Xpadder & RocketLauncher, 6 Controller Setup Help
axythetaxi
Hi everyone,
I've been having a problem trying to set-up my ideal controller configuration which I can't seem to work out.
I have a total of 6 controllers which all have their own Xpadder profiles
My main issue is that when launching HyperSpin or an Emulator, Xpadder will only load one profile and assign it to all my controllers I have plugged in, resulting in them all having player 1's button config
What I really need is for each of them to pick up their own profiles
The profile that is applied to all my controllers is also the last one I click on before leaving RocketLaunchers Keymapper section.
Is there no way to get each controller to use its own profiles and allow me to select which button-set it uses manually?
Currently swapping profiles around by hand gets reset once I swap emulator and go back to HyperSpin.
This is pretty much the last hurdle I can see me facing with my HyperSpin set-up, any thoughts would be grateful.
Thanks
:thumbsup:
(PS I have searched around the forum and haven't come across anything like this, there have been some similar but none using more than two controllers or clearly answering the question)
