demonseed Posted August 23, 2015 Posted August 23, 2015 so I have had issues with PCSX2 and Gzip.. finally got it running and not crashing, but still having two issues. After I run a couple games, when I exit PCSX2 it is not returning to HS properly. I get my desktop showing, no task bar, but can hear HS running. It is running just not getting focus. The other issue is, when I click to load a game, PCSX2 shows windowed then loads... does this on exit too.... This emulator has been a battle.. if you can help thanks so much. Thanksjim Ok So ..... I tried changing the times of 150 and 30 it did not work.. so then I tried deleting the above IF.... and it worked BUT after usually four games.. when PCSX2 goes back to HS, HS is running but not maximixed... so I see the desktop but hear HS.... I am not sure if its the code I deleted or something else? It worked fine Until Jeremy Super cross then it did not return properly Code: 13:53:58:944 | RL | INFO | +N/A | Main - RocketLauncher v1.0.1.2 (www.rlauncher.com) 13:53:58:944 | RL | WARNING | +0 | Main - You have "Logging_Show_Command_Window" enabled. This is only for showing errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done. 13:53:58:954 | RL | WARNING | +16 | Main - You have "Logging_Log_Command_Window" enabled. This is only for logging errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done. 13:53:58:954 | RL | WARNING | +0 | Main - You cannot use debug console and show/log a console for an emulator simultaneously. Turning off debug console to avoid errors launching. 13:53:59:034 | RL | INFO | +78 | Main - System Specs: RocketLauncher Dir: E:\Rocketlauncher RocketLauncher is: 32-bit OS: Microsoft Windows 7 Professional SKU: Professional Total Memory: 8016.31 MB Free Memory: 6635.36 MB Used Memory: 1380.957 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 4 GPU 1 Name: Intel(R) HD Graphics GPU 1 RAM: -1924.00 MB GPU 1 Driver Version: 9.17.10.3347 Sound 1 Device: High Definition Audio Device Sound 1 Status: Enabled Sound 2 Device: High Definition Audio Device Sound 2 Status: Enabled OS Language: English_United_States OS Admin Status: Yes Monitor #1 (\\.\DISPLAY1): 1440x900 (1440x860 work) [Landscape] (Primary) Current AHK Desktop Width: 1440 Current AHK Desktop Height: 900 AutoHotkey Path: C:\Program Files\AutoHotkey\AutoHotkey.exe AHK Version: 1.1.09.04 Unicode: No 13:53:59:034 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\RocketLauncher.exe exists 13:53:59:034 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\BinHexRW.ahk exists 13:53:59:044 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:044 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\BlockInput.exe exists 13:53:59:054 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\CLR.ahk exists 13:53:59:054 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 13:53:59:054 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\COM.ahk exists 13:53:59:074 | RL | DEBUG1 | +31 | CRC Check - CRC matches, this is an official unedited Extension. 13:53:59:074 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Control_AniGif.ahk exists 13:53:59:084 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 13:53:59:084 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gdip.ahk exists 13:53:59:094 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Extension. 13:53:59:104 | RL | INFO | +16 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gdip_alt.ahk exists 13:53:59:114 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:114 | RL | DEBUG1 | +0 | gdip_alt.ahk Version: 1.0.2 13:53:59:114 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gsdll32.dll exists 13:53:59:124 | RL | INFO | +16 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\itextsharp.dll exists 13:53:59:124 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Java.ahk exists 13:53:59:124 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:134 | RL | DEBUG1 | +15 | Java.ahk Version: 1.0.0 13:53:59:134 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\JSON.ahk exists 13:53:59:134 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 13:53:59:134 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Origin.ahk exists 13:53:59:144 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:144 | RL | DEBUG1 | +0 | Origin.ahk Version: 1.0.2 13:53:59:144 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\RegRW64.ahk exists 13:53:59:154 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 13:53:59:154 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\RIni.ahk exists 13:53:59:164 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 13:53:59:174 | RL | INFO | +15 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\SevenZipSharp.dll exists 13:53:59:174 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Steam.ahk exists 13:53:59:184 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:184 | RL | DEBUG1 | +0 | Steam.ahk Version: 1.0.2 13:53:59:194 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\VA.ahk exists 13:53:59:194 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 13:53:59:204 | RL | INFO | +16 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\VA_Extension.ahk exists 13:53:59:204 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:204 | RL | DEBUG1 | +0 | VA_Extension.ahk Version: 1.0.1 13:53:59:204 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\7z.ahk exists 13:53:59:214 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:224 | RL | DEBUG1 | +0 | 7z.ahk Version: 1.0.0 13:53:59:224 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Bezel.ahk exists 13:53:59:234 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:234 | RL | DEBUG1 | +0 | Bezel.ahk Version: 1.1.2 13:53:59:244 | RL | INFO | +15 | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade.ahk exists 13:53:59:254 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:254 | RL | DEBUG1 | +0 | Fade.ahk Version: 1.1.0 13:53:59:264 | RL | INFO | +16 | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade Init.ahk exists 13:53:59:274 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:274 | RL | DEBUG1 | +0 | Fade Init.ahk Version: 1.0.1 13:53:59:274 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade Animations.ahk exists 13:53:59:294 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:294 | RL | DEBUG1 | +0 | Fade Animations.ahk Version: 1.1.6 13:53:59:304 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Pause.ahk exists 13:53:59:314 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:334 | RL | DEBUG1 | +15 | Pause.ahk Version: 1.1.3 13:53:59:334 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Pause Init.ahk exists 13:53:59:344 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:344 | RL | DEBUG1 | +0 | Pause Init.ahk Version: 1.0.2 13:53:59:344 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Keymapper.ahk exists 13:53:59:354 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:354 | RL | DEBUG1 | +0 | Keymapper.ahk Version: 1.1.2 13:53:59:364 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Keymapper Init.ahk exists 13:53:59:374 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:374 | RL | DEBUG1 | +0 | Keymapper Init.ahk Version: 1.0.4 13:53:59:374 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiGame.ahk exists 13:53:59:384 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:384 | RL | DEBUG1 | +0 | MultiGame.ahk Version: 1.0.7 13:53:59:394 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiGame Init.ahk exists 13:53:59:394 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:404 | RL | DEBUG1 | +15 | MultiGame Init.ahk Version: 1.0.0 13:53:59:404 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiPlayer.ahk exists 13:53:59:404 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:414 | RL | DEBUG1 | +16 | MultiPlayer.ahk Version: 1.0.6 13:53:59:414 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Password.ahk exists 13:53:59:424 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:434 | RL | DEBUG1 | +16 | Password.ahk Version: 1.0.1 13:53:59:434 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Rom Mapping Launch Menu.ahk exists 13:53:59:444 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:454 | RL | DEBUG1 | +15 | Rom Mapping Launch Menu.ahk Version: 1.0.5 13:53:59:454 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Shared.ahk exists 13:53:59:474 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:484 | RL | DEBUG1 | +15 | Shared.ahk Version: 1.3.1 13:53:59:484 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Statistics.ahk exists 13:53:59:494 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:504 | RL | DEBUG1 | +0 | Statistics.ahk Version: 1.0.3 13:53:59:504 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Statistics Init.ahk exists 13:53:59:504 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:514 | RL | DEBUG1 | +16 | Statistics Init.ahk Version: 1.0.1 13:53:59:514 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Virtual Drive.ahk exists 13:53:59:514 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:524 | RL | DEBUG1 | +15 | Virtual Drive.ahk Version: 1.0.0 13:53:59:524 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\XHotkey.ahk exists 13:53:59:524 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:534 | RL | DEBUG1 | +0 | XHotkey.ahk Version: 1.0.3 13:53:59:534 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\XHotkey Init.ahk exists 13:53:59:534 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 13:53:59:544 | RL | DEBUG1 | +16 | XHotkey Init.ahk Version: 1.0.0 13:53:59:544 | RL | DEBUG1 | +0 | Main - Raw CLI received: "Sony Playstation 2 Jeremy McGrath Supercross World (USA)" 13:53:59:544 | RL | DEBUG1 | +0 | Main - Received this dbName with no path via CLI: "Jeremy McGrath Supercross World (USA)" 13:53:59:544 | RL | DEBUG1 | +0 | Main - dbName: Jeremy McGrath Supercross World (USA) 13:53:59:554 | RL | WARNING | +0 | Main - No frontendPath was sent via CLI. Defaulting to use HyperSpin in "..\HyperSpin\HyperSpin.exe". If you want to use a different FE Path, please make sure you set up your Front End so it sends this parameter to RocketLauncher: "-f <PATH_TO_MY_FE\FRONTEND.exe>" 13:53:59:564 | RL | INFO | +15 | Main - HyperSpin.exe coordinates are x100 y100 w1080 h625 13:53:59:564 | RL | WARNING | +0 | Main - Front End plugin was not sent via CLI. Defaulting to the "HyperSpin" Plugin. If you want to load a different Front End Plugin, please make sure you set up your Front End so it sends this parameter to RocketLauncher: "-p <PLUGINTYPE>" 13:53:59:574 | RL | INFO | +16 | CheckFile - Checking if E:\Rocketlauncher\Plugins\HyperSpin.plugin exists 13:53:59:574 | RL | INFO | +0 | Main - RocketLauncher received "Sony Playstation 2" and "Jeremy McGrath Supercross World (USA)" 13:53:59:584 | RL | INFO | +0 | Main - Did not find a "E:\Rocketlauncher\Settings\Sony Playstation 2\Game Options.ini" file, skipping any game-specific options. 13:53:59:584 | RL | INFO | +0 | Main - Jeremy McGrath Supercross World (USA) is using the default emulator: PCSX2 13:53:59:584 | RL | INFO | +0 | Main - Checking for a [PCSX2] section in E:\Rocketlauncher\Settings\Sony Playstation 2\Emulators.ini 13:53:59:604 | RL | INFO | +31 | Main - Checking for a [PCSX2] section in E:\Rocketlauncher\Settings\Global Emulators.ini 13:53:59:604 | RL | INFO | +0 | Main - Found [PCSX2] in E:\Rocketlauncher\Settings\Global Emulators.ini 13:53:59:604 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Modules\PCSX2\PCSX2.ahk exists 13:53:59:604 | RL | WARNING | +0 | Main - CRC Check - CRC does not match official module and will not be supported. Continue using at your own risk. 13:53:59:614 | RL | INFO | +0 | Main - Jeremy McGrath Supercross World (USA) will use module: E:\Rocketlauncher\Modules\PCSX2\PCSX2.ahk 13:53:59:624 | RL | INFO | +16 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 13:53:59:634 | RL | INFO | +15 | CheckFile - Checking if E:\Hyperspin\Emulators\Sony Playstation 2\pcsx2.exe exists 13:53:59:634 | RL | INFO | +0 | Main - INI Keys read 13:53:59:644 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\7z.exe exists 13:53:59:644 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\7z.dll exists 13:53:59:644 | RL | INFO | +0 | Main - "Jeremy McGrath Supercross World (USA)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side 13:53:59:644 | RL | INFO | +0 | CheckPaths - Started 13:53:59:654 | RL | DEBUG1 | +16 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms\Jeremy McGrath Supercross World (USA).7z 13:53:59:654 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms\Jeremy McGrath Supercross World (USA)\Jeremy McGrath Supercross World (USA).7z 13:53:59:654 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 13:53:59:664 | RL | DEBUG1 | +16 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms\Jeremy McGrath Supercross World (USA).zip 13:53:59:664 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms\Jeremy McGrath Supercross World (USA)\Jeremy McGrath Supercross World (USA).zip 13:53:59:664 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 13:53:59:664 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms\Jeremy McGrath Supercross World (USA).rar 13:53:59:664 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms\Jeremy McGrath Supercross World (USA)\Jeremy McGrath Supercross World (USA).rar 13:53:59:674 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 13:53:59:674 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms\Jeremy McGrath Supercross World (USA).cue 13:53:59:674 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms\Jeremy McGrath Supercross World (USA)\Jeremy McGrath Supercross World (USA).cue 13:53:59:674 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 13:53:59:684 | RL | DEBUG1 | +15 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms\Jeremy McGrath Supercross World (USA).iso 13:53:59:684 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms\Jeremy McGrath Supercross World (USA)\Jeremy McGrath Supercross World (USA).iso 13:53:59:684 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 13:53:59:684 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms\Jeremy McGrath Supercross World (USA).iso.bz2 13:53:59:684 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms\Jeremy McGrath Supercross World (USA)\Jeremy McGrath Supercross World (USA).iso.bz2 13:53:59:694 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 13:53:59:694 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms\Jeremy McGrath Supercross World (USA).bin.bz2 13:53:59:694 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms\Jeremy McGrath Supercross World (USA)\Jeremy McGrath Supercross World (USA).bin.bz2 13:53:59:694 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 13:53:59:704 | RL | DEBUG1 | +16 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms\Jeremy McGrath Supercross World (USA).bin 13:53:59:704 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms\Jeremy McGrath Supercross World (USA)\Jeremy McGrath Supercross World (USA).bin 13:53:59:704 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 13:53:59:704 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms\Jeremy McGrath Supercross World (USA).gz 13:53:59:724 | RL | INFO | +15 | CheckPaths - Found rom: E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms\Jeremy McGrath Supercross World (USA).gz 13:53:59:724 | RL | DEBUG1 | +0 | CheckPaths - Current romName: Jeremy McGrath Supercross World (USA) 13:53:59:724 | RL | DEBUG1 | +0 | CheckPaths - Current romPath: E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms 13:53:59:724 | RL | DEBUG1 | +0 | CheckPaths - Current romExtension: .gz 13:53:59:724 | RL | INFO | +0 | CheckPaths - Ended 13:53:59:734 | RL | INFO | +16 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook DetectHiddenWindows, ON SetTitleMatchMode, 2 SendMode, Event 0 = 2 pluginPath = E:\Rocketlauncher\Plugins pluginName = HyperSpin pluginExt = .plugin contextOnExit = rlMode = rlTitle = RocketLauncher rlVersion = 1.0.1.2 rlAuthor = djvj rlURL = www.rlauncher.com langFile = E:\Rocketlauncher\Data\Language\Localization.ini primMonitor = 1 frontendPID = 2548 frontendPath = E:\HyperSpin frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = E: exitEmulatorKey = ~Esc exitEmulatorKeyWait = 0 forceHoldKey = ~Esc restoreFE = false exitScriptKey = ~q & ~s toggleCursorKey = ~e & ~t emuFullPath = E:\Hyperspin\Emulators\Sony Playstation 2\pcsx2.exe emuPath = E:\Hyperspin\Emulators\Sony Playstation 2 emuName = PCSX2 emuExt = exe romPath = E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms romPathFromIni = E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms romExtension = .gz romExtensionOrig = .gz romExtensions = 7z|zip|rar|cue|iso|iso.bz2|bin.bz2|bin|gz executable = pcsx2.exe systemDbName = Sony Playstation 2 systemName = Sony Playstation 2 dbPath = dbName = Jeremy McGrath Supercross World (USA) dbExt = romName = Jeremy McGrath Supercross World (USA) romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfGamesByScreen = 7 romMappingMenuWidth = 400 romMappingMenuMargin = 65 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s60 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 7 romMappingTextMargin = 15 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s90 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s22 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s22 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 55 romMappingMenuFlagSeparation = 7 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false altArchiveNameOnly = altRomNameOnly = altArchiveAndRomName = altArchiveAndManyRomNames = altRomNamesOnly = romMapScenario = skipchecks = false romMatchExt = false blockInputTime = 0 blockInputFile = E:\Rocketlauncher\Module Extensions\BlockInput.exe errorLevelReporting = false lockLaunch = false lockLaunchGame = screenRotationAngle = 0 screenRotationAngleGame = logFile = E:\Rocketlauncher\RocketLauncher.log logLabel := [" INFO"," WARNING"," ERROR"," DEBUG1"," DEBUG2"] logLevel = 10 logShowDebugConsole = false logIncludeModule = true logIncludeFileProperties = false logShowCommandWindow = true logCommandWindow = true rlDebugConsoleStdout = sysLang = English_United_States sysType = 64-bit broadcastWindowTitle = navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = 1 navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = NumpadEnter originalWidth = 1440 originalHeight = 900 vdEnabled = false vdFullPath = vdUseSCSI = true vdDriveLetter = vdAddDrive = true servoStikEnabled = false ledblinkyEnabled = false ledblinkyFullPath = ledblinkyProfilePath = E:\Rocketlauncher\Profiles\LEDBlinky ledblinkyRLProfile = E:\Rocketlauncher\Profiles\LEDBlinky\RocketLauncher emuIdleShutdown = 0 launchPasswordHash = UpUpDownDownLeftRightLeftRight hideCursor = false hideEmu = false hideFE = false fadeIn = false fadeInDuration = 0 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = fadeOut = false fadeOutExtraScreen = true fadeOutDuration = fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 0 fadeLyrInterpolation = 7 fadeMuteEmulator = false fadeUseBackgrounds = false fadeWidthBaseRes = 1920 fadeHeightBaseRes = 1080 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Stretch and Lose Aspect fadeLyr2Pos = Stretch and Lose Aspect fadeLyr2X = 0 fadeLyr2Y = 0 fadeLyr2W = fadeLyr2H = fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr2Prefix = Extra Layer 1 - Console fadeLyr3Pos = Center fadeLyr3X = 450 fadeLyr3Y = 450 fadeLyr3W = fadeLyr3H = fadeLyr3Adjust = 1 fadeLyr3PicPad = 0 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3BackImageTransparency = 30 fadeLyr3StaticPos = No Alignment fadeLyr3StaticX = 0 fadeLyr3StaticY = 870|1575 fadeLyr3StaticW = fadeLyr3StaticH = fadeLyr3StaticAdjust = 1 fadeLyr3StaticPicPad = 0 fadeLyr3StaticPrefix = Info Bar fadeLyr4Adjust = 1 fadeLyr4X = 1792|952 fadeLyr4Y = 891|1596 fadeLyr4W = 128 fadeLyr4H = fadeLyr4Pos = No Alignment fadeLyr4FPS = 50 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = Image fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 900 fadeBarWindowH = fadeBarWindowR = 30 fadeBarWindowM = 30 fadeBarWindowHatchStyle = 8 fadeBar = 7zOnly fadeBarNon7zProgressTime = 0 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 30 fadeBarR = 10 fadeBarColor = DD00BFFF fadeBarHatchStyle = 8 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 150 fadeRomInfoDescription = filtered text fadeRomInfoSystemName = image fadeRomInfoYear = text with label fadeRomInfoManufacturer = text with label fadeRomInfoGenre = disabled fadeRomInfoRating = image fadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|Rating fadeRomInfoTextPlacement = User Defined fadeRomInfoTextMargin = 7 fadeRomInfoText1Options = w1600|787 h90 x165 y870|1575 cFFE1E1E1 r4 s90 Left Regular fadeRomInfoText2Options = w400 x8 y15 cFF555555 r4 s60 Bold fadeRomInfoText3Options = w310 x165 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText4Options = w1305|492 h66 x460 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText5Options = cFF555555 r4 s42 Bold fadeRomInfoText6Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topRight fadeStatsInfoTextMargin = 7 fadeStatsInfoText1Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText2Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText3Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText4Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText5Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText6Options = cFFB4B4B4 r4 s22 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFB4B4B4 r4 s30 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFB4B4B4 r4 s30 Right Bold fadeText2 = Extraction Complete, Ready fadeText3 = Loading Game fadeText4 = Loading Complete fadeFont = Bebas Neue fadeSystemAndRomLayersOnly = false fadeExtractionTime = disabled fadeExtractionTimeTextX = 0 fadeExtractionTimeTextY = 0 fadeExtractionTimeTextOptions = cFF555555 r4 s20 Bold fadeInterruptKey = detectFadeErrorEnabled = false fadeImgPath = E:\Rocketlauncher\Media\Fade RLDataPath = E:\Rocketlauncher\Data RLMediaPath = E:\Rocketlauncher\Media RLErrSoundPath = E:\Rocketlauncher\Media\Sounds\Error modulesPath = E:\Rocketlauncher\Modules moduleFullName = E:\Rocketlauncher\Modules\PCSX2\PCSX2.ahk moduleName = PCSX2 modulePath = E:\Rocketlauncher\Modules\PCSX2 moduleExtension = ahk moduleExtensionsPath = E:\Rocketlauncher\Module Extensions libPath = E:\Rocketlauncher\Lib 7zEnabled = true 7zPath = E:\Rocketlauncher\Module Extensions\7z.exe 7zDllPath = E:\Rocketlauncher\Module Extensions\7z.dll 7zExtractPath = C:\Users\Lenovo\AppData\Local\Temp\HS 7zExtractPathOrig = 7zAttachSystemName = false 7zDelTemp = true 7zSounds = true 7zFormats = .zip,.rar,.7z,.lzh,.gzip,.tar 7zFormatsNoP = zip,rar,7z,lzh,gzip,tar mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgWidthBaseRes = 1920 mgHeightBaseRes = 1080 mgYOffset = 500|800 mgFont = Arial mgText1Options = x10p y250|500 w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 100 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgCandidate = mgValidTypes = (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side mgOnLaunch = false pauseEnabled = false pauseKey = m pauseBackToMenuBarKey = n pauseZoomInKey = C pauseZoomOutKey = V pauseScreenshotKey = ~PrintScreen pauseHiToTextPath = E:\Rocketlauncher\Module Extensions\HiToText.exe pauseSaveStateKeyCodes = {F1 down}{F1 up} pauseLoadStateKeyCodes = {F3 down}{F3 up} keymapperEnabled = true keymapperAHKMethod = External keymapper = xpadder xpadderFullPath = E:\Hyperspin\Utilities\Xpadder\Xpadder.exe joyToKeyFullPath = E:\Utilities\JoyToKey\JoyToKey.exe keymapperProfilePath = E:\Rocketlauncher\Profiles\xpadder keymapperFrontEndProfileName = RocketLauncherUI keymapperFrontEndProfile = xpadder keymapperRocketLauncherProfileEnabled = true joyIDsEnabled = true joyIDsPreferredControllersGlobal = Controller (Xbox 360 Wireless Receiver for Windows) joyIDsPreferredControllersSystem = use_global joyIDsPreferredControllersOnExit = CustomJoyNamesEnabled = false CustomJoyNames = rotateMethod = false FEProfile = E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI defaultProfile = E:\Rocketlauncher\Profiles\xpadder\_Default systemProfile = E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2 xPadderSystemProfile = E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2\_Default emuProfile = E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2\PCSX2 romProfile = E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2\Jeremy McGrath Supercross World (USA) RocketLauncherProfile = E:\Rocketlauncher\Profiles\xpadder\RocketLauncher blankProfile = E:\Rocketlauncher\Profiles\xpadder\_Default\blank ahkFEProfile = E:\Rocketlauncher\Profiles\AHK\RocketLauncherUI ahkDefaultProfile = E:\Rocketlauncher\Profiles\AHK\_Default ahkSystemProfile = E:\Rocketlauncher\Profiles\AHK\Sony Playstation 2 ahkEmuProfile = E:\Rocketlauncher\Profiles\AHK\Sony Playstation 2\PCSX2 ahkRomProfile = E:\Rocketlauncher\Profiles\AHK\Sony Playstation 2\Jeremy McGrath Supercross World (USA) ahkRocketLauncherProfile = E:\Rocketlauncher\Profiles\AHK\RocketLauncher bezelEnabled = false bezelICEnabled = false statisticsEnabled = true pressDuration = -1 emuVolume = 1 dxwndIni = E:\Rocketlauncher\Module Extensions\dxwnd\dxwnd.ini dxwndFullPath = E:\Rocketlauncher\Module Extensions\dxwnd\dxwnd.exe mon1O = pacDrivedllFile = E:\Rocketlauncher\Module Extensions\PacDrive32.dll userFadeAnimIniFile = E:\Rocketlauncher\Lib\User Fade Animations.ini 13:53:59:734 | RL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 13:53:59:734 | RL | INFO | +0 | BuildScript - Loaded Keymapper Init.ahk scripts 13:53:59:744 | RL | INFO | +16 | BuildScript - Loaded Statistics Init.ahk scripts 13:53:59:744 | RL | WARNING | +0 | BuildScript - "E:\Rocketlauncher\Lib\User Functions Init.ahk" not found 13:53:59:744 | RL | DEBUG1 | +0 | BuildScript - Module starts on line: 2 13:53:59:744 | RL | INFO | +0 | BuildScript - Validating module 13:53:59:754 | RL | INFO | +0 | BuildScript - Validation complete 13:53:59:754 | RL | INFO | +0 | BuildScript - Module: MEmu = PCSX2 MEmuV = 1.1.0.r5695 MURL = http://pcsx2.net/ MAuthor = djvj MVersion = 2.1.4 MCRC = 17664BEB iCRC = 776E3DD9 MID = 635038268913291718 MSystem = "Sony PlayStation 2" ;---------------------------------------------------------------------------- ; Notes: ; This module has many settings that can be controlled via RocketLauncherUI ; If you want to customize settings per game, add the game to the module's ini using RocketLauncherUI ; If you use Daemon Tools, make sure you have a SCSI virtual drive setup. Not a DT one. ; Tested Virtual Drive support with the cdvdGigaherz CDVD plugin. Make sure you set it to use your SCSI Virtual Drive letter. ; Module will set the CdvdSource to Plugin or Iso depending on if you have Virtual Drive enabled or not. ; If you have any problems closing the emulator, make sure noGUI module setting in RocketLauncherUI is set to default or false. ; ; Per-game memory cards ; This module supports per-game memory cards to prevent them from ever becoming full ; To use this feature, set the PerGameMemoryCards to true in RocketLauncherUI ; You need to create a default blank memory card in the path you have defined in pcsx's ini found in section [Folders], key MemoryCards. ; Make sure one of the current memory cards are blank, then copy it in that folder and rename it to "default.ps2". The module will copy this file to a romName.ps2 for each game launched. ; The module will only insert memory cards into Slot 1. So save your games there. ; ; Linuz cdvd plugin stores its settings in the registry @ HKEY_CURRENT_USER\Software\PS2Eplugin\CDVD\CDVDiso ; ; Run pcsx2 with the --help option to see current CLI parameters ; ; Known CLI options not currently supported by this module: ; --console forces the program log/console to be visible ; --portable enables portable mode operation (requires admin/root access) ; --elf=<str> executes an ELF image ; --forcewiz forces PCSX2 to start the First-time Wizard ;---------------------------------------------------------------------------- StartModule() BezelGUI() FadeInStart() ; PCSX2_ui.ini = default ini that contains memory card info and general settings If FileExist(emuPath . "\portable.ini") { ; portable install Log("Module - PCSX2 is operating in a portable mode") pcsx2IniFile := CheckFile(emuPath . "\inis\PCSX2_ui.ini", "Could not find the default PCSX2_ui.ini file. Please manually run and configure PCSX2 first so this file is created with all your default settings.") } Else { ; default not portable install Log("Module - PCSX2 is operating in a standard installation mode") RegRead, pcsx2IniFolder, HKCU, Software\PCSX2, SettingsFolder pcsx2IniFile := CheckFile(pcsx2IniFolder . "\PCSX2_ui.ini", "Could not find the default PCSX2_ui.ini file. Please manually run and configure PCSX2 first so this file is created with all your default settings.") } settingsFile := modulePath . "\" . moduleName . ".ini" ; global settings Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) noGUI := IniReadCheck(settingsFile, "Settings", "noGUI","false",,1) ; disables display of the gui while running games fullboot := IniReadCheck(settingsFile, "Settings", "fullboot","false",,1) ; disables the quick boot feature, forcing you to sit through the PS2 startup splash screens perGameMemCards := IniReadCheck(settingsFile, "Settings", "PerGameMemoryCards","true",,1) hideConsole := IniReadCheck(settingsFile, "Settings", "HideConsole","true",,1) ; Hides console window from view if it shows up cfgPath := IniReadCheck(settingsFile, "Settings", "cfgpath", emuPath . "\Game Configs",,1) ; specifies the config folder; applies to pcsx2 + plugins autoCreateINIDir := IniReadCheck(settingsFile, "Settings", "AutoCreateINIDir","false",,1) ; Enables the module to auto-create of per game ini files and directories defaultINISPath := IniReadCheck(settingsFile, "Settings", "DefaultINISPath",,,1) ; Path to default INIS folder of PCSX2. gs := IniReadCheck(settingsFile, "Settings|" . romName, "gs",,,1) ; override for the GS plugin pad := IniReadCheck(settingsFile, "Settings|" . romName, "pad",,,1) ; override for the PAD plugin spu2 := IniReadCheck(settingsFile, "Settings|" . romName, "spu2",,,1) ; override for the SPU2 plugin cdvd := IniReadCheck(settingsFile, romName, "cdvd",,,1) ; override for the CDVD plugin usb := IniReadCheck(settingsFile, "Settings|" . romName, "usb",,,1) ; override for the USB plugin fw := IniReadCheck(settingsFile, "Settings|" . romName, "fw",,,1) ; override for the FW plugin dev9 := IniReadCheck(settingsFile, "Settings|" . romName, "dev9",,,1) ; override for the DEV9 plugin vdOveride := IniReadCheck(settingsFile, romName, "VDOveride","false",,1) nohacks := IniReadCheck(settingsFile, romName, "nohacks","false",,1) ; disables all speedhacks gamefixes := IniReadCheck(settingsFile, romName, "gamefixes",,,1) ; Enable specific gamefixes for this session. Use the specified comma or pipe-delimited list of gamefixes: VuAddSub,VuClipFlag,FpuCompare,FpuMul,FpuNeg,EETiming,SkipMpeg,OPHFlag,DMABusy,VIFFIFO,VI,FMVinSoftware cfgPath := GetFullName(cfgPath) IfNotExist % cfgPath FileCreateDir, %cfgPath% ; create the cfg folder if it does not exist ; Create INIs subfolder for the game if it does not exist and if AutoCreateINIDir is true If (autoCreateINIDir = "true") { perINIPath := cfgPath . "\" . romName Log("Module - PerGameIni - perINIPath = " . perINIPath,4) If !FileExist(perINIPath) { If (defaultINISPath != "") { Log("Module - PerGameIni - perINIPath does not exist. So we will create it at " . PerINIPath,4) FileCreateDir, %perINIPath% Log("Module - PerGameIni - Now to copy the ini files from " . defaultINISPath . " to " . perINIPath . ".",4) FileCopy, %defaultINISPath%\*.ini, %perINIPath% } Else { Log("Module - PerGameIni - perINIPath does not exist. So we will create it at " . PerINIPath,4) FileCreateDir, %perINIPath% Log("Module - PerGameIni - Now to copy the ini files from " . emuPath . "\inis" . " to " . perINIPath . ".",4) FileCopy, %emuPath%\inis\*.ini, %perINIPath% } } } BezelStart() Fullscreen := If Fullscreen = "true" ? " --fullscreen" : "" noGUI := If noGUI = "true" ? " --nogui" : "" If (noGUI != "") Log("Module - noGUI is set to true, THIS MAY PREVENT PCSX2 FROM CLOSING PROPERLY. If you have any issues, set it to false or default in RocketLauncherUI.",2) fullboot := If fullboot = "true" ? " --fullboot" : "" nohacks := If nohacks = "true" ? " --nohacks" : "" gamefixes := If gamefixes ? " --gamefixes=" . gamefixes : "" gs := If gs ? " --gs=""" . GetFullName(gs) . """" : "" pad := If pad ? " --pad=""" . GetFullName(pad) . """" : "" spu2 := If spu2 ? " --spu2=""" . GetFullName(spu2) . """" : "" usb := If usb ? " --usb=""" . GetFullName(usb) . """" : "" fw := If fw ? " --fw=""" . GetFullName(fw) . """" : "" dev9 := If dev9 ? " --dev9=""" . GetFullName(dev9) . """" : "" cfgRomPath := cfgPath . "\" . romName cfgPathCLI := If FileExist(cfgRomPath) ? " --cfgpath=""" . GetFullName(cfgRomPath) . """" : "" ; Specify what main ini PCSX2 should use If (cfgPathCLI && FileExist(cfgRomPath . "\PCSX2_ui.ini")) { ;We can't set both cfgpath and cfg CLI switches, so if only PCSX2_ui.ini file exists we use cfg otherwise we use cfgpath ;--cfg specifies a custom configuration file to use instead of PCSX2.ini (does not affect plugins) filecount := 0 Loop, %cfgRomPath%\*.ini filecount++ If (filecount == 1) { ;Only PCSX2_ui.ini found pcsx2IniFile := cfgRomPath . "\PCSX2_ui.ini" Log("Module - Found a game-specific PCSX2_ui.ini in the cfgPath. Telling PCSX2 to use this one instead: " . pcsx2IniFile) cfg := " --cfg=""" . pcsx2IniFile . """" cfgPathCLI := "" } } Log("Module - " . (If cfgPathCLI != "" ? "Setting PCSX2's config path to """ . cfgRomPath . """" : "Using PCSX2's default configuration folder: """ . emuPath . "\inis""")) ; Memory Cards If perGameMemCards = true { IniRead, currentMemCard1, %pcsx2IniFile%, MemoryCards, Slot1_Filename IniRead, memCardPath, %pcsx2IniFile%, Folders, MemoryCards ; folder where memory cards are stored StringLeft, memCardPathLeft, memCardPath, 3 memCardPathIsAbsolute := If (RegExMatch(memCardPathLeft, "[a-zA-Z]:\\") && (StrLen(memCardPath) >= 3)) ; this is 1 only when path looks like this "C:\" memCardPath := If memCardPathIsAbsolute ? memCardPath : emuPath . "\" . memCardPath ; if only a folder name is defined for the memory card path, tack on the emuPath to find the memory cards, otherwise leave the full path as is defaultMemCard := memCardPath . "\default.ps2" ; defining default blank memory card for slot 1 Log("Module - Default memory card for Slot 1 should be: " . defaultMemCard,4) romMemCard1 := memCardPath . "\" . romName . ".ps2" ; defining name for rom's memory card for slot 1 Log("Module - Rom memory card for Slot 1 should be: " . romMemCard1,4) Log("Module - Current memory card inserted in PCSX2's ini in Slot 1 is: " . currentMemCard1) If (currentMemCard1 != romName . ".ps2") { ; if current memory card in slot 1 does not match this romName, switch to one that does if exist or load a default one IfNotExist, %romMemCard1% ; first check if romName.ps2 memory card exists IfNotExist, %defaultMemCard% Log("Module - A default memory card for Slot 1 was not found in """ . memCardPath . """. Please create an empty memory card called ""default.ps2"" in this folder for per-game memory card support.",3) Else { FileCopy, %defaultMemCard%, %romMemCard1% ; create a new blank memory card for this game Log("Module - Creating a new blank memory card for this game in Slot 1: " . romMemCard1) } IniWrite, %romName%.ps2, %pcsx2IniFile%, MemoryCards, Slot1_Filename ; update the ini to use this rom's card Log("Module - Switched memory card in Slot 1 to: " . romMemCard1) } } hideEmuObj := Object("ahk_class wxWindowNR",1) ; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later 7z(romPath, romName, romExtension, 7zExtractPath) pcsx2Ini := LoadProperties(pcsx2IniFile) ; load the config into memory dvdSource := ReadProperty(pcsx2Ini,"CdvdSource") ; read value ; Mount the CD using a Virtual Drive If (vdOveride = "true") ; this allows per-game Virtual Drive support because some games boot to black when Virtual Drive is enabled vdEnabled := vdOveride If (vdEnabled = "true" && InStr(".mds|.mdx|.b5t|.b6t|.bwt|.ccd|.cue|.isz|.nrg|.cdi|.iso|.ape|.flac", romExtension)) { ; if Virtual Drive is enabled and using an image type Virtual Drive can load If !cdvd { vdCDVDPlugin := IniReadCheck(settingsFile, "Settings", "VD_CDVD_Plugin",,,1) If vdCDVDPlugin cdvd := vdCDVDPlugin } cdvd := If cdvd ? " --cdvd=""" . GetFullName(cdvd) . """" : "" If dvdSource != Plugin { Log("Module - CdvdSource was not set to ""Plugin"", changing it so PCSX2 can read from Virtual Drive.") WriteProperty(pcsx2Ini,"CdvdSource","Plugin") ; write a new value to the pcsx2IniFile SaveProperties(pcsx2IniFile,pcsx2Ini) ; save pcsx2IniFile to disk } VirtualDrive("mount",romPath . "\" . romName . romExtension) HideEmuStart() errLvl := Run(executable . " --usecd" . noGUI . Fullscreen . fullboot . nohacks . gamefixes . cfg . cfgPathCLI . gs . pad . spu2 . cdvd . usb . fw . dev9, emuPath, "UseErrorLevel") usedVD = 1 ; tell the rest of the script to use VD methods } Else If romExtension in .iso,.mdf,.nrg,.bin,.img,.gz ; the only formats PCSX2 supports loading directly { If !cdvd { imageCDVDPlugin := IniReadCheck(settingsFile, "Settings", "Image_CDVD_Plugin",,,1) If imageCDVDPlugin cdvd := imageCDVDPlugin } cdvd := If cdvd ? " --cdvd=""" . GetFullName(cdvd) . """" : "" If dvdSource != Iso { Log("Module - CdvdSource was not set to ""Iso"", changing it so PCSX2 can launch this " . romExtension . " image directly") WriteProperty(pcsx2Ini,"CdvdSource","Iso") ; write a new value to the pcsx2IniFile SaveProperties(pcsx2IniFile,pcsx2Ini) ; save pcsx2IniFile to disk } HideEmuStart() errLvl := Run(executable . " """ . romPath . "\" . romName . romExtension . """ " . noGUI . Fullscreen . fullboot . nohacks . gamefixes . cfg . cfgPathCLI . gs . pad . spu2 . cdvd . usb . fw . dev9, emuPath, "UseErrorLevel") } Else If romExtension in .bz2 ; special case format that requires plugin mode and pcsx2 loads it directly { If !cdvd { linuzCDVDPlugin := IniReadCheck(settingsFile, "Settings", "Linuz_CDVD_Plugin",,,1) If linuzCDVDPlugin cdvd := linuzCDVDPlugin } cdvd := If cdvd ? " --cdvd=""" . GetFullName(cdvd) . """" : "" If dvdSource != plugin { Log("Module - CdvdSource was not set to ""Plugin"", changing it so PCSX2 can launch this " . romExtension . " image directly") WriteProperty(pcsx2Ini,"CdvdSource","Plugin") ; write a new value to the pcsx2IniFile SaveProperties(pcsx2IniFile,pcsx2Ini) ; save pcsx2IniFile to disk } oldHex := ReadReg("IsoFile") ; read last used bz2 image newHex := StrToHex(romPath . "\" . romName . romExtension) ; convert new bz2 image path to hex i := 512 - StrLen(newHex) ; get total amount of 0's to add to end of hex to make it 512 bytes Loop, %i% newHex := newHex . "0" ; add required bytes to end If (oldHex != newHex) { Log("Module - Writing new bz2 path to registry",4) WriteReg("IsoFile", newHex) ; write new bz2 path to registry } HideEmuStart() errLvl := Run(executable . " """ . romPath . "\" . romName . romExtension . """ " . noGUI . Fullscreen . fullboot . nohacks . gamefixes . cfg . cfgPathCLI . gs . pad . spu2 . cdvd . usb . fw . dev9, emuPath, "UseErrorLevel") } Else ScriptError("You are trying to run a rom type of """ . romExtension . """ but PCSX2 only supports loading iso|mdf|nrg|bin|img|gz directly. Please turn on Virtual Drive and/or 7z support or put ""cue"" last in your rom extensions for " . MEmu . " instead.") If errLvl ScriptError("Error launching emulator, closing script.") WinWait("ahk_class wxWindowNR",,, "PCSX2") WinWaitActive("ahk_class wxWindowNR",,, "PCSX2") BezelDraw() If hideConsole = true SetTimer, HideConsole, 10 SetTitleMatchMode 2 ;Wrong window might be detected in the next loop if we only use the class name for WinGetTitle so we will add fps to it Loop { ; looping until pcsx2 is done loading game ; tooltip, loop %A_Index%,0,0 Sleep, 200 WinGetTitle, winTitle, fps ahk_class wxWindowNR,, PCSX2 ; excluding the title of the GUI window so we can read the title of the game window instead Log("Detected Window Title is " . winTitle,4) StringSplit, winTextSplit, winTitle, |, %A_Space% If ( winTextSplit10 != "" ) ; 10th position in the array is empty until game actually starts break } HideEmuEnd() FadeInExit() Process("WaitClose", executable) If usedVD VirtualDrive("unmount") 7zCleanUp() BezelExit() FadeOutExit() ExitModule() ReadReg(var1) { regValue := RegRead("HKEY_CURRENT_USER", "Software\PS2Eplugin\CDVD\CDVDiso", var1) Return %regValue% } WriteReg(var1, var2, ValueType="REG_BINARY") { RegWrite(ValueType, "HKEY_CURRENT_USER", "Software\PS2Eplugin\CDVD\CDVDiso", var1, var2) } StrToHex(S) { Return S="" ? "":Chr((*&S>>4)+48) Chr((x:=*&S&15)+48+(x>9)*7) StrToHex(SubStr(S,2)) } MultiGame: ; msgbox % "selectedRom = " . selectedRom . "`nselected game = " . currentButton . "`nmgRomPath = " . mgRomPath . "`nmgRomExt = " . mgRomExt . "`nmgRomName = " . mgRomName ; Unmount the CD from Virtual Drive If usedVD VirtualDrive("unmount") Sleep, 500 ; Required to prevent your Virtual Drive from bugging ; Mount the CD using Virtual Drive If usedVD VirtualDrive("mount",selectedRom) Return HideConsole: hideConsoleTimer++ IfWinExist, Booting ahk_class wxWindowNR { Log("Module - HideConsole - Console window found, hiding it out of view.") WinSet, Transparent, 0, Booting ahk_class wxWindowNR,,fps:,fps: ; hiding the console window WinSet, Transparent, 0, PCSX2 ahk_class wxWindowNR,,fps:,fps: ; hiding the GUI window with the menubar SetTimer, HideConsole, Off } Else If hideConsoleTimer >= 200 SetTimer, HideConsole, Off Return CloseProcess: FadeOutStart() WinMenuSelectItem, PCSX2 ahk_class wxWindowNR,, System, Pause WinClose("PCSX2 ahk_class wxWindowNR") ; sending command to the GUI window to properly close the entire emu Return 13:53:59:764 | RL | INFO | +15 | BuildScript - Loaded Multi-Player scripts 13:53:59:774 | RL | INFO | +16 | BuildScript - Loaded Statistics.ahk script 13:53:59:774 | RL | WARNING | +0 | BuildScript - "E:\Rocketlauncher\Lib\User Functions.ahk" not found 13:53:59:774 | RL | INFO | +0 | BuildScript - Finished injecting functions into module 13:53:59:774 | RL | INFO | +0 | Main - Module is built 13:53:59:784 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\AutoHotkey.dll exists 13:53:59:784 | RL | INFO | +0 | Main - Running module 13:53:59:794 | RL | INFO | +15 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 13:53:59:914 | MD | INFO | +N/A | Module initialized 13:53:59:924 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess" 13:53:59:954 | MD | DEBUG2 | +31 | Keymapper - Checking for the JoyIDs_Preferred_Controllers key in E:\Rocketlauncher\Settings\Sony Playstation 2\Games JoyIDs.ini under section [Jeremy McGrath Supercross World (USA)] 13:53:59:954 | MD | INFO | +0 | LoadPreferredControllers - Started 13:53:59:954 | MD | DEBUG2 | +0 | LoadPreferredControllers - JoyIDsPreferredControllers = Controller (Xbox 360 Wireless Receiver for Windows) 13:53:59:954 | MD | DEBUG2 | +0 | LoadPreferredControllers - Creating a list of currently connected joysticks 13:53:59:984 | MD | INFO | +32 | GetJoystickArray - Started 13:54:00:044 | MD | DEBUG2 | +62 | GetJoystickArray - Joysticks Detected: 1000000000000000 13:54:00:044 | MD | INFO | +0 | GetJoystickGUID - Started 13:54:00:074 | MD | INFO | +31 | GetJoystickGUID - Ended and found GUID: 5041DB96E6EDE4118001444553540000 13:54:00:074 | MD | DEBUG2 | +0 | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 5041DB96E6EDE4118001444553540000 13:54:00:074 | MD | INFO | +0 | GetJoystickArray - Ended 13:54:00:074 | MD | DEBUG2 | +0 | LoadPreferredControllers - Preferred Order Sorting List -> 1.01|045e|02a1|5041DB96E6EDE4118001444553540000 13:54:00:084 | MD | INFO | +0 | LoadPreferredControllers - Sorting Currently Connected joysticks List to match the order of the Preferred Controller List 13:54:00:084 | MD | INFO | +0 | LoadPreferredControllers - Assigning the New Joystick IDs according to the preferred list for the active controllers 13:54:00:084 | MD | INFO | +0 | ChangeJoystickID - Started 13:54:00:084 | MD | DEBUG2 | +0 | ChangeJoystickID - Swapping Joystick ID: 00000000 to the New Joystick ID: 00000000, for the Joystick VID_045e&PID_02a1&GUID_5041DB96E6EDE4118001444553540000 13:54:00:104 | MD | INFO | +31 | ChangeJoystickID - Ended 13:54:00:114 | MD | INFO | +0 | LoadPreferredControllers - Ended 13:54:00:114 | MD | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Utilities\Xpadder\Xpadder.exe exists 13:54:00:134 | MD | INFO | +32 | Keymapper - Loading xpadder 13:54:00:134 | MD | INFO | +0 | RunKeymapper - Started, using method "load" 13:54:00:134 | MD | INFO | +0 | GetJoystickArray - Started 13:54:00:144 | MD | DEBUG2 | +0 | GetJoystickArray - Joysticks Detected: 1000000000000000 13:54:00:164 | MD | INFO | +31 | GetJoystickGUID - Started 13:54:00:164 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 5041DB96E6EDE4118001444553540000 13:54:00:164 | MD | DEBUG2 | +0 | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 5041DB96E6EDE4118001444553540000 13:54:00:174 | MD | INFO | +0 | GetJoystickArray - Ended 13:54:00:174 | MD | DEBUG2 | +0 | RunKeymapper - Found your keymapper application here: "E:\Hyperspin\Utilities\Xpadder\Xpadder.exe" 13:54:00:174 | MD | DEBUG2 | +0 | RunKeymapper - Looping through controllers to find xpadder profiles for each one 13:54:00:174 | MD | DEBUG2 | +0 | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "Controller (Xbox 360 Wireless Receiver for Windows)" 13:54:00:194 | MD | DEBUG2 | +31 | GetProfile - Searching for these profiles (| delimited): E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2\Jeremy McGrath Supercross World (USA)|E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2\PCSX2|E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2\_Default|E:\Rocketlauncher\Profiles\xpadder\_Default|E:\Rocketlauncher\Profiles\xpadder\_Default\blank 13:54:00:194 | MD | DEBUG2 | +0 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2\Jeremy McGrath Supercross World (USA)\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile 13:54:00:194 | MD | DEBUG2 | +0 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2\Jeremy McGrath Supercross World (USA)\p1.xpadderprofile 13:54:00:204 | MD | DEBUG2 | +0 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2\PCSX2\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile 13:54:00:204 | MD | DEBUG2 | +0 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2\PCSX2\p1.xpadderprofile 13:54:00:234 | MD | DEBUG2 | +31 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2\_Default\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile 13:54:00:264 | MD | DEBUG2 | +31 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Sony Playstation 2\_Default\p1.xpadderprofile 13:54:00:264 | MD | DEBUG2 | +0 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile 13:54:00:264 | MD | DEBUG2 | +0 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile 13:54:00:264 | MD | INFO | +0 | GetProfile - Loading Player 1 Profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile 13:54:00:294 | MD | INFO | +32 | RunXpadder - Started 13:54:00:294 | MD | INFO | +0 | Process - Exist JoyToKey.exe 13:54:00:294 | MD | DEBUG2 | +0 | RunXpadder - Closing xpadder to refresh controllers seen by xpadder 13:54:00:304 | MD | INFO | +0 | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe /C 13:54:00:404 | MD | DEBUG1 | +109 | Run - "Xpadder.exe /C" Process ID: 1252 13:54:00:404 | MD | DEBUG2 | +0 | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in E:\Hyperspin\Utilities\Xpadder\xpadder.ini 13:54:00:404 | MD | INFO | +0 | Process - WaitClose Xpadder.exe 2 13:54:00:514 | MD | DEBUG2 | +109 | RunXpadder - Reading the order in E:\Hyperspin\Utilities\Xpadder\xpadder.ini and arranging profiles found to match that order 13:54:00:514 | MD | DEBUG2 | +0 | RunXpadder - No more controllers to be found 13:54:00:514 | MD | INFO | +0 | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile" /M 13:54:00:574 | MD | DEBUG1 | +62 | Run - "Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile" /M" Process ID: 3776 13:54:00:574 | MD | INFO | +0 | RunXpadder - Ended 13:54:00:574 | MD | INFO | +0 | RunKeymapper - Ended 13:54:00:604 | MD | INFO | +32 | Keymapper - Loading External AHK Keymapping 13:54:00:604 | MD | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\AhkLauncher.exe exists 13:54:00:604 | MD | INFO | +0 | RunAHKKeymapper - Started 13:54:00:604 | MD | DEBUG1 | +0 | RunAHKKeymapper - Loading Jeremy McGrath Supercross World (USA), PCSX2, Sony Playstation 2, or _Default AHK Keymapper profile 13:54:00:614 | MD | INFO | +0 | GetAHKProfile - Started 13:54:00:614 | MD | DEBUG2 | +0 | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\Sony Playstation 2\Jeremy McGrath Supercross World (USA).ahk 13:54:00:614 | MD | DEBUG2 | +0 | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\Sony Playstation 2\PCSX2.ahk 13:54:00:614 | MD | DEBUG2 | +0 | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\Sony Playstation 2.ahk 13:54:00:614 | MD | DEBUG2 | +0 | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\_Default.ahk 13:54:00:614 | MD | INFO | +0 | GetAHKProfile - Ended and no profile found 13:54:00:634 | MD | DEBUG1 | +31 | RunAHKKeymapper - If AhkLauncher.exe is running, need to close it first before a new profile can be loaded 13:54:00:634 | MD | INFO | +0 | Process - Exist AhkLauncher.exe 13:54:00:634 | MD | INFO | +0 | RunAHKKeymapper - Ended 13:54:00:634 | MD | INFO | +0 | StartModule - Started 13:54:00:644 | MD | INFO | +0 | StartModule - MEmu: PCSX2 MEmuV: 1.1.0.r5695 MURL: http://pcsx2.net/ MAuthor: djvj MVersion: 2.1.4 MCRC: 17664BEB iCRC: 776E3DD9 MID: MSystem: "Sony PlayStation 2" 13:54:00:644 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "Sony Playstation 2" 13:54:00:644 | MD | INFO | +0 | PluginInit - Started 13:54:00:644 | MD | DEBUG1 | +0 | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating 13:54:00:644 | MD | INFO | +0 | CheckFile - Checking if E:\HyperSpin\Databases\Sony Playstation 2\Sony Playstation 2.xml exists 13:54:00:664 | MD | DEBUG1 | +31 | BuildDatabaseTable - Searching for a "Game Name" in the database 13:54:00:664 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Game Name" in the database! 13:54:00:664 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Name 13:54:00:664 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Name" with a value: "Jeremy McGrath Supercross World (USA)" 13:54:00:664 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Cloneof 13:54:00:674 | MD | DEBUG1 | +0 | BuildDatabaseTable - Could not find: Cloneof 13:54:00:674 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Manufacturer 13:54:00:674 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Manufacturer" with a value: "Acclaim" 13:54:00:674 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Year 13:54:00:674 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Year" with a value: "2001" 13:54:00:694 | MD | DEBUG1 | +31 | BuildDatabaseTable - Searching database for: Genre 13:54:00:704 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Genre" with a value: "Motorcycle" 13:54:00:704 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Rating 13:54:00:704 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Rating" with a value: "Other - NR (Not Rated)" 13:54:00:704 | MD | DEBUG2 | +0 | PluginInit - GameInfo: GameInfo Label: Genre | GameInfo Value: GameInfo Label: Manufacturer | GameInfo Value: GameInfo Label: Name | GameInfo Value: GameInfo Label: Rating | GameInfo Value: GameInfo Label: Year | GameInfo Value: 13:54:00:734 | MD | DEBUG1 | +31 | BuildDatabaseTable - Ended 13:54:00:734 | MD | DEBUG1 | +0 | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo 13:54:00:734 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Game Logo: E:\HyperSpin\Media\Sony Playstation 2\Images\Wheel\Jeremy McGrath Supercross World (USA).png 13:54:00:734 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a System Logo: E:\HyperSpin\Media\Main Menu\Images\Wheel\Sony Playstation 2.png 13:54:00:734 | MD | DEBUG2 | +0 | BuildAssetsTable - Media assets found: Asset Label: Game Logo | Asset Path1: E:\HyperSpin\Media\Sony Playstation 2\Images\Wheel\Jeremy McGrath Supercross World (USA).png | Asset Extension1: png | Asset Type1: game Asset Label: System Logo | Asset Path1: E:\HyperSpin\Media\Main Menu\Images\Wheel\Sony Playstation 2.png | Asset Extension1: png | Asset Type1: system 13:54:00:764 | MD | DEBUG1 | +32 | BuildAssetsTable - Ended 13:54:00:794 | MD | DEBUG1 | +31 | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other 13:54:00:794 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Artwork1: E:\HyperSpin\Media\Sony Playstation 2\Images\Artwork1\Jeremy McGrath Supercross World (USA).png 13:54:00:794 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Box Art: E:\HyperSpin\Media\Sony Playstation 2\Images\Artwork2\Jeremy McGrath Supercross World (USA).png 13:54:00:824 | MD | DEBUG1 | +31 | BuildAssetsTable - Searching for a Cartridge: E:\HyperSpin\Media\Sony Playstation 2\Images\Artwork3\Jeremy McGrath Supercross World (USA).png 13:54:00:834 | RL | WARNING | +1046 | HyperSpin.exe was displaced to x0 y0 w1440 h900 by PCSX2. It is probably running in true fullscreen mode. 13:54:00:854 | MD | DEBUG1 | +31 | BuildAssetsTable - Searching for a Flyers: E:\HyperSpin\Media\Sony Playstation 2\Images\Artwork4\Jeremy McGrath Supercross World (USA).png 13:54:00:854 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Letters: E:\HyperSpin\Media\Sony Playstation 2\Images\Letters 13:54:00:884 | MD | DEBUG1 | +31 | BuildAssetsTable - Searching for a Other: E:\HyperSpin\Media\Sony Playstation 2\Images\Other 13:54:00:914 | MD | DEBUG2 | +32 | BuildAssetsTable - Media assets found: Asset Label: Letters | Asset Path1: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\!.png | Asset Extension1: png | Asset Type1: system Asset Label: Letters | Asset Path2: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\'.png | Asset Extension2: png | Asset Type2: system Asset Label: Letters | Asset Path3: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\(.png | Asset Extension3: png | Asset Type3: system Asset Label: Letters | Asset Path4: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\0.png | Asset Extension4: png | Asset Type4: system Asset Label: Letters | Asset Path5: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\1.png | Asset Extension5: png | Asset Type5: system Asset Label: Letters | Asset Path6: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\2.png | Asset Extension6: png | Asset Type6: system Asset Label: Letters | Asset Path7: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\3.png | Asset Extension7: png | Asset Type7: system Asset Label: Letters | Asset Path8: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\4.png | Asset Extension8: png | Asset Type8: system Asset Label: Letters | Asset Path9: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\5.png | Asset Extension9: png | Asset Type9: system Asset Label: Letters | Asset Path10: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\6.png | Asset Extension10: png | Asset Type10: system Asset Label: Letters | Asset Path11: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\7.png | Asset Extension11: png | Asset Type11: system Asset Label: Letters | Asset Path12: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\8.png | Asset Extension12: png | Asset Type12: system Asset Label: Letters | Asset Path13: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\9.png | Asset Extension13: png | Asset Type13: system Asset Label: Letters | Asset Path14: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\a.png | Asset Extension14: png | Asset Type14: system Asset Label: Letters | Asset Path15: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\b.png | Asset Extension15: png | Asset Type15: system Asset Label: Letters | Asset Path16: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\c.png | Asset Extension16: png | Asset Type16: system Asset Label: Letters | Asset Path17: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\d.png | Asset Extension17: png | Asset Type17: system Asset Label: Letters | Asset Path18: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\e.png | Asset Extension18: png | Asset Type18: system Asset Label: Letters | Asset Path19: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\f.png | Asset Extension19: png | Asset Type19: system Asset Label: Letters | Asset Path20: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\g.png | Asset Extension20: png | Asset Type20: system Asset Label: Letters | Asset Path21: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\h.png | Asset Extension21: png | Asset Type21: system Asset Label: Letters | Asset Path22: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\i.png | Asset Extension22: png | Asset Type22: system Asset Label: Letters | Asset Path23: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\j.png | Asset Extension23: png | Asset Type23: system Asset Label: Letters | Asset Path24: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\k.png | Asset Extension24: png | Asset Type24: system Asset Label: Letters | Asset Path25: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\l.png | Asset Extension25: png | Asset Type25: system Asset Label: Letters | Asset Path26: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\m.png | Asset Extension26: png | Asset Type26: system Asset Label: Letters | Asset Path27: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\n.png | Asset Extension27: png | Asset Type27: system Asset Label: Letters | Asset Path28: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\o.png | Asset Extension28: png | Asset Type28: system Asset Label: Letters | Asset Path29: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\p.png | Asset Extension29: png | Asset Type29: system Asset Label: Letters | Asset Path30: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\q.png | Asset Extension30: png | Asset Type30: system Asset Label: Letters | Asset Path31: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\r.png | Asset Extension31: png | Asset Type31: system Asset Label: Letters | Asset Path32: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\s.png | Asset Extension32: png | Asset Type32: system Asset Label: Letters | Asset Path33: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\t.png | Asset Extension33: png | Asset Type33: system Asset Label: Letters | Asset Path34: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\u.png | Asset Extension34: png | Asset Type34: system Asset Label: Letters | Asset Path35: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\v.png | Asset Extension35: png | Asset Type35: system Asset Label: Letters | Asset Path36: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\w.png | Asset Extension36: png | Asset Type36: system Asset Label: Letters | Asset Path37: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\x.png | Asset Extension37: png | Asset Type37: system Asset Label: Letters | Asset Path38: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\y.png | Asset Extension38: png | Asset Type38: system Asset Label: Letters | Asset Path39: E:\Hyperspin\Media\Sony Playstation 2\Images\Letters\z.png | Asset Extension39: png | Asset Type39: system Asset Label: Other | Asset Path1: E:\Hyperspin\Media\Sony Playstation 2\Images\Other\Pointer.png | Asset Extension1: png | Asset Type1: system 13:54:00:924 | MD | DEBUG1 | +0 | BuildAssetsTable - Ended 13:54:00:944 | MD | DEBUG1 | +31 | BuildAssetsTable - Started - Building Table for: Game Video|System Video 13:54:00:954 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Game Video: E:\HyperSpin\Media\Sony Playstation 2\Video\Jeremy McGrath Supercross World (USA).* 13:54:00:954 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a System Video: E:\HyperSpin\Media\Main Menu\Video\Sony Playstation 2.* 13:54:00:974 | MD | DEBUG2 | +31 | BuildAssetsTable - Media assets found: Asset Label: System Video | Asset Path1: E:\HyperSpin\Media\Main Menu\Video\Sony Playstation 2.mp4 | Asset Extension1: mp4 | Asset Type1: system 13:54:00:974 | MD | DEBUG1 | +0 | BuildAssetsTable - Ended 13:54:00:974 | MD | INFO | +0 | PluginInit - Ended 13:54:00:984 | MD | DEBUG1 | +0 | StartModule - Setting romName to the dbName sent to RocketLauncher: Jeremy McGrath Supercross World (USA) 13:54:00:984 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor" 13:54:00:984 | MD | INFO | +0 | StartModule - Ended 13:54:01:044 | MD | INFO | +62 | Module - PCSX2 is operating in a portable mode 13:54:01:044 | MD | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Emulators\Sony Playstation 2\inis\PCSX2_ui.ini exists 13:54:01:044 | MD | INFO | +0 | Module Setting - [Settings] - Fullscreen: false 13:54:01:044 | MD | INFO | +0 | Module Setting - [Settings] - noGUI: true 13:54:01:044 | MD | INFO | +0 | Module Setting - [Settings] - fullboot: false 13:54:01:074 | MD | INFO | +32 | Module Setting - [Settings] - PerGameMemoryCards: true 13:54:01:074 | MD | INFO | +0 | Module Setting - [Settings] - HideConsole: true 13:54:01:074 | MD | INFO | +0 | Module Setting - [Settings] - cfgpath: E:\Hyperspin\Emulators\Sony Playstation 2\Game Configs 13:54:01:074 | MD | INFO | +0 | Module Setting - [Settings] - AutoCreateINIDir: false 13:54:01:074 | MD | INFO | +0 | Module Setting - [Settings] - DefaultINISPath: 13:54:01:104 | MD | INFO | +31 | Module Setting - [Settings] - gs: 13:54:01:104 | MD | INFO | +0 | Module Setting - [Jeremy McGrath Supercross World (USA)] - gs: 13:54:01:104 | MD | INFO | +0 | Module Setting - [Settings] - pad: 13:54:01:104 | MD | INFO | +0 | Module Setting - [Jeremy McGrath Supercross World (USA)] - pad: 13:54:01:114 | MD | INFO | +0 | Module Setting - [Settings] - spu2: 13:54:01:114 | MD | INFO | +0 | Module Setting - [Jeremy McGrath Supercross World (USA)] - spu2: 13:54:01:114 | MD | INFO | +0 | Module Setting - [Jeremy McGrath Supercross World (USA)] - cdvd: 13:54:01:114 | MD | INFO | +0 | Module Setting - [Settings] - usb: 13:54:01:114 | MD | INFO | +0 | Module Setting - [Jeremy McGrath Supercross World (USA)] - usb: 13:54:01:134 | MD | INFO | +31 | Module Setting - [Settings] - fw: 13:54:01:144 | MD | INFO | +0 | Module Setting - [Jeremy McGrath Supercross World (USA)] - fw: 13:54:01:144 | MD | INFO | +0 | Module Setting - [Settings] - dev9: 13:54:01:144 | MD | INFO | +0 | Module Setting - [Jeremy McGrath Supercross World (USA)] - dev9: 13:54:01:164 | MD | INFO | +31 | Module Setting - [Jeremy McGrath Supercross World (USA)] - VDOveride: false 13:54:01:164 | MD | INFO | +0 | Module Setting - [Jeremy McGrath Supercross World (USA)] - nohacks: false 13:54:01:164 | MD | INFO | +0 | Module Setting - [Jeremy McGrath Supercross World (USA)] - gamefixes: 13:54:01:164 | MD | WARNING | +0 | Module - noGUI is set to true, THIS MAY PREVENT PCSX2 FROM CLOSING PROPERLY. If you have any issues, set it to false or default in RocketLauncherUI. 13:54:01:174 | MD | INFO | +0 | Module - Using PCSX2's default configuration folder: "E:\Hyperspin\Emulators\Sony Playstation 2\inis" 13:54:01:174 | MD | DEBUG1 | +0 | Module - Default memory card for Slot 1 should be: E:\Hyperspin\Emulators\Sony Playstation 2\memcards\default.ps2 13:54:01:174 | MD | DEBUG1 | +0 | Module - Rom memory card for Slot 1 should be: E:\Hyperspin\Emulators\Sony Playstation 2\memcards\Jeremy McGrath Supercross World (USA).ps2 13:54:01:174 | MD | INFO | +0 | Module - Current memory card inserted in PCSX2's ini in Slot 1 is: Island Xtreme Stunts (USA).ps2 13:54:01:174 | MD | ERROR | +0 | Module - A default memory card for Slot 1 was not found in "E:\Hyperspin\Emulators\Sony Playstation 2\memcards". Please create an empty memory card called "default.ps2" in this folder for per-game memory card support. 13:54:01:194 | MD | INFO | +31 | Module - Switched memory card in Slot 1 to: E:\Hyperspin\Emulators\Sony Playstation 2\memcards\Jeremy McGrath Supercross World (USA).ps2 13:54:01:204 | MD | INFO | +0 | 7z - Started, received E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms\Jeremy McGrath Supercross World (USA).gz. If rom is an archive, it will extract to C:\Users\Lenovo\AppData\Local\Temp\HS 13:54:01:204 | MD | INFO | +0 | 7z - This rom type does not need 7z: ".gz" 13:54:01:204 | MD | DEBUG1 | +0 | 7z - Starting non-7z FadeIn animation. 13:54:01:224 | MD | DEBUG1 | +32 | 7z - romPath changed from "E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms" to "E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms" 13:54:01:224 | MD | DEBUG1 | +0 | 7z - romName changed from "Jeremy McGrath Supercross World (USA)" to "Jeremy McGrath Supercross World (USA)" 13:54:01:224 | MD | DEBUG1 | +0 | 7z - romExtension changed from ".gz" to ".gz" 13:54:01:224 | MD | INFO | +0 | 7z - Ended 13:54:01:224 | MD | DEBUG1 | +0 | LoadProperties - Started and loading this cfg into memory: E:\Hyperspin\Emulators\Sony Playstation 2\inis\PCSX2_ui.ini 13:54:01:224 | MD | DEBUG1 | +0 | LoadProperties - Ended 13:54:01:234 | MD | DEBUG1 | +0 | ReadProperty - Started 13:54:01:234 | MD | INFO | +0 | Module Setting - [Settings] - Image_CDVD_Plugin: 13:54:01:234 | MD | INFO | +0 | Run - Running: E:\Hyperspin\Emulators\Sony Playstation 2\pcsx2.exe "E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms\Jeremy McGrath Supercross World (USA).gz" --nogui 13:54:01:354 | MD | INFO | +124 | Run - Showing Command Window to troubleshoot launching. ProcessID: 3288 13:54:01:744 | MD | DEBUG1 | +390 | Run - "pcsx2.exe "E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms\Jeremy McGrath Supercross World (USA).gz" --nogui" Process ID: 3288 13:54:01:744 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: Administrator: C:\Windows\system32\cmd.exe - pcsx2.exe "E:\Hyperspin\Emulators\Sony Playstation 2\PS2Roms\Jeremy McGrath Supercross World (USA).gz" --nogui | Class: ConsoleWindowClass | State: 0 | X: 175 | Y: 175 | Width: 677 | Height: 342 | Window HWND: 0x50262 | Process ID: 3288 | Process Path: C:\Windows\SysWOW64\cmd.exe 13:54:01:744 | MD | INFO | +0 | WinWait - Waiting for "ahk_class wxWindowNR" 13:54:03:698 | MD | DEBUG1 | +1950 | GetActiveWindowStatus - Title: Administrator: C:\Windows\system32\cmd.exe | Class: ConsoleWindowClass | State: 0 | X: 175 | Y: 175 | Width: 677 | Height: 342 | Window HWND: 0x50262 | Process ID: 3288 | Process Path: C:\Windows\SysWOW64\cmd.exe 13:54:03:700 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: Administrator: C:\Windows\system32\cmd.exe | Class: ConsoleWindowClass | State: 0 | X: 175 | Y: 175 | Width: 677 | Height: 342 | Window HWND: 0x50262 | Process ID: 3288 | Process Path: C:\Windows\SysWOW64\cmd.exe 13:54:03:703 | MD | INFO | +0 | WinWaitActive - Waiting for "ahk_class wxWindowNR" 13:54:04:259 | MD | DEBUG1 | +562 | GetActiveWindowStatus - Title: GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 26% | GS: 44% | UI: 4% | State 0 | Class: wxWindowNR | State: 0 | X: 0 | Y: 0 | Width: 1440 | Height: 900 | Window HWND: 0x40280 | Process ID: 2772 | Process Path: E:\Hyperspin\Emulators\Sony Playstation 2\pcsx2.exe 13:54:04:329 | MD | INFO | +78 | Module - HideConsole - Console window found, hiding it out of view. 13:54:04:519 | MD | DEBUG1 | +187 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 22% | GS: 22% | UI: 4% | State 0 13:54:04:721 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 22% | GS: 22% | UI: 4% | State 0 13:54:04:956 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 30% | GS: 15% | UI: 3% | State 0 13:54:05:188 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 34% | GS: 0% | UI: 1% | State 0 13:54:05:391 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 34% | GS: 0% | UI: 1% | State 0 13:54:05:593 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 37% | GS: 0% | UI: 0% | State 0 13:54:05:803 | MD | DEBUG1 | +202 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 37% | GS: 0% | UI: 0% | State 0 13:54:06:033 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 33% | GS: 0% | UI: 0% | State 0 13:54:06:237 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 24% | GS: 0% | UI: 0% | State 0 13:54:06:469 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 24% | GS: 0% | UI: 0% | State 0 13:54:06:673 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 19% | GS: 0% | UI: 0% | State 0 13:54:06:903 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 15% | GS: 0% | UI: 0% | State 0 13:54:07:141 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 15% | GS: 0% | UI: 0% | State 0 13:54:07:347 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 24% | GS: 0% | UI: 0% | State 0 13:54:07:580 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 28% | GS: 0% | UI: 0% | State 0 13:54:07:817 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 28% | GS: 0% | UI: 0% | State 0 13:54:08:066 | MD | DEBUG1 | +249 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 37% | GS: 0% | UI: 0% | State 0 13:54:08:299 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 34% | GS: 0% | UI: 0% | State 0 13:54:08:526 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 34% | GS: 0% | UI: 0% | State 0 13:54:08:732 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 34% | GS: 0% | UI: 0% | State 0 13:54:08:965 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 30% | GS: 0% | UI: 0% | State 0 13:54:09:201 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 30% | GS: 0% | UI: 0% | State 0 13:54:09:406 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 36% | GS: 0% | UI: 0% | State 0 13:54:09:641 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 42% | GS: 0% | UI: 0% | State 0 13:54:09:839 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 42% | GS: 0% | UI: 0% | State 0 13:54:10:070 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 44% | GS: 0% | UI: 0% | State 0 13:54:10:308 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 44% | GS: 0% | UI: 0% | State 0 13:54:10:559 | MD | DEBUG1 | +249 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 36% | GS: 0% | UI: 0% | State 0 13:54:10:759 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 31% | GS: 0% | UI: 0% | State 0 13:54:10:992 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 31% | GS: 0% | UI: 0% | State 0 13:54:11:224 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 30% | GS: 0% | UI: 0% | State 0 13:54:11:434 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 33% | GS: 0% | UI: 0% | State 0 13:54:11:664 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 33% | GS: 0% | UI: 0% | State 0 13:54:11:872 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 39% | GS: 0% | UI: 0% | State 0 13:54:12:099 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 39% | GS: 0% | UI: 0% | State 0 13:54:12:303 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 39% | GS: 0% | UI: 0% | State 0 13:54:12:507 | MD | DEBUG1 | +202 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 36% | GS: 0% | UI: 0% | State 0 13:54:12:738 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 27% | GS: 0% | UI: 0% | State 0 13:54:12:940 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 27% | GS: 0% | UI: 0% | State 0 13:54:13:182 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 31% | GS: 0% | UI: 0% | State 0 13:54:13:415 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 36% | GS: 0% | UI: 0% | State 0 13:54:13:642 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 36% | GS: 0% | UI: 0% | State 0 13:54:13:899 | MD | DEBUG1 | +250 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 36% | GS: 0% | UI: 0% | State 0 13:54:14:131 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 28% | GS: 0% | UI: 0% | State 0 13:54:14:363 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 28% | GS: 0% | UI: 0% | State 0 13:54:14:565 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 25% | GS: 0% | UI: 0% | State 0 13:54:14:798 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 27% | GS: 0% | UI: 0% | State 0 13:54:15:008 | MD | DEBUG1 | +202 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 27% | GS: 0% | UI: 0% | State 0 13:54:15:242 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 31% | GS: 0% | UI: 0% | State 0 13:54:15:476 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 33% | GS: 0% | UI: 0% | State 0 13:54:15:707 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 33% | GS: 0% | UI: 0% | State 0 13:54:15:939 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 37% | GS: 0% | UI: 0% | State 0 13:54:16:178 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 36% | GS: 0% | UI: 0% | State 0 13:54:16:410 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 36% | GS: 0% | UI: 0% | State 0 13:54:16:639 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 31% | GS: 0% | UI: 0% | State 0 13:54:16:875 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 28% | GS: 0% | UI: 0% | State 0 13:54:17:105 | MD | DEBUG1 | +234 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 28% | GS: 0% | UI: 0% | State 0 13:54:17:309 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 34% | GS: 0% | UI: 0% | State 0 13:54:17:700 | MD | DEBUG1 | +390 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 34% | GS: 0% | UI: 0% | State 0 13:54:17:900 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Progressive (field) | Limiter: Normal | fps: 0.00 | EE: 34% | GS: 0% | UI: 0% | State 0 13:54:18:104 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Interlaced (frame) | Limiter: Normal | fps: 0.00 | EE: 40% | GS: 0% | UI: 0% | State 0 13:54:18:310 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Interlaced (frame) | Limiter: Normal | fps: 0.00 | EE: 40% | GS: 0% | UI: 0% | State 0 13:54:18:509 | MD | DEBUG1 | +202 | Detected Window Title is GSdx D3D9 HW | Interlaced (frame) | Limiter: Normal | fps: 59.10 | EE: 29% | GS: 0% | UI: 0% | State 0 13:54:18:715 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Interlaced (frame) | Limiter: Normal | fps: 59.10 | EE: 29% | GS: 0% | UI: 0% | State 0 13:54:18:920 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Interlaced (frame) | Limiter: Normal | fps: 52.47 | EE: 30% | GS: 0% | UI: 16% | State 0 13:54:19:120 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Interlaced (frame) | Limiter: Normal | fps: 55.12 | EE: 22% | GS: 0% | UI: 18% | State 0 13:54:19:322 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Interlaced (frame) | Limiter: Normal | fps: 55.12 | EE: 22% | GS: 0% | UI: 18% | State 0 13:54:19:524 | MD | DEBUG1 | +202 | Detected Window Title is GSdx D3D9 HW | Interlaced (frame) | Limiter: Normal | fps: 53.61 | EE: 25% | GS: 0% | UI: 18% | State 0 13:54:19:728 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Interlaced (frame) | Limiter: Normal | fps: 53.61 | EE: 25% | GS: 0% | UI: 18% | State 0 13:54:19:932 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | Interlaced (frame) | Limiter: Normal | fps: 63.96 | EE: 28% | GS: 0% | UI: 1% | State 0 13:54:20:133 | MD | DEBUG1 | +203 | Detected Window Title is GSdx D3D9 HW | 640x444 | Auto | Interlaced (field) | Limiter: Normal | fps: 60.00 | EE: 25% | GS: 9% | UI: 1% | State 0 13:54:20:136 | MD | INFO | +0 | Process - WaitClose pcsx2.exe 13:55:46:560 | MD | DEBUG1 | +86424 | CloseProcess - Started, user requested to end launched application 13:55:46:563 | MD | INFO | +0 | WinClose - Closing: PCSX2 ahk_class wxWindowNR 13:55:46:671 | MD | DEBUG1 | +110 | CloseProcess - Ended 13:55:49:296 | MD | INFO | +2620 | 7zCleanUp - Started 13:55:49:296 | MD | DEBUG1 | +0 | 7zCleanUp - Deleted 13:55:49:296 | MD | INFO | +0 | 7zCleanUp - Ended 13:55:49:296 | MD | INFO | +0 | ExitModule - Started 13:55:49:296 | MD | INFO | +0 | Starting Updating Statistics: 13:55:49:296 | MD | DEBUG2 | +0 | Total Elapsed Time in Pause in seconds: 0 13:55:49:327 | MD | DEBUG2 | +32 | gameSectionStartTime:692176 13:55:49:359 | MD | DEBUG2 | +31 | ElapsedTime:108 13:55:49:359 | MD | DEBUG2 | +0 | Statistics cleared game name: Jeremy McGrath Supercross World 13:55:49:452 | MD | DEBUG2 | +93 | Loaded game statistics from ini files: Number_of_Times_Played: 0 Last_Time_Played: 0 Average_Time_Played: 0 Total_Time_Played: 0 System_Total_Played_Time: 11101 Total_Global_Played_Time: 36616 13:55:49:452 | MD | DEBUG2 | +0 | Updated Statistics: Number_of_Times_Played: 1 Last_Time_Played: Sunday August 23, 2015 01:54:00 PM Average_Time_Played: 108 Total_Time_Played: 108 System_Total_Played_Time: 11209 Total_Global_Played_Time: 36724 13:55:49:546 | MD | INFO | +94 | Game section statistics updated. 13:55:49:546 | MD | INFO | +0 | RunKeymapper - Started, using method "unload" 13:55:49:546 | MD | INFO | +0 | GetJoystickArray - Started 13:55:49:577 | MD | DEBUG2 | +31 | GetJoystickArray - Joysticks Detected: 1000000000000000 13:55:49:577 | MD | INFO | +0 | GetJoystickGUID - Started 13:55:49:577 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 5041DB96E6EDE4118001444553540000 13:55:49:608 | MD | DEBUG2 | +31 | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 5041DB96E6EDE4118001444553540000 13:55:49:639 | MD | INFO | +32 | GetJoystickArray - Ended 13:55:49:639 | MD | DEBUG2 | +0 | RunKeymapper - Looping through controllers to find xpadder profiles for each one 13:55:49:639 | MD | DEBUG2 | +0 | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "Controller (Xbox 360 Wireless Receiver for Windows)" 13:55:49:639 | MD | DEBUG2 | +0 | GetProfile - Searching for these profiles (| delimited): E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI|E:\Rocketlauncher\Profiles\xpadder\_Default\blank 13:55:49:639 | MD | DEBUG2 | +0 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile 13:55:49:671 | MD | DEBUG2 | +31 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile 13:55:49:671 | MD | INFO | +0 | GetProfile - Loading Player 1 Profile -> E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile 13:55:49:671 | MD | INFO | +0 | RunXpadder - Started 13:55:49:702 | MD | INFO | +31 | Process - Exist JoyToKey.exe 13:55:49:733 | MD | DEBUG2 | +31 | RunXpadder - Closing xpadder to refresh controllers seen by xpadder 13:55:49:733 | MD | INFO | +0 | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe /C 13:55:49:795 | MD | DEBUG1 | +63 | Run - "Xpadder.exe /C" Process ID: 1048 13:55:49:795 | MD | DEBUG2 | +0 | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in E:\Hyperspin\Utilities\Xpadder\xpadder.ini 13:55:49:795 | MD | INFO | +0 | Process - WaitClose Xpadder.exe 2 13:55:50:014 | MD | DEBUG2 | +218 | RunXpadder - Reading the order in E:\Hyperspin\Utilities\Xpadder\xpadder.ini and arranging profiles found to match that order 13:55:50:014 | MD | DEBUG2 | +0 | RunXpadder - No more controllers to be found 13:55:50:014 | MD | INFO | +0 | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile" /M 13:55:50:061 | MD | DEBUG1 | +47 | Run - "Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile" /M" Process ID: 3428 13:55:50:061 | MD | INFO | +0 | RunXpadder - Ended 13:55:50:061 | MD | INFO | +0 | RunKeymapper - Ended 13:55:50:061 | MD | INFO | +0 | RunAHKKeymapper - Started 13:55:50:061 | MD | DEBUG1 | +0 | RunAHKKeymapper - Unloading AhkLauncher 13:55:50:061 | MD | DEBUG1 | +0 | RunAHKKeymapper - If AhkLauncher.exe is running, need to close it first before a new profile can be loaded 13:55:50:061 | MD | INFO | +0 | Process - Exist AhkLauncher.exe 13:55:50:061 | MD | INFO | +0 | RunAHKKeymapper - Ended 13:55:50:107 | MD | DEBUG1 | +47 | ExitModule - Closing command window: cmd.exe PID: 3288 13:55:50:107 | MD | INFO | +0 | Process - Close cmd.exe 13:55:50:107 | MD | INFO | +0 | ExitModule - Ended 13:55:50:107 | MD | INFO | +0 | End of Module Logs 13:55:50:201 | RL | INFO | +109356 | Main - Module ended, exiting RocketLauncher normally 13:55:50:201 | RL | INFO | +0 | ExitScript - Started 13:55:50:201 | RL | DEBUG1 | +0 | ExitScript - Checking what application is currently in focus. 13:55:50:217 | RL | INFO | +16 | SystemCursor - Restoring mouse cursor 13:55:50:217 | RL | INFO | +0 | ExitScript - Ended HERE IS THE MODULE MEmu = PCSX2 MEmuV = 1.1.0.r5695 MURL = http://pcsx2.net/ MAuthor = djvj MVersion = 2.1.4 MCRC = 17664BEB iCRC = 776E3DD9 MID = 635038268913291718 MSystem = "Sony PlayStation 2" ;---------------------------------------------------------------------------- ; Notes: ; This module has many settings that can be controlled via RocketLauncherUI ; If you want to customize settings per game, add the game to the module's ini using RocketLauncherUI ; If you use Daemon Tools, make sure you have a SCSI virtual drive setup. Not a DT one. ; Tested Virtual Drive support with the cdvdGigaherz CDVD plugin. Make sure you set it to use your SCSI Virtual Drive letter. ; Module will set the CdvdSource to Plugin or Iso depending on if you have Virtual Drive enabled or not. ; If you have any problems closing the emulator, make sure noGUI module setting in RocketLauncherUI is set to default or false. ; ; Per-game memory cards ; This module supports per-game memory cards to prevent them from ever becoming full ; To use this feature, set the PerGameMemoryCards to true in RocketLauncherUI ; You need to create a default blank memory card in the path you have defined in pcsx's ini found in section [Folders], key MemoryCards. ; Make sure one of the current memory cards are blank, then copy it in that folder and rename it to "default.ps2". The module will copy this file to a romName.ps2 for each game launched. ; The module will only insert memory cards into Slot 1. So save your games there. ; ; Linuz cdvd plugin stores its settings in the registry @ HKEY_CURRENT_USER\Software\PS2Eplugin\CDVD\CDVDiso ; ; Run pcsx2 with the --help option to see current CLI parameters ; ; Known CLI options not currently supported by this module: ; --console forces the program log/console to be visible ; --portable enables portable mode operation (requires admin/root access) ; --elf=<str> executes an ELF image ; --forcewiz forces PCSX2 to start the First-time Wizard ;---------------------------------------------------------------------------- StartModule() BezelGUI() FadeInStart() ; PCSX2_ui.ini = default ini that contains memory card info and general settings If FileExist(emuPath . "\portable.ini") { ; portable install Log("Module - PCSX2 is operating in a portable mode") pcsx2IniFile := CheckFile(emuPath . "\inis\PCSX2_ui.ini", "Could not find the default PCSX2_ui.ini file. Please manually run and configure PCSX2 first so this file is created with all your default settings.") } Else { ; default not portable install Log("Module - PCSX2 is operating in a standard installation mode") RegRead, pcsx2IniFolder, HKCU, Software\PCSX2, SettingsFolder pcsx2IniFile := CheckFile(pcsx2IniFolder . "\PCSX2_ui.ini", "Could not find the default PCSX2_ui.ini file. Please manually run and configure PCSX2 first so this file is created with all your default settings.") } settingsFile := modulePath . "\" . moduleName . ".ini" ; global settings Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) noGUI := IniReadCheck(settingsFile, "Settings", "noGUI","false",,1) ; disables display of the gui while running games fullboot := IniReadCheck(settingsFile, "Settings", "fullboot","false",,1) ; disables the quick boot feature, forcing you to sit through the PS2 startup splash screens perGameMemCards := IniReadCheck(settingsFile, "Settings", "PerGameMemoryCards","true",,1) hideConsole := IniReadCheck(settingsFile, "Settings", "HideConsole","true",,1) ; Hides console window from view if it shows up cfgPath := IniReadCheck(settingsFile, "Settings", "cfgpath", emuPath . "\Game Configs",,1) ; specifies the config folder; applies to pcsx2 + plugins autoCreateINIDir := IniReadCheck(settingsFile, "Settings", "AutoCreateINIDir","false",,1) ; Enables the module to auto-create of per game ini files and directories defaultINISPath := IniReadCheck(settingsFile, "Settings", "DefaultINISPath",,,1) ; Path to default INIS folder of PCSX2. gs := IniReadCheck(settingsFile, "Settings|" . romName, "gs",,,1) ; override for the GS plugin pad := IniReadCheck(settingsFile, "Settings|" . romName, "pad",,,1) ; override for the PAD plugin spu2 := IniReadCheck(settingsFile, "Settings|" . romName, "spu2",,,1) ; override for the SPU2 plugin cdvd := IniReadCheck(settingsFile, romName, "cdvd",,,1) ; override for the CDVD plugin usb := IniReadCheck(settingsFile, "Settings|" . romName, "usb",,,1) ; override for the USB plugin fw := IniReadCheck(settingsFile, "Settings|" . romName, "fw",,,1) ; override for the FW plugin dev9 := IniReadCheck(settingsFile, "Settings|" . romName, "dev9",,,1) ; override for the DEV9 plugin vdOveride := IniReadCheck(settingsFile, romName, "VDOveride","false",,1) nohacks := IniReadCheck(settingsFile, romName, "nohacks","false",,1) ; disables all speedhacks gamefixes := IniReadCheck(settingsFile, romName, "gamefixes",,,1) ; Enable specific gamefixes for this session. Use the specified comma or pipe-delimited list of gamefixes: VuAddSub,VuClipFlag,FpuCompare,FpuMul,FpuNeg,EETim ing,SkipMpeg,OPHFlag,DMABusy,VIFFIFO,VI,FMVinSoftw are cfgPath := GetFullName(cfgPath) IfNotExist % cfgPath FileCreateDir, %cfgPath% ; create the cfg folder if it does not exist ; Create INIs subfolder for the game if it does not exist and if AutoCreateINIDir is true If (autoCreateINIDir = "true") { perINIPath := cfgPath . "\" . romName Log("Module - PerGameIni - perINIPath = " . perINIPath,4) If !FileExist(perINIPath) { If (defaultINISPath != "") { Log("Module - PerGameIni - perINIPath does not exist. So we will create it at " . PerINIPath,4) FileCreateDir, %perINIPath% Log("Module - PerGameIni - Now to copy the ini files from " . defaultINISPath . " to " . perINIPath . ".",4) FileCopy, %defaultINISPath%\*.ini, %perINIPath% } Else { Log("Module - PerGameIni - perINIPath does not exist. So we will create it at " . PerINIPath,4) FileCreateDir, %perINIPath% Log("Module - PerGameIni - Now to copy the ini files from " . emuPath . "\inis" . " to " . perINIPath . ".",4) FileCopy, %emuPath%\inis\*.ini, %perINIPath% } } } BezelStart() Fullscreen := If Fullscreen = "true" ? " --fullscreen" : "" noGUI := If noGUI = "true" ? " --nogui" : "" If (noGUI != "") Log("Module - noGUI is set to true, THIS MAY PREVENT PCSX2 FROM CLOSING PROPERLY. If you have any issues, set it to false or default in RocketLauncherUI.",2) fullboot := If fullboot = "true" ? " --fullboot" : "" nohacks := If nohacks = "true" ? " --nohacks" : "" gamefixes := If gamefixes ? " --gamefixes=" . gamefixes : "" gs := If gs ? " --gs=""" . GetFullName(gs) . """" : "" pad := If pad ? " --pad=""" . GetFullName(pad) . """" : "" spu2 := If spu2 ? " --spu2=""" . GetFullName(spu2) . """" : "" usb := If usb ? " --usb=""" . GetFullName(usb) . """" : "" fw := If fw ? " --fw=""" . GetFullName(fw) . """" : "" dev9 := If dev9 ? " --dev9=""" . GetFullName(dev9) . """" : "" cfgRomPath := cfgPath . "\" . romName cfgPathCLI := If FileExist(cfgRomPath) ? " --cfgpath=""" . GetFullName(cfgRomPath) . """" : "" ; Specify what main ini PCSX2 should use If (cfgPathCLI && FileExist(cfgRomPath . "\PCSX2_ui.ini")) { ;We can't set both cfgpath and cfg CLI switches, so if only PCSX2_ui.ini file exists we use cfg otherwise we use cfgpath ;--cfg specifies a custom configuration file to use instead of PCSX2.ini (does not affect plugins) filecount := 0 Loop, %cfgRomPath%\*.ini filecount++ If (filecount == 1) { ;Only PCSX2_ui.ini found pcsx2IniFile := cfgRomPath . "\PCSX2_ui.ini" Log("Module - Found a game-specific PCSX2_ui.ini in the cfgPath. Telling PCSX2 to use this one instead: " . pcsx2IniFile) cfg := " --cfg=""" . pcsx2IniFile . """" cfgPathCLI := "" } } Log("Module - " . (If cfgPathCLI != "" ? "Setting PCSX2's config path to """ . cfgRomPath . """" : "Using PCSX2's default configuration folder: """ . emuPath . "\inis""")) ; Memory Cards If perGameMemCards = true { IniRead, currentMemCard1, %pcsx2IniFile%, MemoryCards, Slot1_Filename IniRead, memCardPath, %pcsx2IniFile%, Folders, MemoryCards ; folder where memory cards are stored StringLeft, memCardPathLeft, memCardPath, 3 memCardPathIsAbsolute := If (RegExMatch(memCardPathLeft, "[a-zA-Z]:\\") && (StrLen(memCardPath) >= 3)) ; this is 1 only when path looks like this "C:\" memCardPath := If memCardPathIsAbsolute ? memCardPath : emuPath . "\" . memCardPath ; if only a folder name is defined for the memory card path, tack on the emuPath to find the memory cards, otherwise leave the full path as is defaultMemCard := memCardPath . "\default.ps2" ; defining default blank memory card for slot 1 Log("Module - Default memory card for Slot 1 should be: " . defaultMemCard,4) romMemCard1 := memCardPath . "\" . romName . ".ps2" ; defining name for rom's memory card for slot 1 Log("Module - Rom memory card for Slot 1 should be: " . romMemCard1,4) Log("Module - Current memory card inserted in PCSX2's ini in Slot 1 is: " . currentMemCard1) If (currentMemCard1 != romName . ".ps2") { ; if current memory card in slot 1 does not match this romName, switch to one that does if exist or load a default one IfNotExist, %romMemCard1% ; first check if romName.ps2 memory card exists IfNotExist, %defaultMemCard% Log("Module - A default memory card for Slot 1 was not found in """ . memCardPath . """. Please create an empty memory card called ""default.ps2"" in this folder for per-game memory card support.",3) Else { FileCopy, %defaultMemCard%, %romMemCard1% ; create a new blank memory card for this game Log("Module - Creating a new blank memory card for this game in Slot 1: " . romMemCard1) } IniWrite, %romName%.ps2, %pcsx2IniFile%, MemoryCards, Slot1_Filename ; update the ini to use this rom's card Log("Module - Switched memory card in Slot 1 to: " . romMemCard1) } } hideEmuObj := Object("ahk_class wxWindowNR",1) ; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later 7z(romPath, romName, romExtension, 7zExtractPath) pcsx2Ini := LoadProperties(pcsx2IniFile) ; load the config into memory dvdSource := ReadProperty(pcsx2Ini,"CdvdSource") ; read value ; Mount the CD using a Virtual Drive If (vdOveride = "true") ; this allows per-game Virtual Drive support because some games boot to black when Virtual Drive is enabled vdEnabled := vdOveride If (vdEnabled = "true" && InStr(".mds|.mdx|.b5t|.b6t|.bwt|.ccd|.cue|.isz|.nr g|.cdi|.iso|.ape|.flac", romExtension)) { ; if Virtual Drive is enabled and using an image type Virtual Drive can load If !cdvd { vdCDVDPlugin := IniReadCheck(settingsFile, "Settings", "VD_CDVD_Plugin",,,1) If vdCDVDPlugin cdvd := vdCDVDPlugin } cdvd := If cdvd ? " --cdvd=""" . GetFullName(cdvd) . """" : "" If dvdSource != Plugin { Log("Module - CdvdSource was not set to ""Plugin"", changing it so PCSX2 can read from Virtual Drive.") WriteProperty(pcsx2Ini,"CdvdSource","Plugin") ; write a new value to the pcsx2IniFile SaveProperties(pcsx2IniFile,pcsx2Ini) ; save pcsx2IniFile to disk } VirtualDrive("mount",romPath . "\" . romName . romExtension) HideEmuStart() errLvl := Run(executable . " --usecd" . noGUI . Fullscreen . fullboot . nohacks . gamefixes . cfg . cfgPathCLI . gs . pad . spu2 . cdvd . usb . fw . dev9, emuPath, "UseErrorLevel") usedVD = 1 ; tell the rest of the script to use VD methods } Else If romExtension in .iso,.mdf,.nrg,.bin,.img,.gz ; the only formats PCSX2 supports loading directly { If !cdvd { imageCDVDPlugin := IniReadCheck(settingsFile, "Settings", "Image_CDVD_Plugin",,,1) If imageCDVDPlugin cdvd := imageCDVDPlugin } cdvd := If cdvd ? " --cdvd=""" . GetFullName(cdvd) . """" : "" If dvdSource != Iso { Log("Module - CdvdSource was not set to ""Iso"", changing it so PCSX2 can launch this " . romExtension . " image directly") WriteProperty(pcsx2Ini,"CdvdSource","Iso") ; write a new value to the pcsx2IniFile SaveProperties(pcsx2IniFile,pcsx2Ini) ; save pcsx2IniFile to disk } HideEmuStart() errLvl := Run(executable . " """ . romPath . "\" . romName . romExtension . """ " . noGUI . Fullscreen . fullboot . nohacks . gamefixes . cfg . cfgPathCLI . gs . pad . spu2 . cdvd . usb . fw . dev9, emuPath, "UseErrorLevel") } Else If romExtension in .bz2 ; special case format that requires plugin mode and pcsx2 loads it directly { If !cdvd { linuzCDVDPlugin := IniReadCheck(settingsFile, "Settings", "Linuz_CDVD_Plugin",,,1) If linuzCDVDPlugin cdvd := linuzCDVDPlugin } cdvd := If cdvd ? " --cdvd=""" . GetFullName(cdvd) . """" : "" If dvdSource != plugin { Log("Module - CdvdSource was not set to ""Plugin"", changing it so PCSX2 can launch this " . romExtension . " image directly") WriteProperty(pcsx2Ini,"CdvdSource","Plugin") ; write a new value to the pcsx2IniFile SaveProperties(pcsx2IniFile,pcsx2Ini) ; save pcsx2IniFile to disk } oldHex := ReadReg("IsoFile") ; read last used bz2 image newHex := StrToHex(romPath . "\" . romName . romExtension) ; convert new bz2 image path to hex i := 512 - StrLen(newHex) ; get total amount of 0's to add to end of hex to make it 512 bytes Loop, %i% newHex := newHex . "0" ; add required bytes to end If (oldHex != newHex) { Log("Module - Writing new bz2 path to registry",4) WriteReg("IsoFile", newHex) ; write new bz2 path to registry } HideEmuStart() errLvl := Run(executable . " """ . romPath . "\" . romName . romExtension . """ " . noGUI . Fullscreen . fullboot . nohacks . gamefixes . cfg . cfgPathCLI . gs . pad . spu2 . cdvd . usb . fw . dev9, emuPath, "UseErrorLevel") } Else ScriptError("You are trying to run a rom type of """ . romExtension . """ but PCSX2 only supports loading iso|mdf|nrg|bin|img|gz directly. Please turn on Virtual Drive and/or 7z support or put ""cue"" last in your rom extensions for " . MEmu . " instead.") If errLvl ScriptError("Error launching emulator, closing script.") WinWait("ahk_class wxWindowNR",,, "PCSX2") WinWaitActive("ahk_class wxWindowNR",,, "PCSX2") BezelDraw() If hideConsole = true SetTimer, HideConsole, 10 SetTitleMatchMode 2 ;Wrong window might be detected in the next loop if we only use the class name for WinGetTitle so we will add fps to it Loop { ; looping until pcsx2 is done loading game ; tooltip, loop %A_Index%,0,0 Sleep, 200 WinGetTitle, winTitle, fps ahk_class wxWindowNR,, PCSX2 ; excluding the title of the GUI window so we can read the title of the game window instead Log("Detected Window Title is " . winTitle,4) StringSplit, winTextSplit, winTitle, |, %A_Space% If ( winTextSplit10 != "" ) ; 10th position in the array is empty until game actually starts break } HideEmuEnd() FadeInExit() Process("WaitClose", executable) If usedVD VirtualDrive("unmount") 7zCleanUp() BezelExit() FadeOutExit() ExitModule() ReadReg(var1) { regValue := RegRead("HKEY_CURRENT_USER", "Software\PS2Eplugin\CDVD\CDVDiso", var1) Return %regValue% } WriteReg(var1, var2, ValueType="REG_BINARY") { RegWrite(ValueType, "HKEY_CURRENT_USER", "Software\PS2Eplugin\CDVD\CDVDiso", var1, var2) } StrToHex(S) { Return S="" ? "":Chr((*&S>>4)+48) Chr((x:=*&S&15)+48+(x>9)*7) StrToHex(SubStr(S,2)) } MultiGame: ; msgbox % "selectedRom = " . selectedRom . "`nselected game = " . currentButton . "`nmgRomPath = " . mgRomPath . "`nmgRomExt = " . mgRomExt . "`nmgRomName = " . mgRomName ; Unmount the CD from Virtual Drive If usedVD VirtualDrive("unmount") Sleep, 500 ; Required to prevent your Virtual Drive from bugging ; Mount the CD using Virtual Drive If usedVD VirtualDrive("mount",selectedRom) Return HideConsole: hideConsoleTimer++ IfWinExist, Booting ahk_class wxWindowNR { Log("Module - HideConsole - Console window found, hiding it out of view.") WinSet, Transparent, 0, Booting ahk_class wxWindowNR,,fps:,fps: ; hiding the console window WinSet, Transparent, 0, PCSX2 ahk_class wxWindowNR,,fps:,fps: ; hiding the GUI window with the menubar SetTimer, HideConsole, Off } Else If hideConsoleTimer >= 200 SetTimer, HideConsole, Off Return CloseProcess: FadeOutStart() WinMenuSelectItem, PCSX2 ahk_class wxWindowNR,, System, Pause WinClose("PCSX2 ahk_class wxWindowNR") ; sending command to the GUI window to properly close the entire emu Return
demonseed Posted August 23, 2015 Author Posted August 23, 2015 Hey OK I think I solved it... RESTORE on exit.. seems to work.. I will test it more... The only thing I find annoying is on exit from PCSX2 to HS it still flashes PCSX2 windowed over top of HS before closing PCSX2.. not sure how to eliminate that.
