Nostalgia-Black screen then kicks back
demonseed
Hey
I got intellivison all set up I run it in Nostalgia itself and it works, however in HS, screen goes black to load but then kicks back to HS? any suggestions? I have Nostalgia 5 and bios are installed.
[code]
23:07:13:498 | RL |     INFO  | +N/A   | Main - RocketLauncher v1.0.1.4 (www.rlauncher.com)
23:07:13:498 | RL |  WARNING  | +0     | Main - You have "Logging_Log_Command_Window" enabled. This is only for logging errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done.
23:07:13:608 | RL |     INFO  | +110   | Main - System Specs:
					RocketLauncher Dir: E:\Rocketlauncher
					RocketLauncher is: 32-bit
					OS: Microsoft Windows 7 Professional
					SKU: Professional
					Total Memory: 8016.31 MB
					Free Memory: 4244.38 MB
					Used Memory: 3771.934 MB
					SystemType: 64-bit
					Physical Processors: 1
					Logical Processors: 4
					GPU 1 Name: Intel(R) HD Graphics
					GPU 1 RAM: -1924.00 MB
					GPU 1 Driver Version: 9.17.10.3347
					Sound 1 Device: High Definition Audio Device
					Sound 1 Status: Enabled
					Sound 2 Device: High Definition Audio Device
					Sound 2 Status: Enabled
					OS Admin Status: Yes
					Latest .Net Version: v4.0.30319
					Monitor #1 (\\.\DISPLAY1): 1440x900 (1440x856 work) [Landscape] (Primary)
					Current AHK Desktop Width: 1440
					Current AHK Desktop Height: 900
					AutoHotkey Path: C:\Program Files\AutoHotkey\AutoHotkey.exe
					AHK Version: 1.1.09.04
					Unicode: No
23:07:13:608 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\RocketLauncher.exe exists
23:07:13:618 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					FileDescription         	RocketLauncher
					FileVersion             	1.0.1.4
					LegalCopyright          	©2015 RocketLauncher
					CompanyName             	Your favorite Front End companion! Visit us @ www.rlauncher.com
					File Size:			2063360 bytes
					Created:			5/23/2015 - 10:53:13 PM
					Modified:			11/26/2015 - 12:43:10 AM
23:07:13:618 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Array.ahk exists
23:07:13:628 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
23:07:13:638 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			4924 bytes
					Created:			11/26/2015 - 12:43:11 AM
					Modified:			11/26/2015 - 12:43:11 AM
23:07:13:648 | RL |     INFO  | +15    | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\BinHexRW.ahk exists
23:07:13:668 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
23:07:13:678 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			5077 bytes
					Created:			5/24/2015 - 8:27:48 AM
					Modified:			11/26/2015 - 12:42:57 AM
23:07:13:678 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\BlockInput.exe exists
23:07:13:678 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription
					InternalName
					OriginalFilename
					ProductName
					File Size:			657920 bytes
					Created:			5/24/2015 - 8:26:42 AM
					Modified:			1/2/2014 - 10:27:34 PM
23:07:13:678 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\CLR_L.ahk exists
23:07:13:688 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
23:07:13:688 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5474 bytes
					Created:			9/6/2015 - 8:32:14 PM
					Modified:			9/6/2015 - 8:32:14 PM
23:07:13:688 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Control_AniGif.ahk exists
23:07:13:728 | RL |   DEBUG1  | +46    | CRC Check - CRC matches, this is an official unedited Extension.
23:07:13:728 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5716 bytes
					Created:			5/24/2015 - 8:26:30 AM
					Modified:			4/29/2013 - 1:56:02 PM
23:07:13:738 | RL |     INFO  | +16    | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gdip.ahk exists
23:07:13:738 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
23:07:13:738 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			88789 bytes
					Created:			5/24/2015 - 7:02:39 AM
					Modified:			1/13/2013 - 5:07:30 PM
23:07:13:748 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gdip_alt.ahk exists
23:07:13:748 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:07:13:748 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5895 bytes
					Created:			5/24/2015 - 8:25:59 AM
					Modified:			6/28/2015 - 6:41:33 AM
23:07:13:758 | RL |   DEBUG1  | +16    | gdip_alt.ahk Version: 1.0.2
23:07:13:758 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gsdll32.dll exists
23:07:13:758 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			13090816 bytes
					Created:			5/24/2015 - 8:25:19 AM
					Modified:			1/6/2015 - 9:20:42 PM
23:07:13:758 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\itextsharp.dll exists
23:07:13:768 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	iTextSharp
					FileVersion             	5.4.2.0
					InternalName            	itextsharp.dll
					LegalCopyright          	Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
					OriginalFilename        	itextsharp.dll
					ProductName             	iTextSharp
					ProductVersion          	5.4.2.0
					CompanyName             	1T3XT BVBA
					File Size:			3743744 bytes
					Created:			5/24/2015 - 8:24:07 AM
					Modified:			6/14/2013 - 2:06:21 PM
23:07:13:768 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Java.ahk exists
23:07:13:778 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
23:07:13:788 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			7841 bytes
					Created:			5/24/2015 - 8:27:37 AM
					Modified:			12/23/2014 - 11:02:37 PM
23:07:13:788 | RL |   DEBUG1  | +0     | Java.ahk Version: 1.0.0
23:07:13:798 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\JSON.ahk exists
23:07:13:808 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
23:07:13:818 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			9203 bytes
					Created:			5/24/2015 - 8:26:08 AM
					Modified:			5/5/2013 - 2:22:25 PM
23:07:13:818 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Origin.ahk exists
23:07:13:828 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:07:13:828 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			4904 bytes
					Created:			5/24/2015 - 8:26:27 AM
					Modified:			3/22/2015 - 2:51:41 PM
23:07:13:828 | RL |   DEBUG1  | +0     | Origin.ahk Version: 1.0.2
23:07:13:838 | RL |     INFO  | +16    | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\RegRW64.ahk exists
23:07:13:838 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
23:07:13:838 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			6915 bytes
					Created:			5/24/2015 - 8:28:09 AM
					Modified:			5/8/2014 - 3:06:39 AM
23:07:13:838 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\RIni.ahk exists
23:07:13:858 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
23:07:13:858 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			67561 bytes
					Created:			5/24/2015 - 8:28:04 AM
					Modified:			6/5/2013 - 6:56:23 PM
23:07:13:868 | RL |     INFO  | +16    | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\SevenZipSharp.dll exists
23:07:13:868 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	SevenZipSharp
					FileVersion             	0.64.5717.6837
					InternalName            	SevenZipSharp.dll
					LegalCopyright          	Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
					OriginalFilename        	SevenZipSharp.dll
					ProductName             	SevenZipSharp
					ProductVersion          	0.64.5717.6837
					CompanyName             	Markovtsev Vadim
					File Size:			167424 bytes
					Created:			5/24/2015 - 8:27:30 AM
					Modified:			11/26/2015 - 12:43:04 AM
23:07:13:878 | RL |     INFO  | +15    | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Steam.ahk exists
23:07:13:888 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:07:13:898 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			5347 bytes
					Created:			5/24/2015 - 8:28:20 AM
					Modified:			3/22/2015 - 2:52:25 PM
23:07:13:908 | RL |   DEBUG1  | +0     | Steam.ahk Version: 1.0.2
23:07:13:908 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\VA.ahk exists
23:07:13:908 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
23:07:13:928 | RL |   DEBUG1  | +31    | CheckFile - Attributes:
					File Size:			34688 bytes
					Created:			5/24/2015 - 8:26:53 AM
					Modified:			3/1/2013 - 9:05:47 PM
23:07:13:938 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\VA_Extension.ahk exists
23:07:13:948 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
23:07:13:948 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			3833 bytes
					Created:			5/24/2015 - 8:28:38 AM
					Modified:			1/13/2015 - 8:16:56 PM
23:07:13:958 | RL |   DEBUG1  | +15    | VA_Extension.ahk Version: 1.0.1
23:07:13:958 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\7z.ahk exists
23:07:13:968 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:07:13:968 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			29149 bytes
					Created:			5/29/2015 - 11:47:30 PM
					Modified:			11/26/2015 - 12:42:55 AM
23:07:13:968 | RL |   DEBUG1  | +0     | 7z.ahk Version: 1.0.2
23:07:13:968 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Bezel.ahk exists
23:07:13:008 | RL |   DEBUG1  | +47    | CRC Check - CRC matches, this is an official unedited Library.
23:07:14:008 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			104277 bytes
					Created:			5/24/2015 - 8:28:01 AM
23:07:14:008 | RL |   DEBUG1  | +0     | Bezel.ahk Version: 1.1.7
23:07:14:018 | RL |     INFO  | +16    | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade.ahk exists
23:07:14:038 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
23:07:14:038 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			38251 bytes
					Created:			5/24/2015 - 8:26:50 AM
					Modified:			11/26/2015 - 12:43:06 AM
23:07:14:038 | RL |   DEBUG1  | +0     | Fade.ahk Version: 1.1.4
23:07:14:048 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade Init.ahk exists
23:07:14:048 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:07:14:048 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			1065 bytes
					Created:			5/24/2015 - 8:27:38 AM
					Modified:			11/26/2015 - 12:43:12 AM
23:07:14:058 | RL |   DEBUG1  | +16    | Fade Init.ahk Version: 1.0.2
23:07:14:058 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade Animations.ahk exists
23:07:14:058 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:07:14:068 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			81174 bytes
					Created:			5/24/2015 - 8:27:41 AM
23:07:14:068 | RL |   DEBUG1  | +0     | Fade Animations.ahk Version: 1.1.10
23:07:14:068 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Keymapper.ahk exists
23:07:14:078 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:07:14:078 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			33453 bytes
					Created:			5/24/2015 - 8:28:11 AM
					Modified:			5/30/2015 - 9:18:27 PM
23:07:14:078 | RL |   DEBUG1  | +0     | Keymapper.ahk Version: 1.1.2
23:07:14:078 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Keymapper Init.ahk exists
23:07:14:098 | RL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Library.
23:07:14:098 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			3461 bytes
					Created:			5/24/2015 - 8:26:35 AM
					Modified:			5/30/2015 - 9:18:57 PM
23:07:14:108 | RL |   DEBUG1  | +0     | Keymapper Init.ahk Version: 1.0.4
23:07:14:108 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiGame.ahk exists
23:07:14:118 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
23:07:14:128 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			40753 bytes
					Created:			5/24/2015 - 8:24:03 AM
					Modified:			9/6/2015 - 8:32:13 PM
23:07:14:128 | RL |   DEBUG1  | +0     | MultiGame.ahk Version: 1.0.8
23:07:14:128 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiGame Init.ahk exists
23:07:14:138 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:07:14:138 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			161 bytes
					Created:			5/24/2015 - 8:28:32 AM
					Modified:			4/14/2013 - 1:33:19 PM
23:07:14:138 | RL |   DEBUG1  | +0     | MultiGame Init.ahk Version: 1.0.0
23:07:14:138 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiPlayer.ahk exists
23:07:14:148 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
23:07:14:148 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			66452 bytes
					Created:			5/24/2015 - 8:23:41 AM
					Modified:			11/26/2015 - 12:42:52 AM
23:07:14:158 | RL |   DEBUG1  | +0     | MultiPlayer.ahk Version: 1.0.7
23:07:14:158 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Pause.ahk exists
23:07:14:248 | RL |   DEBUG1  | +93    | CRC Check - CRC matches, this is an official unedited Library.
23:07:14:248 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			392193 bytes
					Created:			5/24/2015 - 8:26:19 AM
					Modified:			11/26/2015 - 12:43:03 AM
23:07:14:258 | RL |   DEBUG1  | +16    | Pause.ahk Version: 1.1.5
23:07:14:258 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Pause Init.ahk exists
23:07:14:258 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:07:14:258 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			553 bytes
					Created:			5/24/2015 - 8:24:21 AM
					Modified:			9/6/2015 - 8:31:51 PM
23:07:14:268 | RL |   DEBUG1  | +15    | Pause Init.ahk Version: 1.0.3
23:07:14:268 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Password.ahk exists
23:07:14:288 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
23:07:14:288 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			10025 bytes
					Created:			5/24/2015 - 8:24:18 AM
					Modified:			9/6/2015 - 8:31:55 PM
23:07:14:288 | RL |   DEBUG1  | +0     | Password.ahk Version: 1.0.2
23:07:14:298 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Rom Mapping Launch Menu.ahk exists
23:07:14:348 | RL |   DEBUG1  | +62    | CRC Check - CRC matches, this is an official unedited Library.
23:07:14:358 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			74101 bytes
					Modified:			11/26/2015 - 12:42:54 AM
23:07:14:358 | RL |   DEBUG1  | +0     | Rom Mapping Launch Menu.ahk Version: 1.0.6
23:07:14:358 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Shared.ahk exists
23:07:14:368 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
23:07:14:368 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			139893 bytes
					Modified:			11/26/2015 - 12:43:02 AM
23:07:14:368 | RL |   DEBUG1  | +0     | Shared.ahk Version: 1.3.5
23:07:14:378 | RL |     INFO  | +16    | CheckFile - Checking if E:\Rocketlauncher\Lib\Statistics.ahk exists
23:07:14:378 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:07:14:378 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			26143 bytes
					Created:			5/24/2015 - 8:26:45 AM
					Modified:			4/9/2015 - 4:16:56 AM
23:07:14:388 | RL |   DEBUG1  | +0     | Statistics.ahk Version: 1.0.3
23:07:14:388 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Statistics Init.ahk exists
23:07:14:388 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:07:14:388 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			33 bytes
					Modified:			12/23/2014 - 11:23:48 PM
23:07:14:398 | RL |   DEBUG1  | +15    | Statistics Init.ahk Version: 1.0.1
23:07:14:398 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\Virtual Drive.ahk exists
23:07:14:408 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
23:07:14:408 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			18329 bytes
					Created:			5/29/2015 - 11:47:33 PM
					Modified:			11/26/2015 - 12:42:58 AM
23:07:14:408 | RL |   DEBUG1  | +0     | Virtual Drive.ahk Version: 1.0.3
23:07:14:408 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\XHotkey.ahk exists
23:07:14:418 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:07:14:438 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			26540 bytes
					Created:			5/24/2015 - 8:28:26 AM
					Modified:			9/6/2015 - 8:32:04 PM
23:07:14:458 | RL |   DEBUG1  | +32    | XHotkey.ahk Version: 1.0.4
23:07:14:458 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Lib\XHotkey Init.ahk exists
23:07:14:468 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
23:07:14:478 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			1063 bytes
					Created:			5/24/2015 - 8:26:46 AM
					Modified:			9/6/2015 - 8:31:50 PM
23:07:14:478 | RL |   DEBUG1  | +0     | XHotkey Init.ahk Version: 1.0.2
23:07:14:478 | RL |   DEBUG1  | +0     | Main - Using HyperSpin normal mode for version 1.4.0.0 found at: E:\Hyperspin\HyperSpin.exe
23:07:14:488 | RL |   DEBUG1  | +16    | Main - Raw CLI received: "Mattel Intellivision Star Wars - The Empire Strikes Back (World)"
23:07:14:498 | RL |   DEBUG1  | +0     | Main - Received this dbName with no path via CLI: "Star Wars - The Empire Strikes Back (World)"
23:07:14:498 | RL |   DEBUG1  | +0     | Main - dbName: Star Wars - The Empire Strikes Back (World)
23:07:14:508 | RL |     INFO  | +15    | Main - Loading Front End Plugin: "HyperSpin"
23:07:14:508 | RL |     INFO  | +0     | Main - HyperSpin.exe coordinates are x0 y0 w1440 h900
23:07:14:518 | RL |     INFO  | +16    | Main - RocketLauncher received "Mattel Intellivision" and "Star Wars - The Empire Strikes Back (World)"
23:07:14:528 | RL |     INFO  | +0     | Main - Did not find a "E:\Rocketlauncher\Settings\Mattel Intellivision\Game Options.ini" file, skipping any game-specific options.
23:07:14:528 | RL |     INFO  | +0     | Main - Star Wars - The Empire Strikes Back (World) is using the default emulator: Nostalgia
23:07:14:538 | RL |     INFO  | +16    | Main - Checking for a [Nostalgia] section in E:\Rocketlauncher\Settings\Mattel Intellivision\Emulators.ini
23:07:14:538 | RL |     INFO  | +0     | Main - Checking for a [Nostalgia] section in E:\Rocketlauncher\Settings\Global Emulators.ini
23:07:14:548 | RL |     INFO  | +0     | Main - Found [Nostalgia] in E:\Rocketlauncher\Settings\Global Emulators.ini
23:07:14:548 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Modules\Nostalgia\Nostalgia.ahk exists
23:07:14:558 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			2215 bytes
					Created:			5/24/2015 - 8:23:39 AM
					Modified:			9/6/2015 - 8:32:09 PM
23:07:14:568 | RL |     INFO  | +16    | Main - CRC Check - CRC matches, this is an official unedited module.
23:07:14:578 | RL |     INFO  | +0     | Main - Star Wars - The Empire Strikes Back (World) will use module: E:\Rocketlauncher\Modules\Nostalgia\Nostalgia.ahk
23:07:14:588 | RL |     INFO  | +15    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
23:07:14:598 | RL |     INFO  | +16    | CheckFile - Checking if E:\Hyperspin\Emulators\Mattel Intellivision\nostalgia.exe exists
23:07:14:598 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			1126400 bytes
					Created:			6/1/2015 - 12:21:56 PM
					Modified:			7/30/2008 - 11:26:14 AM
23:07:14:608 | RL |     INFO  | +0     | Main - INI Keys read
23:07:14:608 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\7z.exe exists
23:07:14:608 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileVersion             	15.06 beta
					InternalName            	7z
					LegalCopyright          	Copyright (c) 1999-2015 Igor Pavlov
					ProductVersion          	15.06 beta
					File Size:			262144 bytes
					Created:			5/24/2015 - 8:26:40 AM
					Modified:			11/26/2015 - 12:42:56 AM
23:07:14:618 | RL |     INFO  | +16    | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\7z.dll exists
23:07:14:628 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					FileDescription         	7z Plugin
					InternalName            	7z
					OriginalFilename        	7z.dll
					File Size:			1012224 bytes
					Created:			5/24/2015 - 8:28:28 AM
					Modified:			11/26/2015 - 12:43:05 AM
23:07:14:628 | RL |     INFO  | +0     | Main - "Star Wars - The Empire Strikes Back (World)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
23:07:14:628 | RL |     INFO  | +0     | CheckPaths - Started
23:07:14:638 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Mattel Intellivision\roms\Star Wars - The Empire Strikes Back (World).7z
23:07:14:638 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Mattel Intellivision\roms\Star Wars - The Empire Strikes Back (World)\Star Wars - The Empire Strikes Back (World).7z
23:07:14:638 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
23:07:14:638 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Mattel Intellivision\roms\Star Wars - The Empire Strikes Back (World).zip
23:07:14:638 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Mattel Intellivision\roms\Star Wars - The Empire Strikes Back (World)\Star Wars - The Empire Strikes Back (World).zip
23:07:14:648 | RL |   DEBUG1  | +16    | CheckPaths - Rom not found
23:07:14:648 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Mattel Intellivision\roms\Star Wars - The Empire Strikes Back (World).bin
23:07:14:658 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Mattel Intellivision\roms\Star Wars - The Empire Strikes Back (World)\Star Wars - The Empire Strikes Back (World).bin
23:07:14:658 | RL |   DEBUG1  | +15    | CheckPaths - Rom not found
23:07:14:668 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Mattel Intellivision\roms\Star Wars - The Empire Strikes Back (World).int
23:07:14:668 | RL |     INFO  | +0     | CheckPaths - Found rom: E:\Hyperspin\Emulators\Mattel Intellivision\roms\Star Wars - The Empire Strikes Back (World).int
23:07:14:678 | RL |   DEBUG1  | +16    | CheckPaths - Current romName: Star Wars - The Empire Strikes Back (World)
23:07:14:678 | RL |   DEBUG1  | +0     | CheckPaths - Current romPath: E:\Hyperspin\Emulators\Mattel Intellivision\roms
23:07:14:678 | RL |   DEBUG1  | +0     | CheckPaths - Current romExtension: .int
23:07:14:678 | RL |     INFO  | +0     | CheckPaths - Ended
23:07:14:688 | RL |     INFO  | +0     | BuildScript - User Variables:
					; INJECTED VARIABLES
					#NoTrayIcon
					#InstallKeybdHook
					DetectHiddenWindows, ON
					SetTitleMatchMode, 2
					SendMode, Event
					0 = 2
					pluginPath = E:\Rocketlauncher\Plugins
					pluginName = HyperSpin
					pluginExt = .plugin
					contextOnExit =
					rlMode =
					rlTitle = RocketLauncher
					rlVersion = 1.0.1.4
					rlAuthor = djvj
					rlURL = www.rlauncher.com
					langFile = E:\Rocketlauncher\Data\Language\Localization.ini
					primMonitor = 1
					frontendPID = 4600
					frontendPath = E:\Hyperspin
					frontendExe = HyperSpin.exe
					frontendExt = exe
					frontendName = HyperSpin
					frontendDrive = E:
					exitEmulatorKey = ~Esc|H3:1joy6
					restoreFE = Restore and Click
					exitScriptKey = ~q & ~s
					toggleCursorKey = ~e & ~t
					emuFullPath = E:\Hyperspin\Emulators\Mattel Intellivision\nostalgia.exe
					emuPath = E:\Hyperspin\Emulators\Mattel Intellivision
					emuName = Nostalgia
					emuExt = exe
					romPath = E:\Hyperspin\Emulators\Mattel Intellivision\roms
					romPathFromIni = E:\Hyperspin\Emulators\Mattel Intellivision\roms
					romExtension = .int
					romExtensionOrig = .int
					romExtensions = 7z|zip|bin|int|rom
					executable = nostalgia.exe
					systemDbName = Mattel Intellivision
					systemName = Mattel Intellivision
					dbPath =
					dbName = Star Wars - The Empire Strikes Back (World)
					dbExt =
					romName = Star Wars - The Empire Strikes Back (World)
					romMapPath =
					romMappingEnabled = false
					romMappingHideParent = false
					romMappingMenuWidth = 400
					romMappingMenuMargin = 65
					romMappingTextMargin = 15
					romMappingGameNameTextFont = Bebas Neue
					romMappingGameNameTextOptions = cFFFFFFFF r4 s40 Regular
					romMappingMenuFlagWidth = 55
					altArchiveNameOnly =
					altRomNameOnly =
					altArchiveAndRomName =
					altArchiveAndManyRomNames =
					altRomNamesOnly =
					romMapScenario =
					skipchecks = false
					romMatchExt = false
					blockInputTime = 0
					blockInputFile = E:\Rocketlauncher\Module Extensions\BlockInput.exe
					errorLevelReporting = false
					lockLaunch = false
					lockLaunchGame =
					screenRotationAngle = 0
					screenRotationAngleGame =
					logFile = E:\Rocketlauncher\RocketLauncher.log
					logLevel = 10
					logShowDebugConsole = true
					logIncludeModule = true
					logShowCommandWindow = false
					logCommandWindow = true
					rlDebugConsoleStdout = 7
					sysType = 64-bit
					broadcastWindowTitle =
					navUpKey = Up
					navDownKey = Down
					navLeftKey = Left
					navRightKey = Right
					navSelectKey = 1
					navP2UpKey = Numpad8
					navP2DownKey = Numpad2
					navP2LeftKey = Numpad4
					navP2RightKey = Numpad6
					navP2SelectKey = NumpadEnter
					originalWidth = 1440
					originalHeight = 900
					vdEnabled = false
					vdFullPath =
					vdUseSCSI = true
					vdDriveLetter =
					vdAddDrive = true
					servoStikEnabled = false
					servoStikExitMode = false
					ledblinkyEnabled = false
					ledblinkySystemName =
					ledblinkyFullPath =
					ledblinkyProfilePath = E:\Rocketlauncher\Profiles\LEDBlinky
					ledblinkyRLProfile = E:\Rocketlauncher\Profiles\LEDBlinky\RocketLauncher
					emuIdleShutdown = 0
					hideCursor = true
					hideEmu = false
					hideFE = false
					fadeIn = false
					fadeInDuration = 500
					fadeInDelay = 0
					fadeInExitDelay = 0
					fadeOutExitDelay = 0
					fadeOut = false
					fadeOutExtraScreen = false
					fadeOutDuration = 500
					fadeOutTransitionAnimation = LegacyFadeOutTransition
					fadeOutDelay = 0
					fadeLyrInterpolation = 7
					fadeMuteEmulator = false
					fadeUseBackgrounds = false
					fadeClickThrough = false
					fadeWidthBaseRes = 1920
					fadeHeightBaseRes = 1080
					fadeLyr1Color = FF000000
					fadeLyr2X = 0
					fadeLyr2Y = 0
					fadeLyr2W =
					fadeLyr2H =
					fadeLyr2Adjust = 1
					fadeLyr2PicPad = 0
					fadeLyr3Pos = Center
					fadeLyr3X = 450
					fadeLyr3Y = 5
					fadeLyr3W =
					fadeLyr3H =
					fadeLyr3Adjust = 1
					fadeLyr3PicPad = 0
					fadeLyr3Speed = 750
					fadeLyr3Type = imageandbar
					fadeLyr3Repeat = 1
					fadeLyr3StaticX = 0
					fadeLyr3StaticY = 870|1575
					fadeLyr3StaticW =
					fadeLyr3StaticH =
					fadeLyr3StaticAdjust = 1
					fadeLyr3StaticPicPad = 0
					fadeLyr4Adjust = 1
					fadeLyr4X = 1792|952
					fadeLyr4Y = 891|1596
					fadeLyr4W = 128
					fadeLyr4H =
					fadeLyr4Pos = No Alignment
					fadeLyr4FPS = 50
					fadeLyr4PicPad = 0
					fadeTranspGifColor = FFFFFF
					fadeBarWindow = Image
					fadeBarWindowX =
					fadeBarWindowY =
					fadeBarWindowW = 900
					fadeBarWindowH =
					fadeBarWindowR = 30
					fadeBarWindowM = 30
					fadeBarWindowHatchStyle = 8
					fadeBar = true
					fadeBarNon7zProgressTime = 0
					fadeBarBack = true
					fadeBarBackColor = FF555555
					fadeBarH = 30
					fadeBarR = 10
					fadeBarColor = DD00BFFF
					fadeBarHatchStyle = 8
					fadeBarPercentageText = true
					fadeBarInfoText = true
					fadeBarXOffset = 0
					fadeBarYOffset = 150
					fadeRomInfoSystemName = image
					fadeRomInfoManufacturer = text with label
					fadeRomInfoGenre = disabled
					fadeRomInfoRating = image
					fadeRomInfoTextMargin = 7
					fadeStatsInfoTextMargin = 7
					fadeText1X = 0
					fadeText1Y = 0
					fadeText1 = Loading Game
					fadeText2X = 0
					fadeText2Y = 0
					fadeText3 = Loading Game
					fadeText4 = Loading Complete
					fadeFont = Bebas Neue
					fadeExtractionTime = disabled
					fadeExtractionTimeTextX = 0
					fadeExtractionTimeTextY = 0
					fadeInterruptKey =
					detectFadeErrorEnabled = false
					fadeImgPath = E:\Rocketlauncher\Media\Fade
					RLDataPath = E:\Rocketlauncher\Data
					RLMediaPath = E:\Rocketlauncher\Media
					RLErrSoundPath = E:\Rocketlauncher\Media\Sounds\Error
					modulesPath = E:\Rocketlauncher\Modules
					moduleFullName = E:\Rocketlauncher\Modules\Nostalgia\Nostalgia.ahk
					moduleName = Nostalgia
					modulePath = E:\Rocketlauncher\Modules\Nostalgia
					moduleExtension = ahk
					moduleExtensionsPath = E:\Rocketlauncher\Module Extensions
					libPath = E:\Rocketlauncher\Lib
					7zEnabled = true
					7zPath = E:\Rocketlauncher\Module Extensions\7z.exe
					7zDllPath = E:\Rocketlauncher\Module Extensions\7z.dll
					7zExtractPath = C:\Users\Lenovo\AppData\Local\Temp\HS
					7zExtractPathOrig =
					7zAttachSystemName = false
					7zDelTemp = true
					7zSounds = true
					mgEnabled = false
					mgKey = ~NumpadSub
					mgBackgroundColor = FF000000
					mgSidePadding = 0.2
					mgWidthBaseRes = 1920
					mgHeightBaseRes = 1080
					mgYOffset = 500|800
					mgFont = Arial
					mgText2Offset = 100
					mgUseSound = true
					mgSoundfreq = 300
					mgExitEffect = none
					mgSelectedEffect = rotate
					mgUseGameArt = false
					mgCandidate =
					mgOnLaunch = false
					pauseEnabled = false
					pauseKey = m
					pauseBackToMenuBarKey = n
					pauseZoomInKey = C
					pauseZoomOutKey = V
					pauseHiToTextPath = E:\Rocketlauncher\Module Extensions\HiToText.exe
					pauseSaveStateKeyCodes = {F5 down}{F5 up}
					pauseLoadStateKeyCodes = {F7 down}{F7 up}
					keymapperEnabled = true
					keymapperAHKMethod = External
					keymapper = xpadder
					xpadderFullPath = E:\Hyperspin\Utilities\Xpadder\Xpadder.exe
					joyToKeyFullPath = E:\Utilities\JoyToKey\JoyToKey.exe
					keymapperProfilePath = E:\Rocketlauncher\Profiles\xpadder
					keymapperFrontEndProfileName = RocketLauncherUI
					keymapperFrontEndProfile = xpadder
					keymapperRocketLauncherProfileEnabled = true
					joyIDsEnabled = true
					joyIDsPreferredControllersGlobal = Controller (Xbox 360 Wireless Receiver for Windows)
					joyIDsPreferredControllersSystem = use_global
					joyIDsPreferredControllersOnExit =
					CustomJoyNamesEnabled = false
					CustomJoyNames =
					rotateMethod = false
					FEProfile = E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI
					defaultProfile = E:\Rocketlauncher\Profiles\xpadder\_Default
					systemProfile = E:\Rocketlauncher\Profiles\xpadder\Mattel Intellivision
					xPadderSystemProfile = E:\Rocketlauncher\Profiles\xpadder\Mattel Intellivision\_Default
					emuProfile = E:\Rocketlauncher\Profiles\xpadder\Mattel Intellivision\Nostalgia
					romProfile = E:\Rocketlauncher\Profiles\xpadder\Mattel Intellivision\Star Wars - The Empire Strikes Back (World)
					RocketLauncherProfile = E:\Rocketlauncher\Profiles\xpadder\RocketLauncher
					blankProfile = E:\Rocketlauncher\Profiles\xpadder\_Default\blank
					ahkFEProfile = E:\Rocketlauncher\Profiles\AHK\RocketLauncherUI
					ahkDefaultProfile = E:\Rocketlauncher\Profiles\AHK\_Default
					ahkSystemProfile = E:\Rocketlauncher\Profiles\AHK\Mattel Intellivision
					ahkEmuProfile = E:\Rocketlauncher\Profiles\AHK\Mattel Intellivision\Nostalgia
					ahkRomProfile = E:\Rocketlauncher\Profiles\AHK\Mattel Intellivision\Star Wars - The Empire Strikes Back (World)
					ahkRocketLauncherProfile = E:\Rocketlauncher\Profiles\AHK\RocketLauncher
					bezelEnabled = false
					bezelICEnabled = false
					statisticsEnabled = true
					pressDuration = -1
					emuVolume = 1
					dxwndIni = E:\Rocketlauncher\Module Extensions\dxwnd\dxwnd.ini
					dxwndFullPath = E:\Rocketlauncher\Module Extensions\dxwnd\dxwnd.exe
					mon1O =
					pacDrivedllFile = E:\Rocketlauncher\Module Extensions\PacDrive32.dll
					userFadeAnimIniFile = E:\Rocketlauncher\Lib\User Fade Animations.ini
23:07:14:698 | RL |     INFO  | +16    | BuildScript - Loaded XHotkey Init.ahk scripts
23:07:14:698 | RL |     INFO  | +0     | BuildScript - Loaded Keymapper Init.ahk scripts
23:07:14:708 | RL |     INFO  | +15    | BuildScript - Loaded Statistics Init.ahk scripts
23:07:14:708 | RL |  WARNING  | +0     | BuildScript - "E:\Rocketlauncher\Lib\User Functions Init.ahk" not found
23:07:14:718 | RL |   DEBUG1  | +0     | BuildScript - Module starts on line: 2
23:07:14:718 | RL |     INFO  | +0     | BuildScript - Validating module
23:07:14:728 | RL |     INFO  | +16    | BuildScript - Validation complete
23:07:14:738 | RL |     INFO  | +15    | BuildScript - Module:
					MEmu = Nostalgia
					MEmuV = v5.0
					MURL = http://www.intellivision.us/intvgames/nostalgia/nostalgia.php
					MAuthor = djvj
					MVersion = 2.0.1
					MCRC = E2C55815
					iCRC = 1E716C97
					MID = 635038268909868866
					MSystem = "Mattel Intellivision"
					; Notes:
					; Place the exec.bin and grom.bin roms in the emu dir uncompressed. If you have the ECS.bin and IntelliVoice.bin roms, place them in there too.
					; If you get a box popping up saying that the content in your roms dir has changed, run the emu exe manually and click yes then exit. It won't pop up again. There is no need to set a roms dir either.
					; To enable fullscreen, set the variable below.
					; Nostalgia stores its config in the registry @ HKEY_CURRENT_USER\Software\ShinyTechnologies\Nostalgia
					StartModule()
					BezelGui()
					FadeInStart()
					BezelStart()
					; Setting Fullscreen setting in registry if it doesn't match what user wants above
					currentFullScreen := ReadReg("Full Screen")
					If ( Fullscreen != "true" And currentFullScreen = 1 ) {
						WriteReg("Full Screen", 0)
						WriteReg("Hide on Run", 0)
					} Else If ( Fullscreen = "true" And currentFullScreen = 0 ) {
						WriteReg("Full Screen", 1)
						WriteReg("Hide on Run", 1)
					Run(executable . " """ . romPath . "\" . romName . romExtension . """", emuPath)
					WinWait("ahk_class NostalgiaGameClass")
					WinWaitActive("ahk_class NostalgiaGameClass")
					BezelDraw()
					FadeInExit()
					7zCleanUp()
					BezelExit()
					FadeOutExit()
					ExitModule()
					ReadReg(var1) {
						RegRead, regValue, HKEY_CURRENT_USER, Software\ShinyTechnologies\Nostalgia, %var1%
						Return %regValue%
					WriteReg(var1, var2) {
						RegWrite, REG_DWORD, HKEY_CURRENT_USER, Software\ShinyTechnologies\Nostalgia, %var1%, %var2%
					HaltEmu:
						Send, !{Enter}
						Sleep, 200
					Return
					RestoreEmu:
						Send, !{Enter}
						Sleep, 800
						Send, {F9 Down}{F9 Up}
					Return
					CloseProcess:
						FadeOutStart()
						WinKill, ahk_class NostalgiaGameClass,,2
					Return
23:07:14:758 | RL |     INFO  | +16    | BuildScript - Loaded Multi-Player scripts
23:07:14:758 | RL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
23:07:14:768 | RL |  WARNING  | +16    | BuildScript - "E:\Rocketlauncher\Lib\User Functions.ahk" not found
23:07:14:768 | RL |     INFO  | +0     | BuildScript - Finished injecting functions into module
23:07:14:768 | RL |     INFO  | +0     | Main - Module is built
23:07:14:768 | RL |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\AutoHotkey.dll exists
23:07:14:778 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			785408 bytes
					Modified:			4/19/2013 - 6:16:32 PM
23:07:14:778 | RL |     INFO  | +0     | Main - Running module
23:07:14:778 | RL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
23:07:14:878 | MD |     INFO  | +N/A   | Module initialized
23:07:14:878 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
23:07:14:878 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups
23:07:14:888 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
23:07:14:888 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
23:07:14:888 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
23:07:14:888 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
23:07:14:888 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
23:07:14:908 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - KeyGroup ~1joy6 not in TableKeyGroups ~Esc,
23:07:14:908 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
23:07:14:908 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
23:07:14:908 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~1joy6" to call a group label
23:07:14:918 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
23:07:14:918 | MD |   DEBUG2  | +0     | Keymapper - Checking for the JoyIDs_Preferred_Controllers key  in E:\Rocketlauncher\Settings\Mattel Intellivision\Games JoyIDs.ini under section [Star Wars - The Empire Strikes Back (World)]
23:07:14:948 | MD |     INFO  | +31    | LoadPreferredControllers - Started
23:07:14:948 | MD |   DEBUG2  | +0     | LoadPreferredControllers - JoyIDsPreferredControllers = Controller (Xbox 360 Wireless Receiver for Windows)
23:07:14:978 | MD |   DEBUG2  | +31    | LoadPreferredControllers - Creating a list of currently connected joysticks
23:07:14:978 | MD |     INFO  | +0     | GetJoystickArray - Started
23:07:14:008 | MD |   DEBUG2  | +32    | GetJoystickArray - Joysticks Detected: 1000000000000000
23:07:15:038 | MD |     INFO  | +31    | GetJoystickGUID - Started
23:07:15:038 | MD |     INFO  | +0     | GetJoystickGUID - Ended and found GUID: 5041DB96E6EDE4118001444553540000
23:07:15:038 | MD |   DEBUG2  | +0     | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 5041DB96E6EDE4118001444553540000
23:07:15:068 | MD |     INFO  | +31    | GetJoystickArray - Ended
23:07:15:078 | MD |   DEBUG2  | +0     | LoadPreferredControllers - Preferred Order Sorting List -> 1.01|045e|02a1|5041DB96E6EDE4118001444553540000
23:07:15:078 | MD |     INFO  | +0     | LoadPreferredControllers - Sorting Currently Connected joysticks List to match the order of the Preferred Controller List
23:07:15:078 | MD |     INFO  | +0     | LoadPreferredControllers - Assigning the New Joystick IDs according to the preferred list for the active controllers
23:07:15:098 | MD |     INFO  | +31    | ChangeJoystickID - Started
23:07:15:098 | MD |   DEBUG2  | +0     | ChangeJoystickID - Swapping Joystick ID: 00000000 to the New Joystick ID: 00000000, for the Joystick VID_045e&PID_02a1&GUID_5041DB96E6EDE4118001444553540000
23:07:15:108 | MD |     INFO  | +0     | ChangeJoystickID - Ended
23:07:15:108 | MD |     INFO  | +0     | LoadPreferredControllers - Ended
23:07:15:128 | MD |     INFO  | +31    | CheckFile - Checking if E:\Hyperspin\Utilities\Xpadder\Xpadder.exe exists
23:07:15:128 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			1178624 bytes
					Created:			6/16/2015 - 11:46:34 AM
					Modified:			2/2/2014 - 3:10:38 PM
23:07:15:128 | MD |     INFO  | +0     | Keymapper - Loading xpadder
23:07:15:138 | MD |     INFO  | +0     | RunKeymapper - Started, using method "load"
23:07:15:138 | MD |     INFO  | +0     | GetJoystickArray - Started
23:07:15:138 | MD |   DEBUG2  | +0     | GetJoystickArray - Joysticks Detected: 1000000000000000
23:07:15:158 | MD |     INFO  | +32    | GetJoystickGUID - Started
23:07:15:168 | MD |     INFO  | +0     | GetJoystickGUID - Ended and found GUID: 5041DB96E6EDE4118001444553540000
23:07:15:168 | MD |   DEBUG2  | +0     | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 5041DB96E6EDE4118001444553540000
23:07:15:168 | MD |     INFO  | +0     | GetJoystickArray - Ended
23:07:15:168 | MD |   DEBUG2  | +0     | RunKeymapper - Found your keymapper application here: "E:\Hyperspin\Utilities\Xpadder\Xpadder.exe"
23:07:15:188 | MD |   DEBUG2  | +31    | RunKeymapper - Looping through controllers to find xpadder profiles for each one
23:07:15:188 | MD |   DEBUG2  | +0     | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "Controller (Xbox 360 Wireless Receiver for Windows)"
23:07:15:188 | MD |   DEBUG2  | +0     | GetProfile - Searching for these profiles (| delimited): E:\Rocketlauncher\Profiles\xpadder\Mattel Intellivision\Star Wars - The Empire Strikes Back (World)|E:\Rocketlauncher\Profiles\xpadder\Mattel Intellivision\Nostalgia|E:\Rocketlauncher\Profiles\xpadder\Mattel Intellivision\_Default|E:\Rocketlauncher\Profiles\xpadder\_Default|E:\Rocketlauncher\Profiles\xpadder\_Default\blank
23:07:15:188 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Mattel Intellivision\Star Wars - The Empire Strikes Back (World)\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
23:07:15:198 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Mattel Intellivision\Star Wars - The Empire Strikes Back (World)\p1.xpadderprofile
23:07:15:198 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Mattel Intellivision\Nostalgia\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
23:07:15:228 | MD |   DEBUG2  | +31    | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Mattel Intellivision\Nostalgia\p1.xpadderprofile
23:07:15:228 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Mattel Intellivision\_Default\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
23:07:15:258 | MD |   DEBUG2  | +31    | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Mattel Intellivision\_Default\p1.xpadderprofile
23:07:15:288 | MD |   DEBUG2  | +31    | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
23:07:15:288 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile
23:07:15:288 | MD |     INFO  | +0     | GetProfile - Loading Player 1 Profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile
23:07:15:288 | MD |     INFO  | +0     | RunXpadder - Started
23:07:15:318 | MD |     INFO  | +32    | Process - Exist JoyToKey.exe
23:07:15:318 | MD |   DEBUG2  | +0     | RunXpadder - Closing xpadder to refresh controllers seen by xpadder
23:07:15:318 | MD |     INFO  | +0     | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe /C
23:07:15:398 | MD |   DEBUG1  | +78    | Run - "Xpadder.exe /C" Process ID: 3384
23:07:15:398 | MD |   DEBUG2  | +0     | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in E:\Hyperspin\Utilities\Xpadder\xpadder.ini
23:07:15:398 | MD |     INFO  | +0     | Process - WaitClose Xpadder.exe 2
23:07:15:628 | MD |   DEBUG2  | +234   | RunXpadder - Reading the order in E:\Hyperspin\Utilities\Xpadder\xpadder.ini and arranging profiles found to match that order
23:07:15:628 | MD |   DEBUG2  | +0     | RunXpadder - No more controllers to be found
23:07:15:638 | MD |     INFO  | +0     | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile" /M
23:07:15:688 | MD |   DEBUG1  | +62    | Run - "Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile" /M" Process ID: 3296
23:07:15:688 | MD |     INFO  | +0     | RunXpadder - Ended
23:07:15:688 | MD |     INFO  | +0     | RunKeymapper - Ended
23:07:15:688 | MD |     INFO  | +0     | Keymapper - Loading External AHK Keymapping
23:07:15:688 | MD |     INFO  | +0     | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\AhkLauncher.exe exists
23:07:15:698 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	AhkLauncher
					FileVersion             	1.0.0.0
					InternalName            	AhkLauncher.exe
					LegalCopyright          	Copyright ©  2013
					OriginalFilename        	AhkLauncher.exe
					ProductName             	AhkLauncher
					ProductVersion          	1.0.0.0
					File Size:			11264 bytes
					Created:			5/24/2015 - 8:28:06 AM
					Modified:			9/4/2013 - 6:30:52 PM
23:07:15:698 | MD |     INFO  | +0     | RunAHKKeymapper - Started
23:07:15:698 | MD |   DEBUG1  | +0     | RunAHKKeymapper - Loading Star Wars - The Empire Strikes Back (World), Nostalgia, Mattel Intellivision, or _Default AHK Keymapper profile
23:07:15:698 | MD |     INFO  | +0     | GetAHKProfile - Started
23:07:15:698 | MD |   DEBUG2  | +0     | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\Mattel Intellivision\Star Wars - The Empire Strikes Back (World).ahk
23:07:15:728 | MD |   DEBUG2  | +31    | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\Mattel Intellivision\Nostalgia.ahk
23:07:15:728 | MD |   DEBUG2  | +0     | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\Mattel Intellivision.ahk
23:07:15:728 | MD |   DEBUG2  | +0     | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\_Default.ahk
23:07:15:728 | MD |     INFO  | +0     | GetAHKProfile - Ended and no profile found
23:07:15:728 | MD |   DEBUG1  | +0     | RunAHKKeymapper - If AhkLauncher.exe is running, need to close it first before a new profile can be loaded
23:07:15:758 | MD |     INFO  | +31    | Process - Exist AhkLauncher.exe
23:07:15:758 | MD |     INFO  | +0     | RunAHKKeymapper - Ended
23:07:15:758 | MD |     INFO  | +0     | StartModule - Started
23:07:15:758 | MD |     INFO  | +0     | StartModule - MEmu: Nostalgia
					MEmuV: v5.0
					MURL: http://www.intellivision.us/intvgames/nostalgia/nostalgia.php
					MAuthor: djvj
					MVersion: 2.0.1
					MCRC: E2C55815
					iCRC: 1E716C97
					MID:
					MSystem: "Mattel Intellivision"
23:07:15:758 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "Mattel Intellivision"
23:07:15:788 | MD |     INFO  | +32    | PluginInit - Started
23:07:15:788 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating
23:07:15:788 | MD |     INFO  | +0     | CheckFile - Checking if E:\Hyperspin\Databases\Mattel Intellivision\Mattel Intellivision.xml exists
23:07:15:788 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			47227 bytes
					Created:			6/1/2015 - 12:34:17 PM
					Modified:			6/1/2015 - 12:33:34 PM
23:07:15:818 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching for a "Game Name" in the database
23:07:15:818 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Game Name" in the database!
23:07:15:818 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Name
23:07:15:818 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Name" with a value: "Star Wars - The Empire Strikes Back (World)"
23:07:15:818 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Cloneof
23:07:15:848 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Could not find: Cloneof
23:07:15:848 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Manufacturer
23:07:15:848 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Manufacturer" with a value: "Parker Bros"
23:07:15:848 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Year
23:07:15:848 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Year" with a value: "1983"
23:07:15:858 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Genre
23:07:15:858 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Genre" with a value: "Shooter"
23:07:15:858 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Rating
23:07:15:858 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Rating" with a value: "HSRS - GA (General Audience)"
23:07:15:858 | MD |   DEBUG2  | +0     | PluginInit - GameInfo:
					GameInfo Label: Genre | GameInfo Value: Shooter
					GameInfo Label: Manufacturer | GameInfo Value: Parker Bros
					GameInfo Label: Name | GameInfo Value: Star Wars - The Empire Strikes Back (World)
					GameInfo Label: Rating | GameInfo Value: HSRS - GA (General Audience)
					GameInfo Label: Year | GameInfo Value: 1983
23:07:15:858 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Ended
23:07:15:878 | MD |   DEBUG1  | +31    | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
23:07:15:878 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Game Logo: E:\Hyperspin\Media\Mattel Intellivision\Images\Wheel\Star Wars - The Empire Strikes Back (World).png
23:07:15:888 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a System Logo: E:\Hyperspin\Media\Main Menu\Images\Wheel\Mattel Intellivision.png
23:07:15:888 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: Game Logo | Asset Path1:  E:\Hyperspin\Media\Mattel Intellivision\Images\Wheel\Star Wars - The Empire Strikes Back (World).png | Asset Extension1:  png | Asset Type1:  game
					Asset Label: System Logo | Asset Path1:  E:\Hyperspin\Media\Main Menu\Images\Wheel\Mattel Intellivision.png | Asset Extension1:  png | Asset Type1:  system
23:07:15:908 | MD |   DEBUG1  | +31    | BuildAssetsTable - Ended
23:07:15:908 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
23:07:15:908 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Artwork1: E:\Hyperspin\Media\Mattel Intellivision\Images\Artwork1\Star Wars - The Empire Strikes Back (World).png
23:07:15:918 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Box Art: E:\Hyperspin\Media\Mattel Intellivision\Images\Artwork2\Star Wars - The Empire Strikes Back (World).png
23:07:15:918 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Cartridge: E:\Hyperspin\Media\Mattel Intellivision\Images\Artwork3\Star Wars - The Empire Strikes Back (World).png
23:07:15:938 | MD |   DEBUG1  | +32    | BuildAssetsTable - Searching for a Flyers: E:\Hyperspin\Media\Mattel Intellivision\Images\Artwork4\Star Wars - The Empire Strikes Back (World).png
23:07:15:938 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Letters: E:\Hyperspin\Media\Mattel Intellivision\Images\Letters
23:07:15:978 | MD |   DEBUG1  | +31    | BuildAssetsTable - Searching for a Other: E:\Hyperspin\Media\Mattel Intellivision\Images\Other
23:07:15:008 | MD |   DEBUG2  | +31    | BuildAssetsTable - Media assets found:
					Asset Label: Letters | Asset Path1:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\!.png | Asset Extension1:  png | Asset Type1:  system
					Asset Label: Letters | Asset Path2:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\'.png | Asset Extension2:  png | Asset Type2:  system
					Asset Label: Letters | Asset Path3:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\(.png | Asset Extension3:  png | Asset Type3:  system
					Asset Label: Letters | Asset Path4:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\0.png | Asset Extension4:  png | Asset Type4:  system
					Asset Label: Letters | Asset Path5:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\1.png | Asset Extension5:  png | Asset Type5:  system
					Asset Label: Letters | Asset Path6:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\2.png | Asset Extension6:  png | Asset Type6:  system
					Asset Label: Letters | Asset Path7:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\3.png | Asset Extension7:  png | Asset Type7:  system
					Asset Label: Letters | Asset Path8:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\4.png | Asset Extension8:  png | Asset Type8:  system
					Asset Label: Letters | Asset Path9:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\5.png | Asset Extension9:  png | Asset Type9:  system
					Asset Label: Letters | Asset Path10:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\6.png | Asset Extension10:  png | Asset Type10:  system
					Asset Label: Letters | Asset Path11:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\7.png | Asset Extension11:  png | Asset Type11:  system
					Asset Label: Letters | Asset Path12:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\8.png | Asset Extension12:  png | Asset Type12:  system
					Asset Label: Letters | Asset Path13:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\9.png | Asset Extension13:  png | Asset Type13:  system
					Asset Label: Letters | Asset Path14:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\a.png | Asset Extension14:  png | Asset Type14:  system
					Asset Label: Letters | Asset Path15:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\b.png | Asset Extension15:  png | Asset Type15:  system
					Asset Label: Letters | Asset Path16:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\c.png | Asset Extension16:  png | Asset Type16:  system
					Asset Label: Letters | Asset Path17:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\d.png | Asset Extension17:  png | Asset Type17:  system
					Asset Label: Letters | Asset Path18:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\e.png | Asset Extension18:  png | Asset Type18:  system
					Asset Label: Letters | Asset Path19:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\f.png | Asset Extension19:  png | Asset Type19:  system
					Asset Label: Letters | Asset Path20:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\g.png | Asset Extension20:  png | Asset Type20:  system
					Asset Label: Letters | Asset Path21:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\h.png | Asset Extension21:  png | Asset Type21:  system
					Asset Label: Letters | Asset Path22:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\i.png | Asset Extension22:  png | Asset Type22:  system
					Asset Label: Letters | Asset Path23:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\j.png | Asset Extension23:  png | Asset Type23:  system
					Asset Label: Letters | Asset Path24:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\k.png | Asset Extension24:  png | Asset Type24:  system
					Asset Label: Letters | Asset Path25:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\l.png | Asset Extension25:  png | Asset Type25:  system
					Asset Label: Letters | Asset Path26:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\m.png | Asset Extension26:  png | Asset Type26:  system
					Asset Label: Letters | Asset Path27:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\n.png | Asset Extension27:  png | Asset Type27:  system
					Asset Label: Letters | Asset Path28:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\o.png | Asset Extension28:  png | Asset Type28:  system
					Asset Label: Letters | Asset Path29:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\p.png | Asset Extension29:  png | Asset Type29:  system
					Asset Label: Letters | Asset Path30:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\q.png | Asset Extension30:  png | Asset Type30:  system
					Asset Label: Letters | Asset Path31:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\r.png | Asset Extension31:  png | Asset Type31:  system
					Asset Label: Letters | Asset Path32:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\s.png | Asset Extension32:  png | Asset Type32:  system
					Asset Label: Letters | Asset Path33:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\t.png | Asset Extension33:  png | Asset Type33:  system
					Asset Label: Letters | Asset Path34:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\u.png | Asset Extension34:  png | Asset Type34:  system
					Asset Label: Letters | Asset Path35:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\v.png | Asset Extension35:  png | Asset Type35:  system
					Asset Label: Letters | Asset Path36:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\w.png | Asset Extension36:  png | Asset Type36:  system
					Asset Label: Letters | Asset Path37:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\x.png | Asset Extension37:  png | Asset Type37:  system
					Asset Label: Letters | Asset Path38:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\y.png | Asset Extension38:  png | Asset Type38:  system
					Asset Label: Letters | Asset Path39:  E:\Hyperspin\Media\Mattel Intellivision\Images\Letters\z.png | Asset Extension39:  png | Asset Type39:  system
					Asset Label: Other | Asset Path1:  E:\Hyperspin\Media\Mattel Intellivision\Images\Other\pointer.png | Asset Extension1:  png | Asset Type1:  system
23:07:16:038 | MD |   DEBUG1  | +31    | BuildAssetsTable - Ended
23:07:16:068 | MD |   DEBUG1  | +31    | BuildAssetsTable - Started - Building Table for: Game Video|System Video
23:07:16:068 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Game Video: E:\Hyperspin\Media\Mattel Intellivision\Video\Star Wars - The Empire Strikes Back (World).*
23:07:16:068 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a System Video: E:\Hyperspin\Media\Main Menu\Video\Mattel Intellivision.*
23:07:16:098 | MD |   DEBUG2  | +32    | BuildAssetsTable - Media assets found:
					Asset Label: Game Video | Asset Path1:  E:\Hyperspin\Media\Mattel Intellivision\Video\Star Wars - The Empire Strikes Back (World).mp4 | Asset Extension1:  mp4 | Asset Type1:  game
					Asset Label: System Video | Asset Path1:  E:\Hyperspin\Media\Main Menu\Video\Mattel Intellivision.flv | Asset Extension1:  flv | Asset Type1:  system
23:07:16:108 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
23:07:16:108 | MD |     INFO  | +0     | PluginInit - Ended
23:07:16:108 | MD |   DEBUG1  | +0     | StartModule - Setting romName to the dbName sent to RocketLauncher: Star Wars - The Empire Strikes Back (World)
23:07:16:128 | MD |     INFO  | +31    | Hiding mouse cursor
23:07:16:138 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
23:07:16:138 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc,~1joy6,
23:07:16:138 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
23:07:16:158 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - Post loop 2 check
23:07:16:158 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
23:07:16:158 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
23:07:16:168 | MD |     INFO  | +0     | StartModule - Ended
23:07:16:168 | MD |     INFO  | +0     | Module Setting - [Settings] - Fullscreen: true
23:07:16:188 | MD |     INFO  | +31    | 7z - Started, received E:\Hyperspin\Emulators\Mattel Intellivision\roms\Star Wars - The Empire Strikes Back (World).int. If rom is an archive, it will extract to C:\Users\Lenovo\AppData\Local\Temp\HS
23:07:16:188 | MD |     INFO  | +0     | 7z - This rom type does not need 7z: ".int"
23:07:16:188 | MD |   DEBUG1  | +0     | 7z - Starting non-7z FadeIn animation.
23:07:16:198 | MD |   DEBUG1  | +0     | 7z - romPath changed from "E:\Hyperspin\Emulators\Mattel Intellivision\roms" to "E:\Hyperspin\Emulators\Mattel Intellivision\roms"
23:07:16:218 | MD |   DEBUG1  | +31    | 7z - romName changed from "Star Wars - The Empire Strikes Back (World)" to "Star Wars - The Empire Strikes Back (World)"
23:07:16:218 | MD |   DEBUG1  | +0     | 7z - romExtension changed from ".int" to ".int"
23:07:16:218 | MD |     INFO  | +0     | 7z - Ended
23:07:16:218 | MD |     INFO  | +0     | Run - Running: E:\Hyperspin\Emulators\Mattel Intellivision\nostalgia.exe "E:\Hyperspin\Emulators\Mattel Intellivision\roms\Star Wars - The Empire Strikes Back (World).int"
23:07:16:258 | MD |   DEBUG1  | +32    | Run - "nostalgia.exe "E:\Hyperspin\Emulators\Mattel Intellivision\roms\Star Wars - The Empire Strikes Back (World).int"" Process ID: 4864
23:07:16:258 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: RocketLauncherUI v1.0.0.9 [ FE = Hyperspin | Plugin = HyperSpin ] | Class: HwndWrapper[RocketLauncherUI.exe;;f4bbb0aa-2370-4f75-ad43-5420de830cdb] | State: 0 | X: 32 | Y: 40 | Width: 1448 | Height: 864 | Window HWND: 0x730428 | Process ID: 5668 | Process Path: E:\Rocketlauncher\RocketLauncherUI\RocketLauncherUI.exe
23:07:16:258 | MD |     INFO  | +0     | WinWait - Waiting for "ahk_class NostalgiaGameClass"
23:07:16:670 | MD |   DEBUG1  | +421   | GetActiveWindowStatus - Title: Star Wars - The Empire Strikes Back | Class: NostalgiaGameClass | State: 0 | X: 0 | Y: 0 | Width: 1024 | Height: 768 | Window HWND: 0x300550 | Process ID: 4864 | Process Path: E:\Hyperspin\Emulators\Mattel Intellivision\Nostalgia\nostalgia.exe
23:07:16:670 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: Star Wars - The Empire Strikes Back | Class: NostalgiaGameClass | State: 0 | X: 0 | Y: 0 | Width: 1024 | Height: 768 | Window HWND: 0x300550 | Process ID: 4864 | Process Path: E:\Hyperspin\Emulators\Mattel Intellivision\Nostalgia\nostalgia.exe
23:07:16:670 | MD |     INFO  | +0     | WinWaitActive - Waiting for "ahk_class NostalgiaGameClass"
23:07:16:830 | MD |   DEBUG1  | +156   | GetActiveWindowStatus - Title: HyperSpin | Class: ThunderRT6FormDC | State: 0 | X: 0 | Y: 0 | Width: 1024 | Height: 768 | Window HWND: 0x5c057a | Process ID: 4600 | Process Path: E:\Hyperspin\HyperSpin.exe
23:07:16:830 | RL |  WARNING  | +2059  | HyperSpin.exe was displaced to x0 y0 w1024 h768 by Nostalgia. It is probably running in true fullscreen mode.
23:07:17:080 | MD |     INFO  | +249   | Process - WaitClose nostalgia.exe
23:07:17:302 | MD |     INFO  | +219   | 7zCleanUp - Started
23:07:17:302 | MD |   DEBUG1  | +0     | 7zCleanUp - Deleted
23:07:17:302 | MD |     INFO  | +0     | 7zCleanUp - Ended
23:07:17:302 | MD |     INFO  | +0     | ExitModule - Started
23:07:17:302 | MD |     INFO  | +0     | Starting Updating Statistics:
23:07:17:332 | MD |   DEBUG2  | +31    | Total Elapsed Time in Pause in seconds: 0
23:07:17:332 | MD |   DEBUG2  | +0     | gameSectionStartTime:200493982
23:07:17:362 | MD |   DEBUG2  | +31    | ElapsedTime:1
23:07:17:362 | MD |   DEBUG2  | +0     | Statistics cleared game name: Star Wars - The Empire Strikes Back
23:07:17:402 | MD |   DEBUG2  | +31    | Loaded game statistics from ini files:
					Number_of_Times_Played: 0
					Last_Time_Played: 0
					Average_Time_Played: 0
					Total_Time_Played: 0
					System_Total_Played_Time: 803
					Total_Global_Played_Time: 9830
23:07:17:402 | MD |   DEBUG2  | +0     | Updated Statistics: Number_of_Times_Played: 1
					Last_Time_Played: Monday November 30, 2015 11:07:16 PM
					Average_Time_Played: 1
					Total_Time_Played: 1
					System_Total_Played_Time: 804
					Total_Global_Played_Time: 9831
23:07:17:462 | MD |     INFO  | +63    | Game section statistics updated.
23:07:17:462 | MD |     INFO  | +0     | RunKeymapper - Started, using method "unload"
23:07:17:462 | MD |     INFO  | +0     | GetJoystickArray - Started
23:07:17:482 | MD |   DEBUG2  | +31    | GetJoystickArray - Joysticks Detected: 1000000000000000
23:07:17:482 | MD |     INFO  | +0     | GetJoystickGUID - Started
23:07:17:482 | MD |     INFO  | +0     | GetJoystickGUID - Ended and found GUID: 5041DB96E6EDE4118001444553540000
23:07:17:482 | MD |   DEBUG2  | +0     | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 5041DB96E6EDE4118001444553540000
23:07:17:492 | MD |     INFO  | +0     | GetJoystickArray - Ended
23:07:17:492 | MD |   DEBUG2  | +0     | RunKeymapper - Looping through controllers to find xpadder profiles for each one
23:07:17:492 | MD |   DEBUG2  | +0     | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "Controller (Xbox 360 Wireless Receiver for Windows)"
23:07:17:492 | MD |   DEBUG2  | +0     | GetProfile - Searching for these profiles (| delimited): E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI|E:\Rocketlauncher\Profiles\xpadder\_Default\blank
23:07:17:492 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile
23:07:17:492 | MD |   DEBUG2  | +0     | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile
23:07:17:522 | MD |     INFO  | +31    | GetProfile - Loading Player 1 Profile -> E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile
23:07:17:522 | MD |     INFO  | +0     | RunXpadder - Started
23:07:17:522 | MD |     INFO  | +0     | Process - Exist JoyToKey.exe
23:07:17:522 | MD |   DEBUG2  | +0     | RunXpadder - Closing xpadder to refresh controllers seen by xpadder
23:07:17:552 | MD |     INFO  | +31    | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe /C
23:07:17:642 | MD |   DEBUG1  | +94    | Run - "Xpadder.exe /C" Process ID: 2732
23:07:17:642 | MD |   DEBUG2  | +0     | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in E:\Hyperspin\Utilities\Xpadder\xpadder.ini
23:07:17:642 | MD |     INFO  | +0     | Process - WaitClose Xpadder.exe 2
23:07:17:862 | MD |   DEBUG2  | +218   | RunXpadder - Reading the order in E:\Hyperspin\Utilities\Xpadder\xpadder.ini and arranging profiles found to match that order
23:07:17:862 | MD |   DEBUG2  | +0     | RunXpadder - No more controllers to be found
23:07:17:862 | MD |     INFO  | +0     | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile" /M
23:07:17:922 | MD |   DEBUG1  | +63    | Run - "Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile" /M" Process ID: 3916
23:07:17:922 | MD |     INFO  | +0     | RunXpadder - Ended
23:07:17:922 | MD |     INFO  | +0     | RunKeymapper - Ended
23:07:17:922 | MD |     INFO  | +0     | RunAHKKeymapper - Started
23:07:17:922 | MD |   DEBUG1  | +0     | RunAHKKeymapper - Unloading AhkLauncher
23:07:17:932 | MD |   DEBUG1  | +0     | RunAHKKeymapper - If AhkLauncher.exe is running, need to close it first before a new profile can be loaded
23:07:17:932 | MD |     INFO  | +0     | Process - Exist AhkLauncher.exe
23:07:17:932 | MD |     INFO  | +0     | RunAHKKeymapper - Ended
23:07:17:952 | MD |     INFO  | +31    | Restoring mouse cursor
23:07:17:952 | MD |     INFO  | +0     | ExitModule - Ended
23:07:17:952 | MD |     INFO  | +0     | End of Module Logs
23:07:18:062 | RL |     INFO  | +1232  | Main - Module ended, exiting RocketLauncher normally
23:07:18:062 | RL |     INFO  | +0     | ExitScript - Started
23:07:18:072 | RL |   DEBUG1  | +0     | ExitScript - Restoring HyperSpin.exe to x0 y0 w1440 h900
23:07:18:222 | RL |   DEBUG1  | +156   | ExitScript - Restoring and Clicking HyperSpin.exe to attempt to put it into focus
23:07:18:222 | RL |   DEBUG1  | +0     | ExitScript - Checking what application is currently in focus.
23:07:18:232 | RL |     INFO  | +16    | SystemCursor - Restoring mouse cursor
23:07:18:242 | RL |     INFO  | +0     | ExitScript - Ended
[/code]
