ePSXe Pad Plugin issue
Dime333
I¨m trying to set up analog controls for ePSXe for my X-Arcade controller. The core pad plugin doesn't let you set the analog controls to keypresses, you need an actual analog controller for that.
I have tried Lilypad and it almost works. I can map the analog sticks to keys but If I set keyboard API to windows messaging, no hotkeys work. The most important one is the exit emulator key, so I can't use that.
If I set keyboard API to RAW input everything works great until I try to use AHK keymapping to remap my control stick to use the keys that control the Left analog stick instead of the d-pad.  So I can't use that eighter.
Are there any other PAD plugins that are compatible with ePSXe? It's really frustrating to be this close to have it working but yet so far away.
Edit: I just mass downloaded pad plugins like crazy. About 20 of them. NONE of them would let me map the analog sticks to the keyboard. Well, there was 1 that kind of worked, but that one was only for PAD 1. This is crazy.
