Setting coin slot to freeplay
Does anyone know whether its an easy task to set the coin slot on an arcade cabinet, to free play? The inside of the door has HI-09UCS and 500 written in a small white block. When I open the door, the part where the coin drops through first, opens up 90 degrees and on the side there are 4 compass points where you can insert a small screwdriver, apart from which, if that's where I need to change the priority, I can't see any other point there that can be adjusted, I have tried all 4 different positions, so it doesn't seem it's a simple case of turning that each time. I'm sure it can be set to free play, but I can't remember what was said when I got it.
