demonseed Posted December 20, 2015 Posted December 20, 2015 So, I am almost done my setup.. couple bugs but almost there.... Kat5200 is causing me grief and I do not understand why. In rocket launcher I test a game and it loads and exits fine. In HS, it flashes a command box then kicks back to HS..?? Any ideas? thansk so much in advance. 22:22:42:140 | RL | INFO | +N/A | Main - RocketLauncher v1.0.1.4 (www.rlauncher.com) 22:22:42:140 | RL | WARNING | +0 | Main - You have "Logging_Log_Command_Window" enabled. This is only for logging errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done. 22:22:42:370 | RL | INFO | +234 | Main - System Specs: RocketLauncher Dir: E:\Rocketlauncher RocketLauncher is: 32-bit OS: Microsoft Windows 7 Professional SKU: Professional Total Memory: 8016.31 MB Free Memory: 4858.03 MB Used Memory: 3158.281 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 4 GPU 1 Name: Intel(R) HD Graphics GPU 1 RAM: -1924.00 MB GPU 1 Driver Version: 9.17.10.3347 Sound 1 Device: High Definition Audio Device Sound 1 Status: Enabled Sound 2 Device: High Definition Audio Device Sound 2 Status: Enabled OS Language: English_United_States OS Admin Status: Yes Latest .Net Version: v4.0.30319 Monitor #1 (\\.\DISPLAY1): 1440x900 (1440x856 work) [Landscape] (Primary) Current AHK Desktop Width: 1440 Current AHK Desktop Height: 900 AutoHotkey Path: C:\Program Files\AutoHotkey\AutoHotkey.exe AHK Version: 1.1.09.04 Unicode: No 22:22:42:380 | RL | INFO | +15 | CheckFile - Checking if E:\Rocketlauncher\RocketLauncher.exe exists 22:22:42:380 | RL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription RocketLauncher FileVersion 1.0.1.4 LegalCopyright ©2015 RocketLauncher ProductName djvj's one swell guy! ProductVersion 1.1.9.4 CompanyName Your favorite Front End companion! Visit us @ www.rlauncher.com File Size: 2063360 bytes Created: 5/23/2015 - 10:53:13 PM Modified: 11/26/2015 - 12:43:10 AM 22:22:42:380 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Array.ahk exists 22:22:42:390 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 22:22:42:390 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 4924 bytes Created: 11/26/2015 - 12:43:11 AM Modified: 11/26/2015 - 12:43:11 AM 22:22:42:390 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\BinHexRW.ahk exists 22:22:42:400 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:400 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 5077 bytes Created: 5/24/2015 - 8:27:48 AM Modified: 11/26/2015 - 12:42:57 AM 22:22:42:400 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\BlockInput.exe exists 22:22:42:400 | RL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription FileVersion 1.1.09.04 InternalName OriginalFilename ProductName ProductVersion 1.1.09.04 File Size: 657920 bytes Created: 5/24/2015 - 8:26:42 AM Modified: 1/2/2014 - 10:27:34 PM 22:22:42:400 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\CLR_L.ahk exists 22:22:42:410 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 22:22:42:420 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 5474 bytes Created: 9/6/2015 - 8:32:14 PM Modified: 9/6/2015 - 8:32:14 PM 22:22:42:420 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Control_AniGif.ahk exists 22:22:42:420 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 22:22:42:430 | RL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 5716 bytes Created: 5/24/2015 - 8:26:30 AM Modified: 4/29/2013 - 1:56:02 PM 22:22:42:430 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gdip.ahk exists 22:22:42:440 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 22:22:42:440 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 88789 bytes Created: 5/24/2015 - 7:02:39 AM Modified: 1/13/2013 - 5:07:30 PM 22:22:42:440 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gdip_alt.ahk exists 22:22:42:450 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:450 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 5895 bytes Created: 5/24/2015 - 8:25:59 AM Modified: 6/28/2015 - 6:41:33 AM 22:22:42:450 | RL | DEBUG1 | +0 | gdip_alt.ahk Version: 1.0.2 22:22:42:450 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gsdll32.dll exists 22:22:42:460 | RL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 13090816 bytes Created: 5/24/2015 - 8:25:19 AM Modified: 1/6/2015 - 9:20:42 PM 22:22:42:460 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\itextsharp.dll exists 22:22:42:460 | RL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription iTextSharp FileVersion 5.4.2.0 InternalName itextsharp.dll LegalCopyright Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved. OriginalFilename itextsharp.dll ProductName iTextSharp ProductVersion 5.4.2.0 CompanyName 1T3XT BVBA File Size: 3743744 bytes Created: 5/24/2015 - 8:24:07 AM Modified: 6/14/2013 - 2:06:21 PM 22:22:42:460 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Java.ahk exists 22:22:42:470 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:470 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 7841 bytes Created: 5/24/2015 - 8:27:37 AM Modified: 12/23/2014 - 11:02:37 PM 22:22:42:470 | RL | DEBUG1 | +0 | Java.ahk Version: 1.0.0 22:22:42:470 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\JSON.ahk exists 22:22:42:480 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 22:22:42:480 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 9203 bytes Created: 5/24/2015 - 8:26:08 AM Modified: 5/5/2013 - 2:22:25 PM 22:22:42:480 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Origin.ahk exists 22:22:42:490 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:490 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 4904 bytes Created: 5/24/2015 - 8:26:27 AM Modified: 3/22/2015 - 2:51:41 PM 22:22:42:490 | RL | DEBUG1 | +0 | Origin.ahk Version: 1.0.2 22:22:42:490 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\RegRW64.ahk exists 22:22:42:500 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Extension. 22:22:42:500 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 6915 bytes Created: 5/24/2015 - 8:28:09 AM Modified: 5/8/2014 - 3:06:39 AM 22:22:42:500 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\RIni.ahk exists 22:22:42:510 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 22:22:42:510 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 67561 bytes Created: 5/24/2015 - 8:28:04 AM Modified: 6/5/2013 - 6:56:23 PM 22:22:42:520 | RL | INFO | +16 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\SevenZipSharp.dll exists 22:22:42:520 | RL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription SevenZipSharp FileVersion 0.64.5717.6837 InternalName SevenZipSharp.dll LegalCopyright Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3 OriginalFilename SevenZipSharp.dll ProductName SevenZipSharp ProductVersion 0.64.5717.6837 CompanyName Markovtsev Vadim File Size: 167424 bytes Created: 5/24/2015 - 8:27:30 AM Modified: 11/26/2015 - 12:43:04 AM 22:22:42:520 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Steam.ahk exists 22:22:42:530 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:530 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 5347 bytes Created: 5/24/2015 - 8:28:20 AM Modified: 3/22/2015 - 2:52:25 PM 22:22:42:530 | RL | DEBUG1 | +0 | Steam.ahk Version: 1.0.2 22:22:42:540 | RL | INFO | +15 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\VA.ahk exists 22:22:42:540 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 22:22:42:540 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 34688 bytes Created: 5/24/2015 - 8:26:53 AM Modified: 3/1/2013 - 9:05:47 PM 22:22:42:540 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\VA_Extension.ahk exists 22:22:42:550 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:550 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 3833 bytes Created: 5/24/2015 - 8:28:38 AM Modified: 1/13/2015 - 8:16:56 PM 22:22:42:550 | RL | DEBUG1 | +0 | VA_Extension.ahk Version: 1.0.1 22:22:42:560 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\7z.ahk exists 22:22:42:560 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:560 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 29149 bytes Created: 5/29/2015 - 11:47:30 PM Modified: 11/26/2015 - 12:42:55 AM 22:22:42:560 | RL | DEBUG1 | +0 | 7z.ahk Version: 1.0.2 22:22:42:570 | RL | INFO | +16 | CheckFile - Checking if E:\Rocketlauncher\Lib\Bezel.ahk exists 22:22:42:570 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:580 | RL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 104277 bytes Created: 5/24/2015 - 8:28:01 AM Modified: 11/26/2015 - 12:42:57 AM 22:22:42:580 | RL | DEBUG1 | +0 | Bezel.ahk Version: 1.1.7 22:22:42:590 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade.ahk exists 22:22:42:590 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:590 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 38251 bytes Created: 5/24/2015 - 8:26:50 AM Modified: 11/26/2015 - 12:43:06 AM 22:22:42:590 | RL | DEBUG1 | +0 | Fade.ahk Version: 1.1.4 22:22:42:600 | RL | INFO | +16 | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade Init.ahk exists 22:22:42:600 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:600 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1065 bytes Created: 5/24/2015 - 8:27:38 AM Modified: 11/26/2015 - 12:43:12 AM 22:22:42:600 | RL | DEBUG1 | +0 | Fade Init.ahk Version: 1.0.2 22:22:42:600 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade Animations.ahk exists 22:22:42:610 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:620 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 81174 bytes Created: 5/24/2015 - 8:27:41 AM Modified: 11/26/2015 - 12:43:12 AM 22:22:42:620 | RL | DEBUG1 | +0 | Fade Animations.ahk Version: 1.1.10 22:22:42:620 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Keymapper.ahk exists 22:22:42:630 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:630 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 33453 bytes Created: 5/24/2015 - 8:28:11 AM Modified: 5/30/2015 - 9:18:27 PM 22:22:42:630 | RL | DEBUG1 | +0 | Keymapper.ahk Version: 1.1.2 22:22:42:630 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Keymapper Init.ahk exists 22:22:42:640 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:650 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 3461 bytes Created: 5/24/2015 - 8:26:35 AM Modified: 5/30/2015 - 9:18:57 PM 22:22:42:650 | RL | DEBUG1 | +0 | Keymapper Init.ahk Version: 1.0.4 22:22:42:650 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiGame.ahk exists 22:22:42:650 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:660 | RL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 40753 bytes Created: 5/24/2015 - 8:24:03 AM Modified: 9/6/2015 - 8:32:13 PM 22:22:42:660 | RL | DEBUG1 | +0 | MultiGame.ahk Version: 1.0.8 22:22:42:660 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiGame Init.ahk exists 22:22:42:670 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:670 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 161 bytes Created: 5/24/2015 - 8:28:32 AM Modified: 4/14/2013 - 1:33:19 PM 22:22:42:670 | RL | DEBUG1 | +0 | MultiGame Init.ahk Version: 1.0.0 22:22:42:670 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiPlayer.ahk exists 22:22:42:690 | RL | DEBUG1 | +31 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:690 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 66452 bytes Created: 5/24/2015 - 8:23:41 AM Modified: 11/26/2015 - 12:42:52 AM 22:22:42:690 | RL | DEBUG1 | +0 | MultiPlayer.ahk Version: 1.0.7 22:22:42:690 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Pause.ahk exists 22:22:42:700 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:710 | RL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 392193 bytes Created: 5/24/2015 - 8:26:19 AM Modified: 11/26/2015 - 12:43:03 AM 22:22:42:710 | RL | DEBUG1 | +0 | Pause.ahk Version: 1.1.5 22:22:42:720 | RL | INFO | +16 | CheckFile - Checking if E:\Rocketlauncher\Lib\Pause Init.ahk exists 22:22:42:720 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:720 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 553 bytes Created: 5/24/2015 - 8:24:21 AM Modified: 9/6/2015 - 8:31:51 PM 22:22:42:720 | RL | DEBUG1 | +0 | Pause Init.ahk Version: 1.0.3 22:22:42:730 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Password.ahk exists 22:22:42:740 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:740 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 10025 bytes Created: 5/24/2015 - 8:24:18 AM Modified: 9/6/2015 - 8:31:55 PM 22:22:42:740 | RL | DEBUG1 | +0 | Password.ahk Version: 1.0.2 22:22:42:750 | RL | INFO | +16 | CheckFile - Checking if E:\Rocketlauncher\Lib\Rom Mapping Launch Menu.ahk exists 22:22:42:750 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:760 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 74101 bytes Created: 5/24/2015 - 8:23:41 AM Modified: 11/26/2015 - 12:42:54 AM 22:22:42:760 | RL | DEBUG1 | +0 | Rom Mapping Launch Menu.ahk Version: 1.0.6 22:22:42:760 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Shared.ahk exists 22:22:42:770 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:780 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 139893 bytes Created: 5/24/2015 - 8:26:27 AM Modified: 11/26/2015 - 12:43:02 AM 22:22:42:780 | RL | DEBUG1 | +0 | Shared.ahk Version: 1.3.5 22:22:42:780 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Statistics.ahk exists 22:22:42:790 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:790 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26143 bytes Created: 5/24/2015 - 8:26:45 AM Modified: 4/9/2015 - 4:16:56 AM 22:22:42:790 | RL | DEBUG1 | +0 | Statistics.ahk Version: 1.0.3 22:22:42:790 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Statistics Init.ahk exists 22:22:42:800 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:800 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 33 bytes Created: 5/24/2015 - 8:28:01 AM Modified: 12/23/2014 - 11:23:48 PM 22:22:42:800 | RL | DEBUG1 | +0 | Statistics Init.ahk Version: 1.0.1 22:22:42:800 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Virtual Drive.ahk exists 22:22:42:810 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:810 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 18329 bytes Created: 5/29/2015 - 11:47:33 PM Modified: 11/26/2015 - 12:42:58 AM 22:22:42:810 | RL | DEBUG1 | +0 | Virtual Drive.ahk Version: 1.0.3 22:22:42:810 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\XHotkey.ahk exists 22:22:42:820 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:820 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26540 bytes Created: 5/24/2015 - 8:28:26 AM Modified: 9/6/2015 - 8:32:04 PM 22:22:42:820 | RL | DEBUG1 | +0 | XHotkey.ahk Version: 1.0.4 22:22:42:820 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\XHotkey Init.ahk exists 22:22:42:830 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:22:42:830 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1063 bytes Created: 5/24/2015 - 8:26:46 AM Modified: 9/6/2015 - 8:31:50 PM 22:22:42:830 | RL | DEBUG1 | +0 | XHotkey Init.ahk Version: 1.0.2 22:22:42:840 | RL | DEBUG1 | +0 | Main - Using HyperSpin normal mode for version 1.4.0.0 found at: E:\Hyperspin\HyperSpin.exe 22:22:42:850 | RL | DEBUG1 | +15 | Main - Raw CLI received: "Atari 5200 Astro Chase (USA)" 22:22:42:850 | RL | DEBUG1 | +0 | Main - Received this dbName with no path via CLI: "Astro Chase (USA)" 22:22:42:850 | RL | DEBUG1 | +0 | Main - dbName: Astro Chase (USA) 22:22:42:860 | RL | INFO | +16 | Main - Loading Front End Plugin: "HyperSpin" 22:22:42:860 | RL | INFO | +0 | Main - HyperSpin.exe coordinates are x0 y0 w1440 h900 22:22:42:860 | RL | INFO | +0 | Main - RocketLauncher received "Atari 5200" and "Astro Chase (USA)" 22:22:42:870 | RL | INFO | +0 | Main - Did not find a "E:\Rocketlauncher\Settings\Atari 5200\Game Options.ini" file, skipping any game-specific options. 22:22:42:870 | RL | INFO | +0 | Main - Astro Chase (USA) is using the default emulator: Kat5200 22:22:42:880 | RL | INFO | +16 | Main - Checking for a [Kat5200] section in E:\Rocketlauncher\Settings\Atari 5200\Emulators.ini 22:22:42:880 | RL | INFO | +0 | Main - Checking for a [Kat5200] section in E:\Rocketlauncher\Settings\Global Emulators.ini 22:22:42:880 | RL | INFO | +0 | Main - Found [Kat5200] in E:\Rocketlauncher\Settings\Global Emulators.ini 22:22:42:880 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Modules\Kat5200\Kat5200.ahk exists 22:22:42:880 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1515 bytes Created: 5/24/2015 - 8:29:16 AM Modified: 7/21/2013 - 1:23:45 PM 22:22:42:890 | RL | INFO | +15 | Main - CRC Check - CRC matches, this is an official unedited module. 22:22:42:890 | RL | INFO | +0 | Main - Astro Chase (USA) will use module: E:\Rocketlauncher\Modules\Kat5200\Kat5200.ahk 22:22:42:900 | RL | INFO | +0 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 22:22:42:910 | RL | INFO | +16 | CheckFile - Checking if E:\Hyperspin\Emulators\Atari 5200\kat5200.exe exists 22:22:42:920 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1141248 bytes Created: 12/2/2015 - 9:51:53 AM Modified: 6/27/2009 - 4:37:50 PM 22:22:42:920 | RL | INFO | +0 | Main - INI Keys read 22:22:42:920 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\7z.exe exists 22:22:42:930 | RL | DEBUG1 | +15 | CheckFile - Attributes: FileDescription 7-Zip Console FileVersion 15.06 beta InternalName 7z LegalCopyright Copyright (c) 1999-2015 Igor Pavlov OriginalFilename 7z.exe ProductName 7-Zip ProductVersion 15.06 beta CompanyName Igor Pavlov File Size: 262144 bytes Created: 5/24/2015 - 8:26:40 AM Modified: 11/26/2015 - 12:42:56 AM 22:22:42:930 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\7z.dll exists 22:22:42:930 | RL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7z Plugin FileVersion 15.06 beta InternalName 7z LegalCopyright Copyright (c) 1999-2015 Igor Pavlov OriginalFilename 7z.dll ProductName 7-Zip ProductVersion 15.06 beta CompanyName Igor Pavlov File Size: 1012224 bytes Created: 5/24/2015 - 8:28:28 AM Modified: 11/26/2015 - 12:43:05 AM 22:22:42:940 | RL | INFO | +16 | Main - "Astro Chase (USA)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side 22:22:42:940 | RL | INFO | +0 | CheckPaths - Started 22:22:42:950 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Atari 5200\roms\Astro Chase (USA).7z 22:22:42:950 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Atari 5200\roms\Astro Chase (USA)\Astro Chase (USA).7z 22:22:42:950 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:22:42:950 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Atari 5200\roms\Astro Chase (USA).zip 22:22:42:950 | RL | DEBUG1 | +0 | CheckPaths - Looking for rom by name in subfolder: E:\Hyperspin\Emulators\Atari 5200\roms\Astro Chase (USA)\Astro Chase (USA).zip 22:22:42:950 | RL | DEBUG1 | +0 | CheckPaths - Rom not found 22:22:42:960 | RL | DEBUG1 | +16 | CheckPaths - Looking for rom: E:\Hyperspin\Emulators\Atari 5200\roms\Astro Chase (USA).a52 22:22:42:960 | RL | INFO | +0 | CheckPaths - Found rom: E:\Hyperspin\Emulators\Atari 5200\roms\Astro Chase (USA).a52 22:22:42:960 | RL | DEBUG1 | +0 | CheckPaths - Current romName: Astro Chase (USA) 22:22:42:960 | RL | DEBUG1 | +0 | CheckPaths - Current romPath: E:\Hyperspin\Emulators\Atari 5200\roms 22:22:42:960 | RL | DEBUG1 | +0 | CheckPaths - Current romExtension: .a52 22:22:42:970 | RL | INFO | +15 | CheckPaths - Ended 22:22:42:970 | RL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook DetectHiddenWindows, ON SetTitleMatchMode, 2 SendMode, Event 0 = 2 pluginPath = E:\Rocketlauncher\Plugins pluginName = HyperSpin pluginExt = .plugin contextOnExit = rlMode = rlTitle = RocketLauncher rlVersion = 1.0.1.4 rlAuthor = djvj rlURL = www.rlauncher.com langFile = E:\Rocketlauncher\Data\Language\Localization.ini primMonitor = 1 frontendPID = 6456 frontendPath = E:\Hyperspin frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = E: exitEmulatorKey = ~Esc|H3:1joy6 restoreFE = Restore and Click exitScriptKey = ~q & ~s toggleCursorKey = ~e & ~t emuFullPath = E:\Hyperspin\Emulators\Atari 5200\kat5200.exe emuPath = E:\Hyperspin\Emulators\Atari 5200 emuName = Kat5200 emuExt = exe romPath = E:\Hyperspin\Emulators\Atari 5200\roms romPathFromIni = E:\Hyperspin\Emulators\Atari 5200\roms romExtension = .a52 romExtensionOrig = .a52 romExtensions = 7z|zip|a52 executable = kat5200.exe systemDbName = Atari 5200 systemName = Atari 5200 dbPath = dbName = Astro Chase (USA) dbExt = romName = Astro Chase (USA) romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfGamesByScreen = 7 romMappingHideParent = false romMappingMenuWidth = 400 romMappingMenuMargin = 65 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s60 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 7 romMappingTextMargin = 15 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s90 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s22 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s22 Regular romMappingGameNameTextFont = Bebas Neue romMappingGameNameTextOptions = cFFFFFFFF r4 s40 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 55 romMappingMenuFlagSeparation = 7 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false altArchiveNameOnly = altRomNameOnly = altArchiveAndRomName = altArchiveAndManyRomNames = altRomNamesOnly = romMapScenario = skipchecks = false romMatchExt = false blockInputTime = 0 blockInputFile = E:\Rocketlauncher\Module Extensions\BlockInput.exe errorLevelReporting = false lockLaunch = false lockLaunchGame = screenRotationAngle = 0 screenRotationAngleGame = logFile = E:\Rocketlauncher\RocketLauncher.log logLabel := [" INFO"," WARNING"," ERROR"," DEBUG1"," DEBUG2"] logLevel = 10 logShowDebugConsole = true logIncludeModule = true logIncludeFileProperties = true logShowCommandWindow = false logCommandWindow = true rlDebugConsoleStdout = 7 sysLang = English_United_States sysType = 64-bit broadcastWindowTitle = navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = 1 navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = NumpadEnter originalWidth = 1440 originalHeight = 900 vdEnabled = false vdFullPath = vdUseSCSI = true vdDriveLetter = vdAddDrive = true servoStikEnabled = false servoStikExitMode = false ledblinkyEnabled = false ledblinkySystemName = ledblinkyFullPath = ledblinkyProfilePath = E:\Rocketlauncher\Profiles\LEDBlinky ledblinkyRLProfile = E:\Rocketlauncher\Profiles\LEDBlinky\RocketLauncher emuIdleShutdown = 0 launchPasswordHash = UpUpDownDownLeftRightLeftRight hideCursor = true hideEmu = false hideFE = false fadeIn = false fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutExtraScreen = false fadeOutDuration = 500 fadeOutTransitionAnimation = LegacyFadeOutTransition fadeOutDelay = 0 fadeLyrInterpolation = 7 fadeMuteEmulator = false fadeUseBackgrounds = false fadeClickThrough = false fadeWidthBaseRes = 1920 fadeHeightBaseRes = 1080 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Stretch and Lose Aspect fadeLyr2Pos = Stretch and Lose Aspect fadeLyr2X = 0 fadeLyr2Y = 0 fadeLyr2W = fadeLyr2H = fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr2Prefix = Extra Layer 1 - Console fadeLyr3Pos = Center fadeLyr3X = 450 fadeLyr3Y = 5 fadeLyr3W = fadeLyr3H = fadeLyr3Adjust = 1 fadeLyr3PicPad = 0 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3BackImageTransparency = 30 fadeLyr3StaticPos = No Alignment fadeLyr3StaticX = 0 fadeLyr3StaticY = 870|1575 fadeLyr3StaticW = fadeLyr3StaticH = fadeLyr3StaticAdjust = 1 fadeLyr3StaticPicPad = 0 fadeLyr3StaticPrefix = Info Bar fadeLyr4Adjust = 1 fadeLyr4X = 1792|952 fadeLyr4Y = 891|1596 fadeLyr4W = 128 fadeLyr4H = fadeLyr4Pos = No Alignment fadeLyr4FPS = 50 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = Image fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 900 fadeBarWindowH = fadeBarWindowR = 30 fadeBarWindowM = 30 fadeBarWindowHatchStyle = 8 fadeBar = true fadeBarNon7zProgressTime = 0 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 30 fadeBarR = 10 fadeBarColor = DD00BFFF fadeBarHatchStyle = 8 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 150 fadeRomInfoDescription = filtered text fadeRomInfoSystemName = image fadeRomInfoYear = text with label fadeRomInfoManufacturer = text with label fadeRomInfoGenre = disabled fadeRomInfoRating = image fadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|Rating fadeRomInfoTextPlacement = User Defined fadeRomInfoTextMargin = 7 fadeRomInfoText1Options = w1600|787 h90 x165 y870|1575 cFFE1E1E1 r4 s90 Left Regular fadeRomInfoText2Options = w400 x8 y15 cFF555555 r4 s60 Bold fadeRomInfoText3Options = w310 x165 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText4Options = w1305|492 h66 x460 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText5Options = cFF555555 r4 s42 Bold fadeRomInfoText6Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topRight fadeStatsInfoTextMargin = 7 fadeStatsInfoText1Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText2Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText3Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText4Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText5Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText6Options = cFFB4B4B4 r4 s22 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFB4B4B4 r4 s30 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFB4B4B4 r4 s30 Right Bold fadeText2 = Extraction Complete, Ready fadeText3 = Loading Game fadeText4 = Loading Complete fadeFont = Bebas Neue fadeSystemAndRomLayersOnly = false fadeExtractionTime = disabled fadeExtractionTimeTextX = 0 fadeExtractionTimeTextY = 0 fadeExtractionTimeTextOptions = cFF555555 r4 s20 Bold fadeInterruptKey = detectFadeErrorEnabled = false fadeImgPath = E:\Rocketlauncher\Media\Fade RLDataPath = E:\Rocketlauncher\Data RLMediaPath = E:\Rocketlauncher\Media RLErrSoundPath = E:\Rocketlauncher\Media\Sounds\Error modulesPath = E:\Rocketlauncher\Modules moduleFullName = E:\Rocketlauncher\Modules\Kat5200\Kat5200.ahk moduleName = Kat5200 modulePath = E:\Rocketlauncher\Modules\Kat5200 moduleExtension = ahk moduleExtensionsPath = E:\Rocketlauncher\Module Extensions libPath = E:\Rocketlauncher\Lib 7zEnabled = true 7zPath = E:\Rocketlauncher\Module Extensions\7z.exe 7zDllPath = E:\Rocketlauncher\Module Extensions\7z.dll 7zExtractPath = C:\Users\Lenovo\AppData\Local\Temp\HS 7zExtractPathOrig = 7zAttachSystemName = false 7zDelTemp = true 7zSounds = true 7zFormats = .zip,.rar,.7z,.lzh,.gzip,.tar 7zFormatsNoP = zip,rar,7z,lzh,gzip,tar mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgWidthBaseRes = 1920 mgHeightBaseRes = 1080 mgYOffset = 500|800 mgFont = Arial mgText1Options = x10p y250|500 w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 100 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgCandidate = mgValidTypes = (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side mgOnLaunch = false pauseEnabled = false pauseKey = m pauseBackToMenuBarKey = n pauseZoomInKey = C pauseZoomOutKey = V pauseScreenshotKey = ~PrintScreen pauseHiToTextPath = E:\Rocketlauncher\Module Extensions\HiToText.exe pauseSaveStateKeyCodes = +{1}|+{2}|+{3}|+{4}|+{5}|+{6}|+{7}|+{8}|+{9} pauseLoadStateKeyCodes = !{1}|!{2}|!{3}|!{4}|!{5}|!{6}|!{7}|!{8}|!{9} keymapperEnabled = true keymapperAHKMethod = External keymapper = xpadder xpadderFullPath = E:\Hyperspin\Utilities\Xpadder\Xpadder.exe joyToKeyFullPath = E:\Utilities\JoyToKey\JoyToKey.exe keymapperProfilePath = E:\Rocketlauncher\Profiles\xpadder keymapperFrontEndProfileName = RocketLauncherUI keymapperFrontEndProfile = xpadder keymapperRocketLauncherProfileEnabled = true joyIDsEnabled = true joyIDsPreferredControllersGlobal = Controller (Xbox 360 Wireless Receiver for Windows) joyIDsPreferredControllersSystem = use_global joyIDsPreferredControllersOnExit = CustomJoyNamesEnabled = false CustomJoyNames = rotateMethod = false FEProfile = E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI defaultProfile = E:\Rocketlauncher\Profiles\xpadder\_Default systemProfile = E:\Rocketlauncher\Profiles\xpadder\Atari 5200 xPadderSystemProfile = E:\Rocketlauncher\Profiles\xpadder\Atari 5200\_Default emuProfile = E:\Rocketlauncher\Profiles\xpadder\Atari 5200\Kat5200 romProfile = E:\Rocketlauncher\Profiles\xpadder\Atari 5200\Astro Chase (USA) RocketLauncherProfile = E:\Rocketlauncher\Profiles\xpadder\RocketLauncher blankProfile = E:\Rocketlauncher\Profiles\xpadder\_Default\blank ahkFEProfile = E:\Rocketlauncher\Profiles\AHK\RocketLauncherUI ahkDefaultProfile = E:\Rocketlauncher\Profiles\AHK\_Default ahkSystemProfile = E:\Rocketlauncher\Profiles\AHK\Atari 5200 ahkEmuProfile = E:\Rocketlauncher\Profiles\AHK\Atari 5200\Kat5200 ahkRomProfile = E:\Rocketlauncher\Profiles\AHK\Atari 5200\Astro Chase (USA) ahkRocketLauncherProfile = E:\Rocketlauncher\Profiles\AHK\RocketLauncher bezelEnabled = false bezelICEnabled = false statisticsEnabled = true pressDuration = -1 emuVolume = 1 dxwndIni = E:\Rocketlauncher\Module Extensions\dxwnd\dxwnd.ini dxwndFullPath = E:\Rocketlauncher\Module Extensions\dxwnd\dxwnd.exe mon1O = pacDrivedllFile = E:\Rocketlauncher\Module Extensions\PacDrive32.dll userFadeAnimIniFile = E:\Rocketlauncher\Lib\User Fade Animations.ini 22:22:42:970 | RL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 22:22:42:980 | RL | INFO | +0 | BuildScript - Loaded Keymapper Init.ahk scripts 22:22:42:980 | RL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 22:22:42:980 | RL | WARNING | +0 | BuildScript - "E:\Rocketlauncher\Lib\User Functions Init.ahk" not found 22:22:42:980 | RL | DEBUG1 | +0 | BuildScript - Module starts on line: 2 22:22:42:980 | RL | INFO | +0 | BuildScript - Validating module 22:22:42:990 | RL | INFO | +16 | BuildScript - Validation complete 22:22:42:990 | RL | INFO | +0 | BuildScript - Module: MEmu = Kat5200 MEmuV = v0.6.2 MURL = http://kat5200.jillybunch.com/ MAuthor = djvj MVersion = 2.0.1 MCRC = 3FDEE537 MID = 635038268901251702 MSystem = "Atari 5200" ;---------------------------------------------------------------------------- ; Notes: ; In you emu dir, create a subdir named bios and place the 5200.rom there extracted. ; When you first start kat5200, you will be presented with a Wizard. Set the bios folder you created as your "Atari 8-bit Image Directory" and leave Scan for BIOS? checked. ; While in the wizard, check the Fullscreen box to enable it and set Video Zoom to 2x. ; CLI is supported but doesn't seem to work. So for now, set your video options from the GUI. ; Settings are stored in the kat5200.db3 file. ; Roms must be extracted, zip is not supported ;---------------------------------------------------------------------------- StartModule() FadeInStart() 7z(romPath, romName, romExtension, 7zExtractPath) If romExtension in %7zFormats% ScriptError("Kat5200 only supports extracted roms. Please extract your roms or turn on 7z for this system as the emu is being sent this extension: """ . romExtension . """") Run(executable . " """ . romPath . "\" . romName . romExtension . """", emuPath) WinWait("kat5200 ahk_class SDL_app") WinWaitActive("kat5200 ahk_class SDL_app") FadeInExit() Process("WaitClose", executable) 7zCleanUp() FadeOutExit() ExitModule() CloseProcess: FadeOutStart() WinClose("kat5200 ahk_class SDL_app") Return 22:22:42:000 | RL | INFO | +15 | BuildScript - Loaded Multi-Player scripts 22:22:43:000 | RL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 22:22:43:000 | RL | WARNING | +0 | BuildScript - "E:\Rocketlauncher\Lib\User Functions.ahk" not found 22:22:43:000 | RL | INFO | +0 | BuildScript - Finished injecting functions into module 22:22:43:010 | RL | INFO | +0 | Main - Module is built 22:22:43:010 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\AutoHotkey.dll exists 22:22:43:010 | RL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription AutoHotkey_H ANSI 32-bit FileVersion 1.1.09.04 InternalName AutoHotkey_H LegalCopyright Copyright (C) 2012 OriginalFilename AutoHotkey.exe ProductName AutoHotkey_H ProductVersion 1.1.09.04 File Size: 785408 bytes Created: 5/24/2015 - 8:28:11 AM Modified: 4/19/2013 - 6:16:32 PM 22:22:43:020 | RL | INFO | +16 | Main - Running module 22:22:43:020 | RL | INFO | +0 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 22:22:43:120 | MD | INFO | +N/A | Module initialized 22:22:43:120 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Started 22:22:43:120 | MD | DEBUG2 | +0 | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups 22:22:43:140 | MD | DEBUG2 | +31 | XHotkeyTableCreation - Post loop 1 check 22:22:43:140 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 2 check 22:22:43:150 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess" 22:22:43:150 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Ended 22:22:43:150 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Started 22:22:43:150 | MD | DEBUG2 | +0 | XHotkeyTableCreation - KeyGroup ~1joy6 not in TableKeyGroups ~Esc, 22:22:43:150 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 1 check 22:22:43:150 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 2 check 22:22:43:180 | MD | DEBUG2 | +31 | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~1joy6" to call a group label 22:22:43:180 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Ended 22:22:43:180 | MD | DEBUG2 | +0 | Keymapper - Checking for the JoyIDs_Preferred_Controllers key in E:\Rocketlauncher\Settings\Atari 5200\Games JoyIDs.ini under section [Astro Chase (USA)] 22:22:43:210 | MD | INFO | +31 | LoadPreferredControllers - Started 22:22:43:210 | MD | DEBUG2 | +0 | LoadPreferredControllers - JoyIDsPreferredControllers = Controller (Xbox 360 Wireless Receiver for Windows) 22:22:43:210 | MD | DEBUG2 | +0 | LoadPreferredControllers - Creating a list of currently connected joysticks 22:22:43:210 | MD | INFO | +0 | GetJoystickArray - Started 22:22:43:210 | MD | DEBUG2 | +0 | GetJoystickArray - Joysticks Detected: 1000000000000000 22:22:43:240 | MD | INFO | +31 | GetJoystickGUID - Started 22:22:43:240 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 5041DB96E6EDE4118001444553540000 22:22:43:240 | MD | DEBUG2 | +0 | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 5041DB96E6EDE4118001444553540000 22:22:43:240 | MD | INFO | +0 | GetJoystickArray - Ended 22:22:43:240 | MD | DEBUG2 | +0 | LoadPreferredControllers - Preferred Order Sorting List -> 1.01|045e|02a1|5041DB96E6EDE4118001444553540000 22:22:43:270 | MD | INFO | +32 | LoadPreferredControllers - Sorting Currently Connected joysticks List to match the order of the Preferred Controller List 22:22:43:270 | MD | INFO | +0 | LoadPreferredControllers - Assigning the New Joystick IDs according to the preferred list for the active controllers 22:22:43:270 | MD | INFO | +0 | ChangeJoystickID - Started 22:22:43:270 | MD | DEBUG2 | +0 | ChangeJoystickID - Swapping Joystick ID: 00000000 to the New Joystick ID: 00000000, for the Joystick VID_045e&PID_02a1&GUID_5041DB96E6EDE4118001444553540000 22:22:43:270 | MD | INFO | +0 | ChangeJoystickID - Ended 22:22:43:300 | MD | INFO | +31 | LoadPreferredControllers - Ended 22:22:43:300 | MD | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Utilities\Xpadder\Xpadder.exe exists 22:22:43:300 | MD | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1178624 bytes Created: 6/16/2015 - 11:46:34 AM Modified: 2/2/2014 - 3:10:38 PM 22:22:43:300 | MD | INFO | +0 | Keymapper - Loading xpadder 22:22:43:300 | MD | INFO | +0 | RunKeymapper - Started, using method "load" 22:22:43:300 | MD | INFO | +0 | GetJoystickArray - Started 22:22:43:310 | MD | DEBUG2 | +0 | GetJoystickArray - Joysticks Detected: 1000000000000000 22:22:43:330 | MD | INFO | +31 | GetJoystickGUID - Started 22:22:43:330 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 5041DB96E6EDE4118001444553540000 22:22:43:330 | MD | DEBUG2 | +0 | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 5041DB96E6EDE4118001444553540000 22:22:43:330 | MD | INFO | +0 | GetJoystickArray - Ended 22:22:43:330 | MD | DEBUG2 | +0 | RunKeymapper - Found your keymapper application here: "E:\Hyperspin\Utilities\Xpadder\Xpadder.exe" 22:22:43:340 | MD | DEBUG2 | +0 | RunKeymapper - Looping through controllers to find xpadder profiles for each one 22:22:43:360 | MD | DEBUG2 | +31 | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "Controller (Xbox 360 Wireless Receiver for Windows)" 22:22:43:360 | MD | DEBUG2 | +0 | GetProfile - Searching for these profiles (| delimited): E:\Rocketlauncher\Profiles\xpadder\Atari 5200\Astro Chase (USA)|E:\Rocketlauncher\Profiles\xpadder\Atari 5200\Kat5200|E:\Rocketlauncher\Profiles\xpadder\Atari 5200\_Default|E:\Rocketlauncher\Profiles\xpadder\_Default|E:\Rocketlauncher\Profiles\xpadder\_Default\blank 22:22:43:360 | MD | DEBUG2 | +0 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Atari 5200\Astro Chase (USA)\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile 22:22:43:360 | MD | DEBUG2 | +0 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Atari 5200\Astro Chase (USA)\p1.xpadderprofile 22:22:43:370 | MD | DEBUG2 | +0 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Atari 5200\Kat5200\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile 22:22:43:370 | MD | DEBUG2 | +0 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Atari 5200\Kat5200\p1.xpadderprofile 22:22:43:370 | MD | DEBUG2 | +0 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Atari 5200\_Default\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile 22:22:43:370 | MD | DEBUG2 | +0 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\Atari 5200\_Default\p1.xpadderprofile 22:22:43:390 | MD | DEBUG2 | +31 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile 22:22:43:400 | MD | DEBUG2 | +0 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile 22:22:43:400 | MD | INFO | +0 | GetProfile - Loading Player 1 Profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile 22:22:43:400 | MD | INFO | +0 | RunXpadder - Started 22:22:43:400 | MD | INFO | +0 | Process - Exist JoyToKey.exe 22:22:43:400 | MD | DEBUG2 | +0 | RunXpadder - Closing xpadder to refresh controllers seen by xpadder 22:22:43:420 | MD | INFO | +32 | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe /C 22:22:43:470 | MD | DEBUG1 | +46 | Run - "Xpadder.exe /C" Process ID: 5380 22:22:43:470 | MD | DEBUG2 | +0 | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in E:\Hyperspin\Utilities\Xpadder\xpadder.ini 22:22:43:470 | MD | INFO | +0 | Process - WaitClose Xpadder.exe 2 22:22:43:685 | MD | DEBUG2 | +219 | RunXpadder - Reading the order in E:\Hyperspin\Utilities\Xpadder\xpadder.ini and arranging profiles found to match that order 22:22:43:685 | MD | DEBUG2 | +0 | RunXpadder - No more controllers to be found 22:22:43:685 | MD | INFO | +0 | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile" /M 22:22:43:725 | MD | DEBUG1 | +31 | Run - "Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile" /M" Process ID: 3008 22:22:43:725 | MD | INFO | +0 | RunXpadder - Ended 22:22:43:725 | MD | INFO | +0 | RunKeymapper - Ended 22:22:43:725 | MD | INFO | +0 | Keymapper - Loading External AHK Keymapping 22:22:43:785 | MD | INFO | +62 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\AhkLauncher.exe exists 22:22:43:815 | MD | DEBUG1 | +32 | CheckFile - Attributes: FileDescription AhkLauncher FileVersion 1.0.0.0 InternalName AhkLauncher.exe LegalCopyright Copyright © 2013 OriginalFilename AhkLauncher.exe ProductName AhkLauncher ProductVersion 1.0.0.0 File Size: 11264 bytes Created: 5/24/2015 - 8:28:06 AM Modified: 9/4/2013 - 6:30:52 PM 22:22:43:815 | MD | INFO | +0 | RunAHKKeymapper - Started 22:22:43:815 | MD | DEBUG1 | +0 | RunAHKKeymapper - Loading Astro Chase (USA), Kat5200, Atari 5200, or _Default AHK Keymapper profile 22:22:43:815 | MD | INFO | +0 | GetAHKProfile - Started 22:22:43:815 | MD | DEBUG2 | +0 | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\Atari 5200\Astro Chase (USA).ahk 22:22:43:815 | MD | DEBUG2 | +0 | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\Atari 5200\Kat5200.ahk 22:22:43:825 | MD | DEBUG2 | +0 | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\Atari 5200.ahk 22:22:43:825 | MD | DEBUG2 | +0 | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\_Default.ahk 22:22:43:825 | MD | INFO | +0 | GetAHKProfile - Ended and no profile found 22:22:43:825 | MD | DEBUG1 | +0 | RunAHKKeymapper - If AhkLauncher.exe is running, need to close it first before a new profile can be loaded 22:22:43:825 | MD | INFO | +0 | Process - Exist AhkLauncher.exe 22:22:43:845 | MD | INFO | +31 | RunAHKKeymapper - Ended 22:22:43:845 | MD | INFO | +0 | StartModule - Started 22:22:43:845 | MD | INFO | +0 | StartModule - MEmu: Kat5200 MEmuV: v0.6.2 MURL: http://kat5200.jillybunch.com/ MAuthor: djvj MVersion: 2.0.1 MCRC: 3FDEE537 iCRC: MID: MSystem: "Atari 5200" 22:22:43:845 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "Atari 5200" 22:22:43:845 | MD | INFO | +0 | PluginInit - Started 22:22:43:855 | MD | DEBUG1 | +0 | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating 22:22:43:855 | MD | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Databases\Atari 5200\Atari 5200.xml exists 22:22:43:855 | MD | DEBUG1 | +0 | CheckFile - Attributes: File Size: 24008 bytes Created: 5/20/2015 - 5:19:45 PM Modified: 8/8/2012 - 7:11:33 PM 22:22:43:855 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching for a "Game Name" in the database 22:22:43:855 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Game Name" in the database! 22:22:43:855 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Name 22:22:43:875 | MD | DEBUG1 | +31 | BuildDatabaseTable - Found "Name" with a value: "Astro Chase (USA)" 22:22:43:875 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Cloneof 22:22:43:875 | MD | DEBUG1 | +0 | BuildDatabaseTable - Could not find: Cloneof 22:22:43:875 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Manufacturer 22:22:43:875 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Manufacturer" with a value: "Parker Brothers" 22:22:43:885 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Year 22:22:43:885 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Year" with a value: "1983" 22:22:43:885 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Genre 22:22:43:885 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Genre" with a value: "Action" 22:22:43:885 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Rating 22:22:43:885 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Rating" with a value: "HSRS - GA (General Audience)" 22:22:43:885 | MD | DEBUG2 | +0 | PluginInit - GameInfo: GameInfo Label: Genre | GameInfo Value: Action GameInfo Label: Manufacturer | GameInfo Value: Parker Brothers GameInfo Label: Name | GameInfo Value: Astro Chase (USA) GameInfo Label: Rating | GameInfo Value: HSRS - GA (General Audience) GameInfo Label: Year | GameInfo Value: 1983 22:22:43:905 | MD | DEBUG1 | +31 | BuildDatabaseTable - Ended 22:22:43:905 | MD | DEBUG1 | +0 | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo 22:22:43:905 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Game Logo: E:\Hyperspin\Media\Atari 5200\Images\Wheel\Astro Chase (USA).png 22:22:43:905 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a System Logo: E:\Hyperspin\Media\Main Menu\Images\Wheel\Atari 5200.png 22:22:43:915 | MD | DEBUG2 | +0 | BuildAssetsTable - Media assets found: Asset Label: Game Logo | Asset Path1: E:\Hyperspin\Media\Atari 5200\Images\Wheel\Astro Chase (USA).png | Asset Extension1: png | Asset Type1: game Asset Label: System Logo | Asset Path1: E:\Hyperspin\Media\Main Menu\Images\Wheel\Atari 5200.png | Asset Extension1: png | Asset Type1: system 22:22:43:935 | MD | DEBUG1 | +31 | BuildAssetsTable - Ended 22:22:43:935 | MD | DEBUG1 | +0 | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other 22:22:43:935 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Artwork1: E:\Hyperspin\Media\Atari 5200\Images\Artwork1\Astro Chase (USA).png 22:22:43:935 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Box Art: E:\Hyperspin\Media\Atari 5200\Images\Artwork2\Astro Chase (USA).png 22:22:43:935 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Cartridge: E:\Hyperspin\Media\Atari 5200\Images\Artwork3\Astro Chase (USA).png 22:22:43:945 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Flyers: E:\Hyperspin\Media\Atari 5200\Images\Artwork4\Astro Chase (USA).png 22:22:43:945 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Letters: E:\Hyperspin\Media\Atari 5200\Images\Letters 22:22:44:005 | MD | DEBUG1 | +63 | BuildAssetsTable - Searching for a Other: E:\Hyperspin\Media\Atari 5200\Images\Other 22:22:44:005 | MD | DEBUG2 | +0 | BuildAssetsTable - Media assets found: Asset Label: Cartridge | Asset Path1: E:\Hyperspin\Media\Atari 5200\Images\Artwork3\Astro Chase (USA).png | Asset Extension1: png | Asset Type1: game Asset Label: Letters | Asset Path1: E:\Hyperspin\Media\Atari 5200\Images\Letters\!.png | Asset Extension1: png | Asset Type1: system Asset Label: Letters | Asset Path2: E:\Hyperspin\Media\Atari 5200\Images\Letters\'.png | Asset Extension2: png | Asset Type2: system Asset Label: Letters | Asset Path3: E:\Hyperspin\Media\Atari 5200\Images\Letters\(.png | Asset Extension3: png | Asset Type3: system Asset Label: Letters | Asset Path4: E:\Hyperspin\Media\Atari 5200\Images\Letters\0.png | Asset Extension4: png | Asset Type4: system Asset Label: Letters | Asset Path5: E:\Hyperspin\Media\Atari 5200\Images\Letters\1.png | Asset Extension5: png | Asset Type5: system Asset Label: Letters | Asset Path6: E:\Hyperspin\Media\Atari 5200\Images\Letters\2.png | Asset Extension6: png | Asset Type6: system Asset Label: Letters | Asset Path7: E:\Hyperspin\Media\Atari 5200\Images\Letters\3.png | Asset Extension7: png | Asset Type7: system Asset Label: Letters | Asset Path8: E:\Hyperspin\Media\Atari 5200\Images\Letters\4.png | Asset Extension8: png | Asset Type8: system Asset Label: Letters | Asset Path9: E:\Hyperspin\Media\Atari 5200\Images\Letters\5.png | Asset Extension9: png | Asset Type9: system Asset Label: Letters | Asset Path10: E:\Hyperspin\Media\Atari 5200\Images\Letters\6.png | Asset Extension10: png | Asset Type10: system Asset Label: Letters | Asset Path11: E:\Hyperspin\Media\Atari 5200\Images\Letters\7.png | Asset Extension11: png | Asset Type11: system Asset Label: Letters | Asset Path12: E:\Hyperspin\Media\Atari 5200\Images\Letters\8.png | Asset Extension12: png | Asset Type12: system Asset Label: Letters | Asset Path13: E:\Hyperspin\Media\Atari 5200\Images\Letters\9.png | Asset Extension13: png | Asset Type13: system Asset Label: Letters | Asset Path14: E:\Hyperspin\Media\Atari 5200\Images\Letters\a.png | Asset Extension14: png | Asset Type14: system Asset Label: Letters | Asset Path15: E:\Hyperspin\Media\Atari 5200\Images\Letters\b.png | Asset Extension15: png | Asset Type15: system Asset Label: Letters | Asset Path16: E:\Hyperspin\Media\Atari 5200\Images\Letters\c.png | Asset Extension16: png | Asset Type16: system Asset Label: Letters | Asset Path17: E:\Hyperspin\Media\Atari 5200\Images\Letters\d.png | Asset Extension17: png | Asset Type17: system Asset Label: Letters | Asset Path18: E:\Hyperspin\Media\Atari 5200\Images\Letters\e.png | Asset Extension18: png | Asset Type18: system Asset Label: Letters | Asset Path19: E:\Hyperspin\Media\Atari 5200\Images\Letters\f.png | Asset Extension19: png | Asset Type19: system Asset Label: Letters | Asset Path20: E:\Hyperspin\Media\Atari 5200\Images\Letters\g.png | Asset Extension20: png | Asset Type20: system Asset Label: Letters | Asset Path21: E:\Hyperspin\Media\Atari 5200\Images\Letters\h.png | Asset Extension21: png | Asset Type21: system Asset Label: Letters | Asset Path22: E:\Hyperspin\Media\Atari 5200\Images\Letters\i.png | Asset Extension22: png | Asset Type22: system Asset Label: Letters | Asset Path23: E:\Hyperspin\Media\Atari 5200\Images\Letters\j.png | Asset Extension23: png | Asset Type23: system Asset Label: Letters | Asset Path24: E:\Hyperspin\Media\Atari 5200\Images\Letters\k.png | Asset Extension24: png | Asset Type24: system Asset Label: Letters | Asset Path25: E:\Hyperspin\Media\Atari 5200\Images\Letters\l.png | Asset Extension25: png | Asset Type25: system Asset Label: Letters | Asset Path26: E:\Hyperspin\Media\Atari 5200\Images\Letters\m.png | Asset Extension26: png | Asset Type26: system Asset Label: Letters | Asset Path27: E:\Hyperspin\Media\Atari 5200\Images\Letters\n.png | Asset Extension27: png | Asset Type27: system Asset Label: Letters | Asset Path28: E:\Hyperspin\Media\Atari 5200\Images\Letters\o.png | Asset Extension28: png | Asset Type28: system Asset Label: Letters | Asset Path29: E:\Hyperspin\Media\Atari 5200\Images\Letters\p.png | Asset Extension29: png | Asset Type29: system Asset Label: Letters | Asset Path30: E:\Hyperspin\Media\Atari 5200\Images\Letters\q.png | Asset Extension30: png | Asset Type30: system Asset Label: Letters | Asset Path31: E:\Hyperspin\Media\Atari 5200\Images\Letters\r.png | Asset Extension31: png | Asset Type31: system Asset Label: Letters | Asset Path32: E:\Hyperspin\Media\Atari 5200\Images\Letters\s.png | Asset Extension32: png | Asset Type32: system Asset Label: Letters | Asset Path33: E:\Hyperspin\Media\Atari 5200\Images\Letters\t.png | Asset Extension33: png | Asset Type33: system Asset Label: Letters | Asset Path34: E:\Hyperspin\Media\Atari 5200\Images\Letters\u.png | Asset Extension34: png | Asset Type34: system Asset Label: Letters | Asset Path35: E:\Hyperspin\Media\Atari 5200\Images\Letters\v.png | Asset Extension35: png | Asset Type35: system Asset Label: Letters | Asset Path36: E:\Hyperspin\Media\Atari 5200\Images\Letters\w.png | Asset Extension36: png | Asset Type36: system Asset Label: Letters | Asset Path37: E:\Hyperspin\Media\Atari 5200\Images\Letters\x.png | Asset Extension37: png | Asset Type37: system Asset Label: Letters | Asset Path38: E:\Hyperspin\Media\Atari 5200\Images\Letters\y.png | Asset Extension38: png | Asset Type38: system Asset Label: Letters | Asset Path39: E:\Hyperspin\Media\Atari 5200\Images\Letters\z.png | Asset Extension39: png | Asset Type39: system Asset Label: Other | Asset Path1: E:\Hyperspin\Media\Atari 5200\Images\Other\Pointer.png | Asset Extension1: png | Asset Type1: system 22:22:44:005 | MD | DEBUG1 | +0 | BuildAssetsTable - Ended 22:22:44:005 | MD | DEBUG1 | +0 | BuildAssetsTable - Started - Building Table for: Game Video|System Video 22:22:44:035 | MD | DEBUG1 | +31 | BuildAssetsTable - Searching for a Game Video: E:\Hyperspin\Media\Atari 5200\Video\Astro Chase (USA).* 22:22:44:035 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a System Video: E:\Hyperspin\Media\Main Menu\Video\Atari 5200.* 22:22:44:035 | MD | DEBUG2 | +0 | BuildAssetsTable - Media assets found: Asset Label: Game Video | Asset Path1: E:\Hyperspin\Media\Atari 5200\Video\Astro Chase (USA).mp4 | Asset Extension1: mp4 | Asset Type1: game Asset Label: System Video | Asset Path1: E:\Hyperspin\Media\Main Menu\Video\Atari 5200.mp4 | Asset Extension1: mp4 | Asset Type1: system 22:22:44:035 | MD | DEBUG1 | +0 | BuildAssetsTable - Ended 22:22:44:035 | MD | INFO | +0 | PluginInit - Ended 22:22:44:045 | RL | WARNING | +1030 | HyperSpin.exe was displaced to x66 y66 w1080 h624 by Kat5200. It is probably running in true fullscreen mode. 22:22:44:065 | MD | DEBUG1 | +31 | StartModule - Setting romName to the dbName sent to RocketLauncher: Astro Chase (USA) 22:22:44:065 | MD | INFO | +0 | Hiding mouse cursor 22:22:44:092 | MD | DEBUG2 | +31 | XHotkeyTableCreation - Started 22:22:44:095 | MD | DEBUG2 | +0 | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc,~1joy6, 22:22:44:105 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 1 check 22:22:44:106 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 2 check 22:22:44:137 | MD | DEBUG2 | +32 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor" 22:22:44:158 | MD | DEBUG2 | +31 | XHotkeyTableCreation - Ended 22:22:44:162 | MD | INFO | +0 | StartModule - Ended 22:22:44:163 | MD | INFO | +0 | 7z - Started, received E:\Hyperspin\Emulators\Atari 5200\roms\Astro Chase (USA).a52. If rom is an archive, it will extract to C:\Users\Lenovo\AppData\Local\Temp\HS 22:22:44:165 | MD | INFO | +0 | 7z - This rom type does not need 7z: ".a52" 22:22:44:166 | MD | DEBUG1 | +0 | 7z - Starting non-7z FadeIn animation. 22:22:44:168 | MD | DEBUG1 | +0 | 7z - romPath changed from "E:\Hyperspin\Emulators\Atari 5200\roms" to "E:\Hyperspin\Emulators\Atari 5200\roms" 22:22:44:198 | MD | DEBUG1 | +31 | 7z - romName changed from "Astro Chase (USA)" to "Astro Chase (USA)" 22:22:44:220 | MD | DEBUG1 | +31 | 7z - romExtension changed from ".a52" to ".a52" 22:22:44:247 | MD | INFO | +31 | 7z - Ended 22:22:44:251 | MD | INFO | +0 | Run - Running: E:\Hyperspin\Emulators\Atari 5200\kat5200.exe "E:\Hyperspin\Emulators\Atari 5200\roms\Astro Chase (USA).a52" 22:22:44:281 | MD | DEBUG1 | +32 | Run - "kat5200.exe "E:\Hyperspin\Emulators\Atari 5200\roms\Astro Chase (USA).a52"" Process ID: 5056 22:22:44:282 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: Believe the Hype - Google Chrome | Class: Chrome_WidgetWin_1 | State: 1 | X: -4 | Y: -4 | Width: 1448 | Height: 864 | Window HWND: 0xe03b8 | Process ID: 1272 | Process Path: C:\Program Files (x86)\Google\Chrome\Application\chrome.exe 22:22:44:284 | MD | INFO | +0 | WinWait - Waiting for "kat5200 ahk_class SDL_app" 22:22:44:532 | MD | DEBUG1 | +249 | GetActiveWindowStatus - Title: E:\Hyperspin\Emulators\Atari 5200\kat5200.exe | Class: ConsoleWindowClass | State: 0 | X: 88 | Y: 88 | Width: 668 | Height: 331 | Window HWND: 0x2a0670 | Process ID: 5056 | Process Path: E:\Hyperspin\Emulators\Atari 5200\kat5200.exe 22:22:44:534 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: E:\Hyperspin\Emulators\Atari 5200\kat5200.exe | Class: ConsoleWindowClass | State: 0 | X: 88 | Y: 88 | Width: 668 | Height: 331 | Window HWND: 0x2a0670 | Process ID: 5056 | Process Path: E:\Hyperspin\Emulators\Atari 5200\kat5200.exe 22:22:44:537 | MD | INFO | +0 | WinWaitActive - Waiting for "kat5200 ahk_class SDL_app" 22:22:44:734 | MD | DEBUG1 | +203 | GetActiveWindowStatus - Title: E:\Hyperspin\Emulators\Atari 5200\kat5200.exe | Class: ConsoleWindowClass | State: 0 | X: 88 | Y: 88 | Width: 668 | Height: 331 | Window HWND: 0x2a0670 | Process ID: 5056 | Process Path: E:\Hyperspin\Emulators\Atari 5200\kat5200.exe 22:22:44:846 | MD | INFO | +109 | Process - WaitClose kat5200.exe 22:22:59:048 | MD | DEBUG1 | +14196 | CloseProcess - Started, user requested to end launched application 22:22:59:050 | MD | INFO | +0 | WinClose - Closing: kat5200 ahk_class SDL_app 22:22:59:270 | MD | DEBUG1 | +234 | CloseProcess - Ended 22:22:59:273 | MD | INFO | +0 | 7zCleanUp - Started 22:22:59:275 | MD | DEBUG1 | +0 | 7zCleanUp - Deleted 22:22:59:276 | MD | INFO | +0 | 7zCleanUp - Ended 22:22:59:278 | MD | INFO | +0 | ExitModule - Started 22:22:59:280 | MD | INFO | +0 | Starting Updating Statistics: 22:22:59:282 | MD | DEBUG2 | +0 | Total Elapsed Time in Pause in seconds: 0 22:22:59:284 | MD | DEBUG2 | +0 | gameSectionStartTime:270762355 22:22:59:285 | MD | DEBUG2 | +0 | ElapsedTime:15 22:22:59:306 | MD | DEBUG2 | +32 | Statistics cleared game name: Astro Chase 22:22:59:346 | MD | DEBUG2 | +31 | Loaded game statistics from ini files: Number_of_Times_Played: 3 Last_Time_Played: Friday December 18, 2015 11:20:20 PM Average_Time_Played: 24 Total_Time_Played: 72 System_Total_Played_Time: 225 Total_Global_Played_Time: 10966 22:22:59:370 | MD | DEBUG2 | +31 | Updated Statistics: Number_of_Times_Played: 4 Last_Time_Played: Saturday December 19, 2015 10:22:44 PM Average_Time_Played: 22 Total_Time_Played: 87 System_Total_Played_Time: 240 Total_Global_Played_Time: 10981 22:22:59:464 | MD | INFO | +94 | Game section statistics updated. 22:22:59:470 | MD | INFO | +0 | RunKeymapper - Started, using method "unload" 22:22:59:489 | MD | INFO | +31 | GetJoystickArray - Started 22:22:59:495 | MD | DEBUG2 | +0 | GetJoystickArray - Joysticks Detected: 1000000000000000 22:22:59:503 | MD | INFO | +0 | GetJoystickGUID - Started 22:22:59:522 | MD | INFO | +31 | GetJoystickGUID - Ended and found GUID: 5041DB96E6EDE4118001444553540000 22:22:59:524 | MD | DEBUG2 | +0 | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 5041DB96E6EDE4118001444553540000 22:22:59:532 | MD | INFO | +0 | GetJoystickArray - Ended 22:22:59:534 | MD | DEBUG2 | +0 | RunKeymapper - Looping through controllers to find xpadder profiles for each one 22:22:59:552 | MD | DEBUG2 | +31 | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "Controller (Xbox 360 Wireless Receiver for Windows)" 22:22:59:555 | MD | DEBUG2 | +0 | GetProfile - Searching for these profiles (| delimited): E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI|E:\Rocketlauncher\Profiles\xpadder\_Default\blank 22:22:59:558 | MD | DEBUG2 | +0 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile 22:22:59:560 | MD | DEBUG2 | +0 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile 22:22:59:564 | MD | INFO | +0 | GetProfile - Loading Player 1 Profile -> E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile 22:22:59:587 | MD | INFO | +31 | RunXpadder - Started 22:22:59:596 | MD | INFO | +0 | Process - Exist JoyToKey.exe 22:22:59:620 | MD | DEBUG2 | +32 | RunXpadder - Closing xpadder to refresh controllers seen by xpadder 22:22:59:626 | MD | INFO | +0 | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe /C 22:22:59:660 | MD | DEBUG1 | +46 | Run - "Xpadder.exe /C" Process ID: 6928 22:22:59:661 | MD | DEBUG2 | +0 | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in E:\Hyperspin\Utilities\Xpadder\xpadder.ini 22:22:59:663 | MD | INFO | +0 | Process - WaitClose Xpadder.exe 2 22:22:59:883 | MD | DEBUG2 | +219 | RunXpadder - Reading the order in E:\Hyperspin\Utilities\Xpadder\xpadder.ini and arranging profiles found to match that order 22:22:59:883 | MD | DEBUG2 | +0 | RunXpadder - No more controllers to be found 22:22:59:883 | MD | INFO | +0 | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile" /M 22:22:59:913 | MD | DEBUG1 | +31 | Run - "Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile" /M" Process ID: 6516 22:22:59:923 | MD | INFO | +0 | RunXpadder - Ended 22:22:59:923 | MD | INFO | +0 | RunKeymapper - Ended 22:22:59:923 | MD | INFO | +0 | RunAHKKeymapper - Started 22:22:59:943 | MD | DEBUG1 | +31 | RunAHKKeymapper - Unloading AhkLauncher 22:22:59:943 | MD | DEBUG1 | +0 | RunAHKKeymapper - If AhkLauncher.exe is running, need to close it first before a new profile can be loaded 22:22:59:943 | MD | INFO | +0 | Process - Exist AhkLauncher.exe 22:22:59:943 | MD | INFO | +0 | RunAHKKeymapper - Ended 22:22:59:953 | MD | INFO | +0 | Restoring mouse cursor 22:22:59:953 | MD | INFO | +0 | ExitModule - Ended 22:22:59:973 | MD | INFO | +31 | End of Module Logs 22:23:00:023 | RL | INFO | +15974 | Main - Module ended, exiting RocketLauncher normally 22:23:00:023 | RL | INFO | +0 | ExitScript - Started 22:23:00:033 | RL | DEBUG1 | +0 | ExitScript - Restoring HyperSpin.exe to x0 y0 w1440 h900 22:23:00:193 | RL | DEBUG1 | +172 | ExitScript - Restoring and Clicking HyperSpin.exe to attempt to put it into focus 22:23:00:193 | RL | DEBUG1 | +0 | ExitScript - Checking what application is currently in focus. 22:23:00:193 | RL | INFO | +0 | SystemCursor - Restoring mouse cursor 22:23:00:213 | RL | INFO | +15 | ExitScript - Ended
