led blinky please help. ill gladly pay to get all buttons and trckball lit correctly
I belive I need to create and input map as I don't have what north coast customs would of emailed me when they built cabinet for me a few years back.
You should be able to create the Device/Port input map without knowing how your hardware is wired;
1) Identify which type of LED controller is installed (LEDWiz, PACDrive, etc.) - the hardware should be stamped with the name.
2) Using the GenLEDBlinkyInputMap.exe app, select the hardware device.
3) Select a port (start with 1) - this should light up a wired button. If nothing lights up, then that port is not in use.
4) If your CP has RGB LEDs, then set the LED Type to the color of the lit button (red, green, or blue). If not RGB, then set the LED Type to Single.
5) Select or type an LED Label based on whatever you want for the lit CP button (P1B1, P1B2, etc.).
6) Click the 'Quick Key' button, then press the button on the CP that is lit - this will detect the keycode.
7) Click the Set Port button to assign the values.
8) Repeat for every port on the device.
