Bruiserh89 Posted March 20, 2016 Posted March 20, 2016 Hi. I'd be grateful for the answer to this one. Its hard to watch the spinning game covers in my hyperspin menu. I've tried to find the solution in HyperHQ but to no avail.
Black Hazor Posted March 20, 2016 Posted March 20, 2016 Hi, what default theme are u using? Normally only the disks are spinning so maybe just try to put the gamecovers from the folder Artwork3 to Artwork4. If that doesnt work unzip the default theme and make a change in the Theme.xml and than zip it again....there is an option called rest="spin slow" under Artwork3 or 4, just change it to rest="none" and ur done.
Bruiserh89 Posted March 20, 2016 Author Posted March 20, 2016 Hi, what default theme are u using? Normally only the disks are spinning so maybe just try to put the gamecovers from the folder Artwork3 to Artwork4. If that doesnt work unzip the default theme and make a change in the Theme.xml and than zip it again....there is an option called rest="spin slow" under Artwork3 or 4, just change it to rest="none" and ur done. Thanks mate. I'll give it a go. Just tried. Swapping the artwork folders did the trick. Makes sense too.
