nblakef
I'm having an issue when ePsXe200 launches through Hyperspin.  It forgets all of my video settings and runs the default settings.  everything is jagged again and rough looking.... sigh... i thought those days were over.  Does anyone have this issue or a fix for it?
what version of windows are you on ? I am  on the older epsxe 1.90 something like that you can use epsxe shark to get more out of it with 3rd party plugins :D  do you have a screen shot of you module settings ?
Hyper Helper Ready To Help
There was a change in ePSXe with this release that the OpenGL plugin is now embedded in the emu. There are no external plugins whatsoever on a clean install. The module did not like this and was still using the external dll plugin. So if you don't put the old OpenGL plugin in the plugin folder, the module can't find the plugin and there's an error. But then the emu is using the old plugin and not the new core one. For a real fix, check here:
http://www.rlauncher.com/forum/showthread.php?2964-Module-issue-with-latest-ePSXe-version
I'm not sure this will fix your issue, but at least it will use the latest plugin. Have you changed your GPU settings in the module or just in the emu? I can imagine you need to do all the settings in the module.
