PC Games/Mugen Loading behind HS?
demonseed
I was finally able to get MUGEN games to run in HS via PClauncher. I have them setup in my PC Games section.  The thing I do not understand is sometimes I run HS and they work fine, then other times, when I click a MUGEN game it loads in the taskbar? I pasted my log... maybe someone can help me? I can not figure out the issue as it is hit and miss .
22:18:35:426 | RL |     INFO  | +N/A   | Main - RocketLauncher v1.0.1.3 (www.rlauncher.com)
22:18:35:426 | RL |  WARNING  | +0     | Main - You have "Logging_Log_Command_Window" enabled. This is only for logging errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done.
22:18:35:516 | RL |     INFO  | +78    | Main - System Specs:
     RocketLauncher Dir: E:\Rocketlauncher
     RocketLauncher is: 32-bit
     OS: Microsoft Windows 7 Professional
     SKU: Professional
     Total Memory: 8016.31 MB
     Free Memory: 6108.07 MB
     Used Memory: 1908.242 MB
     SystemType: 64-bit
     Physical Processors: 1
     Logical Processors: 4
     GPU 1 Name: Intel(R) HD Graphics
     GPU 1 RAM: -1924.00 MB
     GPU 1 Driver Version: 9.17.10.3347
     Sound 1 Device: High Definition Audio Device
     Sound 1 Status: Enabled
     Sound 2 Device: High Definition Audio Device
     Sound 2 Status: Enabled
     OS Admin Status: Yes
     Latest .Net Version: v4.0.30319
     Monitor #1 (\\.\DISPLAY1): 1440x900 (1440x860 work) [Landscape] (Primary)
     Current AHK Desktop Width: 1440
     Current AHK Desktop Height: 900
     AutoHotkey Path: C:\Program Files\AutoHotkey\AutoHotkey.exe
     AHK Version: 1.1.09.04
     Unicode: No
22:18:35:516 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\RocketLauncher.exe exists
22:18:35:526 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
     FileDescription          RocketLauncher
     FileVersion              1.0.1.3
     LegalCopyright           ©2015 RocketLauncher
     ProductName              djvj's one swell guy!
     ProductVersion           1.1.9.4
     CompanyName              Your favorite Front End companion! Visit us @ www.rlauncher.com
     File Size:   2061824 bytes
     Created:   5/23/2015 - 11:53:13 PM
     Modified:   9/6/2015 - 9:32:08 PM
22:18:35:536 | RL |     INFO  | +15    | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\BinHexRW.ahk exists
22:18:35:546 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
22:18:35:546 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   4961 bytes
     Created:   5/24/2015 - 9:27:48 AM
     Modified:   6/4/2014 - 11:48:13 PM
22:18:35:546 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\BlockInput.exe exists
22:18:35:556 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
     FileDescription
     FileVersion              1.1.09.04
     InternalName
     OriginalFilename
     ProductName
     ProductVersion           1.1.09.04
     File Size:   657920 bytes
     Created:   5/24/2015 - 9:26:42 AM
     Modified:   1/2/2014 - 11:27:34 PM
22:18:35:556 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\CLR_L.ahk exists
22:18:35:566 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
22:18:35:566 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   5474 bytes
     Created:   9/6/2015 - 9:32:14 PM
     Modified:   9/6/2015 - 9:32:14 PM
22:18:35:566 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Control_AniGif.ahk exists
22:18:35:586 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
22:18:35:586 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   5716 bytes
     Created:   5/24/2015 - 9:26:30 AM
     Modified:   4/29/2013 - 2:56:02 PM
22:18:35:586 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gdip.ahk exists
22:18:35:596 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
22:18:35:606 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   88789 bytes
     Created:   5/24/2015 - 8:02:39 AM
     Modified:   1/13/2013 - 6:07:30 PM
22:18:35:606 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gdip_alt.ahk exists
22:18:35:616 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
22:18:35:616 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   5895 bytes
     Created:   5/24/2015 - 9:25:59 AM
     Modified:   6/28/2015 - 7:41:33 AM
22:18:35:616 | RL |   DEBUG1  | +0     | gdip_alt.ahk Version: 1.0.2
22:18:35:626 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gsdll32.dll exists
22:18:35:626 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   13090816 bytes
     Created:   5/24/2015 - 9:25:19 AM
     Modified:   1/6/2015 - 10:20:42 PM
22:18:35:626 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\itextsharp.dll exists
22:18:35:636 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
     FileDescription          iTextSharp
     FileVersion              5.4.2.0
     InternalName             itextsharp.dll
     LegalCopyright           Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
     OriginalFilename         itextsharp.dll
     ProductName              iTextSharp
     ProductVersion           5.4.2.0
     CompanyName              1T3XT BVBA
     File Size:   3743744 bytes
     Created:   5/24/2015 - 9:24:07 AM
     Modified:   6/14/2013 - 3:06:21 PM
22:18:35:636 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Java.ahk exists
22:18:35:656 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
22:18:35:666 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
     File Size:   7841 bytes
     Created:   5/24/2015 - 9:27:37 AM
     Modified:   12/24/2014 - 12:02:37 AM
22:18:35:666 | RL |   DEBUG1  | +0     | Java.ahk Version: 1.0.0
22:18:35:676 | RL |     INFO  | +16    | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\JSON.ahk exists
22:18:35:676 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
22:18:35:686 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   9203 bytes
     Created:   5/24/2015 - 9:26:08 AM
     Modified:   5/5/2013 - 3:22:25 PM
22:18:35:686 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Origin.ahk exists
22:18:35:686 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
22:18:35:696 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
     File Size:   4904 bytes
     Created:   5/24/2015 - 9:26:27 AM
     Modified:   3/22/2015 - 3:51:41 PM
22:18:35:696 | RL |   DEBUG1  | +0     | Origin.ahk Version: 1.0.2
22:18:35:706 | RL |     INFO  | +16    | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\RegRW64.ahk exists
22:18:35:706 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
22:18:35:716 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   6915 bytes
     Created:   5/24/2015 - 9:28:09 AM
     Modified:   5/8/2014 - 4:06:39 AM
22:18:35:716 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\RIni.ahk exists
22:18:35:726 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
22:18:35:726 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   67561 bytes
     Created:   5/24/2015 - 9:28:04 AM
     Modified:   6/5/2013 - 7:56:23 PM
22:18:35:736 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\SevenZipSharp.dll exists
22:18:35:736 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     FileDescription          SevenZipSharp
     FileVersion              0.64.4841.31212
     InternalName             SevenZipSharp.dll
     LegalCopyright           Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
     OriginalFilename         SevenZipSharp.dll
     ProductName              SevenZipSharp
     ProductVersion           0.64.4841.31212
     CompanyName              Markovtsev Vadim
     File Size:   165888 bytes
     Created:   5/24/2015 - 9:27:30 AM
     Modified:   4/21/2013 - 12:08:10 AM
22:18:35:736 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Steam.ahk exists
22:18:35:746 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
22:18:35:746 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   5347 bytes
     Created:   5/24/2015 - 9:28:20 AM
     Modified:   3/22/2015 - 3:52:25 PM
22:18:35:746 | RL |   DEBUG1  | +0     | Steam.ahk Version: 1.0.2
22:18:35:756 | RL |     INFO  | +16    | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\VA.ahk exists
22:18:35:756 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
22:18:35:766 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   34688 bytes
     Created:   5/24/2015 - 9:26:53 AM
     Modified:   3/1/2013 - 10:05:47 PM
22:18:35:766 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\VA_Extension.ahk exists
22:18:35:766 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
22:18:35:776 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
     File Size:   3833 bytes
     Created:   5/24/2015 - 9:28:38 AM
     Modified:   1/13/2015 - 9:16:56 PM
22:18:35:776 | RL |   DEBUG1  | +0     | VA_Extension.ahk Version: 1.0.1
22:18:35:776 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\7z.ahk exists
22:18:35:796 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
22:18:35:796 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   29013 bytes
     Created:   5/30/2015 - 12:47:30 AM
     Modified:   9/6/2015 - 9:32:05 PM
22:18:35:796 | RL |   DEBUG1  | +0     | 7z.ahk Version: 1.0.1
22:18:35:796 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Bezel.ahk exists
22:18:35:816 | RL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Library.
22:18:35:816 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   102587 bytes
     Created:   5/24/2015 - 9:28:01 AM
     Modified:   6/28/2015 - 7:41:34 AM
22:18:35:826 | RL |   DEBUG1  | +0     | Bezel.ahk Version: 1.1.2
22:18:35:826 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade.ahk exists
22:18:35:826 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
22:18:35:846 | RL |   DEBUG1  | +31    | CheckFile - Attributes:
     File Size:   37849 bytes
     Created:   5/24/2015 - 9:26:50 AM
     Modified:   9/6/2015 - 9:31:56 PM
22:18:35:846 | RL |   DEBUG1  | +0     | Fade.ahk Version: 1.1.1
22:18:35:846 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade Init.ahk exists
22:18:35:856 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
22:18:35:856 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   999 bytes
     Created:   5/24/2015 - 9:27:38 AM
     Modified:   12/24/2014 - 12:21:02 AM
22:18:35:856 | RL |   DEBUG1  | +0     | Fade Init.ahk Version: 1.0.1
22:18:35:866 | RL |     INFO  | +16    | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade Animations.ahk exists
22:18:35:876 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
22:18:35:876 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   79882 bytes
     Created:   5/24/2015 - 9:27:41 AM
     Modified:   9/6/2015 - 9:31:50 PM
22:18:35:886 | RL |   DEBUG1  | +16    | Fade Animations.ahk Version: 1.1.8
22:18:35:886 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Pause.ahk exists
22:18:35:896 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
22:18:35:906 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   392698 bytes
     Created:   5/24/2015 - 9:26:19 AM
     Modified:   9/6/2015 - 9:31:52 PM
22:18:35:906 | RL |   DEBUG1  | +0     | Pause.ahk Version: 1.1.4
22:18:35:906 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Pause Init.ahk exists
22:18:35:916 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
22:18:35:916 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   553 bytes
     Created:   5/24/2015 - 9:24:21 AM
     Modified:   9/6/2015 - 9:31:51 PM
22:18:35:916 | RL |   DEBUG1  | +0     | Pause Init.ahk Version: 1.0.3
22:18:35:926 | RL |     INFO  | +15    | CheckFile - Checking if E:\Rocketlauncher\Lib\Keymapper.ahk exists
22:18:35:926 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
22:18:35:926 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   33453 bytes
     Created:   5/24/2015 - 9:28:11 AM
     Modified:   5/30/2015 - 10:18:27 PM
22:18:35:936 | RL |   DEBUG1  | +0     | Keymapper.ahk Version: 1.1.2
22:18:35:936 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Keymapper Init.ahk exists
22:18:35:956 | RL |   DEBUG1  | +32    | CRC Check - CRC matches, this is an official unedited Library.
22:18:35:966 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   3461 bytes
     Created:   5/24/2015 - 9:26:35 AM
     Modified:   5/30/2015 - 10:18:57 PM
22:18:35:966 | RL |   DEBUG1  | +0     | Keymapper Init.ahk Version: 1.0.4
22:18:35:966 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiGame.ahk exists
22:18:35:976 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
22:18:35:976 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   40753 bytes
     Created:   5/24/2015 - 9:24:03 AM
     Modified:   9/6/2015 - 9:32:13 PM
22:18:35:986 | RL |   DEBUG1  | +16    | MultiGame.ahk Version: 1.0.8
22:18:35:986 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiGame Init.ahk exists
22:18:35:996 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
22:18:35:006 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
     File Size:   161 bytes
     Created:   5/24/2015 - 9:28:32 AM
     Modified:   4/14/2013 - 2:33:19 PM
22:18:36:006 | RL |   DEBUG1  | +0     | MultiGame Init.ahk Version: 1.0.0
22:18:36:006 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiPlayer.ahk exists
22:18:36:016 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
22:18:36:016 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   58770 bytes
     Created:   5/24/2015 - 9:23:41 AM
     Modified:   7/16/2015 - 11:34:20 PM
22:18:36:016 | RL |   DEBUG1  | +0     | MultiPlayer.ahk Version: 1.0.6
22:18:36:026 | RL |     INFO  | +16    | CheckFile - Checking if E:\Rocketlauncher\Lib\Password.ahk exists
22:18:36:036 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
22:18:36:036 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   10025 bytes
     Created:   5/24/2015 - 9:24:18 AM
     Modified:   9/6/2015 - 9:31:55 PM
22:18:36:036 | RL |   DEBUG1  | +0     | Password.ahk Version: 1.0.2
22:18:36:036 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Rom Mapping Launch Menu.ahk exists
22:18:36:056 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
22:18:36:056 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   73772 bytes
     Modified:   7/16/2015 - 11:34:23 PM
22:18:36:066 | RL |   DEBUG1  | +16    | Rom Mapping Launch Menu.ahk Version: 1.0.5
22:18:36:066 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Shared.ahk exists
22:18:36:076 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
22:18:36:076 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   116503 bytes
22:18:36:086 | RL |   DEBUG1  | +15    | Shared.ahk Version: 1.3.2
22:18:36:086 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Statistics.ahk exists
22:18:36:086 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
22:18:36:096 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
     File Size:   26143 bytes
     Created:   5/24/2015 - 9:26:45 AM
     Modified:   4/9/2015 - 5:16:56 AM
22:18:36:096 | RL |   DEBUG1  | +0     | Statistics.ahk Version: 1.0.3
22:18:36:096 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Statistics Init.ahk exists
22:18:36:106 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
22:18:36:106 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   33 bytes
     Modified:   12/24/2014 - 12:23:48 AM
22:18:36:106 | RL |   DEBUG1  | +0     | Statistics Init.ahk Version: 1.0.1
22:18:36:116 | RL |     INFO  | +16    | CheckFile - Checking if E:\Rocketlauncher\Lib\Virtual Drive.ahk exists
22:18:36:116 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
22:18:36:126 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   17070 bytes
     Created:   5/30/2015 - 12:47:33 AM
     Modified:   9/6/2015 - 9:32:09 PM
22:18:36:126 | RL |   DEBUG1  | +0     | Virtual Drive.ahk Version: 1.0.1
22:18:36:126 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\XHotkey.ahk exists
22:18:36:136 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
22:18:36:136 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   26540 bytes
     Created:   5/24/2015 - 9:28:26 AM
     Modified:   9/6/2015 - 9:32:04 PM
22:18:36:136 | RL |   DEBUG1  | +0     | XHotkey.ahk Version: 1.0.4
22:18:36:136 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\XHotkey Init.ahk exists
22:18:36:146 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
22:18:36:146 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   1063 bytes
     Created:   5/24/2015 - 9:26:46 AM
22:18:36:156 | RL |   DEBUG1  | +0     | XHotkey Init.ahk Version: 1.0.2
22:18:36:156 | RL |   DEBUG1  | +0     | Main - Raw CLI received: "PC Games MUGEN Superheroes"
22:18:36:156 | RL |   DEBUG1  | +0     | Main - Received this dbName with no path via CLI: "MUGEN Superheroes"
22:18:36:156 | RL |   DEBUG1  | +0     | Main - dbName: MUGEN Superheroes
22:18:36:166 | RL |  WARNING  | +15    | Main - Front End plugin was not sent via CLI. Defaulting to the "HyperSpin" Plugin. If you want to load a different Front End Plugin, please make sure you set up your Front End so it sends this parameter to RocketLauncher: "-p <PLUGINTYPE>"
22:18:36:166 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Plugins\HyperSpin.plugin exists
22:18:36:166 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   8969 bytes
     Created:   5/24/2015 - 9:28:44 AM
     Modified:   5/30/2015 - 10:18:21 PM
22:18:36:166 | RL |  WARNING  | +0     | Main - No frontendPath was sent via CLI. Defaulting to use HyperSpin in "..\HyperSpin\HyperSpin.exe". If you want to use a different FE Path, please make sure you set up your Front End so it sends this parameter to RocketLauncher: "-f <PATH_TO_MY_FE\FRONTEND.exe>"
22:18:36:176 | RL |     INFO  | +16    | Main - HyperSpin.exe coordinates are x0 y0 w1440 h900
22:18:36:186 | RL |     INFO  | +0     | Main - RocketLauncher received "PC Games" and "MUGEN Superheroes"
22:18:36:196 | RL |     INFO  | +16    | Main - Found a "Games Options.ini" file, loading it into memory.
22:18:36:206 | RL |     INFO  | +15    | Main - MUGEN Superheroes is using the default emulator: PCLauncher
22:18:36:206 | RL |     INFO  | +0     | Main - Checking for a [PCLauncher] section in E:\Rocketlauncher\Settings\PC Games\Emulators.ini
22:18:36:206 | RL |     INFO  | +0     | Main - Checking for a [PCLauncher] section in E:\Rocketlauncher\Settings\Global Emulators.ini
22:18:36:206 | RL |     INFO  | +0     | Main - Found [PCLauncher] in E:\Rocketlauncher\Settings\Global Emulators.ini
22:18:36:206 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Modules\PCLauncher\PCLauncher.ahk exists
22:18:36:216 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   16076 bytes
     Created:   5/24/2015 - 9:27:46 AM
     Modified:   9/6/2015 - 9:32:06 PM
22:18:36:216 | RL |     INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
22:18:36:216 | RL |     INFO  | +0     | Main - MUGEN Superheroes will use module: E:\Rocketlauncher\Modules\PCLauncher\PCLauncher.ahk
22:18:36:236 | RL |     INFO  | +31    | Main - Using SkipChecks method "Rom and Emu" or emuName = "PCLauncher".
22:18:36:236 | RL |     INFO  | +0     | Main - INI Keys read
22:18:36:236 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\7z.exe exists
22:18:36:236 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     FileDescription          7-Zip Console
     FileVersion              9.20
     InternalName             7z
     LegalCopyright           Copyright (c) 1999-2010 Igor Pavlov
     OriginalFilename         7z.exe
     ProductName              7-Zip
     ProductVersion           9.20
     CompanyName              Igor Pavlov
     File Size:   163840 bytes
     Created:   5/24/2015 - 9:26:40 AM
     Modified:   3/5/2013 - 10:21:50 PM
22:18:36:236 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\7z.dll exists
22:18:36:246 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     FileDescription          7z Standalone Plugin
     FileVersion              9.20
     InternalName             7za
     OriginalFilename         7za.dll
     ProductName              7-Zip
     ProductVersion           9.20
     File Size:   914432 bytes
     Created:   5/24/2015 - 9:28:28 AM
     Modified:   3/5/2013 - 10:21:49 PM
22:18:36:246 | RL |     INFO  | +0     | Main - "MUGEN Superheroes" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
22:18:36:246 | RL |     INFO  | +0     | CheckPaths - Started
22:18:36:246 | RL |   DEBUG1  | +0     | CheckPaths - Current romName:
22:18:36:256 | RL |   DEBUG1  | +16    | CheckPaths - Current romPath:
22:18:36:256 | RL |   DEBUG1  | +0     | CheckPaths - Current romExtension:
22:18:36:256 | RL |     INFO  | +0     | CheckPaths - Ended
22:18:36:266 | RL |     INFO  | +0     | BuildScript - User Variables:
     ; INJECTED VARIABLES
     #NoTrayIcon
     #InstallKeybdHook
     DetectHiddenWindows, ON
     SetTitleMatchMode, 2
     SendMode, Event
     0 = 2
     pluginPath = E:\Rocketlauncher\Plugins
     pluginName = HyperSpin
     pluginExt = .plugin
     contextOnExit =
     rlMode =
     rlTitle = RocketLauncher
     rlVersion = 1.0.1.3
     rlAuthor = djvj
     rlURL = www.rlauncher.com
     langFile = E:\Rocketlauncher\Data\Language\Localization.ini
     primMonitor = 1
     frontendPID = 1656
     frontendPath = E:\HyperSpin
     frontendExe = HyperSpin.exe
     frontendExt = exe
     frontendName = HyperSpin
     frontendDrive = E:
     exitEmulatorKey = ~Esc|H3:1joy6
     restoreFE = false
     exitScriptKey = ~q & ~s
     toggleCursorKey = ~e & ~t
     emuFullPath =
     emuPath =
     emuName = PCLauncher
     emuExt =
     romPath =
     romPathFromIni =
     romExtension =
     romExtensionOrig =
     romExtensions =
     executable =
     systemDbName = PC Games
     systemName = PC Games
     dbPath =
     dbName = MUGEN Superheroes
     dbExt =
     romName =
     romMapPath =
     romMappingEnabled = false
     romMappingMenuWidth = 400
     romMappingMenuMargin = 65
     romMappingTextMargin = 15
     romMappingMenuFlagWidth = 55
     altArchiveNameOnly =
     altRomNameOnly =
     altArchiveAndRomName =
     altArchiveAndManyRomNames =
     altRomNamesOnly =
     romMapScenario =
     skipchecks = false
     romMatchExt = false
     blockInputTime = 0
     blockInputFile = E:\Rocketlauncher\Module Extensions\BlockInput.exe
     errorLevelReporting = false
     lockLaunch = false
     lockLaunchGame =
     screenRotationAngle = 0
     screenRotationAngleGame =
     logFile = E:\Rocketlauncher\RocketLauncher.log
     logLabel := ["    INFO"," WARNING","   ERROR","  DEBUG1","  DEBUG2"]
     logLevel = 10
     logShowDebugConsole = true
     logIncludeModule = true
     logShowCommandWindow = false
     logCommandWindow = true
     rlDebugConsoleStdout = 7
     sysType = 64-bit
     broadcastWindowTitle =
     navUpKey = Up
     navDownKey = Down
     navLeftKey = Left
     navRightKey = Right
     navSelectKey = 1
     navP2UpKey = Numpad8
     navP2DownKey = Numpad2
     navP2LeftKey = Numpad4
     navP2RightKey = Numpad6
     navP2SelectKey = NumpadEnter
     originalWidth = 1440
     originalHeight = 900
     vdEnabled = false
     vdFullPath =
     vdUseSCSI = true
     vdDriveLetter =
     vdAddDrive = true
     servoStikEnabled = false
     servoStikExitMode = false
     ledblinkyEnabled = false
     ledblinkyFullPath =
     ledblinkyProfilePath = E:\Rocketlauncher\Profiles\LEDBlinky
     ledblinkyRLProfile = E:\Rocketlauncher\Profiles\LEDBlinky\RocketLauncher
     emuIdleShutdown = 0
     hideCursor = true
     hideEmu = false
     hideFE = false
     fadeIn = false
     fadeInDuration = 500
     fadeInDelay = 0
     fadeInExitDelay = 0
     fadeOutExitDelay = 0
     fadeOut = false
     fadeOutExtraScreen = false
     fadeOutDuration = 500
     fadeOutTransitionAnimation = LegacyFadeOutTransition
     fadeOutDelay = 0
     fadeLyrInterpolation = 7
     fadeMuteEmulator = false
     fadeUseBackgrounds = false
     fadeWidthBaseRes = 1920
     fadeHeightBaseRes = 1080
     fadeLyr1Color = FF000000
     fadeLyr2X = 0
     fadeLyr2Y = 0
     fadeLyr2W =
     fadeLyr2H =
     fadeLyr2Adjust = 1
     fadeLyr2PicPad = 0
     fadeLyr3Pos = Center
     fadeLyr3X = 450
     fadeLyr3Y = 5
     fadeLyr3W =
     fadeLyr3H =
     fadeLyr3Adjust = 1
     fadeLyr3PicPad = 0
     fadeLyr3Speed = 750
     fadeLyr3Type = imageandbar
     fadeLyr3Repeat = 1
     fadeLyr3StaticX = 0
     fadeLyr3StaticY = 870|1575
     fadeLyr3StaticW =
     fadeLyr3StaticH =
     fadeLyr3StaticAdjust = 1
     fadeLyr3StaticPicPad = 0
     fadeLyr4Adjust = 1
     fadeLyr4X = 1792|952
     fadeLyr4Y = 891|1596
     fadeLyr4W = 128
     fadeLyr4H =
     fadeLyr4Pos = No Alignment
     fadeLyr4FPS = 50
     fadeLyr4PicPad = 0
     fadeTranspGifColor = FFFFFF
     fadeBarWindow = Image
     fadeBarWindowX =
     fadeBarWindowY =
     fadeBarWindowW = 900
     fadeBarWindowH =
     fadeBarWindowR = 30
     fadeBarWindowM = 30
     fadeBarWindowHatchStyle = 8
     fadeBar = true
     fadeBarNon7zProgressTime = 0
     fadeBarBack = true
     fadeBarBackColor = FF555555
     fadeBarH = 30
     fadeBarR = 10
     fadeBarColor = DD00BFFF
     fadeBarHatchStyle = 8
     fadeBarPercentageText = true
     fadeBarInfoText = true
     fadeBarXOffset = 0
     fadeBarYOffset = 150
     fadeRomInfoSystemName = image
     fadeRomInfoManufacturer = text with label
     fadeRomInfoGenre = disabled
     fadeRomInfoRating = image
     fadeRomInfoTextMargin = 7
     fadeStatsInfoTextMargin = 7
     fadeText1X = 0
     fadeText1Y = 0
     fadeText1 = Loading Game
     fadeText2X = 0
     fadeText2Y = 0
     fadeText3 = Loading Game
     fadeText4 = Loading Complete
     fadeFont = Bebas Neue
     fadeExtractionTime = disabled
     fadeExtractionTimeTextX = 0
     fadeExtractionTimeTextY = 0
     fadeInterruptKey =
     detectFadeErrorEnabled = false
     fadeImgPath = E:\Rocketlauncher\Media\Fade
     RLDataPath = E:\Rocketlauncher\Data
     RLMediaPath = E:\Rocketlauncher\Media
     RLErrSoundPath = E:\Rocketlauncher\Media\Sounds\Error
     modulesPath = E:\Rocketlauncher\Modules
     moduleFullName = E:\Rocketlauncher\Modules\PCLauncher\PCLauncher.ahk
     moduleName = PCLauncher
     modulePath = E:\Rocketlauncher\Modules\PCLauncher
     moduleExtension = ahk
     moduleExtensionsPath = E:\Rocketlauncher\Module Extensions
     libPath = E:\Rocketlauncher\Lib
     7zEnabled = true
     7zPath = E:\Rocketlauncher\Module Extensions\7z.exe
     7zDllPath = E:\Rocketlauncher\Module Extensions\7z.dll
     7zExtractPath = C:\Users\Lenovo\AppData\Local\Temp\HS
     7zExtractPathOrig =
     7zAttachSystemName = false
     7zDelTemp = true
     7zSounds = true
     mgEnabled = false
     mgKey = ~NumpadSub
     mgBackgroundColor = FF000000
     mgSidePadding = 0.2
     mgWidthBaseRes = 1920
     mgHeightBaseRes = 1080
     mgYOffset = 500|800
     mgFont = Arial
     mgText2Offset = 100
     mgUseSound = true
     mgSoundfreq = 300
     mgExitEffect = none
     mgSelectedEffect = rotate
     mgUseGameArt = false
     mgCandidate =
     mgOnLaunch = false
     pauseEnabled = false
     pauseKey = m
     pauseBackToMenuBarKey = n
     pauseZoomInKey = C
     pauseZoomOutKey = V
     pauseHiToTextPath = E:\Rocketlauncher\Module Extensions\HiToText.exe
     pauseSaveStateKeyCodes =
     pauseLoadStateKeyCodes =
     keymapperEnabled = true
     keymapperAHKMethod = External
     keymapper = xpadder
     xpadderFullPath = E:\Hyperspin\Utilities\Xpadder\Xpadder.exe
     joyToKeyFullPath = E:\Utilities\JoyToKey\JoyToKey.exe
     keymapperProfilePath = E:\Rocketlauncher\Profiles\xpadder
     keymapperFrontEndProfileName = RocketLauncherUI
     keymapperFrontEndProfile = xpadder
     keymapperRocketLauncherProfileEnabled = true
     joyIDsEnabled = true
     joyIDsPreferredControllersGlobal = Controller (Xbox 360 Wireless Receiver for Windows)
     joyIDsPreferredControllersSystem = use_global
     joyIDsPreferredControllersOnExit =
     CustomJoyNamesEnabled = false
     CustomJoyNames =
     rotateMethod = false
     FEProfile = E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI
     defaultProfile = E:\Rocketlauncher\Profiles\xpadder\_Default
     systemProfile = E:\Rocketlauncher\Profiles\xpadder\PC Games
     xPadderSystemProfile = E:\Rocketlauncher\Profiles\xpadder\PC Games\_Default
     emuProfile = E:\Rocketlauncher\Profiles\xpadder\PC Games\PCLauncher
     romProfile = E:\Rocketlauncher\Profiles\xpadder\PC Games\MUGEN Superheroes
     RocketLauncherProfile = E:\Rocketlauncher\Profiles\xpadder\RocketLauncher
     blankProfile = E:\Rocketlauncher\Profiles\xpadder\_Default\blank
     ahkFEProfile = E:\Rocketlauncher\Profiles\AHK\RocketLauncherUI
     ahkDefaultProfile = E:\Rocketlauncher\Profiles\AHK\_Default
     ahkSystemProfile = E:\Rocketlauncher\Profiles\AHK\PC Games
     ahkEmuProfile = E:\Rocketlauncher\Profiles\AHK\PC Games\PCLauncher
     ahkRomProfile = E:\Rocketlauncher\Profiles\AHK\PC Games\MUGEN Superheroes
     ahkRocketLauncherProfile = E:\Rocketlauncher\Profiles\AHK\RocketLauncher
     bezelEnabled = false
     bezelICEnabled = false
     statisticsEnabled = true
     pressDuration = -1
     emuVolume = 1
     dxwndIni = E:\Rocketlauncher\Module Extensions\dxwnd\dxwnd.ini
     dxwndFullPath = E:\Rocketlauncher\Module Extensions\dxwnd\dxwnd.exe
     mon1O =
     pacDrivedllFile = E:\Rocketlauncher\Module Extensions\PacDrive32.dll
     userFadeAnimIniFile = E:\Rocketlauncher\Lib\User Fade Animations.ini
22:18:36:266 | RL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
22:18:36:276 | RL |     INFO  | +16    | BuildScript - Loaded Keymapper Init.ahk scripts
22:18:36:276 | RL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
22:18:36:276 | RL |  WARNING  | +0     | BuildScript - "E:\Rocketlauncher\Lib\User Functions Init.ahk" not found
22:18:36:276 | RL |   DEBUG1  | +0     | BuildScript - Module starts on line: 2
22:18:36:276 | RL |     INFO  | +0     | BuildScript - Validating module
22:18:36:286 | RL |     INFO  | +15    | BuildScript - Validation complete
22:18:36:286 | RL |     INFO  | +0     | BuildScript - Module:
     MEmu = PCLauncher
     MEmuV =  N/A
     MURL = http://www.rlauncher.com/wiki/index.php?title=PCLauncher
     MAuthor = djvj
     MVersion = 2.1.7
     MCRC = D8BCAECA
     iCRC = A79D31F9
     mId = 635243126483565041
     MSystem = "Arcade PC","Doujin Soft","Examu eX-BOARD","Fan Remakes","Games for Windows","Konami e-Amusement","Konami Bemani","Microsoft Windows","PCLauncher","PC Games","Steam","Steam Big Picture","Taito Type X","Taito Type X2","Touhou","Touhou Project"
     ; Notes:
     ; Use the examples in the ini, in your Modules\PCLauncher\ folder, to add more applications.
     ; PCLauncher supports per-System inis. Copy your PCLauncher ini in the same folder and rename it to match the System's Name. Use this if you have games with the same name across multiple systems.
     ; Read the comments at the top of ini for the definitions of each key.
     ; For informaion on how to use this module and what all the settings do, please see https://sites.google.com/site/RocketLauncher2/additional-features/pclauncher
     StartModule()
     If (romExtensions != "")
      ScriptError("PCLauncher does not use extensions, but you have them set to: """ . romExtensions . """. Please remove all extensions from the PCLauncher emulator in RocketLauncherUI to continue using it.")
     IfExist, % modulePath . "\" . systemName . ".ini" ; use a custom systemName ini if it exists
      settingsFile := modulePath . "\" . systemName . ".ini"
     Else
      settingsFile := CheckFile(modulePath . "\" . moduleName . ".ini", "Could not find """ . modulePath . "\" . moduleName . ".ini"". RocketLauncherUI will create this file when you configure your first game to be used with this " . MEmu . " module.")
     iniLookup = SteamID|Application|AppWaitExe|DiscImage|Parameters|OriginGame|DXWndGame|WorkingFolder|PreLaunch|PreLaunchParameters|PreLaunchMode|PreLaunchSleep|PostLaunch|PostLaunchParameters|PostLaunchSleep|PostExit|PostExitParameters|PostExitSleep|ExitMethod|FadeTitle|FadeInExitSleep|BezelEnabled
     Loop, Parse, iniLookup, |
     { %A_LoopField% := IniReadCheck(settingsFile, dbName, A_LoopField, A_Space,,1)
      If A_LoopField in Application
       If (!Application && !SteamID) { ; Create keys if they do not exist in the ini and this is not a steam game
        IniWrite, %A_Space%, %SettingsFile%, %dbName%, %A_LoopField%
        missingKeys = 1
     ; These settings enable them to be customized per-game in this module
     bezelEnabled := IniReadCheck(settingsFile, "Settings|" . dbName, "BezelEnabled",,,1)
     If bezelEnabled = true
      BezelGUI()
     FadeInStart()
      BezelStart()
     If (missingKeys && !SteamID)
      ScriptError("You have not set up " . dbName . " in RocketLauncherUI yet, so PCLauncher does not know what exe, FadeTitle, and/or SteamID to watch for.")
     ; If Application needs a cd/dvd image in the drive, mount it in DT first
     If DiscImage {
      Log("PCLauncher - Application is a Disc Image, mounting it in DT")
      appIsImage=1
      DiscImage := GetFullName(DiscImage) ; convert a relative path defined in the PCLauncher ini to absolute
      CheckFile(DiscImage,"Cannot find this DiscImage for " . dbName . ":`n" . DiscImage)
      SplitPath,DiscImage,,ImagePath,ImageExt,ImageName
      If ImageExt in mds,mdx,b5t,b6t,bwt,ccd,cue,isz,nrg,cdi,iso,ape,flac
      { VirtualDrive("get") ; get the vdDriveLetter
       VirtualDrive("mount",ImagePath . "\" . ImageName . "." . ImageExt)
      } Else
       ScriptError("You defined a DiscImage, but it is not a supported format for this module and/or DT:`nccd,cdi,cue,iso,isz,nrg")
     ; Verify module's settings are set
     CheckSettings()
     If PreLaunch {
      Log("PCLauncher - PreLaunch set by user, running: " . PreLaunch)
      PreLaunchParameters := If (!PreLaunchParameters or PreLaunchParameters="ERROR" ) ? "" : PreLaunchParameters
      If (preLaunchMode = "run") {
       errLevel := Run(If preLSkip ? PreLaunch : """" . PreLaunchName . """ " . PreLaunchParameters, PreLaunchPath)
       If errLevel
        ScriptError("There was a problem launching your PreLaunch application. Please check it is a valid executable.")
       Sleep, %PreLaunchSleep%
      } Else {
       errLevel := RunWait(If preLSkip ? PreLaunch : """" . PreLaunchName . """ " . PreLaunchParameters, PreLaunchPath)
       If errLevel
     If DXWndGame = true  ; start dxwnd if needed
      DxwndRun()
     If mode in steam,steambp ; steam launch
      Steam(SteamID, Application, Parameters)
     Else If mode = origin  ; origin launch
      Origin(ApplicationName, ApplicationPath, Parameters)
     Else {
      If mode = url
      { Log("PCLauncher - Launching URL.")
       errLevel := Run(Application)
      } Else { ; standard launch
       Log("PCLauncher - Launching a standard application.")
       errLevel := Run("""" . (If WorkingFolder ? ApplicationPath . "\" : "") . ApplicationName . """ " . Parameters, If WorkingFolder ? WorkingFolder : ApplicationPath,, AppPID)
      If errLevel
       ScriptError("There was a problem launching your " . (If appIsImage ? "ImageExe" : "Application") . ". Please check it is a valid executable.")
     If PostLaunch {
      Log("PCLauncher - PostLaunch set by user, running: " . PostLaunch)
      PostLaunchParameters := If (!PostLaunchParameters or PostLaunchParameters="ERROR" ) ? "" : PostLaunchParameters
      errLevel := Run(If postLSkip ? PostLaunch : """" . PostLaunchName . """ " . PostLaunchParameters, PostLaunchPath)
      If errLevel
       ScriptError("There was a problem launching your PostLaunch application. Please check it is a valid executable.")
      Sleep, %PostLaunchSleep%
     If FadeTitle {
      Log("PCLauncher - FadeTitle set by user, waiting for """ . FadeTitle . """")
      WinWait(FadeTitle)
      WinWaitActive(FadeTitle)
     } Else If AppWaitExe {
      Log("PCLauncher - FadeTitle not set by user, but AppWaitExe is. Waiting for AppWaitExe: " . AppWaitExe)
      AppWaitPID := Process("Wait", AppWaitExe, 15)
      If AppWaitPID = 0
       ScriptError("PCLauncher - There was an error getting the Process ID from your AppWaitExe for """ . dbName . """. Please try setting a FadeTitle instead.")
     } Else If SteamIDExe {
      Log("PCLauncher - FadeTitle and AppWaitExe not set by user, but SteamIDExe was found. Waiting for SteamIDExe: " . SteamIDExe)
      SteamIDPID := Process("Wait", SteamIDExe, 15)
      If SteamIDPID = 0
       ScriptError("PCLauncher - There was an error getting the Process ID from your SteamIDExe for """ . dbName . """. Please try setting a FadeTitle instead.")
     } Else If AppPID {
      Log("PCLauncher - FadeTitle and AppWaitExe not set by user, but an AppPID was found. Waiting for AppPID: " . AppPID)
      WinWait("ahk_pid " . AppPID)
      WinWaitActive("ahk_pid " . AppPID)
     } Else
      Log("PCLauncher - FadeTitle and AppWaitExe not set by user and no AppPID found from an Application, PCLauncher has nothing to wait for",3)
      BezelDraw()
     Sleep, %FadeInExitSleep% ; PCLauncher setting for some stubborn games that keeps the fadeIn screen up a little longer
     FadeInExit()
     If AppWaitExe {
      SplitPath,AppWaitExe,AppWaitExe ; In case someone set this as a path accidentally, only want the filename from this key
      Log("PCLauncher - Waiting for AppWaitExe """ . AppWaitExe . """ to close.")
      Process("WaitClose", AppWaitExe)
     } Else If FadeTitle { ; If fadeTitle is set and no appPID was created.
      Log("PCLauncher - Waiting for FadeTitle """ . FadeTitle . """ to close.")
      WinWaitClose(FadeTitle)
      Log("PCLauncher - Waiting for SteamIDExe """ . SteamIDExe . """ to close.")
      Process("WaitClose", SteamIDExe)
     } Else If AppPID {
      Log("PCLauncher - Waiting for AppPID """ . AppPID . """ to close.")
      Process("WaitClose", AppPID)
     } Else
      ScriptError("Could not find a proper AppWaitExe`, FadeTitle`, or AppPID (from the launched Application). Try setting either an AppWaitExe or FadeTitle so the module has something to look for.")
     If PostExit {
      Log("PCLauncher - PostExit set by user, running: " . PostExit)
      PostExitParameters := If (!PostExitParameters or PostExitParameters="ERROR" ) ? "" : PostExitParameters
      errLevel := Run(If postESkip ? PostExit : """" . PostExitName . """ " . PostExitParameters, PostExitPath)
      If errLevel
       ScriptError("There was a problem launching your PostExit application. Please check it is a valid executable.")
      Sleep, %PostExitSleep%
     ; If Application is a cd/dvd image, unmount it in DT
     If appIsImage
      VirtualDrive("unmount")
     ; Close steam if it was not open prior to launch, not really needed anymore because module knows how to launch if steam already running now
     ; If AppPID = 0
      ; Run, Steam.exe -shutdown, %SteamPath% ; close steam
     If DXWndGame = true
      DxwndClose()
      BezelExit()
     FadeOutExit()
     ExitModule()
     CheckSettings() {
      Global Application,ApplicationPath,ApplicationName,ApplicationExt
      Global PreLaunch,PreLaunchPath,PreLaunchName,PreLaunchExt
      Global PostLaunch,PostLaunchPath,PostLaunchName,PostLaunchExt
      Global PostExit,PostExitPath,PostExitName,PostExitExt
      Global moduleName,appIsImage,vdDriveLetter,SteamID,OriginGame,DXWndGame,mode,preLSkip,postLSkip,postESkip,AppWaitExe,SteamIDExe,FadeTitle
      Global modulePath,fadeIn
      Log("CheckSettings - Started")
      ; These checks allow you to run URL and Steam browser protocol commands. Without them ahk would error out that it can't find the file. This is different than setting a SteamID but either work
      If (SteamID) {
       mode = steam ; setting module to use steam mode
       Log("PCLauncher - SteamID is set, setting mode to: """ . mode . """")
      } Else If (SubStr(Application,1,3) = "ste") {
       mode = steambp ; setting module to use Steam Browser Protocol mode
       Log("PCLauncher - Application is a Steam Browser Protocol, setting mode to: """ . mode . """")
      } Else If (SubStr(Application,1,4) = "http") {
       mode = url ; setting module to use url mode
       Log("PCLauncher - Application is a URL, setting mode to: """ . mode . """")
      } Else If OriginGame {
       mode = origin ; setting module to use Origin mode
       Application := GetFullName(Application) ; convert a relative path defined in the PCLauncher ini to absolute
       SplitPath,Application,ApplicationName,ApplicationPath,ApplicationExt
       StringRight, ApplicationBackSlash, Application, 1
       Log("PCLauncher - Origin mode enabled. Will log in to Origin if required.")
      } Else If Application {
       mode = standard ; for standard launching
       Log("PCLauncher - Setting mode to: """ . mode . """")
      } Else ; error if no modes are used
       ScriptError("Please set an Application, SteamID, Steam Browser Protocol, or URL in " moduleName . ".ini for """ . dbName . """")
      If (SteamID && Application) ; do not allow 2 launching methods
       ScriptError("You are trying to use Steam and Application, you must choose one or the other.")
      If ((mode = "steam" || mode = "steambp") && !AppWaitExe && !FadeTitle) { ; && fadeIn = "true") { ; If AppWaitExe or FadeTitle are defined, that will take precedence over the automatic method using the SteamIDs.ini
       SteamIDFile := CheckFile(modulePath . "\SteamIDs.ini")
       If !SteamID
        SplitPath, Application,SteamID ; grab the
       SteamIDExe := IniReadCheck(SteamIDFile, SteamID, "exe","",,1)
       If !SteamIDExe
        ScriptError("You are using launching a Steam game but no way for the module to know what window to wait for after launching. Please set a AppWaitExe, FadeTitle, or make sure your SteamID and the correct exe is defined in the SteamIDs.ini",10)
       Else
        Log("PCLauncher - Found an exe in the SteamIDs.ini for this game: """ . SteamIDExe . """")
      } Else If (mode = "url" && !AppWaitExe && !FadeTitle)
       ScriptError("You are using launching a URL but no way for the module to know what to window to wait for after launching. Please set a AppWaitExe or FadeTitle to your default application that gets launched when opening URLs.",10)
      preLSkip := If (SubStr(PreLaunch,1,4)="http" || SubStr(PreLaunch,1,3)="ste") ? 1:""
      If preLSkip
       Log("PCLauncher - PreLaunch is a URL or Steam Browser Protocol: " . PreLaunch)
      postLSkip := If (SubStr(PostLaunch,1,4)="http" || SubStr(PostLaunch,1,3)="ste") ? 1:""
      If postLSkip
       Log("PCLauncher - PostLaunch is a URL or Steam Browser Protocol: " . PostLaunch)
      postESkip := If (SubStr(PostExit,1,4)="http" || SubStr(PostExit,1,3)="ste") ? 1:""
      If postESkip
       Log("PCLauncher - PostExit is a URL or Steam Browser Protocol: " . PostExit)
      If (ApplicationBackSlash = "\")
       ScriptError("Please make sure your Application does not contain a backslash on the end:`n" . Application)
      If (appIsImage && !ApplicationPath) ; if user only defined an exe for Application with no path, assume it will be found on the root dir of the image when mounted
       ApplicationPath := vdDriveLetter . ":\"
      If (!ApplicationName && mode = "standard" && (mode != "steam" || mode != "steambp"))
       ScriptError("Missing filename on the end of your Application in " . moduleName . ".ini:`n" . Application)
      If (!ApplicationExt && mode = "standard" && (mode != "steam" || mode != "steambp"))
       ScriptError("Missing extension on your Application in " . moduleName . ".ini:`n" . Application)
      If (PreLaunch && !preLSkip) {
       PreLaunch := GetFullName(PreLaunch)
       SplitPath,PreLaunch,PreLaunchName,PreLaunchPath,PreLaunchExt
       StringRight, PreLaunchBackSlash, PreLaunch, 1
       CheckFile(PreLaunch,"Cannot find this PreLaunch application:`n" . PreLaunch)
       If (PreLaunchBackSlash = "\")
        ScriptError("Please make sure your PreLaunch does not contain a backslash on the end:`n" . PreLaunch)
      If (PostLaunch && !postLSkip) {
       PostLaunch := GetFullName(PostLaunch)
       SplitPath,PostLaunch,PostLaunchName,PostLaunchPath,PostLaunchExt
       StringRight, PostLaunchBackSlash, PostLaunch, 1
       CheckFile(PostLaunch,"Cannot find this PostLaunch application:`n" . PostLaunch)
       If (PostLaunchBackSlash = "\")
        ScriptError("Please make sure your PostLaunch does not contain a backslash on the end:`n" . PostLaunch)
      If (PostExit && !postESkip) {
       PostExit := GetFullName(PostExit)
       SplitPath,PostExit,PostExitName,PostExitPath,PostExitExt
       StringRight, PostExitBackSlash, PostExit, 1
       CheckFile(PostExit,"Cannot find this PostExit application:`n" . PostExit)
       If (PostExitBackSlash = "\")
        ScriptError("Please make sure your PostExit does not contain a backslash on the end:`n" . PostExit)
      If mode = standard
       CheckFile(ApplicationPath . "\" . ApplicationName,"Cannot find this Application:`n" . ApplicationPath . "\" . ApplicationName) ; keeping this last so more descriptive errors will trigger first
      Log("CheckSettings - Ended")
     CloseProcess:
      If ExitMethod ; fadeout will only take effect if an ExitMethod method was set, otherwise fade will occur and application will not close
       FadeOutStart()
      If ( ExitMethod = "Process Close AppWaitExe" && AppWaitExe) {
       Log("CloseProcess - ExitMethod is ""Process Close AppWaitExe""")
       Process("Close", AppWaitExe)
      } Else If ( ExitMethod = "WinClose AppWaitExe" && AppWaitExe) {
       Log("CloseProcess - ExitMethod is ""WinClose AppWaitExe""")
       AppWaitExePID := Process("Exist", AppWaitExe)
       WinClose("ahk_pid " . AppWaitExePID)
      } Else If ( ExitMethod = "Process Close Application" ) {
       Log("CloseProcess - ExitMethod is ""Process Close Application""")
       Process("Close", ApplicationName)
      } Else If ( ExitMethod = "WinClose Application" && FadeTitle ) {
       Log("CloseProcess - ExitMethod is ""WinClose Close Application""")
       WinClose(FadeTitle)
      } Else If ( ExitMethod = "Send Alt+F4" ) {
       Log("CloseProcess - ExitMethod is ""Send Alt+F4""")
       Send, !{F4}
      } Else {
       Log("CloseProcess - Default ExitMethod`, using ""WinClose""")
       WinClose(ApplicationName)
     Return
22:18:36:296 | RL |     INFO  | +0     | BuildScript - Loaded Multi-Player scripts
22:18:36:296 | RL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
22:18:36:306 | RL |  WARNING  | +16    | BuildScript - "E:\Rocketlauncher\Lib\User Functions.ahk" not found
22:18:36:306 | RL |     INFO  | +0     | BuildScript - Finished injecting functions into module
22:18:36:306 | RL |     INFO  | +0     | Main - Module is built
22:18:36:306 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\AutoHotkey.dll exists
22:18:36:306 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
     FileDescription          AutoHotkey_H ANSI 32-bit
     InternalName             AutoHotkey_H
     LegalCopyright           Copyright (C) 2012
     OriginalFilename         AutoHotkey.exe
     ProductName              AutoHotkey_H
     File Size:   785408 bytes
     Modified:   4/19/2013 - 7:16:32 PM
22:18:36:316 | RL |     INFO  | +15    | Main - Running module
22:18:36:316 | RL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
22:18:36:406 | MD |     INFO  | +N/A   | Module initialized
22:18:36:406 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
22:18:36:406 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups
22:18:36:406 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
22:18:36:426 | MD |   DEBUG2  | +32    | XHotkeyTableCreation - Post loop 2 check
22:18:36:426 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
22:18:36:426 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
22:18:36:426 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
22:18:36:436 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~1joy6 not in TableKeyGroups ~Esc,
22:18:36:436 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
22:18:36:436 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
22:18:36:436 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~1joy6" to call a group label
22:18:36:436 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
22:18:36:476 | MD |   DEBUG2  | +46    | Keymapper - Checking for the JoyIDs_Preferred_Controllers key  in E:\Rocketlauncher\Settings\PC Games\Games JoyIDs.ini under section [MUGEN Superheroes]
22:18:36:476 | MD |     INFO  | +0     | LoadPreferredControllers - Started
22:18:36:506 | MD |   DEBUG2  | +32    | LoadPreferredControllers - JoyIDsPreferredControllers = Controller (Xbox 360 Wireless Receiver for Windows)
22:18:36:536 | MD |   DEBUG2  | +31    | LoadPreferredControllers - Creating a list of currently connected joysticks
22:18:36:546 | MD |     INFO  | +0     | GetJoystickArray - Started
22:18:36:566 | MD |   DEBUG2  | +31    | GetJoystickArray - Joysticks Detected: 1000000000000000
22:18:36:596 | MD |     INFO  | +31    | GetJoystickGUID - Started
22:18:36:596 | MD |     INFO  | +0     | GetJoystickGUID - Ended and found GUID: 5041DB96E6EDE4118001444553540000
22:18:36:596 | MD |   DEBUG2  | +0     | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 5041DB96E6EDE4118001444553540000
22:18:36:596 | MD |     INFO  | +0     | GetJoystickArray - Ended
22:18:36:606 | MD |   DEBUG2  | +0     | LoadPreferredControllers - Preferred Order Sorting List -> 1.01|045e|02a1|5041DB96E6EDE4118001444553540000
22:18:36:606 | MD |     INFO  | +0     | LoadPreferredControllers - Sorting Currently Connected joysticks List to match the order of the Preferred Controller List
22:18:36:606 | MD |     INFO  | +0     | LoadPreferredControllers - Assigning the New Joystick IDs according to the preferred list for the active controllers
22:18:36:606 | MD |     INFO  | +0     | ChangeJoystickID - Started
22:18:36:606 | MD |   DEBUG2  | +0     | ChangeJoystickID - Swapping Joystick ID: 00000000 to the New Joystick ID: 00000000, for the Joystick VID_045e&PID_02a1&GUID_5041DB96E6EDE4118001444553540000
22:18:36:626 | MD |     INFO  | +31    | ChangeJoystickID - Ended
22:18:36:626 | MD |     INFO  | +0     | LoadPreferredControllers - Ended
22:18:36:626 | MD |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Utilities\Xpadder\Xpadder.exe exists
22:18:36:636 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   1178624 bytes
     Created:   6/16/2015 - 12:46:34 PM
     Modified:   2/2/2014 - 4:10:38 PM
22:18:36:636 | MD |     INFO  | +0     | Keymapper - Loading xpadder
22:18:36:636 | MD |     INFO  | +0     | RunKeymapper - Started, using method "load"
22:18:36:636 | MD |     INFO  | +0     | GetJoystickArray - Started
22:18:36:666 | MD |   DEBUG2  | +32    | GetJoystickArray - Joysticks Detected: 1000000000000000
22:18:36:666 | MD |     INFO  | +0     | GetJoystickGUID - Started
22:18:36:666 | MD |     INFO  | +0     | GetJoystickGUID - Ended and found GUID: 5041DB96E6EDE4118001444553540000
22:18:36:696 | MD |   DEBUG2  | +31    | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 5041DB96E6EDE4118001444553540000
22:18:36:696 | MD |     INFO  | +0     | GetJoystickArray - Ended
22:18:36:696 | MD |   DEBUG2  | +0     | RunKeymapper - Found your keymapper application here: "E:\Hyperspin\Utilities\Xpadder\Xpadder.exe"
22:18:36:696 | MD |   DEBUG2  | +0     | RunKeymapper - Looping through controllers to find xpadder profiles for each one
22:18:36:726 | MD |   DEBUG2  | +31    | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "Controller (Xbox 360 Wireless Receiver for Windows)"
22:18:36:726 | MD |   DEBUG2  | +0     | GetProfile - Searching for these profiles (| delimited): E:\Rocketlauncher\Profiles\xpadder\PC Games\MUGEN Superheroes|E:\Rocketlauncher\Profiles\xpadder\PC Games\PCLauncher|E:\Rocketlauncher\Profiles\xpadder\PC Games\_Default|E:\Rocketlauncher\Profiles\xpadder\_Default|E:\Rocketlauncher\Profiles\xpadder\_Default\blank
22:18:36:726 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\PC Games\MUGEN Superheroes\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
22:18:36:726 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\PC Games\MUGEN Superheroes\p1.xpadderprofile
22:18:36:726 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\PC Games\PCLauncher\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
22:18:36:756 | MD |   DEBUG2  | +31    | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\PC Games\PCLauncher\p1.xpadderprofile
22:18:36:786 | MD |   DEBUG2  | +31    | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\PC Games\_Default\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
22:18:36:786 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\PC Games\_Default\p1.xpadderprofile
22:18:36:786 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
22:18:36:786 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile
22:18:36:796 | MD |     INFO  | +0     | GetProfile - Loading Player 1 Profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile
22:18:36:796 | MD |     INFO  | +0     | RunXpadder - Started
22:18:36:796 | MD |     INFO  | +0     | Process - Exist JoyToKey.exe
22:18:36:796 | MD |   DEBUG2  | +0     | RunXpadder - Closing xpadder to refresh controllers seen by xpadder
22:18:36:796 | MD |     INFO  | +0     | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe /C
22:18:36:846 | MD |   DEBUG1  | +63    | Run - "Xpadder.exe /C" Process ID: 3672
22:18:36:846 | MD |   DEBUG2  | +0     | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in E:\Hyperspin\Utilities\Xpadder\xpadder.ini
22:18:36:846 | MD |     INFO  | +0     | Process - WaitClose Xpadder.exe 2
22:18:37:066 | MD |   DEBUG2  | +218   | RunXpadder - Reading the order in E:\Hyperspin\Utilities\Xpadder\xpadder.ini and arranging profiles found to match that order
22:18:37:066 | MD |   DEBUG2  | +0     | RunXpadder - No more controllers to be found
22:18:37:076 | MD |     INFO  | +0     | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile" /M
22:18:37:126 | MD |   DEBUG1  | +63    | Run - "Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile" /M" Process ID: 2756
22:18:37:126 | MD |     INFO  | +0     | RunXpadder - Ended
22:18:37:126 | MD |     INFO  | +0     | RunKeymapper - Ended
22:18:37:126 | MD |     INFO  | +0     | Keymapper - Loading External AHK Keymapping
22:18:37:126 | MD |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\AhkLauncher.exe exists
22:18:37:136 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
     FileDescription          AhkLauncher
     FileVersion              1.0.0.0
     InternalName             AhkLauncher.exe
     LegalCopyright           Copyright ©  2013
     OriginalFilename         AhkLauncher.exe
     ProductName              AhkLauncher
     ProductVersion           1.0.0.0
     File Size:   11264 bytes
     Created:   5/24/2015 - 9:28:06 AM
     Modified:   9/4/2013 - 7:30:52 PM
22:18:37:136 | MD |     INFO  | +0     | RunAHKKeymapper - Started
22:18:37:136 | MD |   DEBUG1  | +0     | RunAHKKeymapper - Loading MUGEN Superheroes, PCLauncher, PC Games, or _Default AHK Keymapper profile
22:18:37:136 | MD |     INFO  | +0     | GetAHKProfile - Started
22:18:37:136 | MD |   DEBUG2  | +0     | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\PC Games\MUGEN Superheroes.ahk
22:18:37:136 | MD |   DEBUG2  | +0     | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\PC Games\PCLauncher.ahk
22:18:37:156 | MD |   DEBUG2  | +31    | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\PC Games.ahk
22:18:37:156 | MD |   DEBUG2  | +0     | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\_Default.ahk
22:18:37:156 | MD |     INFO  | +0     | GetAHKProfile - Ended and no profile found
22:18:37:166 | MD |   DEBUG1  | +0     | RunAHKKeymapper - If AhkLauncher.exe is running, need to close it first before a new profile can be loaded
22:18:37:166 | MD |     INFO  | +0     | Process - Exist AhkLauncher.exe
22:18:37:166 | MD |     INFO  | +0     | RunAHKKeymapper - Ended
22:18:37:166 | MD |     INFO  | +0     | StartModule - Started
22:18:37:166 | MD |     INFO  | +0     | StartModule - MEmu: PCLauncher
     MEmuV: N/A
     MURL: http://www.rlauncher.com/wiki/index.php?title=PCLauncher
     MAuthor: djvj
     MVersion: 2.1.7
     MCRC: D8BCAECA
     iCRC: A79D31F9
     MID:
     MSystem: "Arcade PC","Doujin Soft","Examu eX-BOARD","Fan Remakes","Games for Windows","Konami e-Amusement","Konami Bemani","Microsoft Windows","PCLauncher","PC Games","Steam","Steam Big Picture","Taito Type X","Taito Type X2","Touhou","Touhou Project"
22:18:37:196 | MD |     INFO  | +31    | StartModule - You have a supported System Name for this module: "PC Games"
22:18:37:196 | MD |     INFO  | +0     | PluginInit - Started
22:18:37:196 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating
22:18:37:196 | MD |     INFO  | +0     | CheckFile - Checking if E:\HyperSpin\Databases\PC Games\PC Games.xml exists
22:18:37:196 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
     File Size:   6859 bytes
     Created:   10/16/2015 - 8:59:23 PM
     Modified:   10/19/2015 - 9:57:52 PM
22:18:37:226 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching for a "Game Name" in the database
22:18:37:226 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Game Name" in the database!
22:18:37:226 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Name
22:18:37:226 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Name" with a value: "MUGEN Superheroes"
22:18:37:256 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching database for: Cloneof
22:18:37:256 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Cloneof
22:18:37:256 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Manufacturer
22:18:37:296 | MD |   DEBUG1  | +32    | BuildDatabaseTable - Could not find: Manufacturer
22:18:37:296 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Year
22:18:37:296 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Year
22:18:37:316 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching database for: Genre
22:18:37:316 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Genre
22:18:37:316 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Rating
22:18:37:326 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Rating
22:18:37:326 | MD |   DEBUG2  | +0     | PluginInit - GameInfo:
     GameInfo Label: Name | GameInfo Value:
22:18:37:326 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Ended
22:18:37:326 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
22:18:37:326 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Game Logo: E:\HyperSpin\Media\PC Games\Images\Wheel\MUGEN Superheroes.png
22:18:37:346 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a System Logo: E:\HyperSpin\Media\Main Menu\Images\Wheel\PC Games.png
22:18:37:346 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
     Asset Label: Game Logo | Asset Path1:  E:\HyperSpin\Media\PC Games\Images\Wheel\MUGEN Superheroes.png | Asset Extension1:  png | Asset Type1:  game
     Asset Label: System Logo | Asset Path1:  E:\HyperSpin\Media\Main Menu\Images\Wheel\PC Games.png | Asset Extension1:  png | Asset Type1:  system
22:18:37:346 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
22:18:37:356 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
22:18:37:356 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Artwork1: E:\HyperSpin\Media\PC Games\Images\Artwork1\MUGEN Superheroes.png
22:18:37:356 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Box Art: E:\HyperSpin\Media\PC Games\Images\Artwork2\MUGEN Superheroes.png
22:18:37:356 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Cartridge: E:\HyperSpin\Media\PC Games\Images\Artwork3\MUGEN Superheroes.png
22:18:37:376 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a Flyers: E:\HyperSpin\Media\PC Games\Images\Artwork4\MUGEN Superheroes.png
22:18:37:376 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Letters: E:\HyperSpin\Media\PC Games\Images\Letters
22:18:37:406 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a Other: E:\HyperSpin\Media\PC Games\Images\Other
22:18:37:416 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
     Asset Label: Letters | Asset Path1:  E:\Hyperspin\Media\PC Games\Images\Letters\!.png | Asset Extension1:  png | Asset Type1:  system
     Asset Label: Letters | Asset Path2:  E:\Hyperspin\Media\PC Games\Images\Letters\'.png | Asset Extension2:  png | Asset Type2:  system
     Asset Label: Letters | Asset Path3:  E:\Hyperspin\Media\PC Games\Images\Letters\(.png | Asset Extension3:  png | Asset Type3:  system
     Asset Label: Letters | Asset Path4:  E:\Hyperspin\Media\PC Games\Images\Letters\0.png | Asset Extension4:  png | Asset Type4:  system
     Asset Label: Letters | Asset Path5:  E:\Hyperspin\Media\PC Games\Images\Letters\1.png | Asset Extension5:  png | Asset Type5:  system
     Asset Label: Letters | Asset Path6:  E:\Hyperspin\Media\PC Games\Images\Letters\2.png | Asset Extension6:  png | Asset Type6:  system
     Asset Label: Letters | Asset Path7:  E:\Hyperspin\Media\PC Games\Images\Letters\3.png | Asset Extension7:  png | Asset Type7:  system
     Asset Label: Letters | Asset Path8:  E:\Hyperspin\Media\PC Games\Images\Letters\4.png | Asset Extension8:  png | Asset Type8:  system
     Asset Label: Letters | Asset Path9:  E:\Hyperspin\Media\PC Games\Images\Letters\5.png | Asset Extension9:  png | Asset Type9:  system
     Asset Label: Letters | Asset Path10:  E:\Hyperspin\Media\PC Games\Images\Letters\6.png | Asset Extension10:  png | Asset Type10:  system
     Asset Label: Letters | Asset Path11:  E:\Hyperspin\Media\PC Games\Images\Letters\7.png | Asset Extension11:  png | Asset Type11:  system
     Asset Label: Letters | Asset Path12:  E:\Hyperspin\Media\PC Games\Images\Letters\8.png | Asset Extension12:  png | Asset Type12:  system
     Asset Label: Letters | Asset Path13:  E:\Hyperspin\Media\PC Games\Images\Letters\9.png | Asset Extension13:  png | Asset Type13:  system
     Asset Label: Letters | Asset Path14:  E:\Hyperspin\Media\PC Games\Images\Letters\a.png | Asset Extension14:  png | Asset Type14:  system
     Asset Label: Letters | Asset Path15:  E:\Hyperspin\Media\PC Games\Images\Letters\b.png | Asset Extension15:  png | Asset Type15:  system
     Asset Label: Letters | Asset Path16:  E:\Hyperspin\Media\PC Games\Images\Letters\c.png | Asset Extension16:  png | Asset Type16:  system
     Asset Label: Letters | Asset Path17:  E:\Hyperspin\Media\PC Games\Images\Letters\d.png | Asset Extension17:  png | Asset Type17:  system
     Asset Label: Letters | Asset Path18:  E:\Hyperspin\Media\PC Games\Images\Letters\e.png | Asset Extension18:  png | Asset Type18:  system
     Asset Label: Letters | Asset Path19:  E:\Hyperspin\Media\PC Games\Images\Letters\f.png | Asset Extension19:  png | Asset Type19:  system
     Asset Label: Letters | Asset Path20:  E:\Hyperspin\Media\PC Games\Images\Letters\g.png | Asset Extension20:  png | Asset Type20:  system
     Asset Label: Letters | Asset Path21:  E:\Hyperspin\Media\PC Games\Images\Letters\h.png | Asset Extension21:  png | Asset Type21:  system
     Asset Label: Letters | Asset Path22:  E:\Hyperspin\Media\PC Games\Images\Letters\i.png | Asset Extension22:  png | Asset Type22:  system
     Asset Label: Letters | Asset Path23:  E:\Hyperspin\Media\PC Games\Images\Letters\j.png | Asset Extension23:  png | Asset Type23:  system
     Asset Label: Letters | Asset Path24:  E:\Hyperspin\Media\PC Games\Images\Letters\k.png | Asset Extension24:  png | Asset Type24:  system
     Asset Label: Letters | Asset Path25:  E:\Hyperspin\Media\PC Games\Images\Letters\l.png | Asset Extension25:  png | Asset Type25:  system
     Asset Label: Letters | Asset Path26:  E:\Hyperspin\Media\PC Games\Images\Letters\m.png | Asset Extension26:  png | Asset Type26:  system
     Asset Label: Letters | Asset Path27:  E:\Hyperspin\Media\PC Games\Images\Letters\n.png | Asset Extension27:  png | Asset Type27:  system
     Asset Label: Letters | Asset Path28:  E:\Hyperspin\Media\PC Games\Images\Letters\o.png | Asset Extension28:  png | Asset Type28:  system
     Asset Label: Letters | Asset Path29:  E:\Hyperspin\Media\PC Games\Images\Letters\p.png | Asset Extension29:  png | Asset Type29:  system
     Asset Label: Letters | Asset Path30:  E:\Hyperspin\Media\PC Games\Images\Letters\q.png | Asset Extension30:  png | Asset Type30:  system
     Asset Label: Letters | Asset Path31:  E:\Hyperspin\Media\PC Games\Images\Letters\r.png | Asset Extension31:  png | Asset Type31:  system
     Asset Label: Letters | Asset Path32:  E:\Hyperspin\Media\PC Games\Images\Letters\s.png | Asset Extension32:  png | Asset Type32:  system
     Asset Label: Letters | Asset Path33:  E:\Hyperspin\Media\PC Games\Images\Letters\t.png | Asset Extension33:  png | Asset Type33:  system
     Asset Label: Letters | Asset Path34:  E:\Hyperspin\Media\PC Games\Images\Letters\u.png | Asset Extension34:  png | Asset Type34:  system
     Asset Label: Letters | Asset Path35:  E:\Hyperspin\Media\PC Games\Images\Letters\v.png | Asset Extension35:  png | Asset Type35:  system
     Asset Label: Letters | Asset Path36:  E:\Hyperspin\Media\PC Games\Images\Letters\w.png | Asset Extension36:  png | Asset Type36:  system
     Asset Label: Letters | Asset Path37:  E:\Hyperspin\Media\PC Games\Images\Letters\x.png | Asset Extension37:  png | Asset Type37:  system
     Asset Label: Letters | Asset Path38:  E:\Hyperspin\Media\PC Games\Images\Letters\y.png | Asset Extension38:  png | Asset Type38:  system
     Asset Label: Letters | Asset Path39:  E:\Hyperspin\Media\PC Games\Images\Letters\z.png | Asset Extension39:  png | Asset Type39:  system
     Asset Label: Other | Asset Path1:  E:\Hyperspin\Media\PC Games\Images\Other\Pointer.png | Asset Extension1:  png | Asset Type1:  system
22:18:37:446 | MD |   DEBUG1  | +32    | BuildAssetsTable - Ended
22:18:37:446 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Game Video|System Video
22:18:37:446 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Game Video: E:\HyperSpin\Media\PC Games\Video\MUGEN Superheroes.*
22:18:37:446 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a System Video: E:\HyperSpin\Media\Main Menu\Video\PC Games.*
22:18:37:506 | MD |   DEBUG2  | +62    | BuildAssetsTable - Media assets found:
     Asset Label: Game Video | Asset Path1:  E:\HyperSpin\Media\PC Games\Video\MUGEN Superheroes.mp4 | Asset Extension1:  mp4 | Asset Type1:  game
     Asset Label: System Video | Asset Path1:  E:\HyperSpin\Media\Main Menu\Video\PC Games.mp4 | Asset Extension1:  mp4 | Asset Type1:  system
22:18:37:506 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
22:18:37:536 | MD |     INFO  | +31    | PluginInit - Ended
22:18:37:566 | MD |   DEBUG1  | +31    | StartModule - Setting romName to the dbName sent to RocketLauncher: MUGEN Superheroes
22:18:37:566 | MD |     INFO  | +0     | Hiding mouse cursor
22:18:37:576 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
22:18:37:576 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc,~1joy6,
22:18:37:576 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
22:18:37:576 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
22:18:37:576 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
22:18:37:596 | MD |   DEBUG2  | +32    | XHotkeyTableCreation - Ended
22:18:37:596 | MD |     INFO  | +0     | StartModule - Ended
22:18:37:606 | MD |     INFO  | +0     | Module Setting - [MUGEN Superheroes] - SteamID:
22:18:37:606 | MD |     INFO  | +0     | Module Setting - [MUGEN Superheroes] - Application: H:\PC Games\MUGEN Superheroes\MUGEN Superheroes.exe
22:18:37:606 | MD |     INFO  | +0     | Module Setting - [MUGEN Superheroes] - AppWaitExe:
22:18:37:606 | MD |     INFO  | +0     | Module Setting - [MUGEN Superheroes] - DiscImage:
22:18:37:606 | MD |     INFO  | +0     | Module Setting - [MUGEN Superheroes] - Parameters:
22:18:37:626 | MD |     INFO  | +31    | Module Setting - [MUGEN Superheroes] - OriginGame:
22:18:37:636 | MD |     INFO  | +0     | Module Setting - [MUGEN Superheroes] - DXWndGame:
22:18:37:636 | MD |     INFO  | +0     | Module Setting - [MUGEN Superheroes] - WorkingFolder:
22:18:37:636 | MD |     INFO  | +0     | Module Setting - [MUGEN Superheroes] - PreLaunch:
22:18:37:636 | MD |     INFO  | +0     | Module Setting - [MUGEN Superheroes] - PreLaunchParameters:
22:18:37:636 | MD |     INFO  | +0     | Module Setting - [MUGEN Superheroes] - PreLaunchMode:
22:18:37:656 | MD |     INFO  | +31    | Module Setting - [MUGEN Superheroes] - PreLaunchSleep:
22:18:37:656 | MD |     INFO  | +0     | Module Setting - [MUGEN Superheroes] - PostLaunch:
22:18:37:656 | MD |     INFO  | +0     | Module Setting - [MUGEN Superheroes] - PostLaunchParameters:
22:18:37:666 | MD |     INFO  | +0     | Module Setting - [MUGEN Superheroes] - PostLaunchSleep:
22:18:37:666 | MD |     INFO  | +0     | Module Setting - [MUGEN Superheroes] - PostExit:
22:18:37:666 | MD |     INFO  | +0     | Module Setting - [MUGEN Superheroes] - PostExitParameters:
22:18:37:666 | MD |     INFO  | +0     | Module Setting - [MUGEN Superheroes] - PostExitSleep:
22:18:37:696 | MD |     INFO  | +31    | Module Setting - [MUGEN Superheroes] - ExitMethod: Send Alt+F4
22:18:37:726 | MD |     INFO  | +31    | Module Setting - [MUGEN Superheroes] - FadeTitle:
22:18:37:756 | MD |     INFO  | +32    | Module Setting - [MUGEN Superheroes] - FadeInExitSleep:
22:18:37:756 | MD |     INFO  | +0     | Module Setting - [MUGEN Superheroes] - BezelEnabled:
22:18:37:786 | MD |     INFO  | +31    | Module Setting - [Settings] - BezelEnabled:
22:18:37:816 | MD |     INFO  | +31    | Module Setting - [MUGEN Superheroes] - BezelEnabled:
22:18:37:826 | MD |     INFO  | +0     | CheckSettings - Started
22:18:37:826 | MD |     INFO  | +0     | PCLauncher - Setting mode to: "standard"
22:18:37:846 | MD |     INFO  | +31    | CheckFile - Checking if H:\PC Games\MUGEN Superheroes\MUGEN Superheroes.exe exists
22:18:37:846 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
     FileDescription          M.U.G.E.N Engine
     FileVersion              1.0.0
     InternalName             mugen
     LegalCopyright           Copyright 1999-2010 Elecbyte
     OriginalFilename         mugen.exe
     ProductName              M.U.G.E.N
     CompanyName              Elecbyte
     LegalTrademarks          Elecbyte, M.U.G.E.N
     File Size:   697344 bytes
     Created:   10/3/2015 - 9:52:14 PM
     Modified:   9/7/2013 - 5:28:12 AM
22:18:37:856 | MD |     INFO  | +0     | CheckSettings - Ended
22:18:37:856 | MD |     INFO  | +0     | PCLauncher - Launching a standard application.
22:18:37:876 | MD |     INFO  | +32    | Run - Running: H:\PC Games\MUGEN Superheroes\"MUGEN Superheroes.exe"
22:18:37:886 | MD |   DEBUG1  | +0     | Run - ""MUGEN Superheroes.exe" " Process ID: 4400
22:18:37:906 | MD |     INFO  | +31    | PCLauncher - FadeTitle and AppWaitExe not set by user, but an AppPID was found. Waiting for AppPID: 4400
22:18:37:916 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: HyperSpin | Class: ThunderRT6FormDC | State: 0 | X: 0 | Y: 0 | Width: 1440 | Height: 900 | Window HWND: 0x134029e | Process ID: 1656 | Process Path: E:\Hyperspin\HyperSpin.exe
22:18:37:916 | MD |     INFO  | +0     | WinWait - Waiting for "ahk_pid 4400"
22:18:38:676 | MD |   DEBUG1  | +764   | GetActiveWindowStatus - Title: HyperSpin | Class: ThunderRT6FormDC | State: 0 | X: 0 | Y: 0 | Width: 1440 | Height: 900 | Window HWND: 0x134029e | Process ID: 1656 | Process Path: E:\Hyperspin\HyperSpin.exe
22:18:38:678 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: HyperSpin | Class: ThunderRT6FormDC | State: 0 | X: 0 | Y: 0 | Width: 1440 | Height: 900 | Window HWND: 0x134029e | Process ID: 1656 | Process Path: E:\Hyperspin\HyperSpin.exe
22:18:38:679 | MD |     INFO  | +0     | WinWaitActive - Waiting for "ahk_pid 4400"
22:18:39:044 | MD |   DEBUG1  | +375   | GetActiveWindowStatus - Title: M.U.G.E.N | Class: SDL_app | State: 0 | X: 0 | Y: 0 | Width: 640 | Height: 480 | Window HWND: 0xae0234 | Process ID: 4400 | Process Path: H:\PC Games\MUGEN Superheroes\MUGEN Superheroes.exe
22:18:39:111 | MD |     INFO  | +62    | PCLauncher - Waiting for AppPID "4400" to close.
22:18:39:113 | MD |     INFO  | +0     | Process - WaitClose 4400
22:18:39:434 | RL |  WARNING  | +3121  | HyperSpin.exe was displaced to x0 y0 w640 h480 by PCLauncher. It is probably running in true fullscreen mode.
22:18:49:734 | MD |   DEBUG1  | +10624 | CloseProcess - Started, user requested to end launched application
22:18:49:736 | MD |     INFO  | +0     | CloseProcess - ExitMethod is "Send Alt+F4"
22:18:49:892 | MD |   DEBUG1  | +156   | CloseProcess - Ended
22:19:10:031 | MD |     INFO  | +20139 | ExitModule - Started
22:19:10:034 | MD |     INFO  | +0     | Starting Updating Statistics:
22:19:10:034 | MD |   DEBUG2  | +0     | Total Elapsed Time in Pause in seconds: 0
22:19:10:034 | MD |   DEBUG2  | +0     | gameSectionStartTime:37072795
22:19:10:034 | MD |   DEBUG2  | +0     | ElapsedTime:32
22:19:10:065 | MD |   DEBUG2  | +32    | Statistics cleared game name: MUGEN Superheroes
22:19:10:096 | MD |   DEBUG2  | +31    | Loaded game statistics from ini files:
     Number_of_Times_Played: 1
     Last_Time_Played: Monday October 19, 2015 09:15:45 PM
     Average_Time_Played: 61
     Total_Time_Played: 61
     System_Total_Played_Time: 4071
     Total_Global_Played_Time: 95777
22:19:10:096 | MD |   DEBUG2  | +0     | Updated Statistics: Number_of_Times_Played: 2
     Last_Time_Played: Monday October 19, 2015 10:18:37 PM
     Average_Time_Played: 47
     Total_Time_Played: 93
     System_Total_Played_Time: 4103
     Total_Global_Played_Time: 95809
22:19:10:159 | MD |     INFO  | +62    | Game section statistics updated.
22:19:10:159 | MD |     INFO  | +0     | RunKeymapper - Started, using method "unload"
22:19:10:159 | MD |     INFO  | +0     | GetJoystickArray - Started
22:19:10:190 | MD |   DEBUG2  | +31    | GetJoystickArray - Joysticks Detected: 1000000000000000
22:19:10:190 | MD |     INFO  | +0     | GetJoystickGUID - Started
22:19:10:190 | MD |     INFO  | +0     | GetJoystickGUID - Ended and found GUID: 5041DB96E6EDE4118001444553540000
22:19:10:190 | MD |   DEBUG2  | +0     | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 5041DB96E6EDE4118001444553540000
22:19:10:190 | MD |     INFO  | +0     | GetJoystickArray - Ended
22:19:10:190 | MD |   DEBUG2  | +0     | RunKeymapper - Looping through controllers to find xpadder profiles for each one
22:19:10:190 | MD |   DEBUG2  | +0     | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "Controller (Xbox 360 Wireless Receiver for Windows)"
22:19:10:221 | MD |   DEBUG2  | +32    | GetProfile - Searching for these profiles (| delimited): E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI|E:\Rocketlauncher\Profiles\xpadder\_Default\blank
22:19:10:221 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
22:19:10:221 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile
22:19:10:221 | MD |     INFO  | +0     | GetProfile - Loading Player 1 Profile -> E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile
22:19:10:221 | MD |     INFO  | +0     | RunXpadder - Started
22:19:10:221 | MD |     INFO  | +0     | Process - Exist JoyToKey.exe
22:19:10:252 | MD |   DEBUG2  | +31    | RunXpadder - Closing xpadder to refresh controllers seen by xpadder
22:19:10:252 | MD |     INFO  | +0     | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe /C
22:19:10:299 | MD |   DEBUG1  | +47    | Run - "Xpadder.exe /C" Process ID: 1008
22:19:10:330 | MD |   DEBUG2  | +31    | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in E:\Hyperspin\Utilities\Xpadder\xpadder.ini
22:19:10:362 | MD |     INFO  | +31    | Process - WaitClose Xpadder.exe 2
22:19:10:580 | MD |   DEBUG2  | +218   | RunXpadder - Reading the order in E:\Hyperspin\Utilities\Xpadder\xpadder.ini and arranging profiles found to match that order
22:19:10:580 | MD |   DEBUG2  | +0     | RunXpadder - No more controllers to be found
22:19:10:611 | MD |     INFO  | +32    | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile" /M
22:19:10:642 | MD |   DEBUG1  | +31    | Run - "Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile" /M" Process ID: 3032
22:19:10:642 | MD |     INFO  | +0     | RunXpadder - Ended
22:19:10:642 | MD |     INFO  | +0     | RunKeymapper - Ended
22:19:10:642 | MD |     INFO  | +0     | RunAHKKeymapper - Started
22:19:10:642 | MD |   DEBUG1  | +0     | RunAHKKeymapper - Unloading AhkLauncher
22:19:10:642 | MD |   DEBUG1  | +0     | RunAHKKeymapper - If AhkLauncher.exe is running, need to close it first before a new profile can be loaded
22:19:10:642 | MD |     INFO  | +0     | Process - Exist AhkLauncher.exe
22:19:10:674 | MD |     INFO  | +31    | RunAHKKeymapper - Ended
22:19:10:674 | MD |     INFO  | +0     | Restoring mouse cursor
22:19:10:674 | MD |     INFO  | +0     | ExitModule - Ended
22:19:10:674 | MD |     INFO  | +0     | End of Module Logs
22:19:10:798 | RL |     INFO  | +31356 | Main - Module ended, exiting RocketLauncher normally
22:19:10:798 | RL |     INFO  | +0     | ExitScript - Started
22:19:10:798 | RL |   DEBUG1  | +0     | ExitScript - Checking what application is currently in focus.
22:19:10:814 | RL |   DEBUG1  | +15    | ExitScript - Control Panel\Appearance and Personalization\Display\Screen Resolution is currently active. Putting focus back on HyperSpin.exe
22:19:16:274 | RL |    ERROR  | +5460  | ExitScript - Timed out trying to put HyperSpin.exe back in focus.
22:19:16:274 | RL |     INFO  | +0     | SystemCursor - Restoring mouse cursor
22:19:16:305 | RL |     INFO  | +32    | ExitScript - Ended
