HyperSpin 1.4 Artwork/Video Issue
theob42
Hello All,
I had a older build of HS and now just building a new setup for HS 1.4 from scratch. Used the new HyperSync. Currently experiencing an odd issue. Not sure if it is due to the artwork not in the correct folder for the default system theme or something else.
If I go into the system (in this case NES), you can see it goes to the last game you were on and that box and video loads. If you then scroll up to a different game you dont see the box. If you happen to hit a game with its own theme, that always loads, and then after you move off the game theme to a default theme, that box will show up. The only way to show the video and box for the default theme is to exist the system and go back in.
Any suggestions? See video below.
