majorspawn Posted March 20, 2016 Posted March 20, 2016 After much stuffing around the solution was to first map the joysticks to player 1 and player 2 binds, then manually edit the retroarch.cfg file so by default the cfg file is configured for the below keyboard keys as an example: input_player1_a = "x"input_player1_b = "z" input_player1_y = "a"input_player1_x = "s"... etc so just change the "x" , "z" etc to whatever you want and save the file, if your keyboard mapping conflicts with other hotkeys within the config as below: input_toggle_fullscreen = f input_toggle_fast_forward = space input_shader_next = m input_shader_prev = n ... etc just change the above to "nul" . something else or leave blank as joystick should be mapped already everything should then work. Im surprised no one had the solution to this, hope this helps someone out. make sure the autosave config option is off, this should be off by default in newish builds Thanks MS My Arcade Projects: SNES PC Project Vewlix Cabinet LS-30 Rotary Joysticks
majorspawn Posted March 20, 2016 Author Posted March 20, 2016 anyone please? real need is to have the default global profile for retroarch configured for both joystick and keyboard key mapping. When I go via the config wizard it asks me to press joystick buttons and only recognizes joystick inputs not keyboard. How do i configure for both? My Arcade Projects: SNES PC Project Vewlix Cabinet LS-30 Rotary Joysticks
dougan78 Posted March 20, 2016 Posted March 20, 2016 I always use keyboard inputs only and use a keymapper like xpadder to map keys to my joystick so I can use both if I want to do that. Good luck.
majorspawn Posted March 21, 2016 Author Posted March 21, 2016 I always use keyboard inputs only and use a keymapper like xpadder to map keys to my joystick so I can use both if I want to do that. Good luck. Yeah thanks unfortunately not an option as I'm using a 4nes4snes which i cant map via xpadder for both players. Can someone please confirm if technically you can map 2 sets of controls for player 1 and 2? eg a direct input joystick and a parallel keyboard encoder. My Arcade Projects: SNES PC Project Vewlix Cabinet LS-30 Rotary Joysticks
