    | CheckPaths - Current romExtension: .gz
20:24:06:758 | RL |     INFO  | +0     | CheckPaths - Ended
20:24:06:758 | RL |     INFO  | +0     | BuildScript - User Variables:
					; INJECTED VARIABLES
					#NoTrayIcon
					#InstallKeybdHook
					DetectHiddenWindows, ON
					SetTitleMatchMode, 2
					SendMode, Event
					0 = 2
					pluginPath = E:\Rocketlauncher\Plugins
					pluginName = HyperSpin
					pluginExt = .plugin
					contextOnExit =
					rlMode =
					rlTitle = RocketLauncher
					rlVersion = 1.0.1.2
					rlAuthor = djvj
					rlURL = www.rlauncher.com
					langFile = E:\Rocketlauncher\Data\Language\Localization.ini
					primMonitor = 1
					frontendPID = 552
					frontendPath = E:\HyperSpin
					frontendExe = HyperSpin.exe
					frontendExt = exe
					frontendName = HyperSpin
					frontendDrive = E:
					exitEmulatorKey = Esc
					exitEmulatorKeyWait = 0
					forceHoldKey = ~Esc
					restoreFE = false
					exitScriptKey = ~q & ~s
					toggleCursorKey = ~e & ~t
					emuFullPath = E:\Hyperspin\Emulators\Sony Playstation 2\pcsx2-gzip-multi-caching.2014-04-20.5.exe
					emuPath = E:\Hyperspin\Emulators\Sony Playstation 2
					emuName = PCSX2
					emuExt = exe
					romPath = E:\PS2GZIPPED
					romPathFromIni = E:\PS2GZIPPED
					romExtension = .gz
					romExtensionOrig = .gz
					romExtensions = 7z|zip|rar|cue|iso|iso.bz2|bin.bz2|bin|gz
					executable = pcsx2-gzip-multi-caching.2014-04-20.5.exe
					systemDbName = Sony Playstation 2
					systemName = Sony Playstation 2
					dbPath =
					dbName = Atari Anthology (USA)
					dbExt =
					romName = Atari Anthology (USA)
					romMapPath =
					romMappingEnabled = false
					romMappingMenuWidth = 400
					romMappingMenuMargin = 65
					romMappingTextMargin = 15
					romMappingMenuFlagWidth = 55
					altArchiveNameOnly =
					altRomNameOnly =
					altArchiveAndRomName =
					altArchiveAndManyRomNames =
					altRomNamesOnly =
					romMapScenario =
					skipchecks = false
					romMatchExt = false
					blockInputTime = 0
					blockInputFile = E:\Rocketlauncher\Module Extensions\BlockInput.exe
					errorLevelReporting = false
					lockLaunch = false
					lockLaunchGame =
					screenRotationAngle = 0
					screenRotationAngleGame =
					logFile = E:\Rocketlauncher\RocketLauncher.log
					logLevel = 10
					logShowDebugConsole = false
					logIncludeModule = true
					logShowCommandWindow = true
					logCommandWindow = true
					rlDebugConsoleStdout =
					sysType = 64-bit
					broadcastWindowTitle =
					navUpKey = Up
					navDownKey = Down
					navLeftKey = Left
					navRightKey = Right
					navSelectKey = 1
					navP2UpKey = Numpad8
					navP2DownKey = Numpad2
					navP2LeftKey = Numpad4
					navP2RightKey = Numpad6
					navP2SelectKey = NumpadEnter
					originalWidth = 1440
					originalHeight = 900
					vdEnabled = false
					vdFullPath =
					vdUseSCSI = true
					vdDriveLetter =
					vdAddDrive = true
					servoStikEnabled = false
					ledblinkyEnabled = false
					ledblinkyFullPath =
					ledblinkyProfilePath = E:\Rocketlauncher\Profiles\LEDBlinky
					ledblinkyRLProfile = E:\Rocketlauncher\Profiles\LEDBlinky\RocketLauncher
					emuIdleShutdown = 0
					hideCursor = false
					hideEmu = false
					hideFE = false
					fadeIn = false
					fadeInDuration = 0
					fadeInDelay = 0
					fadeInExitDelay = 0
					fadeOutExitDelay = 0
					fadeOut = false
					fadeOutExtraScreen = false
					fadeOutDuration = 500
					fadeOutDelay = 0
					fadeLyrInterpolation = 7
					fadeMuteEmulator = false
					fadeUseBackgrounds = false
					fadeWidthBaseRes = 1920
					fadeHeightBaseRes = 1080
					fadeLyr1Color = FF000000
					fadeLyr2X = 0
					fadeLyr2Y = 0
					fadeLyr2W =
					fadeLyr2H =
					fadeLyr2Adjust = 1
					fadeLyr2PicPad = 0
					fadeLyr3Pos = Center
					fadeLyr3X = 450
					fadeLyr3Y = 450
					fadeLyr3W =
					fadeLyr3H =
					fadeLyr3Adjust = 1
					fadeLyr3PicPad = 0
					fadeLyr3Speed = 750
					fadeLyr3Type = imageandbar
					fadeLyr3Repeat = 1
					fadeLyr3StaticX = 0
					fadeLyr3StaticY = 870|1575
					fadeLyr3StaticW =
					fadeLyr3StaticH =
					fadeLyr3StaticAdjust = 1
					fadeLyr3StaticPicPad = 0
					fadeLyr4Adjust = 1
					fadeLyr4X = 1792|952
					fadeLyr4Y = 891|1596
					fadeLyr4W = 128
					fadeLyr4H =
					fadeLyr4Pos = No Alignment
					fadeLyr4FPS = 50
					fadeLyr4PicPad = 0
					fadeTranspGifColor = FFFFFF
					fadeBarWindow = Image
					fadeBarWindowX =
					fadeBarWindowY =
					fadeBarWindowW = 900
					fadeBarWindowH =
					fadeBarWindowR = 30
					fadeBarWindowM = 30
					fadeBarWindowHatchStyle = 8
					fadeBar = 7zOnly
					fadeBarNon7zProgressTime = 0
					fadeBarBack = true
					fadeBarBackColor = FF555555
					fadeBarH = 30
					fadeBarR = 10
					fadeBarColor = DD00BFFF
					fadeBarHatchStyle = 8
					fadeBarPercentageText = true
					fadeBarInfoText = true
					fadeBarXOffset = 0
					fadeBarYOffset = 150
					fadeRomInfoSystemName = image
					fadeRomInfoManufacturer = text with label
					fadeRomInfoGenre = disabled
					fadeRomInfoRating = image
					fadeRomInfoTextMargin = 7
					fadeStatsInfoTextMargin = 7
					fadeText1X = 0
					fadeText1Y = 0
					fadeText1 = Loading Game
					fadeText2X = 0
					fadeText2Y = 0
					fadeText3 = Loading Game
					fadeText4 = Loading Complete
					fadeFont = Bebas Neue
					fadeExtractionTime = disabled
					fadeExtractionTimeTextX = 0
					fadeExtractionTimeTextY = 0
					fadeInterruptKey =
					detectFadeErrorEnabled = true
					fadeImgPath = E:\Rocketlauncher\Media\Fade
					RLDataPath = E:\Rocketlauncher\Data
					RLMediaPath = E:\Rocketlauncher\Media
					RLErrSoundPath = E:\Rocketlauncher\Media\Sounds\Error
					modulesPath = E:\Rocketlauncher\Modules
					moduleFullName = E:\Rocketlauncher\Modules\PCSX2\PCSX2.ahk
					moduleName = PCSX2
					modulePath = E:\Rocketlauncher\Modules\PCSX2
					moduleExtension = ahk
					moduleExtensionsPath = E:\Rocketlauncher\Module Extensions
					libPath = E:\Rocketlauncher\Lib
					7zEnabled = false
					7zPath = E:\Rocketlauncher\Module Extensions\7z.exe
					7zDllPath = E:\Rocketlauncher\Module Extensions\7z.dll
					7zExtractPath = C:\Users\Lenovo\AppData\Local\Temp\HS
					7zExtractPathOrig =
					7zAttachSystemName = false
					7zDelTemp = true
					7zSounds = true
					mgEnabled = false
					mgKey = ~NumpadSub
					mgBackgroundColor = FF000000
					mgSidePadding = 0.2
					mgWidthBaseRes = 1920
					mgHeightBaseRes = 1080
					mgYOffset = 500|800
					mgFont = Arial
					mgText2Offset = 100
					mgUseSound = true
					mgSoundfreq = 300
					mgExitEffect = none
					mgSelectedEffect = rotate
					mgUseGameArt = false
					mgCandidate =
					mgOnLaunch = false
					pauseEnabled = false
					pauseKey = m
					pauseBackToMenuBarKey = n
					pauseZoomInKey = C
					pauseZoomOutKey = V
					pauseHiToTextPath = E:\Rocketlauncher\Module Extensions\HiToText.exe
					pauseSaveStateKeyCodes = {F1 down}{F1 up}
					pauseLoadStateKeyCodes = {F3 down}{F3 up}
					keymapperEnabled = true
					keymapperAHKMethod = External
					keymapper = xpadder
					xpadderFullPath = E:\Hyperspin\Utilities\Xpadder\Xpadder.exe
					joyToKeyFullPath = E:\Utilities\JoyToKey\JoyToKey.exe
					keymapperProfilePath = E:\Rocketlauncher\Profiles\xpadder
					keymapperFrontEndProfileName = RocketLauncherUI
					keymapperFrontEndProfile = xpadder
					keymapperRocketLauncherProfileEnabled = true
					joyIDsEnabled = true
					joyIDsPreferredControllersGlobal = Controller (Xbox 360 Wireless Receiver for Windows)
					joyIDsPreferredControllersSystem = use_global
					joyIDsPreferredControllersOnExit =
					CustomJoyNamesEnabled = false
					CustomJoyNames =
					rotateMethod = false
					FEProfile = E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI
					defaultProfile = E:\Rocketlauncher\Profiles\xpadder\_Default
					systemProfile = E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2
					xPadderSystemProfile = E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2\_Default
					emuProfile = E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2\PCSX2
					romProfile = E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2\Atari Anthology (USA)
					RocketLauncherProfile = E:\Rocketlauncher\Profiles\xpadder\RocketLauncher
					blankProfile = E:\Rocketlauncher\Profiles\xpadder\_Default\blank
					ahkFEProfile = E:\Rocketlauncher\Profiles\AHK\RocketLauncherUI
					ahkDefaultProfile = E:\Rocketlauncher\Profiles\AHK\_Default
					ahkSystemProfile = E:\Rocketlauncher\Profiles\AHK\Sony Playstation 2
					ahkEmuProfile = E:\Rocketlauncher\Profiles\AHK\Sony Playstation 2\PCSX2
					ahkRomProfile = E:\Rocketlauncher\Profiles\AHK\Sony Playstation 2\Atari Anthology (USA)
					ahkRocketLauncherProfile = E:\Rocketlauncher\Profiles\AHK\RocketLauncher
					bezelEnabled = false
					bezelICEnabled = false
					statisticsEnabled = true
					pressDuration = -1
					emuVolume = 1
					dxwndIni = E:\Rocketlauncher\Module Extensions\dxwnd\dxwnd.ini
					dxwndFullPath = E:\Rocketlauncher\Module Extensions\dxwnd\dxwnd.exe
					mon1O =
					pacDrivedllFile = E:\Rocketlauncher\Module Extensions\PacDrive32.dll
					userFadeAnimIniFile = E:\Rocketlauncher\Lib\User Fade Animations.ini
20:24:06:768 | RL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
20:24:06:768 | RL |     INFO  | +0     | BuildScript - Loaded Keymapper Init.ahk scripts
20:24:06:778 | RL |     INFO  | +16    | BuildScript - Loaded Statistics Init.ahk scripts
20:24:06:778 | RL |  WARNING  | +0     | BuildScript - "E:\Rocketlauncher\Lib\User Functions Init.ahk" not found
20:24:06:778 | RL |   DEBUG1  | +0     | BuildScript - Module starts on line: 2
20:24:06:778 | RL |     INFO  | +0     | BuildScript - Validating module
20:24:06:788 | RL |     INFO  | +16    | BuildScript - Validation complete
20:24:06:788 | RL |     INFO  | +0     | BuildScript - Module:
					MEmu = PCSX2
					MEmuV =  1.1.0.r5695
					MURL = http://pcsx2.net/
					MAuthor = djvj
					MVersion = 2.1.4
					MCRC = 17664BEB
					iCRC = 776E3DD9
					MID = 635038268913291718
					MSystem = "Sony PlayStation 2"
					; Notes:
					; This module has many settings that can be controlled via RocketLauncherUI
					; If you want to customize settings per game, add the game to the module's ini using RocketLauncherUI
					; If you use Daemon Tools, make sure you have a SCSI virtual drive setup. Not a DT one.
					; Tested Virtual Drive support with the cdvdGigaherz CDVD plugin. Make sure you set it to use your SCSI Virtual Drive letter.
					; Module will set the CdvdSource to Plugin or Iso depending on if you have Virtual Drive enabled or not.
					; If you have any problems closing the emulator, make sure noGUI module setting in RocketLauncherUI is set to default or false.
					; Per-game memory cards
					; This module supports per-game memory cards to prevent them from ever becoming full
					; To use this feature, set the PerGameMemoryCards to true in RocketLauncherUI
					; You need to create a default blank memory card in the path you have defined in pcsx's ini found in section [Folders], key MemoryCards.
					; Make sure one of the current memory cards are blank, then copy it in that folder and rename it to "default.ps2". The module will copy this file to a romName.ps2 for each game launched.
					; The module will only insert memory cards into Slot 1. So save your games there.
					; Linuz cdvd plugin stores its settings in the registry @ HKEY_CURRENT_USER\Software\PS2Eplugin\CDVD\CDVDiso
					; Run pcsx2 with the --help option to see current CLI parameters
					; Known CLI options not currently supported by this module:
					;  --console        	forces the program log/console to be visible
					;  --portable       	enables portable mode operation (requires admin/root access)
					;  --elf=<str>      	executes an ELF image
					;  --forcewiz       	forces PCSX2 to start the First-time Wizard
					StartModule()
					BezelGUI()
					FadeInStart()
					; PCSX2_ui.ini = default ini that contains memory card info and general settings
					If FileExist(emuPath . "\portable.ini") {	; portable install
						Log("Module - PCSX2 is operating in a portable mode")
						pcsx2IniFile := CheckFile(emuPath . "\inis\PCSX2_ui.ini", "Could not find the default PCSX2_ui.ini file. Please manually run and configure PCSX2 first so this file is created with all your default settings.")
					} Else {	; default not portable install
						Log("Module - PCSX2 is operating in a standard installation mode")
						RegRead, pcsx2IniFolder, HKCU, Software\PCSX2, SettingsFolder
						pcsx2IniFile := CheckFile(pcsx2IniFolder . "\PCSX2_ui.ini", "Could not find the default PCSX2_ui.ini file. Please manually run and configure PCSX2 first so this file is created with all your default settings.")
					; global settings
					noGUI := IniReadCheck(settingsFile, "Settings", "noGUI","false",,1)	; disables display of the gui while running games
					fullboot := IniReadCheck(settingsFile, "Settings", "fullboot","false",,1)	; disables the quick boot feature, forcing you to sit through the PS2 startup splash screens
					perGameMemCards := IniReadCheck(settingsFile, "Settings", "PerGameMemoryCards","true",,1)
					hideConsole := IniReadCheck(settingsFile, "Settings", "HideConsole","true",,1)	; Hides console window from view if it shows up
					cfgPath := IniReadCheck(settingsFile, "Settings", "cfgpath", emuPath . "\Game Configs",,1)	; specifies the config folder; applies to pcsx2 + plugins
					autoCreateINIDir := IniReadCheck(settingsFile, "Settings", "AutoCreateINIDir","false",,1)  ; Enables the module to auto-create of per game ini files and directories
					defaultINISPath := IniReadCheck(settingsFile, "Settings", "DefaultINISPath",,,1)  ; Path to default INIS folder of PCSX2.
					gs := IniReadCheck(settingsFile, "Settings|" . romName, "gs",,,1)	; override for the GS plugin
					pad := IniReadCheck(settingsFile, "Settings|" . romName, "pad",,,1)	; override for the PAD plugin
					spu2 := IniReadCheck(settingsFile, "Settings|" . romName, "spu2",,,1)	; override for the SPU2 plugin
					cdvd := IniReadCheck(settingsFile, romName, "cdvd",,,1)	; override for the CDVD plugin
					usb := IniReadCheck(settingsFile, "Settings|" . romName, "usb",,,1)	; override for the USB plugin
					fw := IniReadCheck(settingsFile, "Settings|" . romName, "fw",,,1)	; override for the FW plugin
					dev9 := IniReadCheck(settingsFile, "Settings|" . romName, "dev9",,,1)	; override for the DEV9 plugin
					vdOveride := IniReadCheck(settingsFile, romName, "VDOveride","false",,1)
					nohacks := IniReadCheck(settingsFile, romName, "nohacks","false",,1)	; disables all speedhacks
					gamefixes := IniReadCheck(settingsFile, romName, "gamefixes",,,1)	; Enable specific gamefixes for this session. Use the specified comma or pipe-delimited list of gamefixes: VuAddSub,VuClipFlag,FpuCompare,FpuMul,FpuNeg,EETiming,SkipMpeg,OPHFlag,DMABusy,VIFFIFO,VI,FMVinSoftware
					cfgPath := GetFullName(cfgPath)
					IfNotExist % cfgPath
						FileCreateDir, %cfgPath%	; create the cfg folder if it does not exist
					; Create INIs subfolder for the game if it does not exist and if AutoCreateINIDir is true
					If (autoCreateINIDir = "true") {
						perINIPath := cfgPath . "\" . romName
						Log("Module - PerGameIni - perINIPath = " . perINIPath,4)
						If !FileExist(perINIPath) {
							If (defaultINISPath != "") {
								Log("Module - PerGameIni - perINIPath does not exist.  So we will create it at " . PerINIPath,4)
								FileCreateDir, %perINIPath%
								Log("Module - PerGameIni - Now to copy the ini files from " . defaultINISPath . " to " . perINIPath . ".",4)
								FileCopy, %defaultINISPath%\*.ini, %perINIPath%
							} Else {
								Log("Module - PerGameIni - Now to copy the ini files from " . emuPath . "\inis" . " to " . perINIPath . ".",4)
								FileCopy, %emuPath%\inis\*.ini, %perINIPath%
					BezelStart()
					Fullscreen := If Fullscreen = "true" ? " --fullscreen" : ""
					noGUI := If noGUI = "true" ? " --nogui" : ""
					If (noGUI != "")
						Log("Module - noGUI is set to true, THIS MAY PREVENT PCSX2 FROM CLOSING PROPERLY. If you have any issues, set it to false or default in RocketLauncherUI.",2)
					fullboot := If fullboot = "true" ? " --fullboot" : ""
					nohacks := If nohacks = "true" ? " --nohacks" : ""
					gamefixes := If gamefixes ? " --gamefixes=" . gamefixes : ""
					gs := If gs ? " --gs=""" . GetFullName(gs) . """" : ""
					pad := If pad ? " --pad=""" . GetFullName(pad) . """" : ""
					spu2 := If spu2 ? " --spu2=""" . GetFullName(spu2) . """" : ""
					usb := If usb ? " --usb=""" . GetFullName(usb) . """" : ""
					fw := If fw ? " --fw=""" . GetFullName(fw) . """" : ""
					dev9 := If dev9 ? " --dev9=""" . GetFullName(dev9) . """" : ""
					cfgRomPath := cfgPath . "\" . romName
					cfgPathCLI := If FileExist(cfgRomPath) ? " --cfgpath=""" . GetFullName(cfgRomPath) . """" : ""
					; Specify what main ini PCSX2 should use
					If (cfgPathCLI && FileExist(cfgRomPath . "\PCSX2_ui.ini")) {
						;We can't set both cfgpath and cfg CLI switches, so if only PCSX2_ui.ini file exists we use cfg otherwise we use cfgpath
						;--cfg specifies a custom configuration file to use instead of PCSX2.ini (does not affect plugins)
						filecount := 0
						Loop, %cfgRomPath%\*.ini
							filecount++
						If (filecount == 1)
							;Only PCSX2_ui.ini found
							pcsx2IniFile := cfgRomPath . "\PCSX2_ui.ini"
							Log("Module - Found a game-specific PCSX2_ui.ini in the cfgPath. Telling PCSX2 to use this one instead: " . pcsx2IniFile)
							cfg := " --cfg=""" . pcsx2IniFile . """"
							cfgPathCLI := ""
					Log("Module - " . (If cfgPathCLI != "" ? "Setting PCSX2's config path to """ . cfgRomPath . """" : "Using PCSX2's default configuration folder: """ . emuPath . "\inis"""))
					; Memory Cards
					If perGameMemCards = true
					{	IniRead, currentMemCard1, %pcsx2IniFile%, MemoryCards, Slot1_Filename
						IniRead, memCardPath, %pcsx2IniFile%, Folders, MemoryCards	; folder where memory cards are stored
						StringLeft, memCardPathLeft, memCardPath, 3
						memCardPathIsAbsolute := If (RegExMatch(memCardPathLeft, "[a-zA-Z]:\\") && (StrLen(memCardPath) >= 3))	; this is 1 only when path looks like this "C:\"
						memCardPath := If memCardPathIsAbsolute ? memCardPath : emuPath . "\" . memCardPath	; if only a folder name is defined for the memory card path, tack on the emuPath to find the memory cards, otherwise leave the full path as is
						defaultMemCard := memCardPath . "\default.ps2"	; defining default blank memory card for slot 1
						Log("Module - Default memory card for Slot 1 should be: " . defaultMemCard,4)
						romMemCard1 := memCardPath . "\" . romName . ".ps2"	; defining name for rom's memory card for slot 1
						Log("Module - Rom memory card for Slot 1 should be: " . romMemCard1,4)
						Log("Module - Current memory card inserted in PCSX2's ini in Slot 1 is: " . currentMemCard1)
						If (currentMemCard1 != romName . ".ps2") {	; if current memory card in slot 1 does not match this romName, switch to one that does if exist or load a default one
							IfNotExist, %romMemCard1%	; first check if romName.ps2 memory card exists
								IfNotExist, %defaultMemCard%
									Log("Module - A default memory card for Slot 1 was not found in """ . memCardPath . """. Please create an empty memory card called ""default.ps2"" in this folder for per-game memory card support.",3)
								Else {
									FileCopy, %defaultMemCard%, %romMemCard1%	; create a new blank memory card for this game
									Log("Module - Creating a new blank memory card for this game in Slot 1: " . romMemCard1)
							IniWrite, %romName%.ps2, %pcsx2IniFile%, MemoryCards, Slot1_Filename	; update the ini to use this rom's card
							Log("Module - Switched memory card in Slot 1 to: " . romMemCard1)
					hideEmuObj := Object("ahk_class wxWindowClassNR",1)	; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
					pcsx2Ini := LoadProperties(pcsx2IniFile)	; load the config into memory
					dvdSource := ReadProperty(pcsx2Ini,"CdvdSource")	; read value
					; Mount the CD using a Virtual Drive
					If (vdOveride = "true")	; this allows per-game Virtual Drive support because some games boot to black when Virtual Drive is enabled
						vdEnabled := vdOveride
					If (vdEnabled = "true" && InStr(".mds|.mdx|.b5t|.b6t|.bwt|.ccd|.cue|.isz|.nrg|.cdi|.iso|.ape|.flac", romExtension)) {	; if Virtual Drive is enabled and using an image type Virtual Drive can load
						If !cdvd {
							vdCDVDPlugin := IniReadCheck(settingsFile, "Settings", "VD_CDVD_Plugin",,,1)
							If vdCDVDPlugin
								cdvd := vdCDVDPlugin
						cdvd := If cdvd ? " --cdvd=""" . GetFullName(cdvd) . """" : ""
						If dvdSource != Plugin
						{	Log("Module - CdvdSource was not set to ""Plugin"", changing it so PCSX2 can read from Virtual Drive.")
							WriteProperty(pcsx2Ini,"CdvdSource","Plugin")	; write a new value to the pcsx2IniFile
							SaveProperties(pcsx2IniFile,pcsx2Ini)	; save pcsx2IniFile to disk
						VirtualDrive("mount",romPath . "\" . romName . romExtension)
						HideEmuStart()
						errLvl := Run(executable . " --usecd" . noGUI . Fullscreen . fullboot . nohacks . gamefixes . cfg . cfgPathCLI . gs . pad . spu2 . cdvd . usb . fw . dev9, emuPath,  "UseErrorLevel")
						usedVD = 1	; tell the rest of the script to use VD methods
					} Else If romExtension in .iso,.mdf,.nrg,.bin,.img,.gz	; the only formats PCSX2 supports loading directly
						If !cdvd {
							imageCDVDPlugin := IniReadCheck(settingsFile, "Settings", "Image_CDVD_Plugin",,,1)
							If imageCDVDPlugin
								cdvd := imageCDVDPlugin
						If dvdSource != Iso
						{	Log("Module - CdvdSource was not set to ""Iso"", changing it so PCSX2 can launch this " . romExtension . " image directly")
							WriteProperty(pcsx2Ini,"CdvdSource","Iso")	; write a new value to the pcsx2IniFile
						HideEmuStart()
						errLvl := Run(executable . " """ . romPath . "\" . romName . romExtension . """ " . noGUI . Fullscreen . fullboot . nohacks . gamefixes . cfg . cfgPathCLI . gs . pad . spu2 . cdvd . usb . fw . dev9, emuPath,  "UseErrorLevel")
					} Else If romExtension in .bz2	; special case format that requires plugin mode and pcsx2 loads it directly
						If !cdvd {
							linuzCDVDPlugin := IniReadCheck(settingsFile, "Settings", "Linuz_CDVD_Plugin",,,1)
							If linuzCDVDPlugin
								cdvd := linuzCDVDPlugin
						If dvdSource != plugin
						{	Log("Module - CdvdSource was not set to ""Plugin"", changing it so PCSX2 can launch this " . romExtension . " image directly")
						oldHex := ReadReg("IsoFile")	; read last used bz2 image
						newHex := StrToHex(romPath . "\" . romName . romExtension)	; convert new bz2 image path to hex
						i := 512 - StrLen(newHex)	; get total amount of 0's to add to end of hex to make it 512 bytes
						Loop, %i%
							newHex := newHex . "0"	; add required bytes to end
						If (oldHex != newHex) {
							Log("Module - Writing new bz2 path to registry",4)
							WriteReg("IsoFile", newHex)	; write new bz2 path to registry
						HideEmuStart()
					} Else
						ScriptError("You are trying to run a rom type of """ . romExtension . """ but PCSX2 only supports loading iso|mdf|nrg|bin|img|gz directly. Please turn on Virtual Drive and/or 7z support or put ""cue"" last in your rom extensions for " . MEmu . " instead.")
					If errLvl
						ScriptError("Error launching emulator, closing script.")
					WinWait("ahk_class wxWindowClassNR",,, "PCSX2")
					WinWaitActive("ahk_class wxWindowClassNR",,, "PCSX2")
					BezelDraw()
					If hideConsole = true
						SetTimer, HideConsole, 10
					SetTitleMatchMode 2 ;Wrong window might be detected in the next loop if we only use the class name for WinGetTitle so we will add fps to it
					Loop { ; looping until pcsx2 is done loading game
						; tooltip, loop %A_Index%,0,0
						Sleep, 200
						WinGetTitle, winTitle, fps ahk_class wxWindowClassNR,, PCSX2 ; excluding the title of the GUI window so we can read the title of the game window instead
						Log("Detected Window Title is " . winTitle,4)
						StringSplit, winTextSplit, winTitle, |, %A_Space%
						If ( winTextSplit10 != "" ) ; 10th position in the array is empty until game actually starts
							break
						If A_Index > 150	; after 30 seconds, error out
							ScriptError("There was an error detecting when PCSX2 finished loading your game. Please report this so the module can be fixed.")
					HideEmuEnd()
					FadeInExit()
					If usedVD
						VirtualDrive("unmount")
					7zCleanUp()
					BezelExit()
					FadeOutExit()
					ExitModule()
					ReadReg(var1) {
						regValue := RegRead("HKEY_CURRENT_USER", "Software\PS2Eplugin\CDVD\CDVDiso", var1)
						Return %regValue%
					WriteReg(var1, var2, ValueType="REG_BINARY") {
						RegWrite(ValueType, "HKEY_CURRENT_USER", "Software\PS2Eplugin\CDVD\CDVDiso", var1, var2)
					StrToHex(S) {
						Return S="" ? "":Chr((*&S>>4)+48) Chr((x:=*&S&15)+48+(x>9)*7) StrToHex(SubStr(S,2))
					MultiGame:
						; msgbox % "selectedRom = " . selectedRom . "`nselected game = " . currentButton . "`nmgRomPath = " . mgRomPath . "`nmgRomExt = " . mgRomExt . "`nmgRomName = "  . mgRomName
						; Unmount the CD from Virtual Drive
						If usedVD
						Sleep, 500	; Required to prevent your Virtual Drive from bugging
						; Mount the CD using Virtual Drive
						If usedVD
							VirtualDrive("mount",selectedRom)
					Return
					HideConsole:
						hideConsoleTimer++
						IfWinExist, Booting ahk_class wxWindowClassNR
						{	Log("Module - HideConsole - Console window found, hiding it out of view.")
							WinSet, Transparent, 0, Booting ahk_class wxWindowClassNR,,fps:,fps:	; hiding the console window
							WinSet, Transparent, 0, PCSX2 ahk_class wxWindowClassNR,,fps:,fps:	; hiding the GUI window with the menubar
							SetTimer, HideConsole, Off
						} Else If hideConsoleTimer >= 200
					Return
					CloseProcess:
						FadeOutStart()
						WinMenuSelectItem, PCSX2 ahk_class wxWindowClassNR,, System, Pause
						WinClose("PCSX2 ahk_class wxWindowClassNR") ; sending command to the GUI window to properly close the entire emu
					Return
20:24:06:808 | RL |     INFO  | +15    | BuildScript - Loaded Multi-Player scripts
20:24:06:818 | RL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
20:24:06:818 | RL |  WARNING  | +0     | BuildScript - "E:\Rocketlauncher\Lib\User Functions.ahk" not found
20:24:06:818 | RL |     INFO  | +0     | BuildScript - Finished injecting functions into module
20:24:06:828 | RL |     INFO  | +16    | Main - Module is built
20:24:06:828 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\AutoHotkey.dll exists
20:24:06:828 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			785408 bytes
					Modified:			4/19/2013 - 7:16:32 PM
20:24:06:838 | RL |     INFO  | +15    | Main - Running module
20:24:06:838 | RL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
20:24:06:968 | MD |     INFO  | +N/A   | Module initialized
20:24:06:998 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
20:24:07:058 | MD |   DEBUG2  | +63    | Keymapper - Checking for the JoyIDs_Preferred_Controllers key  in E:\Rocketlauncher\Settings\Sony Playstation 2\Games JoyIDs.ini under section [Atari Anthology (USA)]
20:24:07:058 | MD |     INFO  | +0     | LoadPreferredControllers - Started
20:24:07:058 | MD |   DEBUG2  | +0     | LoadPreferredControllers - JoyIDsPreferredControllers = Controller (Xbox 360 Wireless Receiver for Windows)
20:24:07:058 | MD |   DEBUG2  | +0     | LoadPreferredControllers - Creating a list of currently connected joysticks
20:24:07:088 | MD |     INFO  | +31    | GetJoystickArray - Started
20:24:07:118 | MD |   DEBUG2  | +31    | GetJoystickArray - Joysticks Detected: 1000000000000000
20:24:07:148 | MD |     INFO  | +31    | GetJoystickGUID - Started
20:24:07:148 | MD |     INFO  | +0     | GetJoystickGUID - Ended and found GUID: 5041DB96E6EDE4118001444553540000
20:24:07:148 | MD |   DEBUG2  | +0     | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 5041DB96E6EDE4118001444553540000
20:24:07:158 | MD |     INFO  | +0     | GetJoystickArray - Ended
20:24:07:158 | MD |   DEBUG2  | +0     | LoadPreferredControllers - Preferred Order Sorting List -> 1.01|045e|02a1|5041DB96E6EDE4118001444553540000
20:24:07:178 | MD |     INFO  | +32    | LoadPreferredControllers - Sorting Currently Connected joysticks List to match the order of the Preferred Controller List
20:24:07:178 | MD |     INFO  | +0     | LoadPreferredControllers - Assigning the New Joystick IDs according to the preferred list for the active controllers
20:24:07:188 | MD |     INFO  | +0     | ChangeJoystickID - Started
20:24:07:188 | MD |   DEBUG2  | +0     | ChangeJoystickID - Swapping Joystick ID: 00000000 to the New Joystick ID: 00000000, for the Joystick VID_045e&PID_02a1&GUID_5041DB96E6EDE4118001444553540000
20:24:07:218 | MD |     INFO  | +31    | ChangeJoystickID - Ended
20:24:07:248 | MD |     INFO  | +31    | LoadPreferredControllers - Ended
20:24:07:248 | MD |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Utilities\Xpadder\Xpadder.exe exists
20:24:07:288 | MD |   DEBUG1  | +47    | CheckFile - Attributes:
					File Size:			1178624 bytes
					Created:			6/16/2015 - 12:46:34 PM
					Modified:			2/2/2014 - 4:10:38 PM
20:24:07:288 | MD |     INFO  | +0     | Keymapper - Loading xpadder
20:24:07:288 | MD |     INFO  | +0     | RunKeymapper - Started, using method "load"
20:24:07:288 | MD |     INFO  | +0     | GetJoystickArray - Started
20:24:07:298 | MD |   DEBUG2  | +0     | GetJoystickArray - Joysticks Detected: 1000000000000000
20:24:07:318 | MD |     INFO  | +31    | GetJoystickGUID - Started
20:24:07:318 | MD |     INFO  | +0     | GetJoystickGUID - Ended and found GUID: 5041DB96E6EDE4118001444553540000
20:24:07:318 | MD |   DEBUG2  | +0     | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 5041DB96E6EDE4118001444553540000
20:24:07:328 | MD |     INFO  | +0     | GetJoystickArray - Ended
20:24:07:328 | MD |   DEBUG2  | +0     | RunKeymapper - Found your keymapper application here: "E:\Hyperspin\Utilities\Xpadder\Xpadder.exe"
20:24:07:328 | MD |   DEBUG2  | +0     | RunKeymapper - Looping through controllers to find xpadder profiles for each one
20:24:07:328 | MD |   DEBUG2  | +0     | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "Controller (Xbox 360 Wireless Receiver for Windows)"
20:24:07:358 | MD |   DEBUG2  | +31    | GetProfile - Searching for these profiles (| delimited): E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2\Atari Anthology (USA)|E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2\PCSX2|E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2\_Default|E:\Rocketlauncher\Profiles\xpadder\_Default|E:\Rocketlauncher\Profiles\xpadder\_Default\blank
20:24:07:418 | MD |   DEBUG2  | +63    | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2\Atari Anthology (USA)\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
20:24:07:418 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2\Atari Anthology (USA)\p1.xpadderprofile
20:24:07:418 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2\PCSX2\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
20:24:07:418 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2\PCSX2\p1.xpadderprofile
20:24:07:448 | MD |   DEBUG2  | +31    | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2\_Default\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
20:24:07:448 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2\_Default\p1.xpadderprofile
20:24:07:448 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
20:24:07:448 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile
20:24:07:478 | MD |     INFO  | +31    | GetProfile - Loading Player 1 Profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile
20:24:07:478 | MD |     INFO  | +0     | RunXpadder - Started
20:24:07:478 | MD |     INFO  | +0     | Process - Exist JoyToKey.exe
20:24:07:488 | MD |   DEBUG2  | +0     | RunXpadder - Closing xpadder to refresh controllers seen by xpadder
20:24:07:488 | MD |     INFO  | +0     | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe /C
20:24:07:558 | MD |   DEBUG1  | +78    | Run - "Xpadder.exe /C" Process ID: 2564
20:24:07:558 | MD |   DEBUG2  | +0     | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in E:\Hyperspin\Utilities\Xpadder\xpadder.ini
20:24:07:558 | MD |     INFO  | +0     | Process - WaitClose Xpadder.exe 2
20:24:07:778 | MD |   DEBUG2  | +218   | RunXpadder - Reading the order in E:\Hyperspin\Utilities\Xpadder\xpadder.ini and arranging profiles found to match that order
20:24:07:778 | MD |   DEBUG2  | +0     | RunXpadder - No more controllers to be found
20:24:07:808 | MD |     INFO  | +32    | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile" /M
20:24:07:838 | MD |   DEBUG1  | +31    | Run - "Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile" /M" Process ID: 3300
20:24:07:838 | MD |     INFO  | +0     | RunXpadder - Ended
20:24:07:868 | MD |     INFO  | +31    | RunKeymapper - Ended
20:24:07:868 | MD |     INFO  | +0     | Keymapper - Loading External AHK Keymapping
20:24:07:868 | MD |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\AhkLauncher.exe exists
20:24:07:868 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	AhkLauncher
					FileVersion             	1.0.0.0
					InternalName            	AhkLauncher.exe
					LegalCopyright          	Copyright ©  2013
					OriginalFilename        	AhkLauncher.exe
					ProductName             	AhkLauncher
					ProductVersion          	1.0.0.0
					File Size:			11264 bytes
					Created:			5/24/2015 - 9:28:06 AM
					Modified:			9/4/2013 - 7:30:52 PM
20:24:07:868 | MD |     INFO  | +0     | RunAHKKeymapper - Started
20:24:07:868 | MD |   DEBUG1  | +0     | RunAHKKeymapper - Loading Atari Anthology (USA), PCSX2, Sony Playstation 2, or _Default AHK Keymapper profile
20:24:07:918 | MD |     INFO  | +47    | GetAHKProfile - Started
20:24:07:918 | MD |   DEBUG2  | +0     | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\Sony Playstation 2\Atari Anthology (USA).ahk
20:24:07:918 | MD |   DEBUG2  | +0     | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\Sony Playstation 2\PCSX2.ahk
20:24:07:918 | MD |   DEBUG2  | +0     | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\Sony Playstation 2.ahk
20:24:07:918 | MD |   DEBUG2  | +0     | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\_Default.ahk
20:24:07:918 | MD |     INFO  | +0     | GetAHKProfile - Ended and no profile found
20:24:07:948 | MD |   DEBUG1  | +31    | RunAHKKeymapper - If AhkLauncher.exe is running, need to close it first before a new profile can be loaded
20:24:07:948 | MD |     INFO  | +0     | Process - Exist AhkLauncher.exe
20:24:07:948 | MD |     INFO  | +0     | RunAHKKeymapper - Ended
20:24:07:948 | MD |     INFO  | +0     | StartModule - Started
20:24:07:948 | MD |     INFO  | +0     | StartModule - MEmu: PCSX2
					MEmuV: 1.1.0.r5695
					MURL: http://pcsx2.net/
					MAuthor: djvj
					MVersion: 2.1.4
					MCRC: 17664BEB
					iCRC: 776E3DD9
					MID:
					MSystem: "Sony PlayStation 2"
20:24:07:978 | MD |     INFO  | +31    | StartModule - You have a supported System Name for this module: "Sony Playstation 2"
20:24:07:978 | MD |     INFO  | +0     | PluginInit - Started
20:24:07:978 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating
20:24:07:978 | MD |     INFO  | +0     | CheckFile - Checking if E:\HyperSpin\Databases\Sony Playstation 2\Sony Playstation 2.xml exists
20:24:07:988 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			872745 bytes
					Created:			5/30/2015 - 2:29:08 PM
					Modified:			5/30/2015 - 2:29:32 PM
20:24:07:008 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching for a "Game Name" in the database
20:24:08:008 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Game Name" in the database!
20:24:08:008 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Name
20:24:08:008 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Name" with a value: "Atari Anthology (USA)"
20:24:08:018 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Cloneof
20:24:08:018 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Cloneof
20:24:08:018 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Manufacturer
20:24:08:018 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Manufacturer" with a value: "Digital Eclipse"
20:24:08:018 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Year
20:24:08:018 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Year" with a value: "2004"
20:24:08:038 | MD |   DEBUG1  | +32    | BuildDatabaseTable - Searching database for: Genre
20:24:08:038 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Genre" with a value: "Compilation"
20:24:08:038 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Rating
20:24:08:038 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Rating" with a value: "Other - NR (Not Rated)"
20:24:08:038 | MD |   DEBUG2  | +0     | PluginInit - GameInfo:
					GameInfo Label: Genre | GameInfo Value:
					GameInfo Label: Manufacturer | GameInfo Value:
					GameInfo Label: Name | GameInfo Value:
					GameInfo Label: Rating | GameInfo Value:
					GameInfo Label: Year | GameInfo Value:
20:24:08:048 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Ended
20:24:08:048 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
20:24:08:048 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Game Logo: E:\HyperSpin\Media\Sony Playstation 2\Images\Wheel\Atari Anthology (USA).png
20:24:08:068 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a System Logo: E:\HyperSpin\Media\Main Menu\Images\Wheel\Sony Playstation 2.png
20:24:08:068 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: Game Logo | Asset Path1:  E:\HyperSpin\Media\Sony Playstation 2\Images\Wheel\Atari Anthology (USA).png | Asset Extension1:  png | Asset Type1:  game
					Asset Label: System Logo | Asset Path1:  E:\HyperSpin\Media\Main Menu\Images\Wheel\Sony Playstation 2.png | Asset Extension1:  png | Asset Type1:  system
20:24:08:068 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
20:24:08:068 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
20:24:08:078 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Artwork1: E:\HyperSpin\Media\Sony Playstation 2\Images\Artwork1\Atari Anthology (USA).png
20:24:08:078 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Box Art: E:\HyperSpin\Media\Sony Playstation 2\Images\Artwork2\Atari Anthology (USA).png
20:24:08:078 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Cartridge: E:\HyperSpin\Media\Sony Playstation 2\Images\Artwork3\Atari Anthology (USA).png
20:24:08:118 | MD |   DEBUG1  | +47    | BuildAssetsTable - Searching for a Flyers: E:\HyperSpin\Media\Sony Playstation 2\Images\Artwork4\Atari Anthology (USA).png
20:24:08:118 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Letters: E:\HyperSpin\Media\Sony Playstation 2\Images\Letters
20:24:08:148 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a Other: E:\HyperSpin\Media\Sony Playstation 2\Images\Other
20:24:08:178 | MD |   DEBUG2  | +31    | BuildAssetsTable - Media assets found:
					Asset Label: Cartridge | Asset Path1:  E:\HyperSpin\Media\Sony Playstation 2\Images\Artwork3\Atari Anthology (USA).png | Asset Extension1:  png | Asset Type1:  game
					Asset Label: Letters | Asset Path1:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\!.png | Asset Extension1:  png | Asset Type1:  system
					Asset Label: Letters | Asset Path2:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\'.png | Asset Extension2:  png | Asset Type2:  system
					Asset Label: Letters | Asset Path3:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\(.png | Asset Extension3:  png | Asset Type3:  system
					Asset Label: Letters | Asset Path4:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\0.png | Asset Extension4:  png | Asset Type4:  system
					Asset Label: Letters | Asset Path5:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\1.png | Asset Extension5:  png | Asset Type5:  system
					Asset Label: Letters | Asset Path6:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\2.png | Asset Extension6:  png | Asset Type6:  system
					Asset Label: Letters | Asset Path7:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\3.png | Asset Extension7:  png | Asset Type7:  system
					Asset Label: Letters | Asset Path8:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\4.png | Asset Extension8:  png | Asset Type8:  system
					Asset Label: Letters | Asset Path9:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\5.png | Asset Extension9:  png | Asset Type9:  system
					Asset Label: Letters | Asset Path10:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\6.png | Asset Extension10:  png | Asset Type10:  system
					Asset Label: Letters | Asset Path11:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\7.png | Asset Extension11:  png | Asset Type11:  system
					Asset Label: Letters | Asset Path12:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\8.png | Asset Extension12:  png | Asset Type12:  system
					Asset Label: Letters | Asset Path13:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\9.png | Asset Extension13:  png | Asset Type13:  system
					Asset Label: Letters | Asset Path14:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\a.png | Asset Extension14:  png | Asset Type14:  system
					Asset Label: Letters | Asset Path15:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\b.png | Asset Extension15:  png | Asset Type15:  system
					Asset Label: Letters | Asset Path16:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\c.png | Asset Extension16:  png | Asset Type16:  system
					Asset Label: Letters | Asset Path17:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\d.png | Asset Extension17:  png | Asset Type17:  system
					Asset Label: Letters | Asset Path18:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\e.png | Asset Extension18:  png | Asset Type18:  system
					Asset Label: Letters | Asset Path19:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\f.png | Asset Extension19:  png | Asset Type19:  system
					Asset Label: Letters | Asset Path20:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\g.png | Asset Extension20:  png | Asset Type20:  system
					Asset Label: Letters | Asset Path21:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\h.png | Asset Extension21:  png | Asset Type21:  system
					Asset Label: Letters | Asset Path22:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\i.png | Asset Extension22:  png | Asset Type22:  system
					Asset Label: Letters | Asset Path23:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\j.png | Asset Extension23:  png | Asset Type23:  system
					Asset Label: Letters | Asset Path24:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\k.png | Asset Extension24:  png | Asset Type24:  system
					Asset Label: Letters | Asset Path25:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\l.png | Asset Extension25:  png | Asset Type25:  system
					Asset Label: Letters | Asset Path26:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\m.png | Asset Extension26:  png | Asset Type26:  system
					Asset Label: Letters | Asset Path27:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\n.png | Asset Extension27:  png | Asset Type27:  system
					Asset Label: Letters | Asset Path28:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\o.png | Asset Extension28:  png | Asset Type28:  system
					Asset Label: Letters | Asset Path29:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\p.png | Asset Extension29:  png | Asset Type29:  system
					Asset Label: Letters | Asset Path30:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\q.png | Asset Extension30:  png | Asset Type30:  system
					Asset Label: Letters | Asset Path31:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\r.png | Asset Extension31:  png | Asset Type31:  system
					Asset Label: Letters | Asset Path32:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\s.png | Asset Extension32:  png | Asset Type32:  system
					Asset Label: Letters | Asset Path33:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\t.png | Asset Extension33:  png | Asset Type33:  system
					Asset Label: Letters | Asset Path34:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\u.png | Asset Extension34:  png | Asset Type34:  system
					Asset Label: Letters | Asset Path35:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\v.png | Asset Extension35:  png | Asset Type35:  system
					Asset Label: Letters | Asset Path36:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\w.png | Asset Extension36:  png | Asset Type36:  system
					Asset Label: Letters | Asset Path37:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\x.png | Asset Extension37:  png | Asset Type37:  system
					Asset Label: Letters | Asset Path38:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\y.png | Asset Extension38:  png | Asset Type38:  system
					Asset Label: Letters | Asset Path39:  E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\z.png | Asset Extension39:  png | Asset Type39:  system
					Asset Label: Other | Asset Path1:  E:\Hyperspin\Media\Sony Playstation 2\Images\Other\Pointer.png | Asset Extension1:  png | Asset Type1:  system
20:24:08:228 | MD |   DEBUG1  | +47    | BuildAssetsTable - Ended
20:24:08:228 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Game Video|System Video
20:24:08:278 | MD |   DEBUG1  | +47    | BuildAssetsTable - Searching for a Game Video: E:\HyperSpin\Media\Sony Playstation 2\Video\Atari Anthology (USA).*
20:24:08:348 | RL |  WARNING  | +1514  | HyperSpin.exe was displaced to x0 y0 w1440 h900 by PCSX2. It is probably running in true fullscreen mode.
20:24:08:368 | MD |   DEBUG1  | +93    | BuildAssetsTable - Searching for a System Video: E:\HyperSpin\Media\Main Menu\Video\Sony Playstation 2.*
20:24:08:368 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: Game Video | Asset Path1:  E:\HyperSpin\Media\Sony Playstation 2\Video\Atari Anthology (USA).mp4 | Asset Extension1:  mp4 | Asset Type1:  game
					Asset Label: System Video | Asset Path1:  E:\HyperSpin\Media\Main Menu\Video\Sony Playstation 2.mp4 | Asset Extension1:  mp4 | Asset Type1:  system
20:24:08:368 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
20:24:08:368 | MD |     INFO  | +0     | PluginInit - Ended
20:24:08:378 | MD |   DEBUG1  | +0     | StartModule - Setting romName to the dbName sent to RocketLauncher: Atari Anthology (USA)
20:24:08:378 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
20:24:08:398 | MD |     INFO  | +31    | StartModule - Ended
20:24:08:398 | MD |     INFO  | +0     | Module - PCSX2 is operating in a portable mode
20:24:08:398 | MD |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Emulators\Sony Playstation 2\inis\PCSX2_ui.ini exists
20:24:08:398 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			4057 bytes
					Created:			5/30/2015 - 8:29:09 AM
					Modified:			8/17/2015 - 8:23:42 PM
20:24:08:408 | MD |     INFO  | +0     | Module Setting - [Settings] - Fullscreen: true
20:24:08:408 | MD |     INFO  | +0     | Module Setting - [Settings] - noGUI: false
20:24:08:428 | MD |     INFO  | +32    | Module Setting - [Settings] - fullboot: false
20:24:08:428 | MD |     INFO  | +0     | Module Setting - [Settings] - PerGameMemoryCards: true
20:24:08:428 | MD |     INFO  | +0     | Module Setting - [Settings] - HideConsole: true
20:24:08:438 | MD |     INFO  | +0     | Module Setting - [Settings] - cfgpath: E:\Hyperspin\Emulators\Sony Playstation 2\Game Configs
20:24:08:458 | MD |     INFO  | +31    | Module Setting - [Settings] - AutoCreateINIDir: false
20:24:08:458 | MD |     INFO  | +0     | Module Setting - [Settings] - DefaultINISPath:
20:24:08:458 | MD |     INFO  | +0     | Module Setting - [Settings] - gs:
20:24:08:458 | MD |     INFO  | +0     | Module Setting - [Atari Anthology (USA)] - gs:
20:24:08:468 | MD |     INFO  | +0     | Module Setting - [Settings] - pad:
20:24:08:468 | MD |     INFO  | +0     | Module Setting - [Atari Anthology (USA)] - pad:
20:24:08:488 | MD |     INFO  | +31    | Module Setting - [Settings] - spu2:
20:24:08:488 | MD |     INFO  | +0     | Module Setting - [Atari Anthology (USA)] - spu2:
20:24:08:488 | MD |     INFO  | +0     | Module Setting - [Atari Anthology (USA)] - cdvd:
20:24:08:498 | MD |     INFO  | +0     | Module Setting - [Settings] - usb:
20:24:08:528 | MD |     INFO  | +31    | Module Setting - [Atari Anthology (USA)] - usb:
20:24:08:558 | MD |     INFO  | +31    | Module Setting - [Settings] - fw:
20:24:08:558 | MD |     INFO  | +0     | Module Setting - [Atari Anthology (USA)] - fw:
20:24:08:588 | MD |     INFO  | +32    | Module Setting - [Settings] - dev9:
20:24:08:588 | MD |     INFO  | +0     | Module Setting - [Atari Anthology (USA)] - dev9:
20:24:08:588 | MD |     INFO  | +0     | Module Setting - [Atari Anthology (USA)] - VDOveride: false
20:24:08:588 | MD |     INFO  | +0     | Module Setting - [Atari Anthology (USA)] - nohacks: false
20:24:08:618 | MD |     INFO  | +31    | Module Setting - [Atari Anthology (USA)] - gamefixes:
20:24:08:648 | MD |     INFO  | +31    | Module - Using PCSX2's default configuration folder: "E:\Hyperspin\Emulators\Sony Playstation 2\inis"
20:24:08:648 | MD |   DEBUG1  | +0     | Module - Default memory card for Slot 1 should be: E:\Hyperspin\Emulators\Sony Playstation 2\memcards\default.ps2
20:24:08:678 | MD |   DEBUG1  | +31    | Module - Rom memory card for Slot 1 should be: E:\Hyperspin\Emulators\Sony Playstation 2\memcards\Atari Anthology (USA).ps2
20:24:08:678 | MD |     INFO  | +0     | Module - Current memory card inserted in PCSX2's ini in Slot 1 is: Alarm fur Cobra 11 - Vol. 2 (Europe).ps2
20:24:08:678 | MD |    ERROR  | +0     | Module - A default memory card for Slot 1 was not found in "E:\Hyperspin\Emulators\Sony Playstation 2\memcards". Please create an empty memory card called "default.ps2" in this folder for per-game memory card support.
20:24:08:688 | MD |     INFO  | +0     | Module - Switched memory card in Slot 1 to: E:\Hyperspin\Emulators\Sony Playstation 2\memcards\Atari Anthology (USA).ps2
20:24:08:708 | MD |   DEBUG1  | +31    | LoadProperties - Started and loading this cfg into memory: E:\Hyperspin\Emulators\Sony Playstation 2\inis\PCSX2_ui.ini
20:24:08:708 | MD |   DEBUG1  | +0     | LoadProperties - Ended
20:24:08:718 | MD |   DEBUG1  | +0     | ReadProperty - Started
20:24:08:718 | MD |     INFO  | +0     | Module Setting - [Settings] - Image_CDVD_Plugin:
20:24:08:718 | MD |     INFO  | +0     | Run - Running: E:\Hyperspin\Emulators\Sony Playstation 2\pcsx2-gzip-multi-caching.2014-04-20.5.exe "E:\PS2GZIPPED\Atari Anthology (USA).gz"  --fullscreen
20:24:08:848 | MD |     INFO  | +141   | Run - Showing Command Window to troubleshoot launching. ProcessID: 4432
20:24:09:258 | MD |   DEBUG1  | +405   | Run - "pcsx2-gzip-multi-caching.2014-04-20.5.exe "E:\PS2GZIPPED\Atari Anthology (USA).gz"  --fullscreen" Process ID: 4432
20:24:09:288 | MD |   DEBUG1  | +32    | GetActiveWindowStatus - Title: Administrator: C:\Windows\system32\cmd.exe | Class: ConsoleWindowClass | State: 0 | X: 175 | Y: 175 | Width: 677 | Height: 342 | Window HWND: 0x130222 | Process ID: 4432 | Process Path: C:\Windows\SysWOW64\cmd.exe
20:24:09:318 | MD |     INFO  | +31    | WinWait - Waiting for "ahk_class wxWindowClassNR"
20:24:11:988 | MD |   DEBUG1  | +2667  | GetActiveWindowStatus - Title: PCSX2  1.3.0-0 (git)  Apr 20 2014 | Class: wxWindowClassNR | State: 0 | X: 145 | Y: 199 | Width: 386 | Height: 251 | Window HWND: 0x1b03c2 | Process ID: 3448 | Process Path: E:\Hyperspin\Emulators\Sony Playstation 2\pcsx2-gzip-multi-caching.2014-04-20.5.exe
20:24:11:990 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: PCSX2  1.3.0-0 (git)  Apr 20 2014 | Class: wxWindowClassNR | State: 0 | X: 145 | Y: 199 | Width: 386 | Height: 251 | Window HWND: 0x1b03c2 | Process ID: 3448 | Process Path: E:\Hyperspin\Emulators\Sony Playstation 2\pcsx2-gzip-multi-caching.2014-04-20.5.exe
20:24:11:992 | MD |     INFO  | +0     | WinWaitActive - Waiting for "ahk_class wxWindowClassNR"
20:24:12:707 | MD |   DEBUG1  | +718   | GetActiveWindowStatus - Title: GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  13% | GS:  67% | VU:   0% | UI:   4% | State 0 | Class: wxWindowClassNR | State: 0 | X: 0 | Y: 0 | Width: 1440 | Height: 900 | Window HWND: 0x200220 | Process ID: 3448 | Process Path: E:\Hyperspin\Emulators\Sony Playstation 2\pcsx2-gzip-multi-caching.2014-04-20.5.exe
20:24:12:857 | MD |     INFO  | +156   | Module - HideConsole - Console window found, hiding it out of view.
20:24:13:050 | MD |   DEBUG1  | +187   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  24% | GS:  34% | VU:   0% | UI:   2% | State 0
20:24:13:313 | MD |   DEBUG1  | +265   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  27% | GS:  22% | VU:   0% | UI:   1% | State 0
20:24:13:611 | MD |   DEBUG1  | +297   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  39% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:13:877 | MD |   DEBUG1  | +265   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  39% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:14:253 | MD |   DEBUG1  | +374   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  43% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:14:514 | MD |   DEBUG1  | +266   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  48% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:14:829 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  48% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:15:093 | MD |   DEBUG1  | +265   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  48% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:15:405 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  43% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:15:681 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  46% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:15:999 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  46% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:16:244 | MD |   DEBUG1  | +249   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  46% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:16:541 | MD |   DEBUG1  | +297   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  51% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:16:791 | MD |   DEBUG1  | +249   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  51% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:17:057 | MD |   DEBUG1  | +265   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  45% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:17:371 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  45% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:17:684 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  42% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:18:025 | MD |   DEBUG1  | +344   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  31% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:18:279 | MD |   DEBUG1  | +249   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:18:638 | MD |   DEBUG1  | +359   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  37% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:18:909 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  39% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:19:258 | MD |   DEBUG1  | +343   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  39% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:19:554 | MD |   DEBUG1  | +296   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  34% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:19:854 | MD |   DEBUG1  | +297   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  39% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:20:178 | MD |   DEBUG1  | +327   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  34% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:20:447 | MD |   DEBUG1  | +266   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  34% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:20:785 | MD |   DEBUG1  | +343   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  34% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:21:172 | MD |   DEBUG1  | +390   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:21:421 | MD |   DEBUG1  | +249   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:21:719 | MD |   DEBUG1  | +297   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:21:975 | MD |   DEBUG1  | +249   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:22:316 | MD |   DEBUG1  | +344   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  37% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:22:596 | MD |   DEBUG1  | +280   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  41% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:22:905 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  40% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:23:153 | MD |   DEBUG1  | +250   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  40% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:23:442 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  44% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:23:750 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  43% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:24:032 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  42% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:24:378 | MD |   DEBUG1  | +343   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  42% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:24:659 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  43% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:24:954 | MD |   DEBUG1  | +296   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  39% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:25:216 | MD |   DEBUG1  | +265   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  39% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:25:526 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  33% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:25:780 | MD |   DEBUG1  | +250   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  33% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:26:046 | MD |   DEBUG1  | +265   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:26:355 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  42% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:26:639 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  42% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:26:960 | MD |   DEBUG1  | +327   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  37% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:27:247 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:27:552 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  31% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:27:855 | MD |   DEBUG1  | +297   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  34% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:28:131 | MD |   DEBUG1  | +280   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  39% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:28:494 | MD |   DEBUG1  | +359   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  34% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:28:730 | MD |   DEBUG1  | +234   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  31% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:29:070 | MD |   DEBUG1  | +343   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  27% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:29:351 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  27% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:29:696 | MD |   DEBUG1  | +343   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  30% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:29:970 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  33% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:30:274 | MD |   DEBUG1  | +297   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:30:588 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  37% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:30:847 | MD |   DEBUG1  | +265   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  37% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:31:128 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:31:424 | MD |   DEBUG1  | +296   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:31:741 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  37% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:32:049 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:32:357 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  33% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:32:645 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  34% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:32:937 | MD |   DEBUG1  | +296   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  33% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:33:268 | MD |   DEBUG1  | +328   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  33% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:33:545 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  31% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:33:854 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  31% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:34:108 | MD |   DEBUG1  | +249   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  35% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:34:470 | MD |   DEBUG1  | +359   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  39% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:34:811 | MD |   DEBUG1  | +343   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:35:102 | MD |   DEBUG1  | +297   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  31% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:35:406 | MD |   DEBUG1  | +296   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  27% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:35:664 | MD |   DEBUG1  | +265   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  22% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:35:946 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  28% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:36:228 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  28% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:36:538 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  34% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:36:840 | MD |   DEBUG1  | +296   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  42% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:37:181 | MD |   DEBUG1  | +344   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:37:446 | MD |   DEBUG1  | +265   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:37:791 | MD |   DEBUG1  | +343   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  30% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:38:085 | MD |   DEBUG1  | +296   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  30% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:38:365 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  25% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:38:682 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  30% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:38:927 | MD |   DEBUG1  | +250   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  30% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:39:228 | MD |   DEBUG1  | +296   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  31% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:39:487 | MD |   DEBUG1  | +265   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  33% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:39:782 | MD |   DEBUG1  | +297   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:40:064 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  37% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:40:346 | MD |   DEBUG1  | +280   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  37% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:40:630 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  37% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:40:936 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  37% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:41:267 | MD |   DEBUG1  | +328   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  37% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:41:599 | MD |   DEBUG1  | +327   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:41:880 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:42:251 | MD |   DEBUG1  | +375   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  30% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:42:536 | MD |   DEBUG1  | +280   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:42:828 | MD |   DEBUG1  | +297   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  30% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:43:144 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  39% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:43:420 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  39% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:43:737 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  34% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:43:997 | MD |   DEBUG1  | +265   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  34% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:44:323 | MD |   DEBUG1  | +327   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  31% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:44:576 | MD |   DEBUG1  | +250   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  33% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:44:868 | MD |   DEBUG1  | +296   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  39% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:45:201 | MD |   DEBUG1  | +328   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  37% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:45:545 | MD |   DEBUG1  | +343   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:45:825 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:46:135 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  33% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:46:465 | MD |   DEBUG1  | +328   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  37% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:46:762 | MD |   DEBUG1  | +296   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:47:058 | MD |   DEBUG1  | +296   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:47:319 | MD |   DEBUG1  | +266   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  31% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:47:638 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:47:914 | MD |   DEBUG1  | +280   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:48:263 | MD |   DEBUG1  | +344   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  34% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:48:553 | MD |   DEBUG1  | +296   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  37% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:48:824 | MD |   DEBUG1  | +265   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  34% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:49:145 | MD |   DEBUG1  | +328   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  30% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:49:429 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  28% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:49:743 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  33% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:50:033 | MD |   DEBUG1  | +296   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  34% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:50:368 | MD |   DEBUG1  | +328   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  33% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:50:630 | MD |   DEBUG1  | +265   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  33% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:50:906 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  28% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:51:209 | MD |   DEBUG1  | +296   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  33% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:51:499 | MD |   DEBUG1  | +296   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:51:784 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  34% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:52:061 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  34% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:52:359 | MD |   DEBUG1  | +296   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  34% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:52:656 | MD |   DEBUG1  | +297   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:52:964 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  37% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:53:217 | MD |   DEBUG1  | +249   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  39% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:53:470 | MD |   DEBUG1  | +250   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  34% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:53:782 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  37% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:54:044 | MD |   DEBUG1  | +265   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  37% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:54:359 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  39% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:54:636 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  43% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:55:013 | MD |   DEBUG1  | +374   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  43% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:55:295 | MD |   DEBUG1  | +281   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  43% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:55:610 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  37% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:55:900 | MD |   DEBUG1  | +297   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:56:200 | MD |   DEBUG1  | +296   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  28% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:56:498 | MD |   DEBUG1  | +296   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  28% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:56:818 | MD |   DEBUG1  | +328   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  34% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:57:150 | MD |   DEBUG1  | +328   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  31% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:57:398 | MD |   DEBUG1  | +249   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  39% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:57:710 | MD |   DEBUG1  | +312   | Detected Window Title is GSdx | Progressive (field) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   0% | State 0
20:24:57:777 | MD |   DEBUG2  | +63    | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
20:24:57:872 | MD |   DEBUG2  | +93    | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc"
20:24:57:978 | MD |   DEBUG2  | +109   | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
20:24:58:042 | MD |   DEBUG2  | +63    | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseError"
20:24:58:523 | MD |   DEBUG1  | +483   | ScriptError - Playing error sound: error12.mp3
20:25:07:712 | MD |   DEBUG2  | +9189  | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
20:25:07:801 | MD |   DEBUG2  | +94    | XHotkeyTableCreation - Disabling "CloseError" standard Hotkey method for key(s): "~Esc"
20:25:07:925 | MD |   DEBUG2  | +124   | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
20:25:07:994 | MD |   DEBUG2  | +63    | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
20:25:08:118 | MD |    ERROR  | +125   | ScriptError - There was an error detecting when PCSX2 finished loading your game. Please report this so the module can be fixed.
20:25:08:208 | MD |     INFO  | +93    | ExitModule - Started
20:25:08:304 | MD |     INFO  | +94    | Starting Updating Statistics:
20:25:08:414 | MD |   DEBUG2  | +109   | Total Elapsed Time in Pause in seconds: 0
20:25:08:492 | MD |   DEBUG2  | +78    | gameSectionStartTime:5499596
20:25:08:586 | MD |   DEBUG2  | +94    | ElapsedTime:60
20:25:08:681 | MD |   DEBUG2  | +93    | Statistics cleared game name: Atari Anthology
20:25:08:809 | MD |   DEBUG2  | +125   | Loaded game statistics from ini files:
					Number_of_Times_Played: 0
					Last_Time_Played: 0
					Average_Time_Played: 0
					Total_Time_Played: 0
					System_Total_Played_Time: 4056
					Total_Global_Played_Time: 27607
20:25:08:941 | MD |   DEBUG2  | +140   | Updated Statistics: Number_of_Times_Played: 1
					Last_Time_Played: Monday August 17, 2015 08:24:08 PM
					Average_Time_Played: 60
					Total_Time_Played: 60
					System_Total_Played_Time: 4116
					Total_Global_Played_Time: 27667
20:25:09:041 | MD |     INFO  | +94    | Game section statistics updated.
20:25:09:046 | MD |     INFO  | +0     | RunKeymapper - Started, using method "unload"
20:25:09:066 | MD |     INFO  | +31    | GetJoystickArray - Started
20:25:09:116 | MD |   DEBUG2  | +47    | GetJoystickArray - Joysticks Detected: 1000000000000000
20:25:09:225 | MD |     INFO  | +109   | GetJoystickGUID - Started
20:25:09:319 | MD |     INFO  | +94    | GetJoystickGUID - Ended and found GUID: 5041DB96E6EDE4118001444553540000
20:25:09:458 | MD |   DEBUG2  | +140   | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 5041DB96E6EDE4118001444553540000
20:25:09:548 | MD |     INFO  | +94    | GetJoystickArray - Ended
20:25:09:692 | MD |   DEBUG2  | +140   | RunKeymapper - Looping through controllers to find xpadder profiles for each one
20:25:09:772 | MD |   DEBUG2  | +78    | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "Controller (Xbox 360 Wireless Receiver for Windows)"
20:25:09:774 | MD |   DEBUG2  | +0     | GetProfile - Searching for these profiles (| delimited): E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI|E:\Rocketlauncher\Profiles\xpadder\_Default\blank
20:25:09:776 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
20:25:09:778 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile
20:25:09:780 | MD |     INFO  | +0     | GetProfile - Loading Player 1 Profile -> E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile
20:25:09:801 | MD |     INFO  | +31    | RunXpadder - Started
20:25:09:861 | MD |     INFO  | +63    | Process - Exist JoyToKey.exe
20:25:09:874 | MD |   DEBUG2  | +0     | RunXpadder - Closing xpadder to refresh controllers seen by xpadder
20:25:09:896 | MD |     INFO  | +31    | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe /C
20:25:09:956 | MD |   DEBUG1  | +62    | Run - "Xpadder.exe /C" Process ID: 664
20:25:09:961 | MD |   DEBUG2  | +0     | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in E:\Hyperspin\Utilities\Xpadder\xpadder.ini
20:25:09:966 | MD |     INFO  | +0     | Process - WaitClose Xpadder.exe 2
20:25:10:456 | MD |   DEBUG2  | +500   | RunXpadder - Reading the order in E:\Hyperspin\Utilities\Xpadder\xpadder.ini and arranging profiles found to match that order
20:25:10:462 | MD |   DEBUG2  | +0     | RunXpadder - No more controllers to be found
20:25:10:464 | MD |     INFO  | +0     | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile" /M
20:25:10:503 | MD |   DEBUG1  | +46    | Run - "Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile" /M" Process ID: 1344
20:25:10:535 | MD |     INFO  | +32    | RunXpadder - Ended
20:25:10:537 | MD |     INFO  | +0     | RunKeymapper - Ended
20:25:10:539 | MD |     INFO  | +0     | RunAHKKeymapper - Started
20:25:10:540 | MD |   DEBUG1  | +0     | RunAHKKeymapper - Unloading AhkLauncher
20:25:10:542 | MD |   DEBUG1  | +0     | RunAHKKeymapper - If AhkLauncher.exe is running, need to close it first before a new profile can be loaded
20:25:10:543 | MD |     INFO  | +0     | Process - Exist AhkLauncher.exe
20:25:10:566 | MD |     INFO  | +31    | RunAHKKeymapper - Ended
20:25:10:568 | MD |   DEBUG1  | +0     | ExitModule - Closing command window: cmd.exe PID: 4432
20:25:10:570 | MD |     INFO  | +0     | Process - Close cmd.exe
20:25:10:573 | MD |     INFO  | +0     | ExitModule - Ended
20:25:10:574 | MD |     INFO  | +0     | End of Module Logs
20:25:10:608 | RL |     INFO  | +62260 | Main - Module ended, exiting RocketLauncher normally
20:25:10:630 | RL |     INFO  | +15    | ExitScript - Started
20:25:10:638 | RL |   DEBUG1  | +0     | ExitScript - Checking what application is currently in focus.
20:25:10:671 | RL |   DEBUG1  | +47    | ExitScript - GSdx | Interlaced (frame) | Limiter: Normal | fps:   0.00 | EE:  36% | GS:   0% | VU:   0% | UI:   4% | State 0 is currently active. Putting focus back on HyperSpin.exe
20:25:10:801 | RL |   DEBUG1  | +125   | ExitScript - Took 1 attempts to put HyperSpin.exe back in focus.
20:25:10:806 | RL |     INFO  | +0     | SystemCursor - Restoring mouse cursor
20:25:10:809 | RL |     INFO  | +0     | ExitScript - Ended
[/code]
Yes I will try that but everything else works great..(psp and ps2 not working) psp has to do with new retroarch or something. This ps2 thing I am not sure and was hopin someone could see problem in log? The log is like Chinese to me.
I saw that error..no idea what the error is.. As I said It all worked about a week ago. Maybe someone will recognize the error.
Ok I have been doing some more testing. The version I am using is 1.3 with GZIp support. I is not working, usually goes to a black screen, however when I tried official .,9 it ran games?  Either my GZIP's are not correct or there is a problem with the support?
Solved my issue with newer build. For the error I had to edit the PCSX2 module..  in rockelauncher/modules..
changed  ahk_class wxwindowclassnr
to
ahk_class wcWindowNR
Only one minor issue now.. PCSX2 small window pops up on load and exit??
Also sometimes it wont load and says an error about could not tell when rom was going to load?
