Special art frustration
snstay
Ive been messing around with this for a while tonight. Is there a way to just keep the special art on all the time with no fade in or out or delay? I just wanna see the xbox button layout all the time.
Thanks
HyperHQ -> Wheel Settings -> Special Art -> set "Type" to "Normal" should have the desired effect.
Thank you it worked out great........except for the main menu. its still fading in and out and not even for what its set in hyper HQ. I also checked the settings ini and its set up correctly.
Did you do HyperHQ -> Wheel Settings -> Main Menu -> Special Art -> set "Type" to "Normal" as well? It has to be set for each wheel. Just tested in my setup and it worked for me.
Got it!!! I completely removed the special art from the folder then simply reinstalled it. Now it works just how i want it.
Thanks Avar!
