Gameboy Dons rom renamer stuck at 385
I've used Don's rom renamer many times with no problem, however when I try to rename The original gameboy it matches 385 and then stops. I've left it on all night and its still stuck at 385.
I got the xml from Hyperspin. Anyone else having a similar issue?
I can look into it sometime this week. In the mean time, try extracting all your gameboy ROMs into a new empty folder. Create another empty folder for the output folder.
Open the ROM renamer and try running it with those two folders.
Let me know if this works. Also, let me know if you noticed any errors when you were unzipping the files.
I have some major enhancements in the next release and would like to ensure this is resolved.
Thanks emb, I did everything you said and it worked like a charm. The only thing I noticed when unzipping the files was that the unzipping process stoped at 9% complete, I exited out thinking there was a problem, however all the roms were extracted perfectly fine to the new folder. Thanks again for your help I've been trying to figure this out for awhile now.
