kcorcoran Posted November 14, 2015 Posted November 14, 2015 I want to add solenoids to my cabinet for visual pinball.As opposed to using visual pinball and led wiz like they do in VP cabinets, I simply want to switch a relay to provide 12v power to my solenoids only when Visual Pinball is run.The relay board I am using takes simple commands via USB and I was able to find an ahk which controls it but I'm at a bit of a loss as to how to use it.At first glance this AHK script looks like much more than I need since I only need to send the commandrelay on 0when the emulator starts andrelay off 0when the emulator quitsBelow is the AHK.Any help would be appreciated. ;############################################################################## ;# # ;# Autohotkey Script to control Numato Lab USB Relay Module # ;# www.numato.com # ;# Uses subroutines from the script published by aobrien at http://www.autoho # ;# tkey.com/board/topic/26231-serial-com-port-console-script/#187247 # ;# # ;# This script can be used with all Numato USB Relay modules. # ;############################################################################## SendMode Input SetWorkingDir %A_ScriptDir% InputBox, comport, Enter Port Number, Simply enter the decimal number. COM will be added automatically.,,,,,,,,0 if ErrorLevel ExitApp InputBox, relaynum, Enter Relay Number ,Enter the number of the relay. Relays are usually numbered 0 - 9 then A - Z. Make sure to use upper case letters when typing relay numbers from A onwards. ,,,,,,,,0 if ErrorLevel ExitApp InputBox, relaycommand, Enter Relay Command (on/off/read),Enter command (on/off/read),,,,,,,,read if ErrorLevel ExitApp if ( not relaycommand = "on" and not relaycommand = "off" and not relaycommand = "read"){ msgbox Please enter a valid relay command ExitApp } RS232_Port = COM%comport% RS232_Settings = %RS232_Port%:baud=19200 parity=N data=8 stop=1 dtr=Off xon=off to=off odsr=off octs=off rts=off idsr=off RS232_FileHandle:=RS232_Initialize(RS232_Settings) if (relaycommand = "on"){ command = relay on %relaynum%`r RS232_Write(RS232_FileHandle, command) } if (relaycommand = "off"){ command = relay off %relaynum%`r RS232_Write(RS232_FileHandle, command) } if (relaycommand = "read"){ command = relay read %relaynum%`r RS232_Write(RS232_FileHandle, command) Sleep, 10 Read_Data := RS232_Read(RS232_FileHandle, 20,RS232_Bytes_Received) StringGetPos OutputVar, Read_Data, off if(not ErrorLevel) msgbox Relay is Off StringGetPos OutputVar, Read_Data,on if(not ErrorLevel) msgbox Relay is On } RS232_Close(RS232_FileHandle) ExitApp ;######################################################################## ;# Initialize RS232 Port # ;######################################################################## RS232_Initialize(RS232_Settings) { ;###### Extract/Format the RS232 COM Port Number ###### ;7/23/08 Thanks krisky68 for finding/solving the bug in which RS232 COM Ports greater than 9 didn't work. StringSplit, RS232_Temp, RS232_Settings, `: RS232_Temp1_Len := StrLen(RS232_Temp1) ;For COM Ports > 9 \\.\ needs to prepended to the COM Port name. If (RS232_Temp1_Len > 4) ;So the valid names are RS232_COM = \\.\%RS232_Temp1% ; ... COM8 COM9 \\.\COM10 \\.\COM11 \\.\COM12 and so on... Else ; RS232_COM = %RS232_Temp1% ;8/10/09 A BIG Thanks to trenton_xavier for figuring out how to make COM Ports greater than 9 work for USB-Serial Dongles. StringTrimLeft, RS232_Settings, RS232_Settings, RS232_Temp1_Len+1 ;Remove the COM number (+1 for the semicolon) for BuildCommDCB. ;MsgBox, RS232_COM=%RS232_COM% `nRS232_Settings=%RS232_Settings% ;###### Build RS232 COM DCB ###### ;Creates the structure that contains the RS232 COM Port number, baud rate,... VarSetCapacity(DCB, 28) BCD_Result := DllCall("BuildCommDCB" ,"str" , RS232_Settings ;lpDef ,"UInt", &DCB) ;lpDCB If (BCD_Result <> 1) { MsgBox, There is a problem with Serial Port communication. `nFailed Dll BuildCommDCB, BCD_Result=%BCD_Result% `nThe Script Will Now Exit. Exit } ;###### Create RS232 COM File ###### ;Creates the RS232 COM Port File Handle RS232_FileHandle := DllCall("CreateFile" ,"Str" , RS232_COM ;File Name ,"UInt", 0xC0000000 ;Desired Access ,"UInt", 3 ;Safe Mode ,"UInt", 0 ;Security Attributes ,"UInt", 3 ;Creation Disposition ,"UInt", 0 ;Flags And Attributes ,"UInt", 0 ;Template File ,"Cdecl Int") If (RS232_FileHandle < 1) { MsgBox, There is a problem with Serial Port communication. `nFailed Dll CreateFile, RS232_FileHandle=%RS232_FileHandle% `nThe Script Will Now Exit. Exit } ;###### Set COM State ###### ;Sets the RS232 COM Port number, baud rate,... SCS_Result := DllCall("SetCommState" ,"UInt", RS232_FileHandle ;File Handle ,"UInt", &DCB) ;Pointer to DCB structure If (SCS_Result <> 1) { MsgBox, There is a problem with Serial Port communication. `nFailed Dll SetCommState, SCS_Result=%SCS_Result% `nThe Script Will Now Exit. RS232_Close(RS232_FileHandle) Exit } ;###### Create the SetCommTimeouts Structure ###### ReadIntervalTimeout = 0x00000001 ReadTotalTimeoutMultiplier = 0x00000000 ReadTotalTimeoutConstant = 0x00000000 WriteTotalTimeoutMultiplier= 0x00000000 WriteTotalTimeoutConstant = 0x00000000 VarSetCapacity(Data, 20, 0) ; 5 * sizeof(DWORD) NumPut(ReadIntervalTimeout, Data, 0, "UInt") NumPut(ReadTotalTimeoutMultiplier, Data, 4, "UInt") NumPut(ReadTotalTimeoutConstant, Data, 8, "UInt") NumPut(WriteTotalTimeoutMultiplier, Data, 12, "UInt") NumPut(WriteTotalTimeoutConstant, Data, 16, "UInt") ;###### Set the RS232 COM Timeouts ###### SCT_result := DllCall("SetCommTimeouts" ,"UInt", RS232_FileHandle ;File Handle ,"UInt", &Data) ;Pointer to the data structure If (SCT_result <> 1) { MsgBox, There is a problem with Serial Port communication. `nFailed Dll SetCommState, SCT_result=%SCT_result% `nThe Script Will Now Exit. RS232_Close(RS232_FileHandle) Exit } Return %RS232_FileHandle% } ;######################################################################## ;# Close RS232 Port # ;######################################################################## RS232_Close(RS232_FileHandle) { ;###### Close the COM File ###### CH_result := DllCall("CloseHandle", "UInt", RS232_FileHandle) If (CH_result <> 1) MsgBox, Failed Dll CloseHandle CH_result=%CH_result% Return } ;######################################################################## ;# Write to RS232 Port # ;######################################################################## RS232_Write(RS232_FileHandle,Message) { ;###### Write the data to the RS232 COM Port ###### WF_Result := DllCall("WriteFile" ,"UInt" , RS232_FileHandle ;File Handle ,"UInt" , &Message ;Pointer to string to send ,"UInt" , Strlen(Message) ;Data Length ,"UInt*", Bytes_Sent ;Returns pointer to num bytes sent ,"Int" , "NULL") If (WF_Result <> 1 or Bytes_Sent <> Strlen(Message)) MsgBox, Failed Dll WriteFile to RS232 COM, result=%WF_Result% `nData Length=%Data_Length% `nBytes_Sent=%Bytes_Sent% } ;######################################################################## ;# Read from RS232 port # ;######################################################################## RS232_Read(RS232_FileHandle,Num_Bytes,ByRef RS232_Bytes_Received) { SetFormat, Integer, HEX ;Set the Data buffer size, prefill with 0x55 = ASCII character "U" ;VarSetCapacity won't assign anything less than 3 bytes. Meaning: If you ; tell it you want 1 or 2 byte size variable it will give you 3. Data_Length := VarSetCapacity(Data, Num_Bytes, 0x55) ;MsgBox, Data_Length=%Data_Length% ;###### Read the data from the RS232 COM Port ###### ;MsgBox, RS232_FileHandle=%RS232_FileHandle% `nNum_Bytes=%Num_Bytes% Read_Result := DllCall("ReadFile" ,"UInt" , RS232_FileHandle ; hFile ,"Str" , Data ; lpBuffer ,"Int" , Num_Bytes ; nNumberOfBytesToRead ,"UInt*", RS232_Bytes_Received ; lpNumberOfBytesReceived ,"Int" , 0) ; lpOverlapped ;MsgBox, RS232_FileHandle=%RS232_FileHandle% `nRead_Result=%Read_Result% `nBR=%RS232_Bytes_Received% ,`nData=%Data% If (Read_Result <> 1) { MsgBox, There is a problem with Serial Port communication. `nFailed Dll ReadFile on RS232 COM, result=%Read_Result% - The Script Will Now Exit. RS232_Close(RS232_FileHandle) Exit } Return Data }
hodenhornchen Posted December 12, 2015 Posted December 12, 2015 mmmh problem ist when you do this you steal the ledwiz controlls from DOF i know what you want to do is use ports double for keys and solenoids the püroblem is ledblinky hook the ledwiz and comes in trouble with DOF what controll all in VP. use one of these for your solenoids you can use it with DOF direct in Vpinmame or another cheap solution is an arduio and the right firmware https://github.com/cithraidt/lwcloneu2/tree/master/firmware
