  • 0
Como Selecionar Start+Select pra sair do Emulador?
alissongamer
Question
Pessoal, estou com uma dúvida, criei um perfil no Xpadder para o Hyperspin e consegui fazer ele iniciar e depois fechar quando sai do emulador, tudo via o HyperSpin Startup Script.
 Agora estou querendo criar uma associação de teclas pra sair do emulador, por exemplo apertando Start+Select no controle simularia a tecla Esc do teclado. Já tentei criando um perfil no RocketLauncher do Xpadder e até do JoyToKey, mas ambos só tem opção pra selecionar apenas um botão para o Esc.
 Teria uma maneira de fazer com que Start+Select simulem o Esc?
3 answers to this question
1. Right click "start button" > Set Selector > Set 2 > While Held
2. click number 2 at bottom of x-padder so it becomes green
3. Left click "select button" > Advanced (bottom right corner) > Assignments > Add Hold Zone (green button) > set it to 1 or 2 seconds > Press Esc Key > Add Release Zone (yellow button)
4. Save profile
4. Save profile
Thanks again for helping me.
Next, I managed to make their scheme, and the right Xpadder, we hold "Start Button" and he sends to "screen 2" and there appears the "Esc" in the "Select Button" and have tested it on my computer I other applications.
I just did a test, I left the default button to exit the hyperspin as "Esc" and functioned normally. It is only in the emulator that does not work (or Hyperlaunch). You know what could be wrong?
Hyperlaunch he did not functioned, I select and nothing happens.
Did you create a new profile for that emulator? I created a x-padder profile for each system. Once you start the emulator, Rocketlauncher automatically switches x-padder profiles for that particular system. It's a bit of work but that gets you the best results.
