U-Trak Trackball, Winipac & MAME - S.O.S.
Rotgut
Hi. everyone!  I have everything up and running with my custom CP.  I am using a Mini-Pac Opti and have assigned most of my controls using Winipac v.2.  The problem is, I cannot for the life of me figure out what I need to do in order to get the U-Trak to operate.
Am I supposed to assign the U-Trak controls in Winipac?  It's not clear to me how the U-Trak is supposed to be "programmed."
Once the U-Trak is "programmed" or whatnot, what are the steps I need to take once I am in an actual MAME game?  I am used to pressing the Tab key to configure controls, but I am pretty much lost as to how to get a game like Centipede (for example) to recognize the U-Trak.
One thing I ** did ** do was go into my MAME.ini file and change "Mouse" from 0 to 1.
Besides that, I'm lost as to what to do.
I have read a lot of conflicting information online and it's confusing to me.  Can anyone help me out?  Thanks in advance  : )
does the trackball work as a mouse outside of mame?  If so then its working/configured.
Do you have just 1 mame ini files?  I used one of gigapigs builds off here and i had to enable mouse in all 4 ini files
just go to inputs, then change trackball x input to moving the trackball sideways.  Should show up as mouse x or something like that
Same goes for trackball y and moving the trackballl up and down.
First, thanks for the advice : )
Yes, the trackball does function as a mouse in Win 7... it also functions to scroll up and down in HyperSpin menus and scrolls up and down when I am in the "Tab" game "key press" options...
I found two (2) MAME.ini files and changed each one from Mouse = 0 to Mouse = 1
Re: the two (2) ini files, one was in the "main" MAME emulator/executable folder and the other one was in a sub folder called "ini"...
When I go to Tab key settings in MAME and go to Track X Analog and Track Y Analog... and I try to program a trackball spin... nothing happens, nothing registers...
Not sure what to do at this point.  I only found two (2) MAME.ini files and I changed them, like I said, so I am at a loss...
Ugh
I feel your pain but you're close.
Is your trackball device set to mouse or keyboard?  Should be mouse.
What version of MAME are you using?
mouse 1
joystick 1
lightgun 1
multimouse 0
trackball device mouse
lightgun device lightgun
positional device lightgun
mouse device mouse.
mouse 1
joystick 1
lightgun 1
multimouse 0
mouse device mouse.
Thanks, dude.  I will check tonight which ver. of MAME.  I think it might be 0.137...
I never altered those other command lines, just the "Mouse = 1" change... that is the only line I was advised to change...
So maybe these other command lines need changed.  Hope that's all it is.
"And don't call me Shirley!"  LOL
mouse 1
joystick 1
lightgun 1
multimouse 0
mouse device mouse.
I am using MAME ver 0128.
Other than the lightgun options (I am not using one), I have done all of these things.  I am truly at a loss.  I have gone into every folder I know of to change any "MAME.ini" files I can find. Still no trackball ability in-game.  It is making me crazy.  If anyone has any advice I would really and truly appreciate it.  Thank you  : )
IDK man.  With everything you've done, it *should* work.
If you've got time try a new version of MAME, and create a new .ini file.   Or reinstall your version of mame and create a new ini file.
