Enable cheat menu in HS
redlightracer
I am running mame UI .141u2 and HS 1.2.0.0. I have enabled cheats in mame and when I run mame outside of HS cheat menu appears, But when I am running HS cheat menu does not appear or F6 will not enable them. I have tried to look every place I could for info before posting here and I am at a dead end! Thank you for any info or help!!
  • 4 weeks later...
I have the same problem.  In RocketLauncherUI, Modules tab, Edit Global Module Settings, I changed CheatMode to true.  I can use Cheats when launched from RocketLauncher or MAME.  However, the cheats menu does not appear when launched from HyperSpin.  Thank you for any help!
Are you guys using X-Arcade controllers? There is a super strange issue with HS that prevents the cheat menu to appear when using an X-arcade. If you use the actual keyboard instead of the button on the X-arcade that is mapped to the cheat key, it will work. This only happens in HS. It works great when launching MAME in RockeLauncherUI.
I am not using X-Arcade.  I am using the keyboard.  I will connect to an IPAC in my arcade cabinet as soon as I resolve this cheat issue.  Any help would be much appreciated!
