griffin518 Posted December 4, 2015 Posted December 4, 2015 Hi All, I've been off tinkering with different themes, bezels, etc for the last couple of weeks and haven't actually been playing many games. I went to play one this afternoon and got a RL error, which I thought was weird since I haven't really changed anything in the last 3 - 4 weeks. So I went into RLUI; everything launches fine. For some reason it seems like HS and RL have become disconnected... and I haven't changed anything recently, even longer for HS itself. Has anyone else had this happend? All systems/games in RL refuse to launch via HS. MAME, RetroArch, DEmul, and NullDC. PC launcher games (Fix it Felix, tested) work fine. Here's the error message I get for MAME as well as my HS log (I don't see anything suspicious in it). Any help would be appreciated. 05:25:15 PM | HyperSpin Started 05:25:15 PM | Going FullScreen 05:25:15 PM | Checking for updates 05:25:15 PM | Update Check Complete 05:25:15 PM | Startup program unavailable 05:25:15 PM | Playing intro video 05:25:16 PM | Error intializing joysticks 05:25:16 PM | Menu Mode is multi 05:25:17 PM | Loading Main Menu.xml 05:25:17 PM | Main Menu.xml successfully loaded 05:25:17 PM | Main Menu wheel loaded successfully 05:25:19 PM | Loading MAME.xml 05:25:19 PM | Main Menu.xml successfully loaded 05:25:20 PM | MAME wheel loaded successfully 05:25:22 PM | Launching Game 05:25:22 PM | Using HyperLaunch 05:25:22 PM | Getting Launcher path 05:25:22 PM | Launcher located at C:\Arcade\RocketLauncher\RocketLauncher.exe 05:25:22 PM | Running Launcher 05:25:22 PM | Launcher Command Line is: C:\Arcade\RocketLauncher\RocketLauncher.exe "MAME" "ghoulsu" 05:25:30 PM | Loading Main Menu.xml 05:25:30 PM | Main Menu.xml successfully loaded 05:25:30 PM | Main Menu wheel loaded successfully 05:25:32 PM | Exit program unavailable 05:25:32 PM | Quiting Hyperspin 05:25:32 PM | Bye! Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
griffin518 Posted December 4, 2015 Author Posted December 4, 2015 Also... after it returns to HS from that error, HS has lost focus. Really annoying. Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
Guest Posted December 4, 2015 Posted December 4, 2015 Easy one - set HyperSpin as the default frontend in RLUI. Check the announcement posts on the RL forums for more info. Sent from my iPhone using Tapatalk
griffin518 Posted December 4, 2015 Author Posted December 4, 2015 It's already set... that was the first thing I verified Now I'm going to go change it and move it back, let's see if that resets things. Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
Guest Posted December 4, 2015 Posted December 4, 2015 It's already set... that was the first thing I verified Now I'm going to go change it and move it back, let's see if that resets things. It can't be fully set or it would be looking in your HyperSpin folder for the databases. The latest updates to RL require you to set HyperSpin as the front end slightly differently. Read the announcement thread at the RL forums - it tells you exactly what to do. Sent from my iPhone using Tapatalk
Guest Posted December 4, 2015 Posted December 4, 2015 The first post at the link below has a screenshot. Make sure you're setup the same. http://www.rlauncher.com/forum/showthread.php?2037-RocketLauncher-v1-0-1-4&p=18317#post18317 Sent from my iPhone using Tapatalk
griffin518 Posted December 5, 2015 Author Posted December 5, 2015 Awesome... just saw it. Interesting that you have to set the full path to HS now. Thanks for your help! I'm barely active in the RL forums, I guess that'll have to change. Thanks again! Download my RocketLauncher bezels: http://hyperspin-fe.com/files/file/14367-griffin518s-bezel-depot/ Best of MAME HyperSpin XML: http://www.hyperspin-fe.com/files/file/11710-griffin518s-best-of-mame-xml-database/ Best of MAME bezel pack: http://www.hyperspin-fe.com/files/file/11711-griffin518s-best-of-mame-bezel-pack/ Custom MAME ini files w/HLSL settings: http://www.hyperspin-fe.com/files/file/11712-griffin518s-best-of-mame-mameuifx-ini-files/
Guest Posted December 5, 2015 Posted December 5, 2015 Awesome... just saw it. Interesting that you have to set the full path to HS now. Thanks for your help! I'm barely active in the RL forums, I guess that'll have to change. Thanks again! Happy days! If you're working this can be marked as solved Aye, always best to post the RL issues over at the RL forums. Sent from my iPhone using Tapatalk
