ublasfu Posted March 1, 2016 Posted March 1, 2016 i cant add pics for some reason anything i do says cannot add file extention anyway when i use visualboy outside of hyperspin it works fine but when im in it i get this message after a few seconds that says "there was a error waiting for visualboyadvance-m please check you have the correct version emulator installed for this module followed by any notes in the module" i have no clue whats going on here any help is greatly appreciated
ublasfu Posted March 2, 2016 Author Posted March 2, 2016 problem is i cant find visualboy 2.0.2 i tried 2.0.0 and it gave me some other kind of error and said user canceled now i got it working i uninstalled and reinstalled but its running at 3000% and i dont have any clue how to slow it down and theres no throttle option i looked at the ini and throttle is at 0 and i found the frameskip part and also says throttle 0
ublasfu Posted March 2, 2016 Author Posted March 2, 2016 I just checked and 2.0.2 is the module version, not the emulator version so that's why you couldn't find it. Set the throttle to 100 (or whatever you want) in the ini and that should fix the speed problem. i changed the throttle and it did absolutely nothing still runnning at 3000%
ublasfu Posted March 3, 2016 Author Posted March 3, 2016 I just checked and 2.0.2 is the module version, not the emulator version so that's why you couldn't find it. Set the throttle to 100 (or whatever you want) in the ini and that should fix the speed problem. ok im guessing its r1099 anyone know where to get visualboyadvamce-m r1099
JoyStickKilla Posted March 4, 2016 Posted March 4, 2016 Have you bothered to check the almighty knowing Google? It brings up countless results for visual boy advance running fast
ublasfu Posted March 4, 2016 Author Posted March 4, 2016 Have you bothered to check the almighty knowing Google? It brings up countless results for visual boy advance running fast yep and i tried everything i knew how to do and nothing is working.....
ublasfu Posted March 5, 2016 Author Posted March 5, 2016 this is getting me so frustrated... how do i get an old module? the old emulator works fine but no matter what i do the newer one wont slow down ive tried everything i seen on google that wasnt code i tried deleting and redownloading i uninstalled from hyperspin reinstalled it just wont work. the old one runs fine but then give me the error telling me to make sure im using correct module
ublasfu Posted March 5, 2016 Author Posted March 5, 2016 WinWait("VisualBoyAdvance-M")WinWaitActive("VisualBoyAdvance-M")BezelDraw()FadeInExit()Process("WaitClose",executable)7zCleanUp()BezelExit()FadeOutExit()ExitModule()CloseProcess: FadeOutStart() WinClose, VisualBoyAdvance-MReturn thats what it says in the vbam module already ..
ublasfu Posted March 5, 2016 Author Posted March 5, 2016 Right....which is why I told you to try changing the exe name. Reread my post. my bad im a little slow with this stuff man thanks for bearing with me im gonna try now
ublasfu Posted March 5, 2016 Author Posted March 5, 2016 lol lol i edited and it told me something like canceled by user then i put the old file back and whatever i did now it wont even load....im gonna restart and try to reinstall again and see what happens this is nuts i reinstalled and it worked fine.... i dont know what i did wrong in the first
