Blank box in left corner when starting Hyperspin
ward614
Has anyone else experienced a blank box appearing in the bottom left corner of the window when they start Hyperspin? It appears to be a single line from a "right click" menu with no text and disappears when double clicked, but it is cramping the style of the frontend.
A picture can be seen here: http://s27.postimg.org/r23pv7bbn/Capture.png
What version of Windows are you running? Also, are you running HyperSpin normally or is it set to boot with your OS? I haven't seen this before but the first thing I'd try would be to run HyperSpin as administrator and potentially experiment with disabling visual themes. Worst case scenario you could use a startup script to hide the desktop enitrely but I'd like to see if we can fix it natively first.
I am running Windows 10 and Hyperspin is set to run normally. Where does one edit the options on visual themes?
Same place as compatibility. Right click the exe and there should be a be options in there. Sorry but I'm on a Win7 PC atm and can't double check. Lemme know if it's not in there or if that doesn't work.
Ok, while the solution wasn't running the Hide Taskbar, putting it in did lead me to find the problem. I had my previous startup program set as HS Startup, which I got from a link on this page quite a while ago. The problem goes away when that is removed, so a rewrote another .bat file to open my key mapper and replaced it. Problem solved!
Thank you all for your help! My system is nearly done thanks in part to the great community here!
