Shelled Hyperspin & .bat file (CMD window visibility)
Last Action Gringo
Hi Hyperspinners,
I'm using .bat files to launch emulators at certain save states (mainly to skip hardware tests where alternate bios isn't available, users of this cab won't know what a hardware test is, so I don't want them thinking they've broken it!). This works really well running HS with windows as the shell, but when I shell HS something changes, and my perfectionism kicks in.
Due to the lack of a taskbar to minimise to, minimised CMD windows show as a tiny window header in the bottom left (over the top of HS) when I run the .bat (it's only there for a split second for most games, but like I said: perfectionism!)
Possible solutions I've seen:
I've seen people mention VB scripts to hide this but I don't know if i can get HS to run a VBS.
Does anyone else have this issue - or has anyone else already got a work around?
P.S. Apologies if this has already been covered on the forums, I find the new forum search tool doesn't always turn up stuff i'm looking for!
This all seems unnecessary though. I have 70 systems setup and working and I simply use the HyperSpin Startup Script to get things going.
