Sheep190 Posted September 26, 2015 Posted September 26, 2015 I've got a problem. I'm using Hyperspin and RetroArch for my SNES and Neo Geo emulation. I'm using the X arcade 2 player controller. with the default settings. I've changed the key config in RA to match my controller but it doesn't work properly in the SNES emulator, NEO GEO works fine though. My second player uses the numlock keys for movement(up down left right)(8,4,6,2). but it only registers when the keyboard is pressed, not when the joystick is pressed. My other buttons work fine though for player two(jumping kicking etc.), only the movement doesn't... I've tried various things like numlock on/off disconnect the keyboard al together but it still wont register in SNES. Thanks in advance!
JayC Posted September 27, 2015 Posted September 27, 2015 Check the config file for SNES. Check your input. Might have the inputs wrong. Check against one of the already working configs.
Sheep190 Posted September 28, 2015 Author Posted September 28, 2015 Gonna check it tonight, hope I can get it working, it's real annoying!
