Bushgopher Posted September 12, 2015 Posted September 12, 2015 So I finally get hyperspin to work after reinstalling it and rocketlauncher. Hyperspin is vs 1.4 and rocketlauncher is up to date. Now i can get at least one mame rom to load from hyperspin when my computer is first turned on but after that it wont load any unless i restart my computer. Anyone dealt with this before? 01:43:58 PM | HyperSpin Started01:43:58 PM | Going FullScreen01:43:58 PM | Checking for updates01:43:58 PM | Update Check Complete01:43:58 PM | Startup program unavailable01:43:58 PM | Playing intro video01:44:05 PM | Error intializing joysticks01:44:05 PM | Menu Mode is single01:44:05 PM | Loading MAME.xml01:44:05 PM | MAME.xml successfully loaded01:44:06 PM | MAME wheel loaded successfully01:44:09 PM | Launching Game01:44:09 PM | Using HyperLaunch01:44:09 PM | Getting Launcher path01:44:09 PM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe01:44:09 PM | Launcher located at G:\HyperSpin\HyperLaunch.exe01:44:09 PM | Running Launcher01:44:09 PM | Launcher Command Line is: G:\HyperSpin\HyperLaunch.exe "MAME" "ldrun"01:47:13 PM | Launching Game01:47:13 PM | Using HyperLaunch01:47:13 PM | Getting Launcher path01:47:13 PM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe01:47:13 PM | Launcher located at G:\HyperSpin\HyperLaunch.exe01:47:13 PM | Running Launcher01:47:13 PM | Launcher Command Line is: G:\HyperSpin\HyperLaunch.exe "MAME" "looping"01:47:20 PM | Launching Game01:47:20 PM | Using HyperLaunch01:47:20 PM | Getting Launcher path01:47:20 PM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe01:47:20 PM | Launcher located at G:\HyperSpin\HyperLaunch.exe01:47:20 PM | Running Launcher01:47:20 PM | Launcher Command Line is: G:\HyperSpin\HyperLaunch.exe "MAME" "looping"01:47:22 PM | Launching Game01:47:22 PM | Using HyperLaunch01:47:22 PM | Getting Launcher path01:47:22 PM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe01:47:22 PM | Launcher located at G:\HyperSpin\HyperLaunch.exe01:47:22 PM | Running Launcher01:47:22 PM | Launcher Command Line is: G:\HyperSpin\HyperLaunch.exe "MAME" "looping"01:47:25 PM | Exit program unavailable01:47:25 PM | Quiting Hyperspin01:47:25 PM | Bye! Load runner would lould load first but after exiting that game and trying to load looping it wouldnt load any more.
Bushgopher Posted September 14, 2015 Author Posted September 14, 2015 I know. I've tried renaming the hyperlaunch path to "g:\rocketlauncher\rocket launcher.exe\" in the settings.ini file and it still always looks like the log I put up. I went through all the settings in rlui so I'm not sure what else to do.
Bushgopher Posted September 14, 2015 Author Posted September 14, 2015 OK I'll give that a try. Thanks for the help.
Bushgopher Posted September 16, 2015 Author Posted September 16, 2015 I changed my hyperlaunch path in the settings.ini file as shown in bold. [Main]Menu_Mode=singleSingle_Mode_Name=MAMEEnable_Exit_Menu=trueEnable_Exit=trueExit_Default=yesExit_Action=exitVersion=1.0.0.0Last_System=MAMEHyperlaunch_Path=G:\RocketLauncher\RocketLauncher.exe\ [Resolution]FullScreen=trueWidth=800Height=600Scanlines_Active=falseScanlines_Image=Scanlines_Scale=2Scanlines_Alpha=0.1 [Optimizer]CPU_Priority=normalQuality=HIGHImage_Smoothing=trueAnimated_Backgrounds=trueInter_Backgrounds=falseLevel1_Backgrounds=trueLevel2_Backgrounds=trueLevel3_Backgrounds=falseLevel4_Backgrounds=falseSpecial_Backgrounds=trueWait_For_Special=falseAnimated_Artworks=trueLevel1_Artworks=trueLevel2_Artworks=true [introVideo]Use_Intro=trueStop_On_Keypress=true [sound]Master_Volume=100Video_Volume=100Wheel_Volume=20Interface_Volume=100 [AttractMode]Active=trueTime=20MaxSpinTime=5HyperSpin=trueWait_For_Video=false [Keyboard]Key_Delay=true [P1 Controls]Start=13Exit=27Up=38Down=40SkipUp=37SkipDown=39SkipUpNumber=70SkipDownNumber=86HyperSpin=32Genre=71Favorites=76 [P2 Controls]Start=69Exit=81Up=87Down=83SkipUp=65SkipDown=68SkipUpNumber=74SkipDownNumber=77HyperSpin=88Genre=72Favorites=90 [P1 Joystick]Enabled=falseJoy=0Threshold=40Start=Button_1Exit=Button_2Up=Analog_UpDown=Analog_DownSkipUp=Analog_LeftSkipDown=Analog_RightSkipUpNumber=Button_3SkipDownNumber=Button_4HyperSpin=Button_5Genre=Button_6Favorites=Button_7 [P2 Joystick]Enabled=falseJoy=1Threshold=40Start=Button_1Exit=Button_2Up=Analog_UpDown=Analog_DownSkipUp=Analog_LeftSkipDown=Analog_RightSkipUpNumber=Button_3SkipDownNumber=Button_4HyperSpin=Button_5Genre=Button_6Favorites=Button_7 [Trackball]Enabled=falseSensitivity=90 [spinner]Enabled=falseSensitivity=90 [startup Program]Executable=Paramaters=Working_Directory=WinState=[Exit Program]Executable=Paramaters=Working_Directory=WinState=NORMAL [LEDBlinky]Active=falsePath= [HiScore]Active=falseY=550Delay=2[HyperLaunch]Last_System=MAMELast_Rom=ldrunExit_Script_Key=~q & ~sExit_Emulator_Key=EscToggle_Cursor_Key=tMultiGame_Key=NumpadSubMultiGame_Select_Key=EnterMultiGame_Exit_Key=EscPath_To_Daemontools=Path_To_CPWizard=Fade_In_Interrupt_Keys=anykeyKeymapper_Path=Keymapper_Profiles_Path=G:\HyperSpin\Keymapper Profiles\ But when you look at my hyperspin log it doesn't show it. 09:36:00 PM | HyperSpin Started09:36:00 PM | Going FullScreen09:36:00 PM | Checking for updates09:36:00 PM | Update Check Complete09:36:00 PM | Startup program unavailable09:36:00 PM | Playing intro video09:36:02 PM | Error intializing joysticks09:36:02 PM | Menu Mode is single09:36:02 PM | Loading MAME.xml09:36:03 PM | MAME.xml successfully loaded09:36:03 PM | MAME wheel loaded successfully09:38:03 PM | Launching Game09:38:03 PM | Using HyperLaunch09:38:03 PM | Getting Launcher path09:38:03 PM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe09:38:03 PM | Launcher located at G:\HyperSpin\HyperLaunch.exe09:38:03 PM | Running Launcher09:38:03 PM | Launcher Command Line is: G:\HyperSpin\HyperLaunch.exe "MAME" "ssf2"09:38:09 PM | Exit program unavailable09:38:09 PM | Quiting Hyperspin09:38:09 PM | Bye! I just don't know what else to do. I really like the look and feel of hyperspin and i dont want to abandon the project quite yet.
Bushgopher Posted September 16, 2015 Author Posted September 16, 2015 nevermind i figured it out. no slash at the end. thanks anyways
Bushgopher Posted September 16, 2015 Author Posted September 16, 2015 Sorry i didnt see your post and you were right. Id buy you a case of beer if i could. Thanks again.
